mokkin Posted April 13, 2022 Posted April 13, 2022 Hi, on my Bananapi M1 I have a 240GB SATA SSD connected for storage. Unfortunately I'm losing connection after a couple of days sometimes hours. Do you have an idea why? Apr 13 22:13:16 localhost rngd[854]: stats: Lowest ready-buffers level: 2 Apr 13 22:13:16 localhost rngd[854]: stats: Entropy starvations: 0 Apr 13 22:13:16 localhost rngd[854]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us Apr 13 22:13:18 localhost kernel: [ 3627.151866] ata1: COMRESET failed (errno=-16) Apr 13 22:13:18 localhost kernel: [ 3627.151914] ata1: hard resetting link Apr 13 22:13:23 localhost kernel: [ 3632.504265] ata1: link is slow to respond, please be patient (ready=0) Apr 13 22:13:28 localhost kernel: [ 3637.184617] ata1: COMRESET failed (errno=-16) Apr 13 22:13:28 localhost kernel: [ 3637.184662] ata1: hard resetting link Apr 13 22:13:33 localhost kernel: [ 3642.537021] ata1: link is slow to respond, please be patient (ready=0) Apr 13 22:14:03 localhost kernel: [ 3672.239231] ata1: COMRESET failed (errno=-16) Apr 13 22:14:03 localhost kernel: [ 3672.239279] ata1: limiting SATA link speed to 1.5 Gbps Apr 13 22:14:03 localhost kernel: [ 3672.239292] ata1: hard resetting link Apr 13 22:14:08 localhost kernel: [ 3677.291612] ata1: COMRESET failed (errno=-16) Apr 13 22:14:08 localhost kernel: [ 3677.291661] ata1: reset failed, giving up Apr 13 22:14:08 localhost kernel: [ 3677.291674] ata1.00: disabled Apr 13 22:14:08 localhost kernel: [ 3677.291801] sd 0:0:0:0: [sda] tag#23 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=60s Apr 13 22:14:08 localhost kernel: [ 3677.291820] sd 0:0:0:0: [sda] tag#23 Sense Key : 0x2 [current] Apr 13 22:14:08 localhost kernel: [ 3677.291832] sd 0:0:0:0: [sda] tag#23 ASC=0x4 ASCQ=0x21 Apr 13 22:14:08 localhost kernel: [ 3677.291849] sd 0:0:0:0: [sda] tag#23 CDB: opcode=0x28 28 00 08 99 ff 00 00 01 00 00 Apr 13 22:14:08 localhost kernel: [ 3677.291859] blk_update_request: I/O error, dev sda, sector 144310016 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 0 Apr 13 22:14:08 localhost kernel: [ 3677.291966] sd 0:0:0:0: [sda] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=60s Apr 13 22:14:08 localhost kernel: [ 3677.291983] sd 0:0:0:0: [sda] tag#24 Sense Key : 0x2 [current] Apr 13 22:14:08 localhost kernel: [ 3677.291996] sd 0:0:0:0: [sda] tag#24 ASC=0x4 ASCQ=0x21 Apr 13 22:14:08 localhost kernel: [ 3677.292010] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x28 28 00 08 9a 00 00 00 01 00 00 Apr 13 22:14:08 localhost kernel: [ 3677.292018] blk_update_request: I/O error, dev sda, sector 144310272 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 0 Apr 13 22:14:08 localhost kernel: [ 3677.292062] ata1: EH complete Apr 13 22:14:08 localhost kernel: [ 3677.292156] sd 0:0:0:0: [sda] tag#25 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:14:08 localhost kernel: [ 3677.292175] sd 0:0:0:0: [sda] tag#25 CDB: opcode=0x28 28 00 08 99 ff 00 00 00 08 00 Apr 13 22:14:08 localhost kernel: [ 3677.292184] blk_update_request: I/O error, dev sda, sector 144310016 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:14:08 localhost kernel: [ 3677.292334] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:14:08 localhost kernel: [ 3677.292354] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 08 99 ff 00 00 00 08 00 Apr 13 22:14:08 localhost kernel: [ 3677.292364] blk_update_request: I/O error, dev sda, sector 144310016 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:14:08 localhost kernel: [ 3677.292644] sd 0:0:0:0: [sda] tag#26 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:14:08 localhost kernel: [ 3677.292667] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x28 28 00 08 99 ff 00 00 00 08 00 Apr 13 22:14:08 localhost kernel: [ 3677.292676] blk_update_request: I/O error, dev sda, sector 144310016 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:14:08 localhost kernel: [ 3677.292812] sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:14:08 localhost kernel: [ 3677.292832] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 08 99 ff 00 00 00 08 00 Apr 13 22:14:08 localhost kernel: [ 3677.292840] blk_update_request: I/O error, dev sda, sector 144310016 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:14:08 localhost kernel: [ 3677.293250] sd 0:0:0:0: [sda] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:14:08 localhost kernel: [ 3677.293276] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x28 28 00 08 99 ff 00 00 00 08 00 Apr 13 22:14:08 localhost kernel: [ 3677.293286] blk_update_request: I/O error, dev sda, sector 144310016 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:14:08 localhost kernel: [ 3677.293468] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:14:08 