S905L-3 can't install any version of armbian .
Hey,guys.I get a TV/box which use S905L-3 CPU,but I can't install any version of armbian.It always like this(any version) bable150's builds.
maybe try other .dtbs ?
here is the entire  logs.
btw,I use tll to flash.
GXLX2:BL1:3cfee7:42a5ae;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;
TE: 78176
BL2 Built : 14:48:45, Sep 26 2018.
gxl g6d68897 - yao.zhang@droid07
Board ID = 4, adc=302
set vcck to 1070 mv
set vddee to 1070 mv
CPU clk: 1200MHz
DDR3
DDR3 chl: Rank0+1 @ 792MHz - FAIL
DDR3 chl: Rank0 @ 792MHz
bist_test rank: 0 2a 06 4e 3a 17 5d 24 00 49 3e 1c 61 24 01 47 3a 17 5e 28 02 4f 3a 16 5f 618   - PASS
Rank0: 2048MB(auto)-2T-11
AddrBus test pass!
-s
Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from eMMC, src: 0x00010200, des: 0x013c0000, size: 0x00007600
Load bl301 from eMMC, src: 0x00018200, des: 0x01380000, size: 0x00002200
Load bl31 from eMMC, src: 0x0001c200, des: 0x10100000, size: 0x00019600
Load bl33 from eMMC, src: 0x00038200, des: 0x01000000, size: 0x00047400
NOTICE:  BL3-1: v1.0(debug):361f8a7
NOTICE:  BL3-1: Built : 16:43:26, Dec 19 2018
NOTICE:  BL31: GXL normal boot!
NOTICE:  BL31: BL33 decompress pass
[Image: gxl_v1.1.3103-9234004 2018-12-27 10:43:23 yao.zhang@droid07]
efuse init ops = c5
efuse init hdcp = c, cf9=7
x2_hp_e = 0
bl30: check_permit, count is 1
bl30: check_permit: ok!
chipid: 0 0 3 c c 0 ad b3 60 a0 0 c5 not ES chip
[0.561599 Inits done]
INFO:    BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x1000000
INFO:    BL3-1: Next image spsr = 0x3c9
DRAM:
MMC:    In:    Out:   Err:   wipe_data=successfulSecd
wipe_cache=successful
upgrade_step=2
[BL31]: tee size: 0
rebootmode=cold_boot
Starting the controller
start amlogic old u-boot
[BL31]: tee size: 0
[BL31]: tee size: 0
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.9.0-arm-64 (root@vbox) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #20.10 SMP PREEMPT Wed Oct 14 12:04:42 MSK 2020
[    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
[    0.000000] efi: UEFI not found.
[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[    0.000000] Reserved memory: created CMA memory pool at 0x000000006b400000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000001000000-0x000000007fffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x7fbf1100-0x7fbf2fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000001000000-0x000000003fffffff]
[    0.000000]   DMA32    [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000001000000-0x0000000004ffffff]
[    0.000000]   node   0: [mem 0x0000000007300000-0x000000000fffffff]
[    0.000000]   node   0: [mem 0x0000000010200000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000001000000-0x000000007fffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] percpu: Embedded 22 pages/cpu s51480 r8192 d30440 u90112
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 502592
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
[    0.000000] Memory: 1636236K/2042880K available (16188K kernel code, 1308K rwdata, 6464K rodata, 3392K init, 927K bss, 144500K reserved, 262144K cma-reserved)
[    0.000000] random: get_random_u64 called from cache_random_seq_create+0x80/0x150 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000314] Console: colour dummy device 80x25
[    0.000733] printk: console [tty0] enabled
[    0.000834] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000855] pid_max: default: 32768 minimum: 301
[    0.000960] LSM: Security Framework initializing
[    0.001062] AppArmor: AppArmor initialized
[    0.001120] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.001143] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.002525] rcu: Hierarchical SRCU implementation.
[    0.003476] EFI services will not be available.
[    0.003771] smp: Bringing up secondary CPUs ...
