Baal Posted June 21, 2022 Share Posted June 21, 2022 Armbianmonitor: http://ix.io/3UHS Hi all After update kernel from 5.10.60 to 5.15 or 5.16 on my Orange PI PC+ MJPEG-Streamer throws: Quote libv4l2: error turning on stream: Cannot allocate memory motion throws: Quote [1:ml1] [ERR] [VID] v4l2_set_mmap: Error starting stream. VIDIOC_STREAMON: Cannot allocate memory I tried to decrease resolution - even 320x240 not helps. Rolling back to 5.10.60 helps, but it's not very sustainable solution. Are there any known solution for 5.15-5.16? Today checked kernel 5.15.43-sunxi and 5.17.11-sunxi - same issue baal@3dprinter:~$ mjpg_streamer -i "input_uvc.so -f 5 -d $(ls -1 /dev/video[1-9] | head -1) -r SVGA -n" -o output_http.so MJPG Streamer Version: git rev: 310b29f4a94c46652b20c4b7b6e5cf24e532af39 i: Using V4L2 device.: /dev/video1 i: Desired Resolution: 800 x 600 i: Frames Per Second.: 5 i: Format............: JPEG i: TV-Norm...........: DEFAULT i: FPS coerced ......: from 5 to 30 o: www-folder-path......: disabled o: HTTP TCP port........: 8080 o: HTTP Listen Address..: (null) o: username:password....: disabled o: commands.............: enabled libv4l2: error turning on stream: Cannot allocate memory Unable to start capture: Cannot allocate memory i: Can't enable video in first time i: cleaning up resources allocated by input thread ^Csetting signal to stop force cancellation of threads and cleanup resources o: cleaning up resources allocated by server thread #00 0 Quote Link to comment Share on other sites More sharing options...
usual user Posted June 21, 2022 Share Posted June 21, 2022 Quote [ 0.000000] cma: Reserved 128 MiB at 0x75c00000 128MiB cma is probably not sufficient according to here: Quote Decoding H.264/H.265 videos can require a large amount of CMA memory, so it is recommended to set a large CMA pool, e.g. using the cma kernel command line parameter. For instance, 256 MiB should be enough to decode 1080p H.264 videos: cma=256M. 1 Quote Link to comment Share on other sites More sharing options...
Solution Baal Posted June 22, 2022 Author Solution Share Posted June 22, 2022 THANK YOU!! I added extraargs=cma=256M to /boot/armbianEnv.txt and it works now. 0 Quote Link to comment Share on other sites More sharing options...
