rt1k Posted September 13, 2016 Posted September 13, 2016 Hi guys, i've the following problem in my attempt to customize/study armbian: - succesfully compiled Armbian_5.17_Bananapim2_Debian_jessie_4.8.0 on Ubuntu 16.04 with default config; - burned image on SD card, (on the same card burned with Armbian_5.14_Bananapim2_Debian_jessie_4.6.2_desktop and the system boot is ok) - the board enter in this reset loop: U-Boot 2016.07-armbian (Sep 11 2016 - 10:06:05 +0200) Allwinner Technology CPU: Allwinner A31s (SUN6I) Model: Sinovoip BPI-M2 DRAM: 1 GiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment HDMI connected: Setting up a 1680x1050 dvi console (overscan 0x0) In: serial Out: vga Err: vga Net: data abort pc : [<7ef5f708>] lr : [<00000000>] reloc pc : [<4a001708>] lr : [<cb0a2000>] sp : 7af36f7c ip : 7efabe89 fp : 00000017 r10: 7efab885 r9 : 7af3dee8 r8 : 000040a0 r7 : 7ef9ee14 r6 : 00000000 r5 : 00000001 r4 : 00000000 r3 : 0000000f r2 : 00000001 r1 : 00000000 r0 : ea00000e Flags: nzCv IRQs off FIQs off Mode SVC_32 Resetting CPU ... resetting ... what's wrong ? cheers rt1k
Igor Posted September 13, 2016 Posted September 13, 2016 No idea, try some older u-boot. Image from download section is working fine .. use it and just install kernel which you just compiled. Leave u-boot as is. We are just finishing a new release and I'll check where is the problem on the way. Thanks for reporting in.
rt1k Posted September 13, 2016 Author Posted September 13, 2016 Hi Igor, just for your reference this is the boot msg with u-boot 2016.05 (Linux bananapim2 4.6.2-sunxi #13 SMP Sun Jun 19 16:22:09 CEST 2016 armv7l GNU/Linux) many thanks for your work and support. regards. rt1k ------------------ U-Boot SPL 2016.05-armbian (Jun 20 2016 - 14:41:50) DRAM: 1024 MiB Trying to boot from MMC1 U-Boot 2016.05-armbian (Jun 20 2016 - 14:41:50 +0200) Allwinner Technology CPU: Allwinner A31s (SUN6I) Model: Sinovoip BPI-M2 DRAM: 1 GiB MMC: SUNXI SD/MMC: 0 HDMI connected: Setting up a 1680x1050 dvi console (overscan 0x0) In: serial Out: vga Err: vga Net: eth0: ethernet@01c30000 <--------- here !!!! starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 5 USB Device(s) found Hit any key to stop autoboot: 0 =>
