Hi All!
Can anyone help me about rotate de ArmBian logo in startup splash screen?
I am working with LCD Display and I want change the logo rotation to portrait mode.
Orange Pi PC and Armbian_22.05.1_Orangepipc_focal_current_5.15.43_xfce_desktop.img.xz.
Display - 7" HDMI Display 1024 x 600
Whats-App-Image-2022-06-20-at-10-50-49.j
Hello Jose,
While I don't have a direct answer for you, maybe I can get you going in the right direction.
I believe the following forum post documents a good portion of what you are wanting to do:
In your case the most simplistic approach would be to manually rotate the image it's self and replace boot.bmp in /boot on the board,  I believe (don't quote me).
Give it a go and let us know if this helps you with your issue.
Cheers!
Hi All!
Because the file /boot/logo.bmp contains another logo(armbian / initializing boot loader) and the logo that I want to rotate shows "armbian / universal operating system", I could not change it, them I adopted another approach:
- The approach that I used was build armbian and do somethings before the construction:
1- Change the file build/packages/blobs/splash/logo.png with the new image (with the rotation that I want);
2- Modify script build/lib/general.sh function boot_logo() to change the spinner position (parameter --pic_position to 0x07).
That's it
Hi,
I haven't found another way to do it.
Maybe someone in the community knows another way and can help.
It would be great if it was possible to change just one image file, for example.
With the current release (23.2) Armbian has moved to using the Plymouth package for the boot screen (for most if not all boards).  I personally don't know much about it, but  the resource files are in /usr/share/plymouth/themes/armbian
