franki Posted September 6, 2016 Share Posted September 6, 2016 Hi I have problem with Cubieboard2 powering off during Legacy Armbian_5.14_Cubieboard2_Debian_jessie_3.4.112 boot. It had been explained a little bit here: http://forum.armbian.com/index.php/topic/1178-cubieboard-1-legacy-boot-failure/ So maybe I need uBoot upgrade. I had written SD card with command: dd if=Armbian_5.14_Cubieboard2_Debian_jessie_3.4.112.raw of=/dev/sdd bs=1M and upgraded uboot from here: http://phelum.net/temp/CB2/u-boot-sunxi-with-spl.bin with command: dd if=u-boot-sunxi-with-spl.bin of=/dev/sdd bs=1k seek=8 full boot output here: U-Boot SPL 2016.05-12902-g0e6e34a-dirty (Jun 19 2016 - 21:55:16) DRAM: 1024 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2016.05-12902-g0e6e34a-dirty (Jun 19 2016 - 21:55:16 +1000) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: Cubietech Cubieboard2 I2C: ready DRAM: 1 GiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial SCSI: SATA link 0 timeout. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst Net: No ethernet found. starting USB... USB0: USB EHCI 1.00 USB1: USB EHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 1 for devices... 1 USB Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2447 bytes read in 181 ms (12.7 KiB/s) ## Executing script at 43100000 0 bytes read in 131 ms (0 Bytes/s) ** File not found /boot/.next ** ** Unrecognized filesystem type ** ** File not found .next ** 46308 bytes read in 344 ms (130.9 KiB/s) 3644163 bytes read in 383 ms (9.1 MiB/s) 5606240 bytes read in 546 ms (9.8 MiB/s) Kernel image @ 0x48000000 [ 0x000000 - 0x558b60 ] ## Loading init Ramdisk from Legacy Image at 42000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3644099 Bytes = 3.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Starting kernel ... <6>Booting Linux on physical CPU 0 <6>Initializing cgroup subsys cpuset <6>Initializing cgroup subsys cpu <5>Linux version 3.4.112-sun7i (root@pluton) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubuntu2) ) #7 SMP PREEMPT Tue Jun 21 15:43:57 CEST 2016 CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: sun7i <6>Memory Reserved: <6> SYS : 0x43000000 - 0x4300ffff ( 64 kB) <6> LCD : 0x44000000 - 0x44ffffff ( 16 MB) Memory policy: ECC disabled, Data cache writealloc <6>sunxi: Allwinner A20 (AW1651/sun7i) detected. <7>On node 0 totalpages: 262144 <7>free_area_init_node: node 0, pgdat c0a89440, node_mem_map d0000000 <7> DMA zone: 512 pages used for memmap <7> DMA zone: 0 pages reserved <7> DMA zone: 65024 pages, LIFO batch:15 <7> Normal zone: 1008 pages used for memmap <7> Normal zone: 128016 pages, LIFO batch:31 <7> HighMem zone: 528 pages used for memmap <7> HighMem zone: 67056 pages, LIFO batch:15 <6>PERCPU: Embedded 8 pages/cpu @d0808000 s8256 r8192 d16320 u32768 <7>pcpu-alloc: s8256 r8192 d16320 u32768 alloc=8*4096<c> <7>pcpu-alloc: <c>[0] <c>0 <c>[0] <c>1 <c> Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096 <5>Kernel command line: console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi7 <6>PID hash table entries: 4096 (order: 2, 16384 bytes) <6>Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) <6>Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) <6>allocated 2097152 bytes of page_cgroup <6>please try 'cgroup_disable=memory' option if you don't want memory cgroups <6>Memory: 1024MB = 1024MB total <5>Memory: 1004732k/1004732k available, 43844k reserved, 270336K highmem <5>Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) lowmem : 0xc0000000 - 0xef800000 ( 760 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0xc0008000 - 0xc09dfe98 (10080 kB) .init : 0xc09e0000 - 0xc0a18040 ( 225 kB) .data : 0xc0a1a000 - 0xc0a91d68 ( 480 kB) .bss : 0xc0a91d8c - 0xc0c66f78 (1877 kB) <6>SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 <6>Preemptible hierarchical RCU implementation. <6> RCU dyntick-idle grace-period acceleration is enabled. <6> Additional per-CPU info printed with stalls. <6>NR_IRQS:192 <6>Architected local timer running at 24.00MHz. <6>sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms <2>start_kernel(): bug: interrupts were enabled early <6>Console: colour dummy device 80x30 <6>console [tty1] enabled <6>Calibrating delay loop... <c>1816.98 BogoMIPS (lpj=9084928) <6>pid_max: default: 32768 minimum: 301 <6>Mount-cache hash table entries: 512 <6>Initializing cgroup subsys cpuacct <6>Initializing cgroup subsys memory <6>Initializing cgroup subsys devices <6>Initializing cgroup subsys freezer <6>Initializing cgroup subsys blkio <6>Initializing cgroup subsys perf_event <6>CPU: Testing write buffer coherency: ok <6>CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 <6>hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available <6>Setting up static identity map for 0x40724a18 - 0x40724a70 CPU1: Booted secondary processor <6>CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 <6>Brought up 2 CPUs <6>SMP: Total of 2 processors activated (3640.52 BogoMIPS). <6>devtmpfs: initialized <6>dummy: <6>NET: Registered protocol family 16 <6>DMA: preallocated 256 KiB pool for atomic coherent allocations <6>hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. <6>hw-breakpoint: maximum watchpoint size is 8 bytes. <6>[ccu-inf] aw clock manager init <6>[ccu-inf] aw_ccu_init <6>[ccu-inf] script config pll3 to 297MHz <6>[ccu-inf] script config pll4 to 300MHz <6>[ccu-inf] script config pll6 to 600MHz <6>[ccu-inf] script config pll7 to 297MHz <6>[ccu-inf] script config pll8 to 336MHz <6>Init eGon pin module V2.0 <6>bio: create slab <bio-0> at 0 <6>sunxi_gpio driver init ver 1.3 <6>gpiochip_add: registered GPIOs 1 to 2 on device: A1X_GPIO <5>SCSI subsystem initialized <7>libata version 3.00 loaded. <6>usbcore: registered new interface driver usbfs <6>usbcore: registered new interface driver hub <6>usbcore: registered new device driver usb <6>Linux media interface: v0.10 <6>Linux video capture interface: v2.00 <6>Advanced Linux Sound Architecture Driver Version 1.0.25. <6>Switching to clocksource arch_sys_counter <5>FS-Cache: Loaded <6>CacheFiles: Loaded <6>cfg80211: Calling CRDA to update world regulatory domain [usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG [sw_hcd0]: usb host driver initialize........ [sw_hcd0]: open_usb_clock [sw_hcd0]: host_init_state = 1 [sw_hcd0]: platform is usb host [sw_hcd0]: sw_hcd_host0: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx (X), HB-ISO Tx (X), SoftConn) [sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IRQ 70 <6>sw_hcd_host0 sw_hcd_host0: sw_hcd host driver <6>sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1 <6>hub 1-0:1.0: USB hub found <6>hub 1-0:1.0: 1 port detected wrn: hcd is not enable, need not start hcd [sw_hcd0]: sw_usb_host0_disable start -------sw_hcd0_soft_disconnect--------- is_on = 0, hcd0_set_vbus_cnt = 0 [sw_hcd_host0]: Set USB Power Off wrn: hcd is not enable, need not stop hcd [sw_hcd0]: close_usb_clock [sw_hcd0]: sw_usb_host0_disable end [sw_udc]: udc_init: version 20080411 <6>NET: Registered protocol family 2 <6>IP route cache hash table entries: 32768 (order: 5, 131072 bytes) <6>TCP established hash table entries: 131072 (order: 8, 1048576 bytes) <6>TCP bind hash table entries: 65536 (order: 7, 786432 bytes) <6>TCP: Hash tables configured (established 131072 bind 65536) <6>TCP: reno registered <6>UDP hash table entries: 512 (order: 2, 16384 bytes) <6>UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) <6>NET: Registered protocol family 1 <6>RPC: Registered named UNIX socket transport module. <6>RPC: Registered udp transport module. <6>RPC: Registered tcp transport module. <6>RPC: Registered tcp NFSv4.1 backchannel transport module. <6>Trying to unpack rootfs image as initramfs... <6>Freeing initrd memory: 3556K <6>audit: initializing netlink socket (disabled) <5>type=2000 audit(0.860:1): initialized highmem bounce pool size: 64 pages <5>VFS: Disk quotas dquot_6.5.2 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) <6>squashfs: version 4.0 (2009/01/31) Phillip Lougher <5>NFS: Registering the id_resolver key type <6>NTFS driver 2.1.30 [Flags: R/W]. <6>fuse init (API version 7.18) <6>JFS: nTxBlock = 7877, nTxLock = 63018 <6>SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled <6>Btrfs loaded <6>msgmni has been set to 1441 <6>alg: No test for stdrng (krng) <6>Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) <6>io scheduler noop registered <6>io scheduler deadline registered <6>io scheduler cfq registered (default) <6>sunxi disp driver loaded (/dev/disp api 1.0) <6>Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled <6>[uart]: used uart info.: 0x01 <6>[uart]: serial probe 0 irq 33 mapbase 0x01c28000 <6>sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a U6_16550A [ 0.000000] Booting Linux on physical CPU 0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4.112-sun7i (root@pluton) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubuntu2) ) #7 SMP PREEMPT Tue Jun 21 15:43:57 CEST 2016 [ 0.000000] Memory Reserved: [ 0.000000] SYS : 0x43000000 - 0x4300ffff ( 64 kB) [ 0.000000] LCD : 0x44000000 - 0x44ffffff ( 16 MB) [ 0.000000] sunxi: Allwinner A20 (AW1651/sun7i) detected. [ 0.000000] PERCPU: Embedded 8 pages/cpu @d0808000 s8256 r8192 d16320 u32768 [ 0.000000] Kernel command line: console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 sunxi_ve_mem_res7 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 1024MB = 1024MB total [ 0.000000] Memory: 1004732k/1004732k