Why is armbian bullseye still unstable for odroid HC2?
I read that armbian bullseye for odroid HC2 is still unstable, while it is considered stable for other boards. Can somone explain the reaseon for this? Or point me to a place where this is discussed?
If I knew what the reason is and it would be not important for my application, I could switch to bullseye now.
Regards,
jba
From hardware support point of view there should not be a difference since all Armbian flavors  (Focal, Buster, Bullseye....) share the very same kernel package. So I'd consider Bullseye as stable too. However dist-upgrades are not supported by Armbian. So the better way would be to start over with a clean (Bullseye) image and port your applications.
Hi Werner,
when I select "Odroid HC1 / HC2 / MC1" in Downloads I am directed to a page where Buster is recommended as stable release ("High level of software maturity").
When looking for other boards (e.g. Odroid HC4) bullseye  is recommended as stable releases ("High level of software maturity").
If I understand you correctly bullseye should have the same status for both boards. So, is this a mistake on the download page? No need to worry about bullseye status?
jba