[    0.004348] Detected VIPT I-cache on CPU1
[    0.004406] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.004948] Detected VIPT I-cache on CPU2
[    0.004996] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.005527] Detected VIPT I-cache on CPU3
[    0.005572] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.005647] smp: Brought up 1 node, 4 CPUs
[    0.005710] SMP: Total of 4 processors activated.
[    0.005721] CPU features: detected: 32-bit EL0 Support
[    0.005733] CPU features: detected: CRC32 instructions
[    0.015612] CPU: All CPU(s) started at EL2
[    0.015671] alternatives: patching kernel code
[    0.016973] devtmpfs: initialized
[    0.022355] Registered cp15_barrier emulation handler
[    0.022386] Registered setend emulation handler
[    0.022401] KASLR disabled due to lack of seed
[    0.022746] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.022780] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.029913] xor: measuring software checksum speed
[    0.068170]    8regs     :  2373.000 MB/sec
[    0.108202]    32regs    :  2723.000 MB/sec
[    0.148242]    arm64_neon:  2310.000 MB/sec
[    0.148253] xor: using function: 32regs (2723.000 MB/sec)
[    0.148312] pinctrl core: initialized pinctrl subsystem
[    0.148865] DMI not present or invalid.
[    0.149364] NET: Registered protocol family 16
[    0.150931] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.151000] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.151141] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.151242] audit: initializing netlink subsys (disabled)
[    0.151464] audit: type=2000 audit(0.148:1): state=initialized audit_enabled=0 res=1
[    0.152504] thermal_sys: Registered thermal governor 'step_wise'
[    0.152751] cpuidle: using governor ladder
[    0.152790] cpuidle: using governor menu
[    0.153123] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.153216] ASID allocator initialised with 65536 entries
[    0.154030] Serial: AMBA PL011 UART driver
[    0.179058] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.179084] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.179097] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.179110] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.180967] cryptd: max_cpu_qlen set to 1000
[    0.248474] raid6: neonx8   gen()  2146 MB/s
[    0.316517] raid6: neonx8   xor()  1608 MB/s
[    0.384577] raid6: neonx4   gen()  2192 MB/s
[    0.452625] raid6: neonx4   xor()  1590 MB/s
[    0.520677] raid6: neonx2   gen()  2096 MB/s
[    0.588734] raid6: neonx2   xor()  1479 MB/s
[    0.656785] raid6: neonx1   gen()  1826 MB/s
[    0.724839] raid6: neonx1   xor()  1249 MB/s
[    0.792894] raid6: int64x8  gen()  1491 MB/s
[    0.860964] raid6: int64x8  xor()   784 MB/s
[    0.929012] raid6: int64x4  gen()  1667 MB/s
[    0.997054] raid6: int64x4  xor()   839 MB/s
[    1.065115] raid6: int64x2  gen()  1420 MB/s
[    1.133166] raid6: int64x2  xor()   730 MB/s
[    1.201225] raid6: int64x1  gen()  1060 MB/s
[    1.269276] raid6: int64x1  xor()   559 MB/s
[    1.269286] raid6: using algorithm neonx4 gen() 2192 MB/s
[    1.269295] raid6: .... xor() 1590 MB/s, rmw enabled
[    1.269306] raid6: using neon recovery algorithm
[    1.269780] ACPI: Interpreter disabled.
[    1.270894] iommu: Default domain type: Translated
[    1.271149] vgaarb: loaded
[    1.271706] SCSI subsystem initialized
[    1.272131] usbcore: registered new interface driver usbfs
[    1.272182] usbcore: registered new interface driver hub
[    1.272247] usbcore: registered new device driver usb
[    1.272652] pps_core: LinuxPPS API ver. 1 registered
[    1.272665] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.272689] PTP clock support registered
[    1.272725] EDAC MC: Ver: 3.0.0
[    1.273569] FPGA manager framework
[    1.273674] Advanced Linux Sound Architecture Driver Initialized.
