I'm having trouble playing some videos on Orange Pi 3 (http://www.orangepi.org/Orange%20Pi%203/), especially those with full HD quality.
I can even play the video, but it keeps crashing.
I'm using MPV or VLC applications to play the video stream directly from YouTube. It is noteworthy that .mp4 files have crashing too, depending on the quality of the video.
I'm using the following command, for example:
or
How does the hardware have these specifications:
CPU:
      H6 Quad-core 64-bit 1.8GHZ ARM Cortex™-A53
GPU:
  •  High-performance multi-core GPU Mali T720
  • OpenGL ES3.1/3.0/2.0/1.1
  • Microsoft DirectX 11 FL9_3
  • ASTC(Adaptive Scalable Texture Compression)
  • Floating point operation greater than 70 GFLOPS
Video Decoding:
  • H265/HEVC Main/Main10 profile@Level5.2 High-tier ;4K@60fps, up to 6Kx4K@30fps
  • H264/AVC BP/MP/HP@level5.1, MVC, 4K@30fps
  •  VP9,Profile 0/2, 4K@30fps
  • AVS+/AVS JIZHUN profile@level 6.0, 1080P@60fps
I don't understand, why the video is not working perfectly, without crashing.
It is worth mentioning that I have already tested the OrangePi 3 with different operating systems:
• Armbian Focal xfce mainline based kernel 5.10.y
• Armbian Bullseye mainline based kernel 5.10.y
• Impish xfce desktop 5.14.15
• Armbian_5.88_Orangepi3_Ubuntu_bionic_dev_5.1.7.7z
If someone can help me.
Thank you very much
  • Werner changed the title to Orange Pi 3 - Crash on video playback
