agarest Posted April 5, 2022 Share Posted April 5, 2022 Hello everyone, I read a lot of threads regarding my problem but couldn't find the solution. Could someone kindly help me? I have a TVbox with S905x and Android installed, I would like to install armbian, I downloaded the ISO, renamed the u-boot file for S905x to u-boot.ext and modified the file "/extlinux/extlinux.conf" leaving only the line without comment with S905x. When I do "update" from Android it makes me choose a .zip file, copy something and then reboot. Unfortunately, however, the system restarts with Android as if nothing had happened. What am I wrong? Thank you very much. Link to comment Share on other sites More sharing options...
SteeMan Posted April 5, 2022 Share Posted April 5, 2022 Have you followed the instructions in this FAQ post: Also, I would recommend using the toothpick method. You need to have a specific type of 'update' andoid app installed for that method to work and I have found that a lot of android boxes don't have the right update app to use that method. I always use the toothpick method to install multiboot. Link to comment Share on other sites More sharing options...