localhost kernel: [ 3677.293490] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 08 99 ff 00 00 00 08 00 Apr 13 22:14:08 localhost kernel: [ 3677.293498] blk_update_request: I/O error, dev sda, sector 144310016 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:14:08 localhost kernel: [ 3677.294579] sd 0:0:0:0: [sda] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:14:08 localhost kernel: [ 3677.294610] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 08 7e 88 00 00 00 08 00 Apr 13 22:14:08 localhost kernel: [ 3677.294620] blk_update_request: I/O error, dev sda, sector 142510080 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0 Apr 13 22:14:08 localhost kernel: [ 3677.294750] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:14:08 localhost kernel: [ 3677.294770] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 08 7e 88 00 00 00 08 00 Apr 13 22:14:08 localhost kernel: [ 3677.294779] blk_update_request: I/O error, dev sda, sector 142510080 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:14:31 localhost kernel: [ 3700.043662] scsi_io_completion_action: 12 callbacks suppressed Apr 13 22:14:31 localhost kernel: [ 3700.043713] sd 0:0:0:0: [sda] tag#11 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:14:31 localhost kernel: [ 3700.043748] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x28 28 00 08 7e 88 00 00 00 08 00 Apr 13 22:14:31 localhost kernel: [ 3700.043758] print_req_error: 12 callbacks suppressed Apr 13 22:14:31 localhost kernel: [ 3700.043764] blk_update_request: I/O error, dev sda, sector 142510080 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:14:31 localhost kernel: [ 3700.044327] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:14:31 localhost kernel: [ 3700.044355] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 08 7e 88 00 00 00 08 00 Apr 13 22:14:31 localhost kernel: [ 3700.044364] blk_update_request: I/O error, dev sda, sector 142510080 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:14:38 localhost systemd[1]: Created slice User Slice of UID 1000. Apr 13 22:14:38 localhost systemd[1]: Starting User Runtime Directory /run/user/1000... Apr 13 22:14:38 localhost systemd[1]: Started User Runtime Directory /run/user/1000. Apr 13 22:14:38 localhost systemd[1]: Starting User Manager for UID 1000... Apr 13 22:14:39 localhost systemd[2141]: Listening on GnuPG cryptographic agent and passphrase cache (restricted). Apr 13 22:14:39 localhost systemd[2141]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers). Apr 13 22:14:39 localhost systemd[2141]: Reached target Paths. Apr 13 22:14:39 localhost systemd[2141]: Listening on GnuPG cryptographic agent and passphrase cache. Apr 13 22:14:39 localhost systemd[2141]: Listening on GnuPG cryptographic agent (ssh-agent emulation). Apr 13 22:14:39 localhost systemd[2141]: Listening on GnuPG network certificate management daemon. Apr 13 22:14:39 localhost systemd[2141]: Reached target Sockets. Apr 13 22:14:39 localhost systemd[2141]: Reached target Timers. Apr 13 22:14:39 localhost systemd[2141]: Reached target Basic System. Apr 13 22:14:39 localhost systemd[1]: Started User Manager for UID 1000. Apr 13 22:14:39 localhost systemd[2141]: Reached target Default. Apr 13 22:14:39 localhost systemd[2141]: Startup finished in 304ms. Apr 13 22:14:39 localhost systemd[1]: Started Session 17 of user markus. Apr 13 22:14:49 localhost kernel: [ 3718.399188] sd 0:0:0:0: [sda] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:14:49 localhost kernel: [ 3718.399248] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x2a 2a 00 0e c4 08 30 00 00 10 00 Apr 13 22:14:49 localhost kernel: [ 3718.399266] blk_update_request: I/O error, dev sda, sector 247728176 op 0x1:(WRITE) flags 0x800 phys_seg 2 prio class 0 Apr 13 22:14:49 localhost kernel: [ 3718.399361] Aborting journal on device sda1-8. Apr 13 22:14:49 localhost kernel: [ 3718.399545] sd 0:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:14:49 localhost kernel: [ 3718.399577] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x2a 2a 00 0e c4 08 00 00 00 08 00 Apr 13 22:14:49 localhost kernel: [ 3718.399591] blk_update_request: I/O error, dev sda, sector 247728128 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0 Apr 13 22:14:49 localhost kernel: [ 3718.399623] blk_update_request: I/O error, dev sda, sector 247728128 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0 Apr 13 22:14:49 localhost kernel: [ 3718.399652] Buffer I/O error on dev sda1, logical block 30965760, lost sync page write Apr 13 22:14:49 localhost kernel: [ 3718.399708] JBD2: Error -5 detected when updating journal superblock for sda1-8. Apr 13 22:14:57 localhost kernel: [ 3726.375693] sd 0:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:14:57 