[    1.274228] NetLabel: Initializing
[    1.274243] NetLabel:  domain hash size = 128
[    1.274252] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.274303] NetLabel:  unlabeled traffic allowed by default
[    1.274823] clocksource: Switched to clocksource arch_sys_counter
[    1.275096] VFS: Disk quotas dquot_6.6.0
[    1.275158] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.275283] FS-Cache: Loaded
[    1.275760] AppArmor: AppArmor Filesystem Enabled
[    1.276000] pnp: PnP ACPI: disabled
[    1.281115] NET: Registered protocol family 2
[    1.281640] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    1.281690] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.281808] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    1.282018] TCP: Hash tables configured (established 16384 bind 16384)
[    1.282179] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.282235] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.282444] NET: Registered protocol family 1
[    1.282935] RPC: Registered named UNIX socket transport module.
[    1.282956] RPC: Registered udp transport module.
[    1.282965] RPC: Registered tcp transport module.
[    1.282974] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.282991] NET: Registered protocol family 44
[    1.283011] PCI: CLS 0 bytes, default 64
[    1.283215] Trying to unpack rootfs image as initramfs...
[    1.701209] Freeing initrd memory: 9776K
[    1.702103] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    1.705606] Initialise system trusted keyrings
[    1.705807] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[    1.710462] zbud: loaded
[    1.711820] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.712099] FS-Cache: Netfs 'nfs' registered for caching
[    1.712645] NFS: Registering the id_resolver key type
[    1.712680] Key type id_resolver registered
[    1.712690] Key type id_legacy registered
[    1.712781] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.712795] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.713790] FS-Cache: Netfs 'cifs' registered for caching
[    1.714087] Key type cifs.spnego registered
[    1.714115] Key type cifs.idmap registered
[    1.714138] ntfs: driver 2.1.32 [Flags: R/W].
[    1.714674] JFS: nTxBlock = 8192, nTxLock = 65536
[    1.719140] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
[    1.720613] ocfs2: Registered cluster interface o2cb
[    1.720818] OCFS2 User DLM kernel interface loaded
[    1.722462] gfs2: GFS2 installed
[    1.759528] NET: Registered protocol family 38
[    1.759560] Key type asymmetric registered
[    1.759571] Asymmetric key parser 'x509' registered
[    1.759580] Asymmetric key parser 'pkcs8' registered
[    1.759648] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.759807] io scheduler mq-deadline registered
[    1.759821] io scheduler kyber registered
[    1.759980] io scheduler bfq registered
[    1.773764] soc soc0: Amlogic Meson Unknown (Unknown) Revision 2a:e (c5:2) Detected
[    1.777799] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
[    1.779723] Serial: AMBA driver
[    1.780117] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 12, base_baud = 1500000) is a meson_uart
[    1.780283] serial serial0: tty port ttyAML6 registered
[    1.780678] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 15, base_baud = 1500000) is a meson_uart
[    2.847999] printk: console [ttyAML0] enabled
[    2.865417] brd: module loaded
[    2.873312] loop: module loaded
[    2.874139] Loading iSCSI transport class v2.0-870.
