Armbian on ASus tinker board S does not support USB flash sticks
Good day.
Yesterday I downloaded the latest Armbian version for the
ASUS Tinker Board S and flashed the built-in eMMC (with Etcher Balena).
The software works fine, but
- the SD card is not mounted as mass storage, the file manager THUNAR does not recognize it. also lsusb does not recognize it.
- a plugged USB- flash-stick is not mounted by the file manager THUNAR, although
lsusb
lists it.
Ist das Problem behebbar?
Is the problem fixable?
The USB stick of a wireless mouse is recognized and also connects to the conputermouse.
Regards
Karl
Translated with www.DeepL.com/Translator (free version)
Armbianmonitor output:
1226 gesamt belegt frei gemeinsam Zwischen verfügbar
1227 Speicher: 2,0Gi 276Mi 1,1Gi 97Mi 606Mi 1,5Gi
1228 Auslager: 1,0Gi 0B 1,0Gi
1229
1230 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
1231 /dev/zram1 zstd 50M 2,8M 520K 908K 4 /var/log
1232 /dev/zram0 lzo-rle 1000,3M 4K 74B 4K 4 [SWAP]
1233
1234 13:51:35 up 18 min, 1 user, load average: 0,62, 0,37, 0,29
1235
1236 [ 5.836490] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
1237 [ 5.836509] cfg80211: failed to load regulatory.db
1238 [ 5.842078] Freeing unused kernel memory: 1024K
1239 [ 5.871346] Run /init as init process
1240 [ 5.871358] with arguments:
1241 [ 5.871368] /init
1242 [ 5.871377] earlyprintk
1243 [ 5.871385] with environment:
1244 [ 5.871394] HOME=/
1245 [ 5.871403] TERM=linux
1246 [ 5.871412] ubootpart=7350c3ca-01
1247 [ 5.871420] cgroup_enable=memory
1248 [ 5.871429] cgroup_memory=1
1249 [ 6.124194] scsi 0:0:0:0: Direct-Access Generic Flash Disk 8.01 PQ: 0 ANSI: 6
1250 [ 6.127101] sd 0:0:0:0: [sda] 491520000 512-byte logical blocks: (252 GB/234 GiB)
1251 [ 6.127958] sd 0:0:0:0: [sda] Write Protect is off
1252 [ 6.127981] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
1253 [ 6.128587] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
1254 [ 6.169993] random: crng init done
1255 [ 6.170080] sda: sda1 sda2
1256 [ 6.175237] sd 0:0:0:0: [sda] Attached SCSI removable disk
1257 [ 6.956487] usbcore: registered new interface driver uas
1258 [ 7.164412] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/button@0[0]' - status (0)
1259 [ 7.164465] gpio gpiochip0: Persistence not supported for GPIO 5
1260 [ 7.165033] input: gpio-keys as /devices/platform/gpio-keys/input/input7
1261 [ 7.981260] EXT4-fs (mmcblk2p1): mounted filesystem with writeback data mode. Opts: (null)
1262 [ 8.409839] systemd[1]: System time before build time, advancing clock.
1263 [ 8.443885] systemd[1]: systemd 245.4-4ubuntu3.13 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
1264 [ 8.445583] systemd[1]: Detected architecture arm.
1265 [ 8.480536] systemd[1]: Set hostname to <tinkerboard>.
1266 [ 8.666691] dw-apb-uart ff690000.serial: forbid DMA for kernel console
1267 [ 9.715414] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
1268 [ 9.715451] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
1269 [ 9.721565] systemd[1]: Created slice system-modprobe.slice.
1270 [ 9.725076] systemd[1]: Created slice system-serial-getty.slice.
1271 [ 9.728081] systemd[1]: Created slice User and Session Slice.
1272 [ 9.729318] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
1273 [ 9.731787] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
1274 [ 9.733115] systemd[1]: Reached target Remote File Systems.
1275 [ 9.733753] systemd[1]: Reached target Slices.
1276 [ 9.734424] systemd[1]: Reached target Swap.
