[ .... ] Installing from repository [ linux-u-boot-orangepi3-lts-edge ]
[ error ] ERROR in function install_deb_chroot [ main.sh:589 -> main.sh:550 -> debootstrap.sh:69 -> distributions.sh:292 -> image-helpers.sh:225 -> general.sh:0 ]
[ error ] Installation of linux-u-boot-orangepi3-lts-edge failed [ orangepi3-lts jammy yes sunxi64 ]
[ o.k. ] Process terminated
[ error ] unmount_on_exit() called! [ main.sh:1 -> image-helpers.sh:0 ]
[ o.k. ] Unmounting [ /home/bogdan/build/.tmp/rootfs-664a2c64-6020-46d2-9a3d-befe609b050d/ ]
[ error ] ERROR in function unmount_on_exit [ main.sh:1 -> image-helpers.sh:94 -> general.sh:0 ]
[ error ] debootstrap-ng was interrupted
Logs: Reading package lists... '/etc/kernel/postinst.d/initramfs-tools' permissions changed from 0755 (rwxr-xr-x) to 0644 (rw-r--r--)
E: Unable to locate package linux-u-boot-orangepi3-lts-edge
8 минут назад, Werner сказал:
Read them :)
and? I didn't find anything about my problem there, except what I attached in post
I suggest to start over with a clean build directory on a clean build environment. Just built Jammy edge for OPi3-LTS without issues.
11 минут назад, Werner сказал:
I tried to build on vm and on board , still this error
What exact build command did you use? Which options did you choose?
If you cannot interpret the logs yourself paste/upload them somewhere.
Did you use repository install? If so build the packages yourself since this board has been added to nighties fairly recently and packages may not be there yet.
1 час назад, Werner сказал:
i choose "Use precompiled packages from Armbian repository" option
retry without this.