[    2.876270] iscsi: registered transport (tcp)
[    2.883855] libphy: Fixed MDIO Bus: probed
[    2.885796] VFIO - User Level meta-driver version: 0.3
[    2.890545] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.895627] ehci-pci: EHCI PCI platform driver
[    2.900060] ehci-platform: EHCI generic platform driver
[    2.905334] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.911326] ohci-pci: OHCI PCI platform driver
[    2.915760] ohci-platform: OHCI generic platform driver
[    2.921396] usbcore: registered new interface driver usb-storage
[    2.927045] mousedev: PS/2 mouse device common for all mice
[    2.933275] i2c /dev entries driver
[    2.939691] sdhci: Secure Digital Host Controller Interface driver
[    2.941910] sdhci: Copyright(c) Pierre Ossman
[    2.946413] Synopsys Designware Multimedia Card Interface Driver
[    2.959756] meson-gx-mmc d0072000.mmc: Got CD GPIO
[    2.987363] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
[    3.012688] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.013775] ledtrig-cpu: registered to indicate activity on CPUs
[    3.019530] meson-sm: secure-monitor enabled
[    3.023827] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
[    3.031058] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
[    3.039176] hid: raw HID events driver (C) Jiri Kosina
[    3.043934] usbcore: registered new interface driver usbhid
[    3.049144] usbhid: USB HID core driver
[    3.053695] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
[BL31]: tee size: 0
[    3.064543] no UART detected at 0x1
[    3.068896] NET: Registered protocol family 17
[    3.069570] Key type dns_resolver registered
[    3.074186] registered taskstats version 1
[    3.077705] Loading compiled-in X.509 certificates
[    3.082527] zswap: loaded using pool lzo/zbud
[    3.087026] Key type ._fscrypt registered
[    3.090666] Key type .fscrypt registered
[    3.094561] Key type fscrypt-provisioning registered
[    3.100278] Btrfs loaded, crc32c=crc32c-generic
[    3.120818] Key type encrypted registered
[    3.120866] AppArmor: AppArmor sha1 policy hashing enabled
[    3.141103] meson-drm d0100000.vpu: Queued 3 outputs on vpu
[    3.143099] mmc1: new HS200 MMC card at address 0001
[    3.146699] mmcblk1: mmc1:0001 Biwin  6.96 GiB
[    3.150804] mmcblk1boot0: mmc1:0001 Biwin  partition 1 4.00 MiB
[    3.156636] mmcblk1boot1: mmc1:0001 Biwin  partition 2 4.00 MiB
[    3.162383] mmcblk1rpmb: mmc1:0001 Biwin  partition 3 4.00 MiB, chardev (241:0)
[    3.166912] meson-dw-hdmi c883a000.hdmi-tx: Unsupported HDMI controller (0d0d:0d:0d)
[    3.177338] ------------[ cut here ]------------
[    3.181691] WARNING: CPU: 3 PID: 33 at drivers/regulator/core.c:2089 _regulator_put.part.0+0x154/0x160
[    3.190905] Modules linked in:
[    3.193927] CPU: 3 PID: 33 Comm: kworker/3:1 Not tainted 5.9.0-arm-64 #20.10
[    3.200910] Hardware name: Amlogic Meson GXL (S905X) P212 Development Board (DT)
[    3.208250] Workqueue: events deferred_probe_work_func
[    3.213332] pstate: 80000005 (Nzcv daif -PAN -UAO BTYPE=--)
[    3.218851] pc : _regulator_put.part.0+0x154/0x160
[    3.223595] lr : regulator_put+0x38/0x50
[    3.227475] sp : ffff800010143930
[    3.230752] x29: ffff800010143930 x28: ffff800012a07000
[    3.236013] x27: ffff80001010bcd8 x26: 00000000ffffffed
[    3.241274] x25: ffff00007f6bd000 x24: ffff00006988c000
[    3.246535] x23: 0000000000000010 x22: ffff8000101439e8
[    3.251796] x21: ffff00007f678e00 x20: ffff800012ad7150
[    3.257058] x19: ffff00006a0f5900 x18: 0000000000000010
[    3.262319] x17: 0000000000006a0c x16: 000000000000698c
[    3.267580] x15: ffff00007f679268 x14: 000000000000034f
[    3.272841] x13: 0000000000000000 x12: 0000000000000001
[    3.278103] x11: 0000000000000000 x10: 00000000000009c0
[    3.283364] x9 : ffff800010143760 x8 : 0000000000000000
[    3.288625] x7 : ffff00007f678e00 x6 : 0000000000000000
[    3.293886] x5 : 0000000000000001 x4 : 0000000000000000
[    3.299148] x3 : ffff800012ad7520 x2 : ffff00007f678e00
[    3.304409] x1 : 0000000000000000 x0 : 0000000000000001
[    3.309671] Call trace:
[    3.312089]  _regulator_put.part.0+0x154/0x160
[    3.316486]  regulator_put+0x38/0x50
[    3.320024]  devm_regulator_release+0x14/0x20
[    3.324337]  release_nodes+0x1b0/0x228
