Cannot use epoll with edge events in Orange Pi Lite H3
Go to solution Solved by Casi,
Hello everyone, I'm creating my coursework project and I should create my own C++ library for easier GPIO usage. I'm struggling with using epoll in my code, because it doesn't register edge events, that I specified. My code looks like this:
void somePollingFunc(std::string path) {
	int epollFD = epoll_create1(0);
	if(epollFD == -1){
		throw std::runtime_error("Failed to create epoll");
	int socketToRead = open(path.c_str(), O_RDONLY | O_NONBLOCK);
	if(socketToRead < 0) {
		throw std::runtime_error(std::string("Failed to open file\nPath: ") + path.data());
	// Creating epoll struct
	struct epoll_event gpioPollFD;
	gpioPollFD.data.fd = socketToRead;
	gpioPollFD.events = EPOLLET;
	// Adding gpio fd to epoll
	if(epoll_ctl(epollFD, EPOLL_CTL_ADD, socketToRead, &gpioPollFD) == -1) {
		throw std::runtime_error("Failed to add custom file descriptor to epoll");
	char readByte;
	bool callbackStop = false;
	int pollValue;
	do {
		pollValue = epoll_wait(epollFD, &gpioPollFD, 1, 100);
		if(pollValue == 0){ continue; }
		if(::read(gpioPollFD.data.fd, &readByte, 1)){
			callbackStop = callback(readByte);
		lseek(gpioPollFD.data.fd, 0, SEEK_SET);
	} while(!callbackStop);
	close(epollFD);
I checked my edge file, its value is set right, also I experimented using EPOLLIN or EPOLLPRI, they both works for every action that happen to socket
Am I missing something or such functionality doesn't work?
Edited by Casi
On 11/30/2021 at 4:31 AM, Werner said:
There is no Orange Pi Lite 3.
I'm sorry, I've meant Orange PI Lite with H3 processor. Sorry for long reply. As a newbie I have limitations for posts
  • Solution
I've found my error, I've found my error, I filtered all events with EPOLLET flag that is input-only, so it newer occured in output
  • Werner changed the title to Cannot use epoll with edge events in Orange Pi Lite H3