1277 [ 9.735110] systemd[1]: Reached target System Time Set.
1278 [ 9.736730] systemd[1]: Listening on Syslog Socket.
1279 [ 9.738186] systemd[1]: Listening on fsck to fsckd communication Socket.
1280 [ 9.739374] systemd[1]: Listening on initctl Compatibility Named Pipe.
1281 [ 9.741582] systemd[1]: Listening on Journal Audit Socket.
1282 [ 9.743259] systemd[1]: Listening on Journal Socket (/dev/log).
1283 [ 9.744957] systemd[1]: Listening on Journal Socket.
1284 [ 9.746626] systemd[1]: Listening on udev Control Socket.
1285 [ 9.747928] systemd[1]: Listening on udev Kernel Socket.
1286 [ 9.749366] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
1287 [ 9.758327] systemd[1]: Mounting POSIX Message Queue File System...
1288 [ 9.769921] systemd[1]: Mounting Kernel Debug File System...
1289 [ 9.781716] systemd[1]: Mounting Kernel Trace File System...
1290 [ 9.795811] systemd[1]: Starting Restore / save the current clock...
1291 [ 9.807968] systemd[1]: Starting Set the console keyboard layout...
1292 [ 9.820310] systemd[1]: Starting Create list of static device nodes for the current kernel...
1293 [ 9.822001] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
1294 [ 9.835298] systemd[1]: Started Nameserver information manager.
1295 [ 9.837328] systemd[1]: Reached target Network (Pre).
1296 [ 9.841783] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
1297 [ 9.842383] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
1298 [ 9.859128] systemd[1]: Starting Load Kernel Modules...
1299 [ 9.872246] systemd[1]: Starting Remount Root and Kernel File Systems...
1300 [ 9.885510] systemd[1]: Starting udev Coldplug all Devices...
1301 [ 9.906572] systemd[1]: Mounted POSIX Message Queue File System.
1302 [ 9.909428] systemd[1]: Mounted Kernel Debug File System.
1303 [ 9.911813] systemd[1]: Mounted Kernel Trace File System.
1304 [ 9.920286] systemd[1]: Finished Restore / save the current clock.
1305 [ 9.930200] systemd[1]: Finished Create list of static device nodes for the current kernel.
1306 [ 9.954244] systemd[1]: Finished Load Kernel Modules.
1307 [ 9.957574] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
1308 [ 9.968358] systemd[1]: Mounting Kernel Configuration File System...
1309 [ 9.979690] systemd[1]: Starting Apply Kernel Variables...
1310 [ 9.990953] EXT4-fs (mmcblk2p1): re-mounted. Opts: commit=600,errors=remount-ro
1311 [ 10.011899] systemd[1]: Finished Remount Root and Kernel File Systems.
1312 [ 10.014404] systemd[1]: Mounted Kernel Configuration File System.
1313 [ 10.017775] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
1314 [ 10.018172] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
1315 [ 10.027339] systemd[1]: Starting Load/Save Random Seed...
1316 [ 10.039418] systemd[1]: Starting Create System Users...
1317 [ 10.118470] systemd[1]: Finished Load/Save Random Seed.
1318 [ 10.126721] systemd[1]: Finished Apply Kernel Variables.
1319 [ 10.135596] systemd[1]: Finished Create System Users.
1320 [ 10.147391] systemd[1]: Starting Create Static Device Nodes in /dev...
1321 [ 10.239090] systemd[1]: Finished Create Static Device Nodes in /dev.
1322 [ 10.249411] systemd[1]: Starting udev Kernel Device Manager...
1323 [ 10.371518] systemd[1]: Finished Set the console keyboard layout.
1324 [ 10.373555] systemd[1]: Reached target Local File Systems (Pre).
1325 [ 10.383463] systemd[1]: Mounting /tmp...
1326 [ 10.407098] systemd[1]: Mounted /tmp.
1327 [ 10.416444] systemd[1]: Reached target Local File Systems.
1328 [ 10.425540] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
1329 [ 10.434297] systemd[1]: Starting Armbian ZRAM config...