[    3.328044]  devres_release_group+0x90/0xe8
[    3.332184]  component_bind_all+0x114/0x260
[    3.336325]  meson_drv_bind_master+0x364/0x488
[    3.340722]  meson_drv_bind+0x14/0x28
[    3.344345]  try_to_bring_up_master+0x168/0x1d0
[    3.348830]  component_master_add_with_match+0xb4/0x100
[    3.354005]  meson_drv_probe+0xd4/0x128
[    3.357800]  platform_drv_probe+0x54/0xa8
[    3.361767]  really_probe+0xe4/0x3b0
[    3.365303]  driver_probe_device+0x58/0xb8
[    3.369357]  __device_attach_driver+0x84/0xc8
[    3.373671]  bus_for_each_drv+0x78/0xc8
[    3.377464]  __device_attach+0xf0/0x150
[    3.381260]  device_initial_probe+0x14/0x20
[    3.385401]  bus_probe_device+0x9c/0xa8
[    3.389196]  deferred_probe_work_func+0x74/0xb0
[    3.393683]  process_one_work+0x1a0/0x328
[    3.397647]  worker_thread+0x1f8/0x420
[    3.401357]  kthread+0x140/0x160
[    3.404549]  ret_from_fork+0x10/0x34
[    3.408083] ---[ end trace 275a17427592d210 ]---
[    3.412829] meson-drm d0100000.vpu: failed to bind c883a000.hdmi-tx (ops meson_dw_hdmi_ops): -19
[    3.421387] meson-drm d0100000.vpu: Couldn't bind all components
[    3.427630] meson-drm d0100000.vpu: master bind failed: -19
[    3.434800] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
[    3.439438] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
[    3.445623] meson8b-dwmac c9410000.ethernet: PTP uses main clock
[    3.451479] meson8b-dwmac c9410000.ethernet: no reset control found
[    3.458414] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[    3.464839] meson8b-dwmac c9410000.ethernet:         DWMAC1000
[    3.469933] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
[    3.477349] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
[    3.484765] meson8b-dwmac c9410000.ethernet: COE Type 2
[    3.489940] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
[    3.496926] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
[    3.503383] meson8b-dwmac c9410000.ethernet: Normal descriptors
[    3.509175] meson8b-dwmac c9410000.ethernet: Ring mode enabled
[    3.514953] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.523280] libphy: stmmac: probed
[    3.527623] dwc3-meson-g12a d0078080.usb: USB2 ports: 2
[    3.531461] dwc3-meson-g12a d0078080.usb: USB3 ports: 0
[    4.067920] dwc2 c9100000.usb: supply vusb_d not found, using dummy regulator
[    4.069547] dwc2 c9100000.usb: supply vusb_a not found, using dummy regulator
[    4.076768] dwc2 c9100000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
[    4.085114] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.088976] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    4.096659] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
[    4.105876] xhci-hcd xhci-hcd.0.auto: irq 42, io mem 0xc9000000
[    4.111985] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[    4.119892] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.127046] usb usb1: Product: xHCI Host Controller
[    4.131875] usb usb1: Manufacturer: Linux 5.9.0-arm-64 xhci-hcd
[    4.137739] usb usb1: SerialNumber: xhci-hcd.0.auto
[    4.143093] hub 1-0:1.0: USB hub found
[    4.146296] hub 1-0:1.0: 2 ports detected
[    4.150556] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.155709] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    4.163282] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    4.169788] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.177848] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[    4.185956] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.193115] usb usb2: Product: xHCI Host Controller
[    4.197942] usb usb2: Manufacturer: Linux 5.9.0-arm-64 xhci-hcd
[    4.203807] usb usb2: SerialNumber: xhci-hcd.0.auto
[    4.209092] hub 2-0:1.0: USB hub found
[    4.212378] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
[    4.222038] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
[    4.253124] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
get_dvfs_info 0007
[    4.273320] mmc2: new high speed SDIO card at address 8800
[    4.274132] libphy: mdio_mux: probed
[    4.284942] libphy: mdio_mux: probed
[    4.287107] printk: console [netcon0] enabled
[    4.287211] netconsole: network logging started
[    4.293121] ALSA device list:
[    4.294632]   No soundcards found.