available, 43844k reserved, 270336K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc09dfe98 (10080 kB) [ 0.000000] .init : 0xc09e0000 - 0xc0a18040 ( 225 kB) [ 0.000000] .data : 0xc0a1a000 - 0xc0a91d68 ( 480 kB) [ 0.000000] .bss : 0xc0a91d8c - 0xc0c66f78 (1877 kB) [ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] Additional per-CPU info printed with stalls. [ 0.000000] NR_IRQS:192 [ 0.000000] Architected local timer running at 24.00MHz. [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms [ 0.000000] start_kernel(): bug: interrupts were enabled early [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty1] enabled [ 0.013674] Calibrating delay loop... 1816.98 BogoMIPS (lpj=9084928) [ 0.076012] pid_max: default: 32768 minimum: 301 [ 0.079677] Mount-cache hash table entries: 512 [ 0.083883] Initializing cgroup subsys cpuacct [ 0.087221] Initializing cgroup subsys memory [ 0.090653] Initializing cgroup subsys devices [ 0.094101] Initializing cgroup subsys freezer [ 0.097337] Initializing cgroup subsys blkio [ 0.101020] Initializing cgroup subsys perf_event [ 0.104612] CPU: Testing write buffer coherency: ok [ 0.109822] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.116943] hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available [ 0.122499] Setting up static identity map for 0x40724a18 - 0x40724a70 [ 0.297418] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.299424] Brought up 2 CPUs [ 0.304763] SMP: Total of 2 processors activated (3640.52 BogoMIPS). [ 0.307997] devtmpfs: initialized [ 0.314071] dummy: [ 0.317779] NET: Registered protocol family 16 [ 0.324233] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.332185] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.337018] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.340183] [ccu-inf] aw clock manager init [ 0.342464] [ccu-inf] aw_ccu_init [ 0.346438] [ccu-inf] script config pll3 to 297MHz [ 0.350199] [ccu-inf] script config pll4 to 300MHz [ 0.353956] [ccu-inf] script config pll6 to 600MHz [ 0.357728] [ccu-inf] script config pll7 to 297MHz [ 0.361485] [ccu-inf] script config pll8 to 336MHz [ 0.364258] Init eGon pin module V2.0 [ 0.373854] bio: create slab <bio-0> at 0 [ 0.377450] sunxi_gpio driver init ver 1.3 [ 0.383113] gpiochip_add: registered GPIOs 1 to 2 on device: A1X_GPIO [ 0.386284] SCSI subsystem initialized [ 0.393854] usbcore: registered new interface driver usbfs [ 0.398198] usbcore: registered new interface driver hub [ 0.402376] usbcore: registered new device driver usb [ 0.405530] Linux media interface: v0.10 [ 0.409173] Linux video capture interface: v2.00 [ 0.414776] Advanced Linux Sound Architecture Driver Version 1.0.25. [ 0.420364] Switching to clocksource arch_sys_counter [ 0.422482] FS-Cache: Loaded [ 0.424765] CacheFiles: Loaded [ 0.435780] cfg80211: Calling CRDA to update world regulatory domain [ 0.496991] sw_hcd_host0 sw_hcd_host0: sw_hcd host driver [ 0.503711] sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1 [ 0.507162] hub 1-0:1.0: USB hub found [ 0.510073] hub 1-0:1.0: 1 port detected [ 0.544252] NET: Registered protocol family 2 [ 0.560816] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.567761] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.575278] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) [ 0.582052] TCP: Hash tables configured (established 131072 bind 65536) [ 0.584270] TCP: reno registered [ 0.589156] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.594503] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.598126] NET: Registered protocol family 1 [ 0.603392] RPC: Registered named UNIX socket transport module. [ 0.607119] RPC: Registered udp transport module. [ 0.610787] RPC: Registered tcp transport module. [ 0.616198] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.620785] Trying to unpack rootfs image as initramfs... [ 0.867611] Freeing initrd memory: 3556K [ 0.873256] audit: initializing netlink socket (disabled) [ 0.877074] type=2000 audit(0.860:1): initialized [ 0.893375] VFS: Disk quotas dquot_6.5.2 [ 0.906151] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.911685] NFS: Registering the id_resolver key type [ 0.916280] NTFS driver 2.1.30 [Flags: R/W]. [ 0.919581] fuse init (API version 7.18) [ 0.924268] JFS: nTxBlock = 7877, nTxLock = 63018 [ 0.942390] SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled [ 0.946695] Btrfs loaded [ 0.949536] msgmni has been set to 1441 [ 0.957079] alg: No test for stdrng (krng) [ 0.963771] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) [ 0.966718] io scheduler noop registered [ 0.969953] io scheduler deadline registered [ 0.973652] io scheduler cfq registered (default) [ 0.978527] sunxi disp driver loaded (/dev/disp api 