1330 [ 10.452393] systemd[1]: Starting Set console font and keymap...
1331 [ 10.472492] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
1332 [ 10.486312] systemd[1]: Condition check resulted in Load AppArmor profiles managed internally by snapd being skipped.
1333 [ 10.486846] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
1334 [ 10.487457] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
1335 [ 10.519036] systemd[1]: plymouth-read-write.service: Succeeded.
1336 [ 10.524489] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
1337 [ 10.535293] systemd[1]: Started udev Kernel Device Manager.
1338 [ 10.571196] systemd[1]: Finished Set console font and keymap.
1339 [ 11.208985] core: _opp_supported_by_regulators: OPP minuV: 1475000 maxuV: 1475000, not supported by regulator
1340 [ 11.209010] cpu cpu0: _opp_add: OPP not supported by regulators (2016000000)
1341 [ 11.209332] core: _opp_supported_by_regulators: OPP minuV: 1475000 maxuV: 1475000, not supported by regulator
1342 [ 11.209351] cpu cpu0: _opp_add: OPP not supported by regulators (2040000000)
1343 [ 11.209686] core: _opp_supported_by_regulators: OPP minuV: 1475000 maxuV: 1475000, not supported by regulator
1344 [ 11.209704] cpu cpu0: _opp_add: OPP not supported by regulators (2064000000)
1345 [ 11.210065] core: _opp_supported_by_regulators: OPP minuV: 1500000 maxuV: 1500000, not supported by regulator
1346 [ 11.210084] cpu cpu0: _opp_add: OPP not supported by regulators (2088000000)
1347 [ 11.210418] core: _opp_supported_by_regulators: OPP minuV: 1500000 maxuV: 1500000, not supported by regulator
1348 [ 11.210437] cpu cpu0: _opp_add: OPP not supported by regulators (2112000000)
1349 [ 11.210742] core: _opp_supported_by_regulators: OPP minuV: 1500000 maxuV: 1500000, not supported by regulator
1350 [ 11.210760] cpu cpu0: _opp_add: OPP not supported by regulators (2136000000)
1351 [ 11.211353] core: _opp_supported_by_regulators: OPP minuV: 1500000 maxuV: 1500000, not supported by regulator
1352 [ 11.211373] cpu cpu0: _opp_add: OPP not supported by regulators (2160000000)
1353 [ 11.211717] core: _opp_supported_by_regulators: OPP minuV: 1500000 maxuV: 1500000, not supported by regulator
1354 [ 11.211735] cpu cpu0: _opp_add: OPP not supported by regulators (2184000000)
1355 [ 11.212061] core: _opp_supported_by_regulators: OPP minuV: 1500000 maxuV: 1500000, not supported by regulator
1356 [ 11.212078] cpu cpu0: _opp_add: OPP not supported by regulators (2208000000)
1357 [ 11.212121] cpu cpu0: _opp_is_duplicate: duplicate OPPs detected. Existing: freq: 1704000000, volt: 1350000, enabled: 1. New: freq: 1704000000, volt: 1350000, enabled: 1
1358 [ 11.212159] cpu cpu0: _opp_is_duplicate: duplicate OPPs detected. Existing: freq: 1800000000, volt: 1400000, enabled: 1. New: freq: 1800000000, volt: 1400000, enabled: 1
1359 [ 11.215194] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 500000 KHz, changing to: 600000 KHz
1360 [ 11.239635] zram: Added device: zram0
1361 [ 11.239934] zram: Added device: zram1
1362 [ 11.240214] zram: Added device: zram2
1363 [ 11.311929] systemd[1]: Finished udev Coldplug all Devices.
1364 [ 11.315977] r8723bs: module is from the staging directory, the quality is unknown, you have been warned.
1365 [ 11.319914] RTL8723BS: module init start
1366 [ 11.319919] RTL8723BS: rtl8723bs vXXX.XXX.5.5_12290.20140916_BTCOEX20140507-4E40
1367 [ 11.319921] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
1368 [ 11.322681] pnetdev = 34189b2b
1369 [ 11.336851] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
1370 [ 11.347660] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
1371 [ 11.357353] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active.