[    4.299351] Freeing unused kernel memory: 3392K
[    4.315045] Run /init as init process
[    4.482900] usb 1-2: new high-speed USB device number 2 using xhci-hcd
[    4.635945] usb 1-2: New USB device found, idVendor=14cd, idProduct=2536, bcdDevice= 3.00
[    4.638490] usb 1-2: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[    4.645616] usb 1-2: Product: Mass Storage Device
[    4.650283] usb 1-2: Manufacturer: Generic USB Device
[    4.655675] usb 1-2: SerialNumber: 2536201609180000
[    4.661592] usb-storage 1-2:1.0: USB Mass Storage device detected
[    4.667246] scsi host0: usb-storage 1-2:1.0
[    4.675006] usbcore: registered new interface driver uas
[    4.779916] random: fast init done
[    5.702412] scsi 0:0:0:0: Direct-Access     Mass     Storage Device   1.00 PQ: 0 ANSI: 0 CCS
[    5.710995] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    5.711340] sd 0:0:0:0: [sda] 15376384 512-byte logical blocks: (7.87 GB/7.33 GiB)
[    5.718487] sd 0:0:0:0: [sda] Write Protect is off
[    5.723142] sd 0:0:0:0: [sda] No Caching mode page found
[    5.728205] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    5.770207]  sda: sda1 sda2
[    5.772393] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    6.452397] EXT4-fs (sda2): mounted filesystem with writeback data mode. Opts: data=writeback
[    7.369066] systemd[1]: System time before build time, advancing clock.
[    7.471859] NET: Registered protocol family 10
[    7.503486] Segment Routing with IPv6
[    7.545592] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    7.561824] systemd[1]: Detected architecture arm64.
[    7.601490] systemd[1]: Set hostname to <arm-64>.
[    8.079100] systemd[1]: /etc/systemd/system/serial-getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring
[    8.091397] systemd[1]: /etc/systemd/system/serial-getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring
[    8.104543] systemd[1]: /etc/systemd/system/getty@.service.d/override.conf:5: Unknown lvalue 'After' in section 'Service', ignoring
[    8.193816] random: systemd: uninitialized urandom read (16 bytes read)
[    8.203411] random: systemd: uninitialized urandom read (16 bytes read)
[    8.205220] systemd[1]: Listening on Journal Socket.
[    8.210065] random: systemd: uninitialized urandom read (16 bytes read)
[    8.216505] systemd[1]: Listening on Journal Socket (/dev/log).
[    8.228061] systemd[1]: Mounting POSIX Message Queue File System...
