angavrilov89 Posted October 19, 2021 Posted October 19, 2021 My Opi first not start when i edit armbianEnv.txt. what am I doing wrong? "For proper hardware support you need to edit /boot/armbianEnv.txt and add: fdtfile=sun7i-a20-orangepi.dtb following by reboot."
Werner Posted October 19, 2021 Posted October 19, 2021 I am not sure if this isn't a hint from ages ago when boards used phased-out 3.14.y kernel....
phelum Posted October 20, 2021 Posted October 20, 2021 18 hours ago, angavrilov89 said: My Opi first not start when i edit armbianEnv.txt. what am I doing wrong? "For proper hardware support you need to edit /boot/armbianEnv.txt and add: fdtfile=sun7i-a20-orangepi.dtb following by reboot." Hi, What OrangePi board do you have ? I have an early model OrangePi A20 board and the .dtb you mention does work, This is when using a 5.x.x kernel. It will also run with an old 3.4 kernel but this doesn't use a .dtb and I don't think the standard boot.src will boot it anyway. Cheers, Steven
