Why am I getting error logs when trying to update, upgrade, etc?
buster debian 10
orangepi
chromium
no firewall
Reading package lists... Done
E: Repository 'http://security.debian.org buster/updates InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
N: Repository 'http://httpredir.debian.org/debian buster InRelease' changed its 'Version' value from '10.2' to '10.11'
E: Repository 'http://httpredir.debian.org/debian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
E: Repository 'http://httpredir.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'stable-updates' to 'oldstable-updates'
W: Skipping acquire of configured file 'main/binary-armhf/Packages' as repository 'https://repo.protonvpn.com/debian stable InRelease' does not seem to provide it (sources.list entry misspelt?)
Err:1 http://httpredir.debian.org/debian buster/main armhf libjs-jquery all 3.3.1~dfsg-3
404 Not Found [IP: 151.101.14.132 80]
Err:2 http://httpredir.debian.org/debian buster/main armhf libjs-underscore all 1.9.1~dfsg-1
Err:3 http://httpredir.debian.org/debian buster/main armhf python3-dnspython all 1.16.0-1
E: Failed to fetch http://httpredir.debian.org/debian/pool/main/j/jquery/libjs-jquery_3.3.1~dfsg-3_all.deb 404 Not Found [IP: 151.101.14.132 80]
E: Failed to fetch http://httpredir.debian.org/debian/pool/main/u/underscore/libjs-underscore_1.9.1~dfsg-1_all.deb 404 Not Found [IP: 151.101.14.132 80]
E: Failed to fetch http://httpredir.debian.org/debian/pool/main/d/dnspython/python3-dnspython_1.16.0-1_all.deb 404 Not Found [IP: 151.101.14.132 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Seems like the selected debian mirror is down or not sync. Nothing Armbian can do about. Ask Debian to fix it.
Btw. httpredir.debian.org is obsolete for years now. Use deb.debian.org instead.
Thanks Werner.
Q1: For the following, is there something I need to type into the terminal to "accept it" ?
Q2: How can I change httpredir.debian.org to deb.debian.org ?
I did not create my system - all I can do is use the terminal and no longer have access to the firewall.
3 hours ago, newpsswd1 said:
Thanks Werner.
https://www.google.com/search?client=firefox-b-e&q=N%3A+This+must+be+accepted+explicitly+before+updates+for+this+repository+can+be+applied.
2nd result
Edit your /etc/apt/sources.list
THis is how the document has been without change:
deb http://deb.debian.org/debian buster main contrib non-free #deb-src http://deb.debian.org/debian buster main contrib non-free deb http://deb.debian.org/debian buster-updates main contrib non-free #deb-src http://deb.debian.org/debian buster-updates main contrib non-free deb http://deb.debian.org/debian buster-backports main contrib non-free #deb-src http://deb.debian.org/debian buster-backports main contrib non-free deb http://security.debian.org/ buster/updates main contrib non-free #deb-src http://security.debian.org/ buster/updates main contrib non-free