[    8.230480] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    8.334724] EXT4-fs (sda2): re-mounted. Opts: commit=600,errors=remount-ro
[   10.629599] SError Interrupt on CPU2, code 0xbf000002 -- SError
[   10.629603] CPU: 2 PID: 357 Comm: systemd-udevd Tainted: G        W         5.9.0-arm-64 #20.10
[   10.629605] Hardware name: Amlogic Meson GXL (S905X) P212 Development Board (DT)
[   10.629607] pstate: 00000005 (nzcv daif -PAN -UAO BTYPE=--)
[   10.629608] pc : el1_sync_handler+0xf8/0x130
[   10.629610] lr : el1_sync+0x7c/0x100
[   10.629611] sp : ffff8000103a3750
[   10.629613] x29: ffff8000103a3750 x28: ffff00007cc17000
[   10.629616] x27: 0000000000000100 x26: 0000000000000000
[   10.629620] x25: 0000000000000001 x24: ffff80000a215270
[   10.629623] x23: 0000000080000005 x22: ffff80000a20af08
[   10.629626] x21: ffff8000103a38a0 x20: 0000ffffffffffff
[   10.629629] x19: ffff00006b1d8148 x18: 0000000000000001
[   10.629632] x17: 0000000000000000 x16: 0000000000000000
[   10.629636] x15: ffff00007cc17468 x14: ffffffffffffffff
[   10.629639] x13: 0000000000000020 x12: 0101010101010101
[   10.629642] x11: 0000000000000040 x10: ffff800012a37ef8
[   10.629645] x9 : ffff800012a37ef0 x8 : ffff00007f0026f0
[   10.629649] x7 : 0000000000000000 x6 : 0000000000000000
[   10.629652] x5 : ffff00007f0026c8 x4 : ffff800010c46000
[   10.629655] x3 : 0000000096000210 x2 : 0000002200000000
[   10.629658] x1 : 0000000000000000 x0 : ffff8000103a3760
[   10.629662] Kernel panic - not syncing: Asynchronous SError Interrupt
[   10.629665] CPU: 2 PID: 357 Comm: systemd-udevd Tainted: G        W         5.9.0-arm-64 #20.10
[   10.629667] Hardware name: Amlogic Meson GXL (S905X) P212 Development Board (DT)
[   10.629668] Call trace:
[   10.629669]  dump_backtrace+0x0/0x1a0
[   10.629671]  show_stack+0x18/0x28
[   10.629672]  dump_stack+0xc0/0x11c
[   10.629673]  panic+0x15c/0x31c
[   10.629674]  nmi_panic+0x8c/0x90
[   10.629676]  arm64_serror_panic+0x78/0x84
[   10.629677]  do_serror+0x78/0x180
[   10.629678]  el1_error+0x8c/0x108
[   10.629680]  el1_sync_handler+0xf8/0x130
[   10.629681]  el1_sync+0x7c/0x100
[   10.629682]  lima_mmu_init+0x40/0x118 [lima]
[   10.629684]  lima_device_init+0x1b8/0x5f0 [lima]
[   10.629685]  lima_pdev_probe+0xa0/0x190 [lima]
[   10.629686]  platform_drv_probe+0x54/0xa8
[   10.629688]  really_probe+0xe4/0x3b0
[   10.629689]  driver_probe_device+0x58/0xb8
[   10.629690]  device_driver_attach+0x74/0x80
[   10.629692]  __driver_attach+0x58/0xe0
[   10.629693]  bus_for_each_dev+0x70/0xc0
[   10.629694]  driver_attach+0x24/0x30
[   10.629695]  bus_add_driver+0x14c/0x1f0
[   10.629697]  driver_register+0x64/0x120
[   10.629698]  __platform_driver_register+0x48/0x58
[   10.629700]  lima_platform_driver_init+0x24/0x1000 [lima]
[   10.629701]  do_one_initcall+0x54/0x1bc
[   10.629702]  do_init_module+0x54/0x200
[   10.629704]  load_module+0x1de8/0x23f0
[   10.629705]  __do_sys_finit_module+0xd8/0xf0
[   10.629707]  __arm64_sys_finit_module+0x20/0x30
[   10.629708]  el0_svc_common.constprop.0+0x74/0x1f0
[   10.629709]  do_el0_svc+0x24/0x90
[   10.629711]  el0_sync_handler+0x180/0x2f8
[   10.629712]  el0_sync+0x158/0x180
[   10.629733] SMP: stopping secondary CPUs
[   10.629735] Kernel Offset: disabled
[   10.629736] CPU features: 0x0040002,20002004
[   10.629737] Memory Limit: none
thanks for your reply!
with those newer amlogic socs you never know what you get - they seem to randomly remove or exchange components and give it a new name - i once got an s905l2 working by changing the mali config (https://github.com/hexdump0815/linux-mainline-and-mali-generic-stable-kernel/blob/master/misc.av8/patches/mali-with-only-2-pp-cores.patch), but your problem looks different ... so in the end its better to avoid any newer amlogic boxes ...
best wishes - hexdump
