Dear Igor,
Thank you very mutch for tis great job!
I did some tests based on your image with udoo-quad, works perfect!
But I do have some trouble on udoo-dual, kernel stops without any console output (just loading kernel...)
so I decided to compile my own, but I get
[ o.k. ] Compiling uboot
[ o.k. ] Compiler version [ arm-linux-gnueabihf-gcc 5.4.0 ]
make: *** Keine Regel, um „udoo_qdl_config“ zu erstellen.  Schluss.
What do I have to change?
Best regards
Marcus
Theirs sources and a path was changed so I need to adjust patches ... working on it.
Thanks!  :P
Edit: It builds now but need to see if it boots too since there were some other changes in uboot.
Unfortunately it does not boot - it keeps resetting when kernel is loaded. I have to dig in more or set u-boot sources back in the past.
Dear Igor,
I am sorry to disturbe again, now I am able to compile and create image (next-console), but the kernel still wont start on udoo-d and even not on udoo-quad
Marcus
Huh. It was booting on mine ... will check again, perhaps I forgot to push something.
One thing which could be the problem - since sources were changed, you need to delete:
sources/u-boot-udoo
before restart the compilation. This will download new / working u-boot source. I am almost sure this is the problem.
Hi Igor,
I just set up my virtual machine completely new.
I am getting following (unchanged) result:
U-Boot SPL 2015.10-armbian (Sep 05 2016 - 18:35:42)
U-Boot 2015.10-armbian (Sep 05 2016 - 18:35:42 +0200)
CPU:   Freescale i.MX6DL rev1.1 at 792 MHz
Reset cause: POR
Board: UDOO DualLite
DRAM:  1 GiB
MMC:   FSL_SDHC: 0
No panel detected: default to HDMI
Display: HDMI (1280x720)
In:    serial
Out:   serial
Err:   serial
Net:   Phy 4 not found
using phy at 4
PHY reset timed out
FEC [PRIME]
Error: FEC address not set.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc
Found U-Boot script /boot.scr
** File not found /boot.scr **
824 bytes read in 88 ms (8.8 KiB/s)
Running bootscript from mmc ...
## Executing script at 12000000
0 bytes read in 59 ms (0 Bytes/s)
0 bytes read in 64 ms (0 Bytes/s)
37690 bytes read in 379 ms (96.7 KiB/s)
6137616 bytes read in 419 ms (14 MiB/s)
Kernel image @ 0x12000000 [ 0x000000 - 0x5da710 ]
## Flattened Device Tree blob at 18000000
   Booting using the fdt blob at 0x18000000
   Using Device Tree in place at 18000000, end 1800c339
Starting kernel ...
Not much output to console from kernel could be normal - change console to serial and enlarge verbosity level or just wait little longer that serial console kick in and / or connect remotely. Initial problem was broken u-boot, the rest is more or less unchanged.
For double you most likely need to select other / proper device tree in boot script. I never search to make support for other versions beside Quad.