1372 [ 11.365431] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
1373 [ 11.368998] systemd[1]: Reached target Local Encrypted Volumes.
1374 [ 11.389651] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
1375 [ 11.427064] RTL8723BS: rtw_ndev_init(wlan0)
1376 [ 11.427784] RTL8723BS: module init ret =0
1377 [ 11.428562] systemd[1]: Starting Raise network interfaces...
1378 [ 11.452077] zram0: detected capacity change from 0 to 1048838144
1379 [ 11.555169] Adding 1024252k swap on /dev/zram0. Priority:5 extents:1 across:1024252k SSFS
1380 [ 11.608683] systemd[1]: Found device /dev/ttyS2.
1381 [ 11.623988] gpiomem-rk3288 ff750000.rk3288-gpiomem: Initialised: Registers at 0xff750000
1382 [ 11.666742] dw_wdt ff800000.watchdog: No valid TOPs array specified
1383 [ 11.721229] rockchip-rga ff920000.rga: HW Version: 0x00.00
1384 [ 11.721619] rockchip-rga ff920000.rga: Registered rockchip-rga as /dev/video0
1385 [ 11.806547] panfrost ffa30000.gpu: clock rate = 400000000
1386 [ 11.807364] panfrost ffa30000.gpu: [drm:panfrost_devfreq_init [panfrost]] Failed to register cooling device
1387 [ 11.807408] panfrost ffa30000.gpu: mali-t760 id 0x750 major 0x0 minor 0x0 status 0x1
1388 [ 11.807415] panfrost ffa30000.gpu: features: 00000000,100277bf, issues: 00000000,24040400
1389 [ 11.807420] panfrost ffa30000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
1390 [ 11.807424] panfrost ffa30000.gpu: shader_present=0xf l2_present=0x1
1391 [ 11.831557] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
1392 [ 11.832586] hantro-vpu ff9a0000.video-codec: Adding to iommu group 2
1393 [ 11.833071] hantro-vpu ff9a0000.video-codec: registered rockchip,rk3288-vpu-enc as /dev/video1
1394 [ 11.833199] hantro-vpu ff9a0000.video-codec: registered rockchip,rk3288-vpu-dec as /dev/video2
1395 [ 11.845144] zram1: detected capacity change from 0 to 52428800
1396 [ 11.865151] rk3288-crypto ff8a0000.cypto-controller: Crypto Accelerator successfully registered
1397 [ 11.868845] [drm] Initialized panfrost 1.1.0 20180908 for ffa30000.gpu on minor 1
1398 [ 11.919210] systemd[1]: Finished Armbian ZRAM config.
1399 [ 11.994922] systemd[1]: Starting Armbian memory supported logging...
1400 [ 12.194085] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
1401 [ 12.194124] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
1402 [ 12.305440] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
1403 [ 12.311531] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]'
1404 [ 12.311552] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]'
1405 [ 12.439220] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
1406 [ 12.439571] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
1407 [ 12.440437] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
1408 [ 12.444147] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
1409 [ 12.448720] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
1410 [ 12.449082] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
1411 [ 12.453320] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
1412 [ 12.453676] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
1413 [ 12.453810] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
1414 [ 12.453945] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
1415 [ 12.454097] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
1416 [ 12.454199] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
1417 [ 12.456432] systemd[1]: Finished Raise network interfaces.
1418 [ 12.669295] systemd[1]: plymouth-read-write.service: Succeeded.
1419 [ 12.671001] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
1420 [ 12.701324] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
1421 [ 12.701629] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
1422 [ 12.701744] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
1423 [ 12.705418] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
1424 [ 12.708870] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
1425 [ 12.708963] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
1426 [ 12.709178] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
1427 [ 12.709284] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
1428 [ 12.709420] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
1429 [ 12.709545] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
1430 [ 12.709637] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
1431 [ 12.712729] systemd[1]: Starting Load/Save RF Kill Switch Status...
