  • 0
Analog audio output low volume with mpd server (orange pi pc)
jstan
Question
I have problem with mpd server and sound volume in mpd. When I set volume to max in alsamixer and in mpd  (mpc volume 100) sound is very quiet. When I run mplayer with the same mp3 and alsamixer settings the sound is very loud. I tried mixer_type set to software and hardware in mpd.conf but with no effect. I think the problem is with allwinner audiocodec because when I use usb sound card everything works as expected ( them same sound levels in mpd and mplayer ).
Is there any trick to solve this?
Link to comment
Share on other sites
8 answers to this question
Help us fund some #badass gear for our continuous integration build framework
  • 0
Exactly this was my intention and I followed the first guide. First I installed the system cleanly and after that I installed apt-get install mpd mpc ncmpc with its all of thousands dependencies.
After that I created the playlists exactly as described and the first difference was, that i the path was not correct (/var/lib/mpd/music/radio.pls instead of /var/lib/music/radio.pls).
After I created the pls at the correct place I found out that mpd must be started manually and after that a mpc load radio.pls and mpc play works perfectly.
BUT sound is too quiet. I tried three different in-ear headphones and also a analog to bluetooth sender and my denon receiver. sound is very very quiet overall. I tried to set alsamixer volume to the highest and also set the volume in script.bin from 31 to 100 - but no change.
Changed the renderer to software in /etc/mpd.conf but then I can change volume in mpc so, that 100% is as quiet as before and everything below is much quieter....
Link to comment
  • 0
this helped great
 File: /etc/asound.conf:
    pcm.!default {
        type hw
        card 0
        device 0
      ctl.!default {
        type hw
        card 0
pcm.louder {
        type plug
        slave.pcm "dmix"
        ttable.0.0 3.0
        ttable.1.1 3.0
pcm.!default "louder"
Link to comment
  • 0
Hi
Looking at the orange PI PC schematic
Analogue audio output is made with a 4.7µF capacitor in serial with a 30K resistor
This seems odd
Either capacitor or resistor is too big .
In all cases it need a high input impedance load
and should not work with any kind of earphone.
On the orange PI plus an amplifier is added and an earphone should work.
HTH
Link to comment
  • 0
Hi
This seems odd
HTH
on my opi pc plus sound volume is now as loud as on my samsung smartphone... perhaps there is a other schematic on the opi PC PLUS...
Link to comment
