odroidhc2 Posted December 1, 2021 Posted December 1, 2021 Armbianmonitor: http://ix.io/3GGn Radarr installed from armbian-confign to my Odroid XU4 wont start on boot or after enter this command in ssh shell: /usr/bin/taskset -c 4-7 /usr/bin/mono --debug /opt/Radarr/Radarr.exe -nobrowser This is error: [Info] Bootstrap: Starting Radarr - /opt/Radarr/Radarr.exe - Version 3.2.2.5080 [Trace] DiskProviderBase: Deleting file: /root/.config/Radarr/radarr.pid [Info] Router: Application mode: Interactive [Fatal] ConsoleApp: EPIC FAIL! [v3.2.2.5080] System.TypeInitializationException: The type initializer for 'NzbDrone.Core.Datastore.DbFactory' threw an exception. ---> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.TypeInitializationException: The type initializer for 'System.Text.Json.JsonSerializerOptions' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Text.Json.Serialization.Converters.IEnumerableConverterFactory' threw an exception. ---> System.TypeLoadException: Could not find method '.ctor' due to a type load error: Type System.Text.Json.Serialization.Converters.IDictionaryConverter`1[TCollection] has invalid vtable method slot 32 with method none assembly:/opt/Radarr/System.Text.Json.dll type:IDictionaryConverter`1 member:(null) --- End of inner exception stack trace --- at System.Text.Json.JsonSerializerOptions..cctor () [0x0001f] in <156be8dd8a8748a88733a94decab76f8>:0 --- End of inner exception stack trace --- at NzbDrone.Core.Datastore.Converters.EmbeddedDocumentConverter`1[T]..ctor () [0x00006] in <70bcba0d870f4fcb9ba91f295f9b5ffe>:0 at (wrapper managed-to-native) System.Reflection.MonoCMethod.InternalInvoke(System.Reflection.MonoCMethod,object,object[],System.Exception&) at System.Reflection.MonoCMethod.InternalInvoke (System.Object obj, System.Object[] parameters, System.Boolean wrapExceptions) [0x00008] in <d0e12f672b88444ab4b6d9b2ecf20142>:0 --- End of inner exception stack trace --- at System.Reflection.MonoCMethod.InternalInvoke (System.Object obj, System.Object[] parameters, System.Boolean wrapExceptions) [0x0001f] in <d0e12f672b88444ab4b6d9b2ecf20142>:0 at System.RuntimeType.CreateInstanceMono (System.Boolean nonPublic, System.Boolean wrapExceptions) [0x000ca] in <d0e12f672b88444ab4b6d9b2ecf20142>:0 at System.RuntimeType.CreateInstanceSlow (System.Boolean publicOnly, System.Boolean wrapExceptions, System.Boolean skipCheckThis, System.Boolean fillCache, System.Threading.StackCrawlMark& stackMark) [0x0000c] in <d0e12f672b88444ab4b6d9b2ecf20142>:0 at System.RuntimeType.CreateInstanceDefaultCtor (System.Boolean publicOnly, System.Boolean skipCheckThis, System.Boolean fillCache, System.Boolean wrapExceptions, System.Threading.StackCrawlMark& stackMark) [0x0002a] in <d0e12f672b88444ab4b6d9b2ecf20142>:0 at System.Activator.CreateInstance (System.Type type, System.Boolean nonPublic, System.Boolean wrapExceptions) [0x00040] in <d0e12f672b88444ab4b6d9b2ecf20142>:0 at System.Activator.CreateInstance (System.Type type, System.Boolean nonPublic) [0x00000] in <d0e12f672b88444ab4b6d9b2ecf20142>:0 at System.Activator.CreateInstance (System.Type type) [0x00000] in <d0e12f672b88444ab4b6d9b2ecf20142>:0 at NzbDrone.Core.Datastore.TableMapping.RegisterEmbeddedConverter (System.Type embeddedType, System.Type embeddedConverterDefinition) [0x00011] in <70bcba0d870f4fcb9ba91f295f9b5ffe>:0 at NzbDrone.Core.Datastore.TableMapping.RegisterEmbeddedConverter () [0x0005a] in <70bcba0d870f4fcb9ba91f295f9b5ffe>:0 at NzbDrone.Core.Datastore.TableMapping.RegisterMappers () [0x00000] in <70bcba0d870f4fcb9ba91f295f9b5ffe>:0 at NzbDrone.Core.Datastore.TableMapping.Map () [0x00000] in <70bcba0d870f4fcb9ba91f295f9b5ffe>:0 at NzbDrone.Core.Datastore.DbFactory..cctor () [0x00019] in <70bcba0d870f4fcb9ba91f295f9b5ffe>:0 --- End of inner exception stack trace --- at Radarr.Host.NzbDroneConsoleFactory.Start () [0x00012] in <2455a9609adc45b3a9a0f78eecee6c40>:0 at Radarr.Host.Router.Route (Radarr.Host.ApplicationModes applicationModes) [0x0007f] in <2455a9609adc45b3a9a0f78eecee6c40>:0 at Radarr.Host.Bootstrap.Start (Radarr.Host.ApplicationModes applicationModes, NzbDrone.Common.EnvironmentInfo.StartupContext startupContext) [0x00047] in <2455a9609adc45b3a9a0f78eecee6c40>:0 at Radarr.Host.Bootstrap.Start (NzbDrone.Common.EnvironmentInfo.StartupContext startupContext, Radarr.Host.IUserAlert userAlert, System.Action`1[T] startCallback) [0x00084] in <2455a9609adc45b3a9a0f78eecee6c40>:0 at NzbDrone.Console.ConsoleApp.Main (System.String[] args) [0x00031] in <3b55af499a4744cd9076c8219c6a8353>:0 Press enter to exit
Werner Posted December 1, 2021 Posted December 1, 2021 Moved to Common issues / peer to peer technical support even though installed via armbian-config it is still 3rd party software
