armbian-next development
2 hours ago, ALIGMSTEN said:
BUILD_MINIMAL=yes
/usr/lib/armbian/armbian-firstlogin: line 111: curl: command not found
Might be minimal image and firstlogin don't like each other?
Either way, please open GitHub issue with those, can't keep up with 2 places for issues.
Link to comment
Share on other sites
On 2/26/2023 at 3:51 PM, rpardini said:
On 2/26/2023 at 3:16 PM, schwar3kat said:
Downloading required [ ORAS tooling ]
Thanks @schwar3kat ! This has been elusive, but its clear that when the tooling is 1st downloaded, the parsing fails.
2nd run the tooling is already there so doesn't fail.
Will try to address!
Do you want me to log a GitHub issue for this?
Link to comment
That would be helpful, yes, thanks. To reproduce the problem, you can delete `cache/tools/oras` and the bug should appear again...
Link to comment
I couldn't reproduce the problem, after deleting `cache/tools/oras`, even with CLEAN_LEVEL=debs ARTIFACT_IGNORE_CACHE=yes.
I deleted the whole cache and was able to reproduce it.
EDIT:  deleting cache/tools/oras. does reproduce the error.  Not sure why I didn't get the same result earlier.
https://github.com/armbian/build/issues/4889
Link to comment
