killwill Posted September 18, 2016 Posted September 18, 2016 - Please, after update my Orange PI One for Linux 5.20 , reboot the machine and nothing. - The leds of the board off. Only leds static in wire cable. - I tested others .raws compatyble with OpiOne and it is the same. - Can help me ,please an thanks ; )
Igor Posted September 18, 2016 Posted September 18, 2016 Which kernel (I assume you had 3.4.112) and did you encounter any errors during update? Edit: image from download section (Jessie Server) works fine, tested right now. Here is boot log. Check docs for resolving standard problems. 1
killwill Posted September 18, 2016 Author Posted September 18, 2016 On 9/18/2016 at 5:31 PM, Igor said: Which kernel (I assume you had 3.4.112) and did you encounter any errors during update? Edit: image from download section (Jessie Server) works fine, tested right now. Here is boot log. Check docs for resolving standard problems. Hi, I'm using .raw (old) because I can not boot with .img After upgrade return : Errors were encountered while processing: /var/cache/apt/archives/armbian-tools-jessie_5.20_armhf.deb E: Sub-process /usr/bin/dpkg returned an error code (1) root@orangepione:~# reboot thanks
Igor Posted September 18, 2016 Posted September 18, 2016 .raw was renamed to .img in latest update. There is no other diff. If upgrading is failed, you don't reboot until you find out what's wrong ... I guess we need to write this somewhere since you are not the only one with this problem. Check for a solution: http://forum.armbian.com/index.php/topic/2058-upgrade-problem-with-520-on-xenial/ 2
killwill Posted September 18, 2016 Author Posted September 18, 2016 On 9/18/2016 at 6:00 PM, Igor said: .raw was renamed to .img in latest update. There is no other diff. If upgrading is failed, you don't reboot until you find out what's wrong ... I guess we need to write this somewhere since you are not the only one with this problem. Check for a solution: http://forum.armbian.com/index.php/topic/2058-upgrade-problem-with-520-on-xenial/ Okay, I keep trying. Thank you for your help
killwill Posted September 18, 2016 Author Posted September 18, 2016 On 9/18/2016 at 6:00 PM, Igor said: .raw was renamed to .img in latest update. There is no other diff. If upgrading is failed, you don't reboot until you find out what's wrong ... I guess we need to write this somewhere since you are not the only one with this problem. Check for a solution: http://forum.armbian.com/index.php/topic/2058-upgrade-problem-with-520-on-xenial/ SOLVED !!! after dist-upgrade and before of reboot : sudo apt-get install -f be happy thanks to Igor and tkaiser 3