1432 [ 12.721790] systemd[1]: plymouth-read-write.service: Succeeded.
1433 [ 12.723366] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
1434 [ 12.728510] systemd[1]: Started Load/Save RF Kill Switch Status.
1435 [ 13.469980] usbcore: registered new interface driver snd-usb-audio
1436 [ 13.487930] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
1437 [ 13.488232] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
1438 [ 13.488338] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
1439 [ 13.491508] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
1440 [ 13.495122] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
1441 [ 13.495224] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
1442 [ 13.495441] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
1443 [ 13.495539] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
1444 [ 13.495634] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
1445 [ 13.495732] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
1446 [ 13.495802] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
1447 [ 13.508215] systemd[1]: plymouth-read-write.service: Succeeded.
1448 [ 13.509567] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
1449 [ 14.567383] systemd[1]: Finished Armbian memory supported logging.
1450 [ 14.575523] systemd[1]: Starting Journal Service...
1451 [ 14.780092] systemd[1]: Started Journal Service.
1452 [ 14.799946] systemd-journald[831]: Received client request to flush runtime journal.
1453 [ 15.629678] gpio gpiochip4: Persistence not supported for GPIO 26
1454 [ 15.629952] gpio gpiochip4: Persistence not supported for GPIO 29
1455 [ 15.630133] gpio gpiochip4: Persistence not supported for GPIO 31
1456 [ 15.917832] squashfs: version 4.0 (2009/01/31) Phillip Lougher
1457 [ 16.053464] Initializing XFRM netlink socket
1458 [ 16.130712] PPP generic driver version 2.4.2
1459 [ 16.132180] NET: Registered protocol family 24
1460 [ 16.176891] l2tp_core: L2TP core driver, V2.0
1461 [ 16.180357] l2tp_netlink: L2TP netlink interface
1462 [ 16.196362] l2tp_ppp: PPPoL2TP kernel driver, V2.0
1463 [ 16.415893] rk_gmac-dwmac ff290000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211E Gigabit Ethernet] (irq=POLL)
1464 [ 16.427034] rk_gmac-dwmac ff290000.ethernet eth0: No Safety Features support found
1465 [ 16.427048] rk_gmac-dwmac ff290000.ethernet eth0: PTP not supported by HW
1466 [ 16.427429] rk_gmac-dwmac ff290000.ethernet eth0: configuring for phy/rgmii link mode
1467 [ 16.502370] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin
1468 [ 17.669868] dw-apb-uart ff180000.serial: failed to request DMA
1469 [ 19.730305] RTL8723BS: rtw_set_802_11_connect(wlan0) fw_state = 0x00000008
1470 [ 20.028161] RTL8723BS: start auth
1471 [ 20.031027] RTL8723BS: auth success, start assoc
1472 [ 20.034375] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
1473 [ 20.034394] RTL8723BS: assoc success
1474 [ 20.336646] RTL8723BS: send eapol packet
1475 [ 20.343267] RTL8723BS: send eapol packet
1476 [ 20.343455] RTL8723BS: set pairwise key camid:4, addr:a0:e4:cb:09:93:be, kid:0, type:AES
1477 [ 20.343741] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
