wolverin Posted May 31, 2022 Posted May 31, 2022 Hi all. I understand, maybe my board Nanopi Neo CORE is not supported on the forum, but maybe someone will tell me how to write dts correctly # uname -a Linux NanoPi-NEO-Core 4.14.111 #126 SMP Mon Feb 22 17:04:18 CST 2021 armv7l armv7l armv7l GNU/Linux I compiled and installed ffmpeg with Cedrus H264 and cedar_ve.ko After that I see # dmesg | grep cedar [ 4.982170] cedar_ve: loading out-of-tree module taints kernel. [ 4.988972] sunxi cedar version 0.1 I'm trying to edit and compile /boot/sun8i-h3-nanopi-neo-core.dts using sun8i-h3-nanopi-neo-air.dts First I change before soc reserved-memory { #address-cells = <0x01>; #size-cells = <0x01>; ranges; cma@43c00000 { compatible = "shared-dma-pool"; reusable; reg = < 0x57c00000 0x6000000 >; linux,cma-default; phandle = < 0x84 >; }; }; and change in soc video-engine@01c0e000 { compatible = "allwinner,sunxi-cedar-ve"; reg = < 0x1c0e000 0x1000 0x1c00000 0x10 0x1c20000 0x800 >; memory-region = < 0x84 >; syscon = < 0x15 >; clocks = < 0x03 0x29 0x03 0x6c 0x03 0x61 >; clock-names = "ahb", "mod", "ram"; resets = < 0x03 0x1a >; interrupts = < 0x00 0x3a 0x04 >; status = "okay"; }; after that I get # dmesg | grep cedar [ 4.944911] cedar_ve: loading out-of-tree module taints kernel. [ 4.951697] sunxi cedar version 0.1 [ 4.955629] [cedar]: install start!!! [ 4.959521] cedar_ve: cedar-ve the get irq is 55 [ 4.964193] sunxi-cedar 1c0e000.video-engine: assigned reserved memory node cma@43c00000 [ 4.972512] sunxi-cedar 1c0e000.video-engine: syscon failed... [ 4.998164] sunxi-cedar 1c0e000.video-engine: failed to get ahb clock then I change and the board is no longer loaded syscon@1c00000 { compatible = "allwinner,sun8i-h3-system-controller", "syscon"; reg = < 0x1c00000 0x1000 >; #address-cells = < 0x01 >; #size-cells = < 0x01 >; ranges; sram@1d00000 { compatible = "mmio-sram"; reg = < 0x1d00000 0x80000 >; #address-cells = < 0x01 >; #size-cells = < 0x01 >; ranges = < 0x00 0x1d00000 0x80000 >; sram-section@0 { compatible = "allwinner,sun8i-h3-sram-c1", "allwinner,sun4i-a10-sram-c1"; reg = < 0x00 0x80000 >; }; }; }; Orig sun8i-h3-nanopi-neo-core.dts Скрытый текст /dts-v1/; / { interrupt-parent = <0x1>; #address-cells = <0x1>; #size-cells = <0x1>; model = "FriendlyElec NanoPi-NEO-Core"; compatible = "friendlyelec,nanopi-neo-core", "allwinner,sun8i-h3"; clocks { #address-cells = <0x1>; #size-cells = <0x1>; ranges; osc24M_clk { #clock-cells = <0x0>; compatible = "fixed-clock"; clock-frequency = <0x16e3600>; clock-output-names = "osc24M"; linux,phandle = <0x1b>; phandle = <0x1b>; }; osc32k_clk { #clock-cells = <0x0>; compatible = "fixed-clock"; clock-frequency = <0x8000>; clock-output-names = "osc32k"; linux,phandle = <0x1c>; phandle = <0x1c>; }; internal-osc-clk { #clock-cells = <0x0>; compatible = "fixed-clock"; clock-frequency = <0xf42400>; clock-accuracy = <0x11e1a300>; clock-output-names = "iosc"; linux,phandle = <0x2f>; phandle = <0x2f>; }; }; display-engine { compatible = "allwinner,sun8i-h3-display-engine"; allwinner,pipelines = <0x2 0x3>; status = "okay"; linux,phandle = <0x41>; phandle = <0x41>; }; soc { compatible = "simple-bus"; #address-cells = <0x1>; #size-cells = <0x1>; ranges; clock@1000000 { compatible = "allwinner,sun8i-a83t-de2-clk"; reg = <0x1000000 0x100000>; clocks = <0x4 0x30 0x4 0x65>; clock-names = "bus", "mod"; resets = <0x4 0x22>; #clock-cells = <0x1>; #reset-cells = <0x1>; assigned-clocks = <0x4 0x65>; assigned-clock-parents = <0x4 0xd>; assigned-clock-rates = <0x19bfcc00>; linux,phandle = <0x8>; phandle = <0x8>; }; hdmi@1ee0000 { #sound-dai-cells = <0x0>; compatible = "allwinner,sun8i-h3-dw-hdmi"; reg = <0x1ee0000 0x10000 0x1ef0000 0x10000>; reg-io-width = <0x1>; interrupts = <0x0 0x58 0x4>; clocks = <0x4 0x2f 0x4 0x6f 0x4 0x70>; clock-names = "iahb", "isfr", "ddc"; resets = <0x4 0x20 0x4 0x21>; reset-names = "hdmi", "ddc"; status = "okay"; linux,phandle = <0xd>; phandle = <0xd>; ports { #address-cells = <0x1>; #size-cells = <0x0>; port@0 { #address-cells = <0x1>; #size-cells = <0x0>; reg = <0x0>; linux,phandle = <0x42>; phandle = <0x42>; endpoint@0 { reg = <0x0>; remote-endpoint = <0x5>; linux,phandle = <0x11>; phandle = <0x11>; }; }; port@1 { #address-cells = <0x1>; #size-cells = <0x0>; reg = <0x1>; linux,phandle = <0x43>; phandle = <0x43>; endpoint { remote-endpoint = <0x6>; linux,phandle = <0x3b>; phandle = <0x3b>; }; }; }; }; i2s@1c22800 { #sound-dai-cells = <0x0>; compatible = "allwinner,sun8i-h3-i2s"; reg = <0x1c22800 0x400>; interrupts = <0x0 0xf 0x4>; clocks = <0x4 0x3a 0x4 0x56>; clock-names = "apb", "mod"; dmas = <0x7 0x1b>; resets = <0x4 0x2d>; dma-names = "tx"; status = "okay"; linux,phandle = <0xe>; phandle = <0xe>; }; mixer@1100000 { compatible = "allwinner,sun8i-h3-de2-mixer0"; reg = <0x1100000 0x100000>; clocks = <0x8 0x0 0x8 