localhost kernel: [ 3726.375737] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 08 7e 88 00 00 00 08 00 Apr 13 22:14:57 localhost kernel: [ 3726.375749] blk_update_request: I/O error, dev sda, sector 142510080 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:14:57 localhost kernel: [ 3726.376315] sd 0:0:0:0: [sda] tag#13 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:14:57 localhost kernel: [ 3726.376344] sd 0:0:0:0: [sda] tag#13 CDB: opcode=0x28 28 00 08 7e 88 00 00 00 08 00 Apr 13 22:14:57 localhost kernel: [ 3726.376354] blk_update_request: I/O error, dev sda, sector 142510080 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:15:00 localhost kernel: [ 3728.940667] sd 0:0:0:0: [sda] tag#14 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:15:00 localhost kernel: [ 3728.940711] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x28 28 00 08 7e 88 00 00 00 08 00 Apr 13 22:15:00 localhost kernel: [ 3728.940722] blk_update_request: I/O error, dev sda, sector 142510080 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:15:00 localhost kernel: [ 3728.941248] sd 0:0:0:0: [sda] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:15:00 localhost kernel: [ 3728.941277] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x28 28 00 08 7e 88 00 00 00 08 00 Apr 13 22:15:00 localhost kernel: [ 3728.941286] blk_update_request: I/O error, dev sda, sector 142510080 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:15:01 localhost CRON[2252]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1) Apr 13 22:15:01 localhost CRON[2254]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs) Apr 13 22:15:16 localhost kernel: [ 3745.741588] sd 0:0:0:0: [sda] tag#15 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:15:16 localhost kernel: [ 3745.741634] sd 0:0:0:0: [sda] tag#15 CDB: opcode=0x28 28 00 07 a3 08 00 00 01 00 00 Apr 13 22:15:16 localhost kernel: [ 3745.741645] blk_update_request: I/O error, dev sda, sector 128124928 op 0x0:(READ) flags 0x80700 phys_seg 31 prio class 0 Apr 13 22:15:16 localhost kernel: [ 3745.741805] sd 0:0:0:0: [sda] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:15:16 localhost kernel: [ 3745.741830] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x28 28 00 07 a3 08 00 00 00 08 00 Apr 13 22:15:16 localhost kernel: [ 3745.741838] blk_update_request: I/O error, dev sda, sector 128124928 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:15:16 localhost kernel: [ 3745.741895] EXT4-fs error (device sda1): ext4_journal_check_start:83: comm proftpd: Detected aborted journal Apr 13 22:15:16 localhost kernel: [ 3745.742109] sd 0:0:0:0: [sda] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:15:16 localhost kernel: [ 3745.742129] sd 0:0:0:0: [sda] tag#16 CDB: opcode=0x2a 2a 00 00 00 08 00 00 00 08 00 Apr 13 22:15:16 localhost kernel: [ 3745.742137] blk_update_request: I/O error, dev sda, sector 2048 op 0x1:(WRITE) flags 0x3800 phys_seg 1 prio class 0 Apr 13 22:15:16 localhost kernel: [ 3745.742158] blk_update_request: I/O error, dev sda, sector 2048 op 0x1:(WRITE) flags 0x3800 phys_seg 1 prio class 0 Apr 13 22:15:16 localhost kernel: [ 3745.742174] Buffer I/O error on dev sda1, logical block 0, lost sync page write Apr 13 22:15:16 localhost kernel: [ 3745.742213] EXT4-fs (sda1): I/O error while writing superblock Apr 13 22:15:16 localhost kernel: [ 3745.742225] EXT4-fs (sda1): Remounting filesystem read-only Apr 13 22:15:16 localhost kernel: [ 3745.742715] sd 0:0:0:0: [sda] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:15:16 localhost kernel: [ 3745.742740] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 07 a3 08 00 00 00 08 00 Apr 13 22:15:16 localhost kernel: [ 3745.742749] blk_update_request: I/O error, dev sda, sector 128124928 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:15:21 localhost kernel: [ 3750.198217] sd 0:0:0:0: [sda] tag#17 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:15:21 localhost kernel: [ 3750.198261] sd 0:0:0:0: [sda] tag#17 CDB: opcode=0x28 28 00 07 a3 08 00 00 00 08 00 Apr 13 22:15:21 localhost kernel: [ 3750.198272] blk_update_request: I/O error, dev sda, sector 128124928 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:15:21 localhost kernel: [ 3750.198808] sd 0:0:0:0: [sda] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s Apr 13 22:15:21 localhost kernel: [ 3750.198837] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 07 a3 08 00 00 00 08 00 Apr 13 22:15:21 localhost kernel: [ 3750.198845] blk_update_request: I/O error, dev sda, sector 128124928 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 Apr 13 22:15:58 localhost chronyd[701]: Selected source 144.91.116.85 Apr 13 22:17:01 localhost CRON[2274]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