1478 [ 20.345030] RTL8723BS: set group key camid:5, addr:a0:e4:cb:09:93:be, kid:2, type:AES
1479 [ 37.857975] vcc_sd: supplied by vcc_io
1480 [ 37.858109] vcc_sd: disabling
1481 [ 525.279968] mmc0: card 0001 removed
1482 [ 525.339848] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
1483 [ 525.392304] mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
1484 [ 525.449061] mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
1485 [ 525.512587] mmc_host mmc0: Bus speed (slot 0) = 187500Hz (slot req 100000Hz, actual 93750HZ div = 1)
1486
1487
1488
1489 ### interrupts:
1490 CPU0 CPU1 CPU2 CPU3
1491 25: 34978 29949 45201 75003 GIC-0 29 Level arch_timer
1492 26: 0 0 0 0 GIC-0 30 Level arch_timer
1493 29: 0 0 0 0 GIC-0 104 Level rk_timer
1494 30: 0 0 0 0 GIC-0 183 Level arm-pmu
1495 31: 0 0 0 0 GIC-0 184 Level arm-pmu
1496 32: 0 0 0 0 GIC-0 185 Level arm-pmu
1497 33: 0 0 0 0 GIC-0 186 Level arm-pmu
1498 34: 0 0 0 0 GIC-0 34 Level ff250000.dma-controller
1499 35: 0 0 0 0 GIC-0 35 Level ff250000.dma-controller
1500 36: 405 0 0 0 GIC-0 32 Level ffb20000.dma-controller
1501 37: 0 0 0 0 GIC-0 33 Level ffb20000.dma-controller
1502 38: 47881 0 0 0 GIC-0 64 Level dw-mci
1503 39: 167803 0 0 0 GIC-0 65 Level dw-mci
1504 40: 72820 0 0 0 GIC-0 67 Level dw-mci
1505 41: 3 0 0 0 GIC-0 68 Level ff100000.saradc
1506 42: 105 0 0 0 GIC-0 97 Level ff170000.i2c
1507 43: 23 0 0 0 GIC-0 87 Level ttyS0
1508 45: 3 0 0 0 GIC-0 89 Level ttyS2
1509 48: 0 0 0 0 GIC-0 69 Level rockchip_thermal
1510 49: 0 0 0 0 GIC-0 59 Level eth0
1511 50: 0 0 0 0 GIC-0 60 Level eth0
1512 51: 299 0 10768 0 GIC-0 56 Level ehci_hcd:usb3
1513 52: 89010 8645477 0 0 GIC-0 57 Level ff540000.usb, dwc2_hsotg:usb1
1514 53: 0 0 0 0 GIC-0 55 Level ff580000.usb, ff580000.usb, dwc2_hsotg:usb2
1515 54: 1200 0 0 0 GIC-0 92 Level ff650000.i2c
1516 55: 0 0 0 0 GIC-0 93 Level ff660000.i2c
1517 56: 0 0 0 0 GIC-0 111 Edge ff800000.watchdog
1518 58: 0 0 0 0 GIC-0 80 Level rk-crypto
1519 59: 0 0 0 0 GIC-0 50 Level ff920000.rga
1520 60: 18854 0 0 0 GIC-0 47 Level ff930300.iommu, ff930000.vop
1521 61: 0 0 0 0 GIC-0 48 Level ff940300.iommu, ff940000.vop
1522 62: 1 0 0 0 GIC-0 135 Level ff980000.hdmi, dw-hdmi-cec
1523 63: 0 0 0 0 GIC-0 41 Level ff9a0000.video-codec
1524 64: 0 0 0 0 GIC-0 42 Level ff9a0000.video-codec
1525 65: 0 0 0 0 GIC-0 43 Level ff9a0800.iommu
1526 66: 27858 0 0 0 GIC-0 38 Level panfrost-job
1527 67: 0 0 0 0 GIC-0 39 Level panfrost-mmu
1528 68: 2 0 0 2593 GIC-0 40 Level panfrost-gpu
1529 78: 0 0 0 0 rockchip_gpio_irq 4 Level rk808
1530 84: 0 0 0 0 rk808 5 Edge RTC alarm
1531 88: 0 0 0 0 rockchip_gpio_irq 5 Edge GPIO Key Power
1532 IPI0: 0 0 0 0 CPU wakeup interrupts
1533 IPI1: 0 0 0 0 Timer broadcast interrupts
1534 IPI2: 881 856 915 726 Rescheduling interrupts
1535 IPI3: 52982 36714 83184 83220 Function call interrupts
1536 IPI4: 0 0 0 0 CPU stop interrupts
1537 IPI5: 2729 250 271 925 IRQ work interrupts
1538 IPI6: 0 0 0 0 completion interrupts
1539 Err: 0
Please upload the whole output above to an online pasteboard service
and provide the URL in the forum where you have been asked for this.
schong@tinkerboard:~$ +