1.0) [ 0.984076] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 0.988753] [uart]: used uart info.: 0x01 [ 0.993466] [uart]: serial probe 0 irq 33 mapbase 0x01c28000 [ 1.019772] sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a U6_16550A <6>console [ttyS0] enabled [ 1.686564] console [ttyS0] enabled <7>G2D: drv_g2d_init <6>G2D: Module initialized.major:250 [ 1.696076] G2D: Module initialized.major:250 <6>brd: module loaded [ 1.709624] brd: module loaded <6>loop: module loaded [ 1.718622] loop: module loaded [NAND] nand driver version: 0x2 0x9 <4>Dev Sunxi softw311 nand magic does not match for MBR 1: �������� [ 1.787878] Dev Sunxi softw311 nand magic does not match for MBR 1: �������� <4>Dev Sunxi softw311 nand magic does not match for MBR 2: �������� [ 1.800992] Dev Sunxi softw311 nand magic does not match for MBR 2: �������� <4>Dev Sunxi softw311 nand magic does not match for MBR 3: �������� [ 1.814055] Dev Sunxi softw311 nand magic does not match for MBR 3: �������� <4>Dev Sunxi softw311 nand magic does not match for MBR 4: �������� [ 1.827114] Dev Sunxi softw311 nand magic does not match for MBR 4: �������� <4>Dev Sunxi softw311 nand header bad for all MBR copies, MBR corrupted or not present. [ 1.841906] Dev Sunxi softw311 nand header bad for all MBR copies, MBR corrupted or not present. <4>Dev Sunxi softw411 nand magic does not match for MBR 1: �������� [ 1.856718] Dev Sunxi softw411 nand magic does not match for MBR 1: �������� <4>Dev Sunxi softw411 nand magic does not match for MBR 2: �������� [ 1.871782] Dev Sunxi softw411 nand magic does not match for MBR 2: �������� <4>Dev Sunxi softw411 nand magic does not match for MBR 3: �������� [ 1.886837] Dev Sunxi softw411 nand magic does not match for MBR 3: �������� <4>Dev Sunxi softw411 nand magic does not match for MBR 4: �������� [ 1.901868] Dev Sunxi softw411 nand magic does not match for MBR 4: �������� <4>Dev Sunxi softw411 nand header bad for all MBR copies, MBR corrupted or not present. [ 1.916665] Dev Sunxi softw411 nand header bad for all MBR copies, MBR corrupted or not present. <6> nand: unknown partition table [ 1.928515] nand: unknown partition table [NAND]nand driver, ok. pwm-sunxi: pwm0 configured - period: 20, duty_percent: 50, duty: 10 <6>sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP [ 1.947672] sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP <6>ahci: SSS flag set, parallel bus scan disabled [ 1.959151] ahci: SSS flag set, parallel bus scan disabled <6>sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode [ 1.972065] sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode <6>sw_ahci sw_ahci.0: flags: ncq sntf stag pm led clo only pio slum part ccc [ 1.987414] sw_ahci sw_ahci.0: flags: ncq sntf stag pm led clo only pio slum part ccc <6>scsi0 : sw_ahci_platform [ 1.998736] scsi0 : sw_ahci_platform <6>ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88 [ 2.009577] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88 <3>[spi-err] Get spi devices number failed [ 2.021590] [spi-err] Get spi devices number failed <3>[spi-err] register spi devices board info failed [ 2.031200] [spi-err] register spi devices board info failed <4>spi: cannot find any using configuration for all 4 spi controllers, return directly! [ 2.046419] spi: cannot find any using configuration for all 4 spi controllers, return directly! <6>bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) [ 2.063055] bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) <6>Fixed MDIO Bus: probed [ 2.074970] Fixed MDIO Bus: probed <6>sunxi_emac Using mii phy on PortA [ 2.081706] sunxi_emac Using mii phy on PortA <6>sunxi_emac Using MAC from SID: 02:03:08:82:e6:1c[ 2.100892] sunxi_emac Using MAC from SID: 02:03:08:82:e6:1c<4>emac_init fetch emac using configuration failed [ 2.112877] emac_init fetch emac using configuration failed <6>gmac driver is disabled [ 2.121124] gmac driver is disabled <6>PPP generic driver version 2.4.2 [ 2.127840] PPP generic driver version 2.4.2 <6>PPP BSD Compression module registered [ 2.136047] PPP BSD Compression module registered <6>PPP Deflate Compression module registered [ 2.144786] PPP Deflate Compression module registered <6>PPP MPPE Compression module registered [ 2.156979] PPP MPPE Compression module registered <6>NET: Registered protocol family 24 [ 2.165228] NET: Registered protocol family 24 <6>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.175801] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver <6>ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.187575] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [sw-ehci1]: open clock [sw-ehci1]: Set USB Power ON <6>sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.225340] sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver <6>sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2 [ 2.239103] sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2 <6>sw-ehci sw-ehci.1: irq 71, io mem 0x01c14000 [ 2.250589] sw-ehci sw-ehci.1: irq 71, io mem 0x01c14000 <6>sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00 [ 2.274802] sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00 <6>hub 2-0:1.0: USB hub found [ 2.283605] hub 2-0:1.0: USB hub found <6>hub 2-0:1.0: 1 port detected [ 2.290254] hub 2-0:1.0: 1 port detected [sw-ohci1]: open clock <6>sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 2.323005] sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver <6>sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3 [ 2.336396] sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3 <6>sw-ohci sw-ohci.1: irq 96, io mem 0x01c14400 [ 2.347763] sw-ohci sw-ohci.1: irq 96, io mem 0x01c14400 <6>hub 3-0:1.0: USB hub found [ 2.417769] hub 3-0:1.0: USB hub found <6>hub 3-0:1.0: 1 port detected [ 2.424453] hub 3-0:1.0: 1 port detected [sw-ehci2]: open clock [sw-ehci2]: Set USB Power ON <6>sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.460128] sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver <6>sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 4 [ 2.473845] sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 4 <6>sw-ehci sw-ehci.2: irq 72, io mem 0x01c1c000 [ 2.485313] sw-ehci sw-ehci.2: irq 72, io mem 0x01c1c000 <6>sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00 [ 2.514804] sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00 <6>hub 4-0:1.0: USB hub found [ 2.523610] hub 4-0:1.0: USB hub found <6>hub 4-0:1.0: 1 port detected [ 2.530254] hub 4-0:1.0: 1 port detected [sw-ohci2]: open clock <6>sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 2.562998] sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver <6>sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 5 [ 2.576382] sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 5 <6>sw-ohci sw-ohci.2: irq 97, io mem 0x01c1c400 [ 2.587756] sw-ohci sw-ohci.2: irq 97, io mem 0x01c1c400 <6>hub 5-0:1.0: USB hub found [ 2.657808] hub 5-0:1.0: USB hub found <6>hub 5-0:1.0: 1 port detected [ 2.664479] hub 5-0:1.0: 1 port detected <6>Initializing USB Mass Storage driver... [ 2.672651] Initializing USB Mass Storage driver... <6>usbcore: registered new interface driver usb-storage [ 2.682677] usbcore: registered new interface driver usb-storage <6>USB Mass Storage support registered. [ 2.692276] USB Mass Storage support registered. <6>usbcore: registered new interface driver ums-alauda [ 2.701830] usbcore: registered new interface driver ums-alauda <6>usbcore: registered new interface driver ums-cypress [ 2.712787] usbcore: registered new interface driver ums-cypress <6>usbcore: registered new interface driver ums-datafab <6>ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 2<.723815] usbcore: registered new interface driver ums-datafab 6[ 2.728951] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) >ata1.00: ATA-8: INTEL SSDSA2CT040G3, 4PC10362, max UDMA/133 [ < 2.746670] ata1.00: ATA-8: INTEL SSDSA2CT040G3, 4PC10362, max UDMA/133 6>ata1.00: 78165360 sectors, multi 1: LBA48 NCQ (depth 31/32) [ 2<.758832] ata1.00: 78165360 sectors, multi 1: LBA48 NCQ (depth 31/32) 6>ata1.00: configured for UDMA/133 [ 2.7<68653] ata1.00: configured for UDMA/133 5>scsi 0:0:0:0: Direct-Access ATA INTEL SSDSA2CT04 4PC1 PQ: 0 ANSI: 5 [ 2.779<945] scsi 0:0:0:0: Direct-Access ATA INTEL SSDSA2CT04 4PC1 PQ: 0 ANSI: 5 5>sd 0:0:0:0: [sda] 78165360 512-byte logical blocks: (40.0 GB/37.2 GiB) [ 2.794<541] sd 0:0:0:0: [sda] 78165360 512-byte logical blocks: (40.0 GB/37.2 GiB) 5>sd 0:0:0:0: [sda] Write Protect is off [ < 2.805842] sd 0:0:0:0: [sda] Write Protect is off 7>sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 <5>sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA <6>usbcore: registered new interface driver ums_eneub6250 [ < 2.822801] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA 6>us[ 2.827935] usbcore: registered new interface driver ums_eneub6250 bcore: registered new interface driver ums-freecom [ < 2.848087] usbcore: registered new interface driver ums-freecom 6>usbcore: registered new interface driver ums-isd200 [ < 2.858948] usbcore: registered new interface driver ums-isd200 6>usbcore: registered new interface driver ums-jumpshot [ < 2.869895] usbcore: registered new interface driver ums-jumpshot 6>usbcore: registered new interface driver ums-karma [ < 2.880756] usbcore: registered new interface driver ums-karma 6>usbcore: registered new interface driver ums-onetouch [ < 2.891616] usbcore: registered new interface driver ums-onetouch 