struthio Posted April 2, 2022 Posted April 2, 2022 Hi, I have 4 FriendlyElec NanoPi Neo 3 boards. Till now they were working fine, but after today 'apt upgrade' none of them boot anymore. I got one connected in debug mode and got this log: => DDR version 1.16 20190528 ID:0x805 N In DDR4 333MHz Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=16 CS=1 Die Bus-Width=16 Size=2048MB ddrconfig:14 OUT Boot1 Release Time: May 13 2019 17:34:36, version: 2.50 ChipType = 0x11, 248 mmc2:cmd1,20 emmc reinit mmc2:cmd1,20 emmc reinit mmc2:cmd1,20 SdmmcInit=2 1 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=30436MB FwPartOffset=2000 , 0 StorageInit ok = 33580 Raw SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x337a9f0 signature is wrong recovery gpt... GPT 0x337a9f0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 hdr 000000000337a3b0 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, Load OK, addr=0x200000, size=0xab950 RunBL31 0x40000 INFO: Preloader serial: 2 NOTICE: BL31: v1.3(debug):403e0b816 NOTICE: BL31: Built : 14:13:08, Aug 11 2020 NOTICE: BL31:Rockchip release version: v1.3 INFO: ARM GICv2 driver initialized INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 1 INFO: plat_rockchip_pmu_init: pd status 0xe INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.10-armbian (May 06 2021 - 17:55:54 +0000) Model: FriendlyElec NanoPi R2S DRAM: 2 GiB PMIC: RK8050 (on=0x40, off=0x00) MMC: mmc@ff500000: 1 Loading Environment from MMC... MMC Device 0 not found *** Warning - No MMC card found, using default environment In: serial@ff130000 Out: serial@ff130000 Err: serial@ff130000 Model: FriendlyElec NanoPi R2S Net: eth0: ethernet@ff540000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3185 bytes read in 8 ms (388.7 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 261 bytes read in 4 ms (63.5 KiB/s) 14236833 bytes read in 623 ms (21.8 MiB/s) 30083584 bytes read in 1307 ms (22 MiB/s) Failed to load '/boot/dtb/rockchip/rk3328-nanopi-neo3-rev02.dtb' libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 1314 bytes read in 9 ms (142.6 KiB/s) Applying kernel provided DT overlay rockchip-spi-jedec-nor.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 1266 bytes read in 9 ms (136.7 KiB/s) Applying kernel provided DT overlay rockchip-spi-spidev.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Error applying DT overlays, restoring original DT Failed to load '/boot/dtb/rockchip/rk3328-nanopi-neo3-rev02.dtb' Moving Image from 0x2080000 to 0x2200000, end=3f50000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 14236769 Bytes = 13.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree SCRIPT FAILED: continuing... MMC Device 0 not found no mmc device at slot 0 starting USB... No working controllers found USB is stopped. Please issue 'usb start' first. starting USB... No working controllers found ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/01-b6-20-d4-48-8b-b5 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 (...) SD card is good and I can read it in PC in normal SD-to-USB reader. Is there a way to boot from this state ? Is NEO3 still supported ? Board: Not on the list
SteeMan Posted April 3, 2022 Posted April 3, 2022 I'm pretty sure this is a duplicate of a previously reported issue:
