haryvincent176 Posted October 21, 2021 Posted October 21, 2021 My third Orange Pi Zero came last week, yesterday I plugged it and had heating issues... So I started reading, learning and testing.... Setup: OPiZ-1: 256 MB, no SPI flash - Has extension board plugged - for comparison OPiZ-2: 512 MB, with SPI flash OPiZ-3: 256 MB, with SPI flash (new one with problem) Test conditions: All with (newish) Sandisk Ultra 16 GB Class 10 All new formatted (SD Formatter) and burned/validated (Etcher v1.0.0) with Armbian_5.25_Orangepizero_Debian_jessie_default_3.4.113.img All on my desk - side by side, ambient temperature 25.0-25.1 C (20 cm from boards, no air flow) No case, no passive/active cooling Power supply 7 port 5V 36W total, 2.4A per port (wait, wait, I tried others, separated etc - I'm testing them with USB V/A/W tester - 5.2-5.3V / 0.260-0.350 A) First install done, rebooted, apt-get update && apt-get upgrade'd, rebooted, tested
Werner Posted October 21, 2021 Posted October 21, 2021 Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs). With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported. Your report is invalid for one or more of the following reasons (non-exhaustive list): it is for an unsupported board or image (CSC/EOS/WIP/edge) it is for software that is not supported (such as userspace modules installed on top of the core operating system) it has been logged in the wrong forum (for example requests for help that are not actual bug reports) it lacks requested data (armbianmonitor output) it could have been easily solved by a quick search and/or reading documentation Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat)