6>usbcore: registered new interface driver ums-realtek [ < 2.902650] usbcore: registered new interface driver ums-realtek 6>usbcore: registered new interface driver ums-sddr09 [ < 2.913519] usbcore: registered new interface driver ums-sddr09 6>usbcore: registered new interface driver ums-sddr55 [ < 2.924294] usbcore: registered new interface driver ums-sddr55 6>usbcore: registered new interface driver ums-usbat [ < 2.934981] usbcore: registered new interface driver ums-usbat 6>mousedev: PS/2 mouse device common for all mice [ = 2.945322] mousedev: PS/2 mouse device common for all mice ==========================hv_keypad_init===================== ========HV Inital =================== <6> sda: [ 2.960746<] sda: 5>sd 0:0:0:0: [sda] Attached SCSI disk [ 2.966254] sd 0:0:0:0: [sda] Attached SCSI disk <3>tkey_fetch_sysconfig_para: tkey_unused. [ 2.974831] tkey_fetch_sysconfig_para: tkey_unused. hv_keypad_init: after fetch_sysconfig_para: normal_i2c: 0x0. normal_i2c[1]: 0x0 <3>sunxi-rtc sunxi-rtc: Error: Set LOSC to external failed. [ 2.992746] sunxi-rtc sunxi-rtc: Error: Set LOSC to external failed. <3>sunxi-rtc sunxi-rtc: Warning: RTC time will be wrong! [ 3.004182] sunxi-rtc sunxi-rtc: Warning: RTC time will be wrong! <6>sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0 [ 3.015692] sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0 <6>i2c /dev entries driver [ 3.024363] i2c /dev entries driver config i2c gpio with gpio_config api <6>axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected [ 3.037104] axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected <6>axp_mfd 0-0034: AXP internal temperature monitoring enabled [ 3.048259] axp_mfd 0-0034: AXP internal temperature monitoring enabled <4>i2c i2c-0: Invalid probe address 0x00 [ 3.059646] i2c i2c-0: Invalid probe address 0x00 <6>I2C: i2c-0: AW16XX I2C adapter [ 3.067450] I2C: i2c-0: AW16XX I2C adapter [cedar dev]: not installed! ve_mem_reserve=0 [tt]----- avs_dev driver load... ---- [tt]----- register iomem ---- [tt]--- avs_dev driver load ok!! ----- [ace_drv] start!!! [ace_drv] init end!!! [pa_drv] start!!! [pa_drv] init end!!! <6>axp20_ldo1: 1300 mV [ 3.096838] axp20_ldo1: 1300 mV <6>axp20_ldo2: 1800 <--> 3300 mV at 3000 mV [ 3.105311] axp20_ldo2: 1800 <--> 3300 mV at 3000 mV Then Cubieboard2 just goes dead, I would also be happy with Vanilla image (which works), had it had NAND support. Is this the matter of compiling new kernel with nand support ? Best Regards Marek Link to comment Share on other sites More sharing options...
Igor Posted September 6, 2016 Share Posted September 6, 2016 After this fix, our tools are producing an working image. You only need to recompile boot loader, working source is Denx mainline, branch: v2015.10 There is no NAND support in Vanilla. Link to comment Share on other sites More sharing options...
franki Posted September 8, 2016 Author Share Posted September 8, 2016 Thank You. I will test it and report Best Regards Marek Link to comment Share on other sites More sharing options...
franki Posted September 9, 2016 Author Share Posted September 9, 2016 Hi I have checked two images: http://mirror.igorpecovnik.com/test/U-boot-2016.01-Armbian_5.17_Cubieboard2_Debian_jessie_3.4.112.7z http://mirror.igorpecovnik.com/test/U-boot-2015.10-Armbian_5.17_Cubieboard2_Debian_jessie_3.4.112.7z Boot is OK and the installation process, but there is problem with nand-sata-install. (boot from NAND, root on SATA) I have created /dev/sda1 and performed installation, all went well, but it doesn't boot without SD card. Here is console output from first image <4>Dev Sunxi softw311 nand magic does not match for MBR 1: softw411 <4>Dev Sunxi softw311 nand magic does not match for MBR 2: �������� <4>Dev Sunxi softw311 nand magic does not match for MBR 3: �������� <4>Dev Sunxi softw311 nand magic does not match for MBR 4: �������� <4>Dev Sunxi softw311 nand header bad for all MBR copies, MBR corrupted or not present. <4>Dev Sunxi softw411 nand: part 1, start 65536, size 65536 <4>Dev Sunxi softw411 nand: part 2, start 131072, size 7651328 <6> nand: nand1 nand2 <4>Dev Sunxi softw311 nand magic does not match for MBR 1: softw411 <4>Dev Sunxi softw311 nand magic does not match for MBR 2: �������� <4>Dev Sunxi softw311 nand magic does not match for MBR 3: �������� <4>Dev Sunxi softw311 nand magic does not match for MBR 4: �������� <4>Dev Sunxi softw311 nand header bad for all MBR copies, MBR corrupted or not present. <4>Dev Sunxi softw411 nand: part 1, start 65536, size 65536 <4>Dev Sunxi softw411 nand: part 2, start 131072, size 7651328 <6> nand: nand1 nand2 �┌��─��─��─�─��─��─��─��─��─��─��─��─��─NAND boot / SATA root install��─��─��─��─��─��─��─��─�─��─��─��─�─��─��─��─��┠��│ ��│ ��All done. Power off and remove SD to boot from NAND ��│ ��│ ��│ ��├��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─�─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─�� ��│ <Power off> < Exit > ��│ ��└��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─�─��─��─��─�─��─��─��─�─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─�� <30>systemd-shutdown[1]: Sending SIGTERM to remaining processes... <46>systemd-journald[175]: Received SIGTERM from PID 1 (systemd-shutdow). <30>systemd-shutdown[1]: Sending SIGKILL to remaining processes... <30>systemd-shutdown[1]: Unmounting file systems. <30>systemd-shutdown[1]: Unmounting /sys/kernel/config. <30>systemd-shutdown[1]: Unmounting /sys/fs/fuse/connections. <30>systemd-shutdown[1]: Unmounting /sys/kernel/debug. <30>systemd-shutdown[1]: Unmounting /dev/mqueue. <6>EXT4-fs (mmcblk0p1): re-mounted. Opts: (null) <6>EXT4-fs (mmcblk0p1): re-mounted. Opts: (null) <6>EXT4-fs (mmcblk0p1): re-mounted. Opts: (null) <30>systemd-shutdown[1]: All filesystems unmounted. <30>systemd-shutdown[1]: Deactivating swaps. <30>systemd-shutdown[1]: All swaps deactivated. <30>systemd-shutdown[1]: Detaching loop devices. <30>systemd-shutdown[1]: All loop devices detached. <30>systemd-shutdown[1]: Detaching DM devices. <30>systemd-shutdown[1]: All DM devices detached. <30>systemd-shutdown[1]: Powering off. <5>sd 0:0:0:0: [sda] Synchronizing SCSI cache <5>sd 0:0:0:0: [sda] Stopping disk <6>[sw-ohci2]: shutdown start [sw-ohci2]: close clock <6>[sw-ohci2]: shutdown end <6>[sw-ehci2]: shutdown start [sw-ehci2]: Set USB Power OFF [sw-ehci2]: close clock <6>[sw-ehci2]: shutdown end <6>[sw-ohci1]: shutdown start [sw-ohci1]: close clock <6>[sw-ohci1]: shutdown end <6>[sw-ehci1]: shutdown start [sw-ehci1]: Set USB Power OFF [sw-ehci1]: close clock <6>[sw-ehci1]: shutdown end wrn: hcd is disable, need not shutdown [NAND]shutdown nand try to shutdown 0 time Nand flash shutdown ok! <0>Power down. [ 1262.984858] Power down. <6>[hotplug]: cpu(0) try to kill cpu(1) <3>[hotplug]: try to kill cpu:1 failed! [axp] send power-off command! <4>[sched_delayed] sched: RT throttling activated �HELLO! BOOT0 is starting! boot0 version : 3.0.0 dram size =1024 sum=0x01be1e3a src_sum=0x01be1e3a Ready to disable icache. Jump to secend Boot. [ 0.131] U-Boot 2011.09-rc1-00003-ge89ab14-dirty (Jan 03 2014 - 12:57:33) Allwinner Technology [ 0.140]version: 1.1.0 [ 0.144]pmbus: ready [ 0.248]PMU: AXP209 [ 0.251]PMU: AXP20x found [ 0.254]PMU: bat ratio = 100 [ 0.257]after set, dcdc2 =1400mv [ 0.261]PMU: dcdc2 1400 [ 0.263]PMU: pll1 912 Mhz boot_clock = 912 dcdc2_vol = 1400 [ 0.271]after set, dcdc2 =1400mv dcdc3_vol = 1250 ldo2_vol = 3000 ldo3_vol = 2800 ldo4_vol = 2800 power_start = 0 storage_type = -1 usb_recovery = 1 find power_sply to end fel key old mode run key detect no key found no key input dram_para_set start dram_para_set end [ 0.307]DRAM: 1 GiB relocation Offset is: 35b23000 donn't initialize ther user_gpio (main_key:boot_init_gpio) DRV_DISP_Init: opened [ 0.521]boot_disp.output_type=4 [ 0.525]boot_disp.output_mode=4 [ 0.528]boot_disp.auto_hpd=1 workmode = 0 [ 1.832]NAND: NAND_UbootInit NB1 : enter NAND_LogicInit nand : get id_number_ctl from script, 3 not burn nand partition table! NB1 : nand_info_init fail [ 5.367]nand init fail set to recovery try sprite_led_gpio config sprite_led_gpio start sunxi sprite begin screen_width = 800 screen_height = 480 bar x1: 200 y1: 200 bar x2: 600 y2: 280 read mbr failed sprite update error: no data part found read mbr failed sprite update error: read image start error sprite update error: current card sprite failed now hold the machine fail to find part named env Using default environment In: serial Out: serial Err: serial --------fastboot partitions-------- mbr not exist base bootcmd=run setargs_nand boot_normal bootcmd set setargs_nand key 0 recovery key high 6, low 4 cant find fstbt value no misc partition is found to be run cmd=run setargs_nand boot_normal the part isn't exist WORK_MODE_BOOT WORK_MODE_BOOT [ 5.461]Hit any key to stop autoboot: 0 cant find part named boot sunxi_flash - sunxi_flash sub-system Usage: sunxi_flash read command parmeters : parmeters 0 : addr to load(hex only) parmeters 1 : the name of the part to be load [parmeters 2] : the number of bytes to be load(hex only) if [parmeters 2] not exist, the number of bytes to be load is the size of the part indecated on partemeter 1 boota: bad boot image magic, maybe not a boot.img? sunxi# and here output from second image Armbian for Cubieboard 2 install script, http://www.armbian.com | Author: Igor ��─��─��─��─��─��─��─��─��─��─��─��─�─��─��─��─�─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─�─��─��─��─�─��─��─��─�─��─��─��─��─��─��─��─��─��─��─��─� ��┌��─��─�─��─��─��─��─��─��─��─��─��─��─NAND