0x6>; clock-names = "bus", "mod"; resets = <0x8 0x0>; status = "okay"; linux,phandle = <0x2>; phandle = <0x2>; ports { #address-cells = <0x1>; #size-cells = <0x0>; port@1 { #address-cells = <0x1>; #size-cells = <0x0>; reg = <0x1>; linux,phandle = <0x44>; phandle = <0x44>; endpoint@0 { reg = <0x0>; remote-endpoint = <0x9>; linux,phandle = <0xf>; phandle = <0xf>; }; endpoint@1 { reg = <0x1>; remote-endpoint = <0xa>; linux,phandle = <0x12>; phandle = <0x12>; }; }; }; }; mixer@1200000 { compatible = "allwinner,sun8i-h3-de2-mixer1"; reg = <0x1200000 0x100000>; clocks = <0x8 0x1 0x8 0x7>; clock-names = "bus", "mod"; resets = <0x8 0x2>; status = "disabled"; linux,phandle = <0x3>; phandle = <0x3>; ports { #address-cells = <0x1>; #size-cells = <0x0>; port@1 { #address-cells = <0x1>; #size-cells = <0x0>; reg = <0x1>; linux,phandle = <0x45>; phandle = <0x45>; endpoint@0 { reg = <0x0>; remote-endpoint = <0xb>; linux,phandle = <0x10>; phandle = <0x10>; }; endpoint@1 { reg = <0x1>; remote-endpoint = <0xc>; linux,phandle = <0x13>; phandle = <0x13>; }; }; }; }; sound { compatible = "simple-audio-card"; simple-audio-card,format = "i2s"; simple-audio-card,name = "allwinner,hdmi"; simple-audio-card,mclk-fs = <0x100>; status = "okay"; linux,phandle = <0x46>; phandle = <0x46>; simple-audio-card,codec { sound-dai = <0xd>; }; simple-audio-card,cpu { sound-dai = <0xe>; }; }; lcd-controller@1c0c000 { compatible = "allwinner,sun8i-h3-tcon"; reg = <0x1c0c000 0x1000>; interrupts = <0x0 0x56 0x4>; clocks = <0x4 0x2a 0x4 0x66>; clock-names = "ahb", "tcon-ch1"; resets = <0x4 0x1b>; reset-names = "lcd"; status = "okay"; linux,phandle = <0x47>; phandle = <0x47>; ports { #address-cells = <0x1>; #size-cells = <0x0>; port@0 { #address-cells = <0x1>; #size-cells = <0x0>; reg = <0x0>; linux,phandle = <0x48>; phandle = <0x48>; endpoint@0 { reg = <0x0>; remote-endpoint = <0xf>; linux,phandle = <0x9>; phandle = <0x9>; }; endpoint@1 { reg = <0x1>; remote-endpoint = <0x10>; linux,phandle = <0xb>; phandle = <0xb>; }; }; port@1 { #address-cells = <0x1>; #size-cells = <0x0>; reg = <0x1>; linux,phandle = <0x49>; phandle = <0x49>; endpoint@1 { reg = <0x1>; remote-endpoint = <0x11>; linux,phandle = <0x5>; phandle = <0x5>; }; }; }; }; lcd-controller@1c0d000 { compatible = "allwinner,sun8i-h3-tcon"; reg = <0x1c0d000 0x1000>; interrupts = <0x0 0x57 0x4>; clocks = <0x4 0x2b 0x4 0x67>; clock-names = "ahb", "tcon-ch1"; resets = <0x4 0x1c>; reset-names = "lcd"; status = "disabled"; linux,phandle = <0x4a>; phandle = <0x4a>; ports { #address-cells = <0x1>; #size-cells = <0x0>; port@0 { #address-cells = <0x1>; #size-cells = <0x0>; reg = <0x0>; linux,phandle = <0x4b>; phandle = <0x4b>; endpoint@0 { reg = <0x0>; remote-endpoint = <0x12>; linux,phandle = <0xa>; phandle = <0xa>; }; endpoint@1 { reg = <0x1>; remote-endpoint = <0x13>; linux,phandle = <0xc>; phandle = <0xc>; }; }; port@1 { #address-cells = <0x1>; #size-cells = <0x0>; reg = <0x1>; linux,phandle = <0x4c>; phandle = <0x4c>; }; }; }; syscon@1c00000 { compatible = "allwinner,sun8i-h3-system-controller", "syscon"; reg = <0x1c00000 0x1000>; linux,phandle = <0x1d>; phandle = <0x1d>; }; dma-controller@01c02000 { compatible = "allwinner,sun8i-h3-dma"; reg = <0x1c02000 0x1000>; interrupts = <0x0 0x32 0x4>; clocks = <0x4 0x15>; resets = <0x4 0x6>; #dma-cells = <0x1>; linux,phandle = <0x7>; phandle = <0x7>; }; mmc@01c0f000 { reg = <0x1c0f000 0x1000>; resets = <0x4 0x7>; reset-names = "ahb"; interrupts = <0x0 0x3c 0x4>; status = "okay"; #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun7i-a20-mmc"; clocks = <0x4 0x16 0x4 0x47 0x4 0x49 0x4 0x48>; clock-names = "ahb", "mmc", "output", "sample"; bus-width = <0x4>; non-removable; pinctrl-names = "default"; pinctrl-0 = <0x14 0x15>; boot_device = <0x0>; vmmc-supply = <0x16>; linux,phandle = <0x4d>; phandle = <0x4d>; }; mmc@01c10000 { reg = <0x1c10000 0x1000>; resets = <0x4 0x8>; reset-names = "ahb"; interrupts = <0x0 0x3d 0x4>; status = "disabled"; #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun7i-a20-mmc"; clocks = <0x4 0x17 0x4 0x4a 0x4 0x4c 0x4 0x4b>; clock-names = "ahb", "mmc", "output", "sample"; linux,phandle = <0x4e>; phandle = <0x4e>; }; mmc@01c11000 { reg = <0x1c11000 0x1000>; resets = <0x4 0x9>; reset-names = "ahb"; interrupts = <0x0 0x3e 0x4>; status = "okay"; #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun7i-a20-mmc"; clocks = <0x4 0x18 0x4 0x4d 0x4 0x4f 0x4 0x4e>; clock-names = "ahb", "mmc", "output", "sample"; boot_device = <0x0>; pinctrl-names = "default"; pinctrl-0 = <0x17>; vmmc-supply = <0x16>; bus-width = <0x8>; non-removable; cap-mmc-hw-reset; linux,phandle = <0x4f>; phandle = <0x4f>; }; usb@01c19000 { compatible = "allwinner,sun8i-h3-musb"; reg = <0x1c19000 0x400>; clocks = <0x4 0x20>; resets = <0x4 0x11>; interrupts = <0x0 0x47 0x4>; interrupt-names = "mc"; phys = <0x18 