Enabling SELINUX on "Debian GNU/Linux 10 (buster)"
Hello to all good folks in Armbian team!
On a odroid HC1/HC2 - where everything works like a swis clock, i cant - no matter what i do - to get "getenforce Enforcing" .
I would be thankful if someone could point to the right direction.
uname -a
Linux odroid 5.4.151-odroidxu4 #21.08.3 SMP PREEMPT Fri Oct 8 19:52:26 UTC 2021 armv7l GNU/Linux
cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
NAME="Debian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
cat /etc/selinux/config
# This file controls the state of SELinux on the system.
# SELINUX= can take one of these three values:
# enforcing - SELinux security policy is enforced.
# permissive - SELinux prints warnings instead of enforcing.
# disabled - No SELinux policy is loaded.
SELINUX=enforcing
# SELINUXTYPE= can take one of these two values:
# default - equivalent to the old strict and targeted policies
# mls     - Multi-Level Security (for military and educational use)
# src     - Custom policy built from source
SELINUXTYPE=default
# SETLOCALDEFS= Check local definition changes
SETLOCALDEFS=0
 on "cat /boot/config-5.4.151-odroidxu4" on # Security options i have related on selinux:
# CONFIG_SECURITY_DMESG_RESTRICT is not set
CONFIG_SECURITY=y
CONFIG_SECURITYFS=y
CONFIG_SECURITY_NETWORK=y
CONFIG_SECURITY_NETWORK_XFRM=y
CONFIG_SECURITY_PATH=y
CONFIG_LSM_MMAP_MIN_ADDR=0
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
CONFIG_HARDENED_USERCOPY=y
CONFIG_HARDENED_USERCOPY_FALLBACK=y
CONFIG_FORTIFY_SOURCE=y
# CONFIG_STATIC_USERMODEHELPER is not set
CONFIG_SECURITY_SELINUX=y
CONFIG_SECURITY_SELINUX_BOOTPARAM=y
# CONFIG_SECURITY_SELINUX_DISABLE is not set
CONFIG_SECURITY_SELINUX_DEVELOP=y
CONFIG_SECURITY_SELINUX_AVC_STATS=y
CONFIG_SECURITY_SELINUX_CHECKREQPROT_VALUE=1
CONFIG_SECURITY_SMACK=y
# CONFIG_SECURITY_SMACK_BRINGUP is not set
CONFIG_SECURITY_SMACK_NETFILTER=y
CONFIG_SECURITY_SMACK_APPEND_SIGNALS=y
CONFIG_SECURITY_TOMOYO=y
CONFIG_SECURITY_TOMOYO_MAX_ACCEPT_ENTRY=2048
CONFIG_SECURITY_TOMOYO_MAX_AUDIT_LOG=1024
# CONFIG_SECURITY_TOMOYO_OMIT_USERSPACE_LOADER is not set
CONFIG_SECURITY_TOMOYO_POLICY_LOADER="/sbin/tomoyo-init"
CONFIG_SECURITY_TOMOYO_ACTIVATION_TRIGGER="/sbin/init"
# CONFIG_SECURITY_TOMOYO_INSECURE_BUILTIN_SETTING is not set
CONFIG_SECURITY_APPARMOR=y
CONFIG_SECURITY_APPARMOR_HASH=y
CONFIG_SECURITY_APPARMOR_HASH_DEFAULT=y
# CONFIG_SECURITY_APPARMOR_DEBUG is not set
##what i did:
apt remove apparmour
"Reading package lists... Done
Building dependency tree
E: Unable to locate package apparmour"  #so apparmour is no longer present
apt update && upgrade
apt install selinux-basics selinux-policy-default auditd
#all has installed ok no problem with dependencies et all
## i did observe, in /boot/config-5.4.151-odroidxu4 the folowing lines about apparmour:
# Automatically generated file; DO NOT EDIT.
## at command:
"selinux-activate"
## i get
"Activating SE Linux
SE Linux is activated.  You may need to reboot now."
#but no change after reboot
I'm facing the same issue with my armbian XU4 bullseyes.
I've noticed in the /boot/config-5.4.225-odroidxu4 file, that there are multiple security modules compiled in the kernel
$ grep SECURITY /boot/config-5.4.225-odroidxu4
ONFIG_SECURITY=y
CONFIG_SECURITYFS=y
# CONFIG_SECURITY_LOADPIN is not set
CONFIG_SECURITY_YAMA=y
CONFIG_SECURITY_SAFESETID=y
CONFIG_SECURITY_LOCKDOWN_LSM=y
CONFIG_SECURITY_LOCKDOWN_LSM_EARLY=y
# CONFIG_DEFAULT_SECURITY_SELINUX is not set
# CONFIG_DEFAULT_SECURITY_SMACK is not set
# CONFIG_DEFAULT_SECURITY_TOMOYO is not set
CONFIG_DEFAULT_SECURITY_APPARMOR=y
# CONFIG_DEFAULT_SECURITY_DAC is not set
I see SElinux, AppArmor, Smack and Tomoyo.
But if you look at the last lines, it seems that the default security module loaded, is AppArmor.
I remember that the choice of the security module can be done by adding the parameter security= in the boot line.
I haven't tested it, because I'm a bit lost on "how to change this parameter" for the XU4.
Would it be in the /boot/boot.ini ? I do not see where.
In the initrd ?
How to update this ?
mmmm, this
worth trying :
apt install policycoreutils selinux-basics selinux-policy-default auditd
selinux-activate
vi /boot/armbianEnv.txt
# add a line: extraargs=selinux=1 security=selinux
# this is needed with stock config where security is unset and SElinux is disabled by default
tested on Odroid XU4 with armbian bullseyes
# uname -a
Linux thor 5.4.225-odroidxu4 #22.11.1 SMP PREEMPT Wed Nov 30 10:55:16 UTC 2022 armv7l GNU/Linux
# cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=odroidxu4
BOARD_NAME="Odroid XU4"
BOARDFAMILY=odroidxu4
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=84940abbbe3d
VERSION=22.11.1
LINUXFAMILY=odroidxu4
ARCH=arm
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
BRANCH=current
I've added in /boot/boot.ini
# activate selinux
setenv extraargs "selinux=1 security=selinux"
before line
# final boot args
setenv bootargs "${bootrootfs} ${videoconfig} smsc95xx.macaddr=${macaddr} governor=${governor} ${hdmi_phy_control} usb-storage.quirks=${usbstoragequirks} ${extraargs}"
and rebooted.
After reboot :
root~# getenforce
Permissive
:D