boot / SATA root install��─��─��─�─��─��─��─�─��─��─��─��─��─��─��─��─��┠��│ ��│ �│All done. Power off and remove SD to boot from NAND ��│ ��│ ��│ ��├��─��─��─��─��─��─��─�─��─��─��─�─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─�─��─��─��─�─��─��─��─��─��─��─��─��─��─��─��─��─�� ��│ <Power off> < Exit > ��│ ��└��─��─��─��─��─��─�─��─��─��─�─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─��─�─��─��─��─�─��─��─��─�─��─��─��─��─��─��─��─��─��─��─��─��─��─�� <30>systemd-shutdown[1]: Sending SIGTERM to remaining processes... <46>systemd-journald[176]: Received SIGTERM from PID 1 (systemd-shutdow). <30>systemd-shutdown[1]: Sending SIGKILL to remaining processes... <30>systemd-shutdown[1]: Unmounting file systems. <30>systemd-shutdown[1]: Unmounting /sys/fs/fuse/connections. <30>systemd-shutdown[1]: Unmounting /sys/kernel/config. <30>systemd-shutdown[1]: Unmounting /sys/kernel/debug. <30>systemd-shutdown[1]: Unmounting /dev/mqueue. <6>EXT4-fs (mmcblk0p1): re-mounted. Opts: (null) <6>EXT4-fs (mmcblk0p1): re-mounted. Opts: (null) <6>EXT4-fs (mmcblk0p1): re-mounted. Opts: (null) <30>systemd-shutdown[1]: All filesystems unmounted. <30>systemd-shutdown[1]: Deactivating swaps. <30>systemd-shutdown[1]: All swaps deactivated. <30>systemd-shutdown[1]: Detaching loop devices. <30>systemd-shutdown[1]: All loop devices detached. <30>systemd-shutdown[1]: Detaching DM devices. <30>systemd-shutdown[1]: All DM devices detached. <30>systemd-shutdown[1]: Powering off. <5>sd 0:0:0:0: [sda] Synchronizing SCSI cache <5>sd 0:0:0:0: [sda] Stopping disk <6>[sw-ohci2]: shutdown start [sw-ohci2]: close clock <6>[sw-ohci2]: shutdown end <6>[sw-ehci2]: shutdown start [sw-ehci2]: Set USB Power OFF [sw-ehci2]: close clock <6>[sw-ehci2]: shutdown end <6>[sw-ohci1]: shutdown start [sw-ohci1]: close clock <6>[sw-ohci1]: shutdown end <6>[sw-ehci1]: shutdown start [sw-ehci1]: Set USB Power OFF [sw-ehci1]: close clock <6>[sw-ehci1]: shutdown end wrn: hcd is disable, need not shutdown [NAND]shutdown nand try to shutdown 0 time Nand flash shutdown ok! <0>Power down. [ 1297.823885] Power down. <6>[hotplug]: cpu(0) try to kill cpu(1) <3>[hotplug]: try to kill cpu:1 failed! [axp] send power-off command! �HELLO! BOOT0 is starting! boot0 version : 3.0.0 dram size =1024 sum=0x01be1e3a src_sum=0x01be1e3a Ready to disable icache. Jump to secend Boot. [ 0.131] U-Boot 2011.09-rc1-00003-ge89ab14-dirty (Jan 03 2014 - 12:57:33) Allwinner Technology [ 0.140]version: 1.1.0 [ 0.143]pmbus: ready [ 0.248]PMU: AXP209 [ 0.251]PMU: AXP20x found [ 0.254]PMU: bat ratio = 100 [ 0.257]after set, dcdc2 =1400mv [ 0.261]PMU: dcdc2 1400 [ 0.263]PMU: pll1 912 Mhz boot_clock = 912 dcdc2_vol = 1400 [ 0.271]after set, dcdc2 =1400mv dcdc3_vol = 1250 ldo2_vol = 3000 ldo3_vol = 2800 ldo4_vol = 2800 power_start = 0 storage_type = -1 usb_recovery = 1 find power_sply to end fel key old mode run key detect no key found no key input dram_para_set start dram_para_set end [ 0.307]DRAM: 1 GiB relocation Offset is: 35b23000 donn't initialize ther user_gpio (main_key:boot_init_gpio) DRV_DISP_Init: opened [ 0.521]boot_disp.output_type=4 [ 0.525]boot_disp.output_mode=4 [ 0.528]boot_disp.auto_hpd=1 workmode = 0 [ 1.832]NAND: NAND_UbootInit NB1 : enter NAND_LogicInit nand : get id_number_ctl from script, 3 not burn nand partition table! NB1 : nand_info_init fail [ 5.364]nand init fail set to recovery try sprite_led_gpio config sprite_led_gpio start sunxi sprite begin screen_width = 800 screen_height = 480 bar x1: 200 y1: 200 bar x2: 600 y2: 280 read mbr failed sprite update error: no data part found read mbr failed sprite update error: read image start error sprite update error: current card sprite failed now hold the machine fail to find part named env Using default environment In: serial Out: serial Err: serial --------fastboot partitions-------- mbr not exist base bootcmd=run setargs_nand boot_normal bootcmd set setargs_nand key 0 recovery key high 6, low 4 cant find fstbt value no misc partition is found to be run cmd=run setargs_nand boot_normal the part isn't exist WORK_MODE_BOOT WORK_MODE_BOOT [ 5.458]Hit any key to stop autoboot: 0 cant find part named boot sunxi_flash - sunxi_flash sub-system Usage: sunxi_flash read command parmeters : parmeters 0 : addr to load(hex only) parmeters 1 : the name of the part to be load [parmeters 2] : the number of bytes to be load(hex only) if [parmeters 2] not exist, the number of bytes to be load is the size of the part indecated on partemeter 1 boota: bad boot image magic, maybe not a boot.img? sunxi# Any suggestion what might went wrong? Best Regards Marek Link to comment Share on other sites More sharing options...
