Duarte Dias Posted March 19, 2022 Posted March 19, 2022 (edited) Hello I am trying to configure two mcp2515 CAN controllers and bind them to the mcp251x kernel driver. I managed to get the first one working using Chip Select 0 I saw that cs-gpio can be used to use a GPIO pin as an extra CHIP select Is it possible to directly map de second CHIP SELECT using a GPIO on the following device tree overlay ? /dts-v1/; /plugin/; / { compatible = "rockchip,rockpi","rockchip,rk3399"; /* enable spi-dev for spi1 */ fragment@0 { target = <&spi1>; __overlay__ { status = "okay"; }; }; /* the interrupt pin of the can-controller */ /* Hat uses physical pin 22 (GPIO4_D5) which translate to gpio 157 */ fragment@1 { target = <&pinctrl>; __overlay__ { can1_pins: can1_pins { rockchip,pins = <4 157 0 &pcfg_output_low>; }; }; }; /* the clock/oscillator of the can-controller */ fragment@2 { target-path = "/"; __overlay__ { /* external oscillator of mcp2515 on SPI1 */ can1_osc: can1_osc { compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <16000000>; clock-output-names = "can1_osc"; }; }; }; /* the spi config of the can-controller itself binding everything together */ fragment@3 { target = <&spi1>; __overlay__ { #address-cells = <1>; #size-cells = <0>; can1: mcp2515@1 { reg = <1>; compatible = "microchip,mcp2515"; pinctrl-names = "default"; #pinctrl-0 = <&can1_pins>; spi-max-frequency = <10000000>; interrupt-parent = <&gpio4>; interrupts = <22 8>; clocks = <&can1_osc>; }; }; }; __overrides__ { oscillator = <&can1_osc>,"clock-frequency:0"; spimaxfrequency = <&can1>,"spi-max-frequency:0"; interrupt = <&can1_pins>,"rockchip,pins:0",<&can1>,"interrupts:0"; }; }; Thanks in advance Edited March 19, 2022 by Duarte Dias
Werner Posted March 19, 2022 Posted March 19, 2022 Moved to P2P help. Lacking proper logs armbian.com/bugs