0x0>; phy-names = "usb"; extcon = <0x18 0x0>; status = "okay"; dr_mode = "otg"; linux,phandle = <0x50>; phandle = <0x50>; }; eeprom@01c14000 { compatible = "allwinner,sun8i-h3-sid"; reg = <0x1c14000 0x400>; linux,phandle = <0x51>; phandle = <0x51>; }; phy@01c19400 { compatible = "allwinner,sun8i-h3-usb-phy"; reg = <0x1c19400 0x2c 0x1c1a800 0x4 0x1c1b800 0x4 0x1c1c800 0x4 0x1c1d800 0x4>; reg-names = "phy_ctrl", "pmu0", "pmu1", "pmu2", "pmu3"; clocks = <0x4 0x58 0x4 0x59 0x4 0x5a 0x4 0x5b>; clock-names = "usb0_phy", "usb1_phy", "usb2_phy", "usb3_phy"; resets = <0x4 0x0 0x4 0x1 0x4 0x2 0x4 0x3>; reset-names = "usb0_reset", "usb1_reset", "usb2_reset", "usb3_reset"; status = "okay"; #phy-cells = <0x1>; usb0_id_det-gpios = <0x19 0x6 0xc 0x0>; usb0_vbus-supply = <0x1a>; linux,phandle = <0x18>; phandle = <0x18>; }; usb@01c1a000 { compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; reg = <0x1c1a000 0x100>; interrupts = <0x0 0x48 0x4>; clocks = <0x4 0x21 0x4 0x25>; resets = <0x4 0x12 0x4 0x16>; status = "okay"; linux,phandle = <0x52>; phandle = <0x52>; }; usb@01c1a400 { compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; reg = <0x1c1a400 0x100>; interrupts = <0x0 0x49 0x4>; clocks = <0x4 0x21 0x4 0x25 0x4 0x5c>; resets = <0x4 0x12 0x4 0x16>; status = "okay"; linux,phandle = <0x53>; phandle = <0x53>; }; usb@01c1b000 { compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; reg = <0x1c1b000 0x100>; interrupts = <0x0 0x4a 0x4>; clocks = <0x4 0x22 0x4 0x26>; resets = <0x4 0x13 0x4 0x17>; phys = <0x18 0x1>; phy-names = "usb"; status = "okay"; linux,phandle = <0x54>; phandle = <0x54>; }; usb@01c1b400 { compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; reg = <0x1c1b400 0x100>; interrupts = <0x0 0x4b 0x4>; clocks = <0x4 0x22 0x4 0x26 0x4 0x5d>; resets = <0x4 0x13 0x4 0x17>; phys = <0x18 0x1>; phy-names = "usb"; status = "okay"; linux,phandle = <0x55>; phandle = <0x55>; }; usb@01c1c000 { compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; reg = <0x1c1c000 0x100>; interrupts = <0x0 0x4c 0x4>; clocks = <0x4 0x23 0x4 0x27>; resets = <0x4 0x14 0x4 0x18>; phys = <0x18 0x2>; phy-names = "usb"; status = "okay"; linux,phandle = <0x56>; phandle = <0x56>; }; usb@01c1c400 { compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; reg = <0x1c1c400 0x100>; interrupts = <0x0 0x4d 0x4>; clocks = <0x4 0x23 0x4 0x27 0x4 0x5e>; resets = <0x4 0x14 0x4 0x18>; phys = <0x18 0x2>; phy-names = "usb"; status = "okay"; linux,phandle = <0x57>; phandle = <0x57>; }; usb@01c1d000 { compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; reg = <0x1c1d000 0x100>; interrupts = <0x0 0x4e 0x4>; clocks = <0x4 0x24 0x4 0x28>; resets = <0x4 0x15 0x4 0x19>; phys = <0x18 0x3>; phy-names = "usb"; status = "okay"; linux,phandle = <0x58>; phandle = <0x58>; }; usb@01c1d400 { compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; reg = <0x1c1d400 0x100>; interrupts = <0x0 0x4f 0x4>; clocks = <0x4 0x24 0x4 0x28 0x4 0x5f>; resets = <0x4 0x15 0x4 0x19>; phys = <0x18 0x3>; phy-names = "usb"; status = "okay"; linux,phandle = <0x59>; phandle = <0x59>; }; clock@01c20000 { reg = <0x1c20000 0x400>; clocks = <0x1b 0x1c>; clock-names = "hosc", "losc"; #clock-cells = <0x1>; #reset-cells = <0x1>; compatible = "allwinner,sun8i-h3-ccu"; linux,phandle = <0x4>; phandle = <0x4>; }; pinctrl@01c20800 { reg = <0x1c20800 0x400>; interrupts = <0x0 0xb 0x4 0x0 0x11 0x4>; clocks = <0x4 0x36 0x1b 0x1c>; clock-names = "apb", "hosc", "losc"; gpio-controller; #gpio-cells = <0x3>; interrupt-controller; #interrupt-cells = <0x3>; compatible = "allwinner,sun8i-h3-pinctrl"; linux,phandle = <0x19>; phandle = <0x19>; csi { pins = "PE0", "PE1", "PE2", "PE3", "PE4", "PE5", "PE6", "PE7", "PE8", "PE9", "PE10", "PE11"; function = "csi"; linux,phandle = <0x2e>; phandle = <0x2e>; }; emac0 { pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD7", "PD8", "PD9", "PD10", "PD12", "PD13", "PD15", "PD16", "PD17"; function = "emac"; drive-strength = <0x28>; linux,phandle = <0x5a>; phandle = <0x5a>; }; i2s0 { pins = "PA18", "PA19", "PA20", "PA21"; function = "i2s0"; linux,phandle = <0x24>; phandle = <0x24>; }; i2c0 { pins = "PA11", "PA12"; function = "i2c0"; linux,phandle = <0x2b>; phandle = <0x2b>; }; i2c1 { pins = "PA18", "PA19"; function = "i2c1"; linux,phandle = <0x2c>; phandle = <0x2c>; }; i2c2 { pins = "PE12", "PE13"; function = "i2c2"; linux,phandle = <0x2d>; phandle = <0x2d>; }; mmc0@0 { pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; function = "mmc0"; drive-strength = <0x1e>; bias-pull-up; linux,phandle = <0x14>; phandle = <0x14>; }; mmc0_cd_pin@0 { pins = "PF6"; function = "gpio_in"; bias-pull-up; linux,phandle = <0x15>; phandle = <0x15>; }; mmc1@0 { pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5"; function = "mmc1"; drive-strength = <0x1e>; bias-pull-up; linux,phandle = <0x5b>; phandle = <0x5b>; }; mmc2_8bit { pins = "PC5", "PC6", "PC8", "PC9", "PC10", "PC11", "PC12", "PC13", "PC14", "PC15", "PC16"; function = "mmc2"; drive-strength = <0x28>; bias-pull-up; linux,phandle = <0x17>; phandle = <0x17>; }; spdif@0 { pins = "PA17"; function = "spdif"; linux,phandle = <0x5c>; phandle = <0x5c>; }; spi0 { pins = "PC0", "PC1", "PC2", "PC3"; function = "spi0"; linux,phandle = <0x1f>; phandle = <0x1f>; }; spi1 { pins = "PA15", "PA16", "PA14", "PA13"; function = "spi1"; linux,phandle = <0x21>; phandle = <0x21>; }; uart0@0 { pins = "PA4", "PA5"; function = "uart0"; linux,phandle = <0x26>; phandle = <0x26>; }; uart1 { pins = "PG6", "PG7"; function = "uart1"; linux,phandle = <0x27>; phandle = <0x27>; }; uart1_rts_cts { pins = "PG8", "PG9"; function = "uart1"; linux,phandle = <0x5d>; phandle = <0x5d>; }; uart2 { pins = "PA0", "PA1"; function = "uart2"; linux,phandle = <0x28>; phandle = <0x28>; }; uart2_rts_cts { pins = "PA2", "PA3"; function = "uart2"; linux,phandle = <0x5e>; phandle = <0x5e>; }; uart3 { pins = "PA13", "PA14"; function = "uart3"; linux,phandle = <0x29>; phandle = <0x29>; }; uart3_rts_cts { pins = "PA15", "PA16"; function = "uart3"; linux,phandle = <0x2a>; phandle = <0x2a>; }; pwm0 { pins = "PA5"; function = "pwm0"; linux,phandle = <0x22>; phandle = <0x22>; }; led_pins { pins = "PA10"; function = "gpio_out"; linux,phandle = <0x3c>; phandle = <0x3c>; }; spi0_cs_pins { pins = "PC3", "PA6"; function = "gpio_out"; linux,phandle = <0x20>; phandle = <0x20>; }; }; ths@01c25000 { #thermal-sensor-cells = <0x0>; compatible = "allwinner,sun8i-h3-ths"; reg = <0x1c25000 0x400 0x1c14234 0x4>; interrupts = <0x0 0x1f 0x4>; resets = <0x4 0x2a>; reset-names = "ahb"; clocks = <0x4 0x37 0x4 0x45>; clock-names = "ahb", "ths"; linux,phandle = <0x34>; phandle = <0x34>; }; timer@01c20c00 { compatible = "allwinner,sun4i-a10-timer"; reg = <0x1c20c00 0xa0>; interrupts = <0x0 0x12 0x4 0x0 0x13 0x4>; clocks = <0x1b>; }; ethernet@1c30000 { compatible = "allwinner,sun8i-h3-emac"; syscon = <0x1d>; reg = <0x1c30000 0x10000>; interrupts = <0x0 0x52 0x4>; interrupt-names = "macirq"; resets = <0x4 0xc>; reset-names = "stmmaceth"; clocks = <0x4 0x1b>; clock-names = "stmmaceth"; #address-cells = <0x1>; #size-cells = <0x0>; status = "okay"; local-mac-address = [00 00 00 00 00 00]; phy-handle = <0x1e>; phy-mode = "mii"; allwinner,leds-active-low; linux,phandle = <0x5f>; phandle = <0x5f>; mdio { #address-cells = <0x1>; #size-cells = <0x0>; linux,phandle = <0x60>; phandle = <0x60>; ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x1>; clocks = <0x4 0x43>; resets = <0x4 0x27>; linux,phandle = <0x1e>; phandle = <0x1e>; }; }; }; spi@01c68000 { compatible = "allwinner,sun8i-h3-spi"; reg = <0x1c68000 0x1000>; interrupts = <0x0 0x41 0x4>; clocks = <0x4 0x1e 0x4 0x52>; clock-names = "ahb", "mod"; dmas = <0x7 0x17 0x7 0x17>; dma-names = "rx", "tx"; pinctrl-names = "default"; pinctrl-0 = <0x1f 0x20>; resets = <0x4 0xf>; status = "okay"; #address-cells = <0x1>; #size-cells = <0x0>; cs-gpios = <0x19 0x2 0x3 0x0 0x19 0x0 0x6 0x0>; linux,phandle = <0x61>; phandle = <0x61>; spi@0 { compatible = "nanopi,spidev"; reg = <0x0>; status = "okay"; spi-max-frequency = <0x989680>; linux,phandle = <0x62>; phandle = <0x62>; }; spiflash@0 { #address-cells = <0x1>; #size-cells = <0x1>; compatible = "mxicy,mx25l12805d"; reg = <0x0>; status = "disabled"; spi-max-frequency = <0x2faf080>; mode = <0x0>; linux,phandle = <0x63>; phandle = <0x63>; partition@0 { reg = <0x0 0x1000000>; label = "spi-flash"; }; }; pitft@0 { compatible = "sitronix,st7789v"; reg = <0x0>; status = "disabled"; spi-max-frequency = <0x2faf080>; rotate = <0x5a>; fps = <0x21>; buswidth = <0x8>; dc-gpios = <0x19 0x0 0x1 0x0>; reset-gpios = <0x19 0x6 0xb 0x0>; led-gpios = <0x19 0x0 0x0 0x1>; debug = <0x0>; linux,phandle = <0x64>; phandle = <0x64>; }; pitft-ts@1 { compatible = "ti,ads7846"; reg = <0x1>; status = "disabled"; spi-max-frequency = <0x1e8480>; interrupt-parent = <0x19>; interrupts = <0x6 0x9 0x2>; pendown-gpio = <0x19 0x6 0x9 0x1>; ti,swap-xy; ti,vref-delay-usecs = <0x3e8>; ti,x-min = [00 64]; ti,x-max = [0f ff]; ti,y-min = [00 64]; ti,y-max = [0f ff]; ti,vref-mv = <0xce4>; ti,x-plate-ohms = [01 00]; ti,penirq-recheck-delay-usecs = <0xa>; ti,settle-delay-usec = [00 64]; ti,keep-vref-on = <0x1>; ti,pressure-max = [0f ff]; ti,debounce-max = <0xa>; ti,debounce-tol = <0x1e>; ti,debounce-rep = <0x1>; linux,phandle = <0x65>; phandle = <0x65>; }; }; spi@01c69000 { compatible = "allwinner,sun8i-h3-spi"; reg = <0x1c69000 0x1000>; interrupts = <0x0 0x42 0x4>; clocks = <0x4 0x1f 0x4 0x53>; clock-names = "ahb", "mod"; dmas = <0x7 0x18 0x7 0x18>; dma-names = "rx", "tx"; pinctrl-names = "default"; pinctrl-0 = <0x21>; resets = <0x4 0x10>; status = "disable"; #address-cells = <0x1>; #size-cells = <0x0>; linux,phandle = <0x66>; phandle = <0x66>; spi@1 { compatible = "nanopi,spidev"; reg = <0x0>; spi-max-frequency = <0x989680>; linux,phandle = <0x67>; phandle = <0x67>; }; }; watchdog@01c20ca0 { compatible = "allwinner,sun6i-a31-wdt"; reg = <0x1c20ca0 0x20>; interrupts = <0x0 0x19 0x4>; linux,phandle = <0x68>; phandle = <0x68>; }; spdif@01c21000 { #sound-dai-cells = <0x0>; compatible = "allwinner,sun8i-h3-spdif"; reg = <0x1c21000 0x400>; interrupts = <0x0 0xc 0x4>; clocks = <0x4 0x35 0x4 0x57>; resets = <0x4 0x29>; clock-names = "apb", "spdif"; dmas = <0x7 0x2>; dma-names = "tx"; status = "disabled"; linux,phandle = <0x69>; phandle = <0x69>; }; pwm@01c21400 { compatible = "allwinner,sun8i-h3-pwm"; reg = <0x1c21400 0x8>; clocks = <0x1b>; #pwm-cells = <0x3>; status = "disabled"; pinctrl-names = "default"; pinctrl-0 = <0x22>; linux,phandle = <0x6a>; phandle = <0x6a>; }; codec@01c22c00 { #sound-dai-cells = <0x0>; compatible = "allwinner,sun8i-h3-codec"; reg = <0x1c22c00 0x400>; interrupts = <0x0 0x1d 0x4>; clocks = <0x4 0x34 0x4 0x6d>; clock-names = "apb", "codec"; resets = <0x4 0x28>; dmas = <0x7 0xf 0x7 0xf>; dma-names = "rx", "tx"; allwinner,codec-analog-controls = <0x23>; status = "okay"; allwinner,audio-routing = "Line Out", "LINEOUT", "MIC1", "Mic", "Mic", "MBIAS"; linux,phandle = <0x6b>; phandle = <0x6b>; }; i2s@01c22000 { #sound-dai-cells = <0x0>; compatible = "allwinner,sun8i-h3-i2s"; reg = <0x1c22000 0x400>; interrupts = <0x0 0xd 0x4>; clocks = <0x4 0x38 0x4 0x54>; clock-names = "apb", "mod"; resets = <0x4 0x2b>; pinctrl-names = "default"; pinctrl-0 = <0x24>; dmas = <0x7 0x3 0x7 0x3>; dma-names = "rx", "tx"; status = "disabled"; #address-cells = <0x1>; #size-cells = <0x0>; sound-dai = <0x25>; linux,phandle = <0x3f>; phandle = <0x3f>; }; serial@01c28000 { compatible = "snps,dw-apb-uart"; reg = <0x1c28000 0x400>; interrupts = <0x0 0x0 0x4>; reg-shift = <0x2>; reg-io-width = <0x4>; clocks = <0x4 0x3e>; resets = <0x4 0x31>; dmas = <0x7 0x6 0x7 0x6>; dma-names = "rx", "tx"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <0x26>; linux,phandle = <0x6c>; phandle = <0x6c>; }; serial@01c28400 { compatible = "snps,dw-apb-uart"; reg = <0x1c28400 0x400>; interrupts = <0x0 0x1 0x4>; reg-shift = <0x2>; reg-io-width = <0x4>; clocks = <0x4 0x3f>; resets = <0x4 0x32>; dmas = <0x7 0x7 0x7 0x7>; dma-names = "rx", "tx"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <0x27>; linux,phandle = <0x6d>; phandle = <0x6d>; }; serial@01c28800 { compatible = "snps,dw-apb-uart"; reg = <0x1c28800 0x400>; interrupts = <0x0 0x2 0x4>; reg-shift = <0x2>; reg-io-width = <0x4>; clocks = <0x4 0x40>; resets = <0x4 0x33>; dmas = <0x7 0x8 0x7 0x8>; dma-names = "rx", "tx"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <0x28>; linux,phandle = <0x6e>; phandle = <0x6e>; }; serial@01c28c00 { compatible = "snps,dw-apb-uart"; reg = <0x1c28c00 0x400>; interrupts = <0x0 0x3 0x4>; reg-shift = <0x2>; reg-io-width = <0x4>; clocks = <0x4 0x41>; resets = <0x4 0x34>; dmas = <0x7 0x9 0x7 0x9>; dma-names = "rx", "tx"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <0x29 0x2a>; linux,phandle = <0x6f>; phandle = <0x6f>; }; i2c@01c2ac00 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x1c2ac00 0x400>; interrupts = <0x0 0x6 0x4>; clocks = <0x4 0x3b>; resets = <0x4 0x2e>; pinctrl-names = "default"; pinctrl-0 = <0x2b>; status = "okay"; #address-cells = <0x1>; #size-cells = <0x0>; linux,phandle = <0x70>; phandle = <0x70>; rtc@68 { compatible = "dallas,ds1307"; reg = <0x68>; }; }; i2c@01c2b000 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x1c2b000 0x400>; interrupts = <0x0 0x7 0x4>; clocks = <0x4 0x3c>; resets = <0x4 0x2f>; pinctrl-names = "default"; pinctrl-0 = <0x2c>; status = "okay"; #address-cells = <0x1>; #size-cells = <0x0>; linux,phandle = <0x71>; phandle = <0x71>; }; i2c@01c2b400 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x1c2b400 0x400>; interrupts = <0x0 0x8 0x4>; clocks = <0x4 0x3d>; resets = <0x4 0x30>; pinctrl-names = "default"; pinctrl-0 = <0x2d>; status = "okay"; #address-cells = <0x1>; #size-cells = <0x0>; linux,phandle = <0x72>; phandle = <0x72>; }; interrupt-controller@01c81000 { compatible = "arm,gic-400"; reg = <0x1c81000 0x1000 0x1c82000 0x2000 0x1c84000 0x2000 0x1c86000 0x2000>; interrupt-controller; #interrupt-cells = <0x3>; interrupts = <0x1 0x9 0xf04>; linux,phandle = <0x1>; phandle = <0x1>; }; camera@01cb0000 { compatible = "allwinner,sun8i-h3-csi", "allwinner,sun6i-a31-csi"; reg = <0x1cb0000 0x1000>; interrupts = <0x0 0x54 0x4>; clocks = <0x4 0x2d 0x4 0x6a 0x4 0x62>; clock-names = "bus", "mod", "ram"; resets = <0x4 0x1e>; pinctrl-names = "default"; pinctrl-0 = <0x2e>; status = "disabled"; linux,phandle = <0x73>; phandle = <0x73>; }; rtc@01f00000 { compatible = "allwinner,sun6i-a31-rtc"; reg = <0x1f00000 0x54>; interrupts = <0x0 0x28 0x4 0x0 0x29 0x4>; linux,phandle = <0x74>; phandle = <0x74>; }; clock@1f01400 { compatible = "allwinner,sun8i-h3-r-ccu"; reg = <0x1f01400 0x100>; clocks = <0x1b 0x1c 0x2f 0x4 0x9>; clock-names = "hosc", "losc", "iosc", "pll-periph"; #clock-cells = <0x1>; #reset-cells = <0x1>; linux,phandle = <0x30>; phandle = <0x30>; }; codec-analog@01f015c0 { compatible = "allwinner,sun8i-h3-codec-analog"; reg = <0x1f015c0 0x4>; linux,phandle = <0x23>; phandle = <0x23>; }; ir@01f02000 { compatible = "allwinner,sun5i-a13-ir"; clocks = <0x30 0x4 0x30 0xb>; clock-names = "apb", "ir"; resets = <0x30 0x0>; interrupts = <0x0 0x25 0x4>; reg = <0x1f02000 0x40>; status = "disabled"; pinctrl-names = "default"; pinctrl-0 = <0x31>; linux,phandle = <0x75>; phandle = <0x75>; }; i2c@01f02400 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x1f02400 0x400>; interrupts = <0x0 0x2c 0x4>; pinctrl-names = "default"; pinctrl-0 = <0x32>; clocks = <0x30 0x9>; clock-frequency = <0x186a0>; resets = <0x30 0x5>; status = "disabled"; #address-cells = <0x1>; #size-cells = <0x0>; linux,phandle = <0x76>; phandle = <0x76>; }; pinctrl@01f02c00 { compatible = "allwinner,sun8i-h3-r-pinctrl"; reg = <0x1f02c00 0x400>; interrupts = <0x0 0x2d 0x4>; clocks = <0x30 0x3 0x1b 0x1c>; clock-names = "apb", "hosc", "losc"; gpio-controller; #gpio-cells = <0x3>; interrupt-controller; #interrupt-cells = <0x3>; linux,phandle = <0x3a>; phandle = <0x3a>; ir@0 { pins = "PL11"; function = "s_cir_rx"; linux,phandle = <0x31>; phandle = <0x31>; }; r_i2c@0 { pins = "PL0", "PL1"; function = "s_i2c"; linux,phandle = <0x32>; phandle = <0x32>; }; led_pins { pins = "PL10"; function = "gpio_out"; linux,phandle = <0x3d>; phandle = <0x3d>; }; key_pins { pins = "PL3"; function = "gpio_in"; linux,phandle = <0x3e>; phandle = <0x3e>; }; }; gpu@1c40000 { compatible = "allwinner,sun8i-h3-mali", "allwinner,sun7i-a20-mali", "arm,mali-400"; reg = <0x1c40000 0x10000>; interrupts = <0x0 0x61 0x4 0x0 0x62 0x4 0x0 0x63 0x4 0x0 0x64 0x4 0x0 0x66 0x4 0x0 0x67 0x4 0x0 0x65 0x4>; interrupt-names = "gp", "gpmmu", "pp0", "ppmmu0", "pp1", "ppmmu1", "pmu"; clocks = <0x4 0x31 0x4 0x72>; clock-names = "bus", "core"; resets = <0x4 0x23>; memory-region = <0x33>; assigned-clocks = <0x4 0x72>; assigned-clock-rates = <0x16e36000>; linux,phandle = <0x77>; phandle = <0x77>; }; }; thermal-zones { cpu_thermal { polling-delay-passive = <0x14a>; polling-delay = <0x3e8>; thermal-sensors = <0x34 0x0>; linux,phandle = <0x78>; phandle = <0x78>; trips { cpu_warm { temperature = <0xea60>; hysteresis = <0x7d0>; type = "passive"; linux,phandle = <0x35>; phandle = <0x35>; }; cpu_hot { temperature = <0x11170>; hysteresis = <0x7d0>; type = "passive"; linux,phandle = <0x37>; phandle = <0x37>; }; cpu_very_hot { temperature = <0x13880>; hysteresis = <0x7d0>; type = "passive"; linux,phandle = <0x38>; phandle = <0x38>; }; cpu_crit { temperature = <0x186a0>; hysteresis = <0x7d0>; type = "critical"; linux,phandle = <0x79>; phandle = <0x79>; }; }; cooling-maps { cpu_warm_limit_cpu { trip = <0x35>; cooling-device = <0x36 0xffffffff 0x1>; }; cpu_hot_limit_cpu { trip = <0x37>; cooling-device = <0x36 0xffffffff 0x2>; }; cpu_very_hot_limit_cpu { trip = <0x38>; cooling-device = <0x36 0x3 0xffffffff>; }; }; }; }; cpus { #address-cells = <0x1>; #size-cells = <0x0>; cpu@0 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <0x0>; clocks = <0x4 0xe>; clock-latency = <0x3b9b0>; clock-frequency = <0x47868c00>; operating-points = <0x124f80 0x13d620 0xc7380 0x10c8e0 0x98580 0x10c8e0 0x75300 0x10c8e0 0x4c2c0 0x10c8e0 0x3a980 0x10c8e0 0x1d4c0 0x10c8e0>; #cooling-cells = <0x2>; cooling-min-level = <0x0>; cooling-max-level = <0x3>; cpu0-supply = <0x39>; linux,phandle = <0x36>; phandle = <0x36>; }; cpu@1 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <0x1>; clock-frequency = <0x47868c00>; }; cpu@2 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <0x2>; clock-frequency = <0x47868c00>; }; cpu@3 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <0x3>; clock-frequency = <0x47868c00>; }; }; reserved-memory { #address-cells = <0x1>; #size-cells = <0x1>; ranges; linux,cma { compatible = "shared-dma-pool"; reusable; size = <0x4000000>; alignment = <0x2000>; linux,cma-default; linux,phandle = <0x33>; phandle = <0x33>; }; }; timer { compatible = "arm,armv7-timer"; interrupts = <0x1 0xd 0xf08 0x1 0xe 0xf08 0x1 0xb 0xf08 0x1 0xa 0xf08>; }; ahci-5v { compatible = "regulator-fixed"; regulator-name = "ahci-5v"; regulator-min-microvolt = <0x4c4b40>; regulator-max-microvolt = <0x4c4b40>; regulator-boot-on; enable-active-high; gpio = <0x19 0x1 0x8 0x0>; status = "disabled"; linux,phandle = <0x7a>; phandle = <0x7a>; }; usb0-vbus { compatible = "regulator-fixed"; regulator-name = "usb0-vbus"; regulator-min-microvolt = <0x4c4b40>; regulator-max-microvolt = <0x4c4b40>; enable-active-high; gpio = <0x3a 0x0 0x2 0x0>; status = "okay"; linux,phandle = <0x1a>; phandle = <0x1a>; }; usb1-vbus { compatible = "regulator-fixed"; regulator-name = "usb1-vbus"; regulator-min-microvolt = <0x4c4b40>; regulator-max-microvolt = <0x4c4b40>; regulator-boot-on; enable-active-high; gpio = <0x19 0x7 0x6 0x0>; status = "disabled"; linux,phandle = <0x7b>; phandle = <0x7b>; }; usb2-vbus { compatible = "regulator-fixed"; regulator-name = "usb2-vbus"; regulator-min-microvolt = <0x4c4b40>; regulator-max-microvolt = <0x4c4b40>; regulator-boot-on; enable-active-high; gpio = <0x19 0x7 0x3 0x0>; status = "disabled"; linux,phandle = <0x7c>; phandle = <0x7c>; }; vcc3v0 { compatible = "regulator-fixed"; regulator-name = "vcc3v0"; regulator-min-microvolt = <0x2dc6c0>; regulator-max-microvolt = <0x2dc6c0>; linux,phandle = <0x7d>; phandle = <0x7d>; }; vcc3v3 { compatible = "regulator-fixed"; regulator-name = "vcc3v3"; regulator-min-microvolt = <0x325aa0>; regulator-max-microvolt = <0x325aa0>; linux,phandle = <0x16>; phandle = <0x16>; }; vcc5v0 { compatible = "regulator-fixed"; regulator-name = "vcc5v0"; regulator-min-microvolt = <0x4c4b40>; regulator-max-microvolt = <0x4c4b40>; linux,phandle = <0x40>; phandle = <0x40>; }; aliases { serial0 = "/soc/serial@01c28000"; serial1 = "/soc/serial@01c28400"; serial2 = "/soc/serial@01c28800"; serial3 = "/soc/serial@01c28c00"; i2c0 = "/soc/i2c@01c2ac00"; i2c1 = "/soc/i2c@01c2b000"; i2c2 = "/soc/i2c@01c2b400"; spi0 = "/soc/spi@01c68000"; spi1 = "/soc/spi@01c69000"; pwm0 = "/soc/pwm@01c21400"; mmc0 = "/soc/mmc@01c0f000"; mmc2 = "/soc/mmc@01c11000"; ethernet0 = "/soc/ethernet@1c30000"; i2s0 = "/soc/i2s@01c22000"; pcm5102a = "/pcm5102a-codec"; spidev0 = "/soc/spi@01c68000/spi@0"; spiflash = "/soc/spi@01c68000/spiflash@0"; pitft = "/soc/spi@01c68000/pitft@0"; pitft_ts = "/soc/spi@01c68000/pitft-ts@1"; ir = "/soc/ir@01f02000"; }; chosen { stdout-path = "serial0:115200n8"; }; connector { compatible = "hdmi-connector"; type = [61 00]; port { endpoint { remote-endpoint = <0x3b>; linux,phandle = <0x6>; phandle = <0x6>; }; }; }; leds { compatible = "gpio-leds"; pinctrl-names = "default"; pinctrl-0 = <0x3c 0x3d>; status { label = "status_led"; gpios = <0x19 0x0 0xa 0x0>; linux,default-trigger = "heartbeat"; }; pwr { label = "LED2"; gpios = <0x3a 0x0 0xa 0x0>; default-state = "on"; }; }; r_gpio_keys { compatible = "gpio-keys"; input-name = "k1"; pinctrl-names = "default"; pinctrl-0 = <0x3e>; k1 { label = "k1"; linux,code = <0x74>; gpios = <0x3a 0x0 0x3 0x1>; }; }; gpio-regulator { compatible = "regulator-gpio"; regulator-name = "vdd-cpux"; regulator-type = "voltage"; regulator-boot-on; regulator-always-on; regulator-min-microvolt = <0x10c8e0>; regulator-max-microvolt = <0x13d620>; regulator-ramp-delay = <0x32>; gpios = <0x3a 0x0 0x6 0x0>; gpios-states = <0x1>; states = <0x10c8e0 0x0 0x13d620 0x1>; linux,phandle = <0x39>; phandle = <0x39>; }; pcm5102a-codec { #sound-dai-cells = <0x0>; compatible = "ti,pcm5102a"; status = "disabled"; linux,phandle = <0x25>; phandle = <0x25>; }; sound_i2s { compatible = "simple-audio-card"; simple-audio-card,name = "I2S-master"; simple-audio-card,mclk-fs = <0x100>; simple-audio-card,format = "i2s"; status = "okay"; simple-audio-card,cpu { sound-dai = <0x3f>; }; simple-audio-card,codec { sound-dai = <0x25>; }; }; vcc1v2 { compatible = "regulator-fixed"; regulator-name = "vcc1v2"; regulator-min-microvolt = <0x124f80>; regulator-max-microvolt = <0x124f80>; regulator-always-on; regulator-boot-on; vin-supply = <0x40>; gpio = <0x3a 0x0 0x8 0x0>; enable-active-high; linux,phandle = <0x7e>; phandle = <0x7e>; }; vcc-dram { compatible = "regulator-fixed"; regulator-name = "vcc-dram"; regulator-min-microvolt = <0x16e360>; regulator-max-microvolt = <0x16e360>; regulator-always-on; regulator-boot-on; vin-supply = <0x40>; gpio = <0x3a 0x0 0x9 0x0>; enable-active-high; linux,phandle = <0x7f>; phandle = <0x7f>; }; vdd-cpux { compatible = "regulator-fixed"; regulator-name = "vdd-cpux-en"; regulator-min-microvolt = <0x124f80>; regulator-max-microvolt = <0x124f80>; regulator-always-on; regulator-boot-on; vin-supply = <0x40>; gpio = <0x3a 0x0 0x8 0x0>; enable-active-high; linux,phandle = <0x80>; phandle = <0x80>; }; __symbols__ { osc24M = "/clocks/osc24M_clk"; osc32k = "/clocks/osc32k_clk"; iosc = "/clocks/internal-osc-clk"; de = "/display-engine"; display_clocks = "/soc/clock@1000000"; hdmi = "/soc/hdmi@1ee0000"; hdmi_in = "/soc/hdmi@1ee0000/ports/port@0"; hdmi_in_tcon0 = "/soc/hdmi@1ee0000/ports/port@0/endpoint@0"; hdmi_out = "/soc/hdmi@1ee0000/ports/port@1"; hdmi_out_con = "/soc/hdmi@1ee0000/ports/port@1/endpoint"; i2s2 = "/soc/i2s@1c22800"; mixer0 = "/soc/mixer@1100000"; mixer0_out = "/soc/mixer@1100000/ports/port@1"; mixer0_out_tcon0 = "/soc/mixer@1100000/ports/port@1/endpoint@0"; mixer0_out_tcon1 = "/soc/mixer@1100000/ports/port@1/endpoint@1"; mixer1 = "/soc/mixer@1200000"; mixer1_out = "/soc/mixer@1200000/ports/port@1"; mixer1_out_tcon0 = "/soc/mixer@1200000/ports/port@1/endpoint@0"; mixer1_out_tcon1 = "/soc/mixer@1200000/ports/port@1/endpoint@1"; sound_hdmi = "/soc/sound"; tcon0 = "/soc/lcd-controller@1c0c000"; tcon0_in = "/soc/lcd-controller@1c0c000/ports/port@0"; tcon0_in_mixer0 = "/soc/lcd-controller@1c0c000/ports/port@0/endpoint@0"; tcon0_in_mixer1 = "/soc/lcd-controller@1c0c000/ports/port@0/endpoint@1"; tcon0_out = "/soc/lcd-controller@1c0c000/ports/port@1"; tcon0_out_hdmi = "/soc/lcd-controller@1c0c000/ports/port@1/endpoint@1"; tcon1 = "/soc/lcd-controller@1c0d000"; tcon1_in = "/soc/lcd-controller@1c0d000/ports/port@0"; tcon1_in_mixer0 = "/soc/lcd-controller@1c0d000/ports/port@0/endpoint@0"; tcon1_in_mixer1 = "/soc/lcd-controller@1c0d000/ports/port@0/endpoint@1"; tcon1_out = "/soc/lcd-controller@1c0d000/ports/port@1"; syscon = "/soc/syscon@1c00000"; dma = "/soc/dma-controller@01c02000"; mmc0 = "/soc/mmc@01c0f000"; mmc1 = "/soc/mmc@01c10000"; mmc2 = "/soc/mmc@01c11000"; usb_otg = "/soc/usb@01c19000"; sid = "/soc/eeprom@01c14000"; usbphy = "/soc/phy@01c19400"; ehci0 = "/soc/usb@01c1a000"; ohci0 = "/soc/usb@01c1a400"; ehci1 = "/soc/usb@01c1b000"; ohci1 = "/soc/usb@01c1b400"; ehci2 = "/soc/usb@01c1c000"; ohci2 = "/soc/usb@01c1c400"; ehci3 = "/soc/usb@01c1d000"; ohci3 = "/soc/usb@01c1d400"; ccu = "/soc/clock@01c20000"; pio = "/soc/pinctrl@01c20800"; csi_pins = "/soc/pinctrl@01c20800/csi"; emac_rgmii_pins = "/soc/pinctrl@01c20800/emac0"; i2s0_pins = "/soc/pinctrl@01c20800/i2s0"; i2c0_pins = "/soc/pinctrl@01c20800/i2c0"; i2c1_pins = "/soc/pinctrl@01c20800/i2c1"; i2c2_pins = "/soc/pinctrl@01c20800/i2c2"; mmc0_pins_a = "/soc/pinctrl@01c20800/mmc0@0"; mmc0_cd_pin = "/soc/pinctrl@01c20800/mmc0_cd_pin@0"; mmc1_pins_a = "/soc/pinctrl@01c20800/mmc1@0"; mmc2_8bit_pins = "/soc/pinctrl@01c20800/mmc2_8bit"; spdif_tx_pins_a = "/soc/pinctrl@01c20800/spdif@0"; spi0_pins = "/soc/pinctrl@01c20800/spi0"; spi1_pins = "/soc/pinctrl@01c20800/spi1"; uart0_pins_a = "/soc/pinctrl@01c20800/uart0@0"; uart1_pins = "/soc/pinctrl@01c20800/uart1"; uart1_rts_cts_pins = "/soc/pinctrl@01c20800/uart1_rts_cts"; uart2_pins = "/soc/pinctrl@01c20800/uart2"; uart2_rts_cts_pins = "/soc/pinctrl@01c20800/uart2_rts_cts"; uart3_pins = "/soc/pinctrl@01c20800/uart3"; uart3_rts_cts_pins = "/soc/pinctrl@01c20800/uart3_rts_cts"; pwm0_pins = "/soc/pinctrl@01c20800/pwm0"; leds_npi = "/soc/pinctrl@01c20800/led_pins"; spi0_cs_pins = "/soc/pinctrl@01c20800/spi0_cs_pins"; ths = "/soc/ths@01c25000"; emac = "/soc/ethernet@1c30000"; mdio = "/soc/ethernet@1c30000/mdio"; int_mii_phy = "/soc/ethernet@1c30000/mdio/ethernet-phy@1"; spi0 = "/soc/spi@01c68000"; spidev0 = "/soc/spi@01c68000/spi@0"; spiflash = "/soc/spi@01c68000/spiflash@0"; pitft = "/soc/spi@01c68000/pitft@0"; pitft_ts = "/soc/spi@01c68000/pitft-ts@1"; spi1 = "/soc/spi@01c69000"; spidev1 = "/soc/spi@01c69000/spi@1"; wdt0 = "/soc/watchdog@01c20ca0"; spdif = "/soc/spdif@01c21000"; pwm = "/soc/pwm@01c21400"; codec = "/soc/codec@01c22c00"; i2s0 = "/soc/i2s@01c22000"; uart0 = "/soc/serial@01c28000"; uart1 = "/soc/serial@01c28400"; uart2 = "/soc/serial@01c28800"; uart3 = "/soc/serial@01c28c00"; i2c0 = "/soc/i2c@01c2ac00"; i2c1 = "/soc/i2c@01c2b000"; i2c2 = "/soc/i2c@01c2b400"; gic = "/soc/interrupt-controller@01c81000"; csi = "/soc/camera@01cb0000"; rtc = "/soc/rtc@01f00000"; r_ccu = "/soc/clock@1f01400"; codec_analog = "/soc/codec-analog@01f015c0"; ir = "/soc/ir@01f02000"; r_i2c = "/soc/i2c@01f02400"; r_pio = "/soc/pinctrl@01f02c00"; ir_pins_a = "/soc/pinctrl@01f02c00/ir@0"; r_i2c_pins_a = "/soc/pinctrl@01f02c00/r_i2c@0"; leds_r_npi = "/soc/pinctrl@01f02c00/led_pins"; sw_r_npi = "/soc/pinctrl@01f02c00/key_pins"; mali = "/soc/gpu@1c40000"; cpu_thermal = "/thermal-zones/cpu_thermal"; cpu_warm = "/thermal-zones/cpu_thermal/trips/cpu_warm"; cpu_hot = "/thermal-zones/cpu_thermal/trips/cpu_hot"; cpu_very_hot = "/thermal-zones/cpu_thermal/trips/cpu_very_hot"; cpu_crit = "/thermal-zones/cpu_thermal/trips/cpu_crit"; cpu0 = "/cpus/cpu@0"; cma = "/reserved-memory/linux,cma"; reg_ahci_5v = "/ahci-5v"; reg_usb0_vbus = "/usb0-vbus"; reg_usb1_vbus = "/usb1-vbus"; reg_usb2_vbus = "/usb2-vbus"; reg_vcc3v0 = "/vcc3v0"; reg_vcc3v3 = "/vcc3v3"; reg_vcc5v0 = "/vcc5v0"; hdmi_con_in = "/connector/port/endpoint"; vdd_cpux = "/gpio-regulator"; pcm5102a = "/pcm5102a-codec"; reg_vcc1v2 = "/vcc1v2"; reg_vcc_dram = "/vcc-dram"; reg_vdd_cpux = "/vdd-cpux"; }; }; 0 Quote
Werner Posted May 31, 2022 Posted May 31, 2022 (edited) moving to unsupported oops, they share the same image since hardware is nearly identical. So it is supported. However your firmware is very outdated. Armbian can only support the most recent version due to lack of resources. Anyway maybe a member of the community has some clue. Edited May 31, 2022 by Werner correction 0 Quote
