Alexey Guskov Posted June 1, 2022 Posted June 1, 2022 Bluetooth device does not appear on my armbian (kernel is 5.17.5-media, tried on edge-media and current-media as well). # hciconfig version Can't get device info: No such device # bluetoothctl Agent registered [bluetooth]# devices No default controller available HCI socket does not seem to be created. Got this in dmesg: [ 11.990128] Bluetooth: HCI device and connection manager initialized [ 11.990145] Bluetooth: HCI socket layer initialized [ 11.990164] Bluetooth: L2CAP socket layer initialized [ 11.990188] Bluetooth: SCO socket layer initialized [ 12.081220] Bluetooth: HCI UART driver ver 2.3 [ 12.081245] Bluetooth: HCI UART protocol H4 registered [ 12.081250] Bluetooth: HCI UART protocol BCSP registered [ 12.081352] Bluetooth: HCI UART protocol LL registered [ 12.081358] Bluetooth: HCI UART protocol ATH3K registered [ 12.081397] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 12.081760] Bluetooth: HCI UART protocol Intel registered [ 12.082139] Bluetooth: HCI UART protocol Broadcom registered [ 12.082205] Bluetooth: HCI UART protocol QCA registered [ 12.082211] Bluetooth: HCI UART protocol AG6XX registered [ 12.082335] Bluetooth: HCI UART protocol Marvell registered [ 12.082530] rockchip-pinctrl pinctrl: pin gpio0-17 already requested by fdd50000.serial; cannot claim for serial0-0 [ 12.082544] rockchip-pinctrl pinctrl: pin-17 (serial0-0) status -22 [ 12.082550] rockchip-pinctrl pinctrl: could not request pin 17 (gpio0-17) from group bt-enable-h on device rockchip-pinctrl [ 12.082557] hci_uart_bcm serial0-0: Error applying setting, reverse things back [ 12.297655] cfg80211: failed to load regulatory.db [ 12.308441] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.firefly,rk3566-roc-pc.txt failed with error -2 [ 12.308466] brcmfmac mmc2:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac43455-sdio.firefly,rk3566-roc-pc.txt [ 12.549006] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [ 12.589256] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04 Looks like wifi firmware loaded okay (not sure if the chip uses same blob for bluetooth and wifi, probably not), but there's some conflict with fdd50000.serial (which is uart0, another strange thing). To me it looks like a bug in .dts, but could not find it so far. Tried removing uart0 from .dtd. HCI device appears after that, but HCI socket is down and not responding. (Maybe I need to trigger gpio pin to enable bluetooth, but why doesn't it happen automatically?) Any ideas? 0 Quote
balbes150 Posted June 1, 2022 Posted June 1, 2022 You didn't specify the model, are we talking about Station M1 or M2 ? 0 Quote
Alexey Guskov Posted June 1, 2022 Author Posted June 1, 2022 On 6/1/2022 at 2:53 PM, balbes150 said: You didn't specify the model, are we talking about Station M1 or M2 ? Expand M2 0 Quote
Alexey Guskov Posted June 2, 2022 Author Posted June 2, 2022 Looks like the source of the conflict is here: &uart0 { ... pinctrl-0 = <&uart0_xfer>; // RK_PC0 is rx and RK_PC1 is tx ... }; &uart1 { ... bluetooth { ... device-wake-gpios = <&gpio2 RK_PC1 GPIO_ACTIVE_HIGH>; host-wake-gpios = <&gpio2 RK_PC0 GPIO_ACTIVE_HIGH>; shutdown-gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; // RK_PB4 and RK_PC1 ... }; }; So, indeed, bluetooth device is conflicting with uart0 1 Quote
balbes150 Posted June 2, 2022 Posted June 2, 2022 On 6/2/2022 at 5:17 AM, Alexey Guskov said: So, indeed, bluetooth device is conflicting with uart0 Expand uart0 disabled ? 0 Quote
Jeremiah Cornelius Posted August 26, 2022 Posted August 26, 2022 So how do we disable Uart0? ๐ 0 Quote
