potz Posted September 1, 2015 Posted September 1, 2015 Hello! I have installed Igors Debian Wheezy Kernel 3.4.108 image on SD-Card for my BananaPi Pro. All is fine, thanks Igor! (after changing to Sandisk) But I can't activate the onboard Wifi-module. sudo modprobe ap6210 brings error: FATAL: Module ap6210 not found I tried a lot of thinks, but no result: root@bananapi:~# lsmod Module Size Used by cpufreq_userspace 3524 0 bnep 14462 2 bluetooth 264185 7 bnep brcmfmac 96909 0 brcmutil 4800 1 brcmfmac spidev 6366 0 I can activate the Lemaker 5'' touchscreen an the I2S-Audio in the script.bin-file, but no Wifi-module! I need all of this for my project and it's written it should work on Igors site: http://www.igorpecovnik.com/2014/09/07/banana-pi-debian-sd-image/ What should I do? Please help! Thanks! Andi
Igor Posted September 1, 2015 Posted September 1, 2015 Module name is not apxxxx but bcmdhd They are more or less the same.
potz Posted September 2, 2015 Author Posted September 2, 2015 Hi Igor! This is also not working: root@bananapi:~# sudo modprobe bcmdhd ERROR: could not insert 'bcmdhd': No such device It seems I have to activate this, but where? Thanks! Andi
Igor Posted September 2, 2015 Posted September 2, 2015 Huh. Are you sure you are using kernel 3.4.108 ? uname -a In kernel 4.x we have yet another module: brcmfmac
potz Posted September 2, 2015 Author Posted September 2, 2015 Yes, I think so: root@bananapi:~# uname -a Linux bananapi 3.4.108-banana #16 SMP PREEMPT Wed Aug 26 06:29:23 CEST 2015 armv7l GNU/Linux But I tried to load this module and this is possible, but no Wifi can activate. See in my first post. Andi
Igor Posted September 2, 2015 Posted September 2, 2015 Aha, are you using correct script bin? Is this in place? [sdio_wifi_pro_para] sdio_wifi_pro_used = 1 sdio_wifi_pro_sdc_id = 3 sdio_wifi_pro_mod_sel = 7 ap6xxx_wl_regon = port:PH22<1><default><default><0> ap6xxx_wl_vdd_en = port:PH27<1><default><default><0> [usb_wifi_para] usb_wifi_used = 1 usb_wifi_usbc_num = 2 Do a test with latest build on a separate SD card with only Wifi enabled. Perhaps on board wifi doesn't work together with LCD / I2S ? It's possible.
potz Posted September 2, 2015 Author Posted September 2, 2015 Yes, it seems. I renamed the bananapipro.bin to script.bin an copied in the boot-directory. I tried a lot... ;-) Thanks! Andi I have to go working now. Maybe more in the evening.? Thanks!
Igor Posted September 2, 2015 Posted September 2, 2015 We'll get to the bottom of this somehow Sadly I don't have Banana PRO around to recreate exact scenario, only the original one. Until later.
potz Posted September 2, 2015 Author Posted September 2, 2015 Igor, thanks! How can I help? At first I can buy one or two SD-cards more today for testing. Sorry because my English is not so well und I'm a linux newbie! Andi
Igor Posted September 2, 2015 Posted September 2, 2015 Just do thing step by step. One thing at the time to find out where is the problem.
potz Posted September 2, 2015 Author Posted September 2, 2015 Just do thing step by step. One thing at the time to find out where is the problem. Hi Igor! What's the next step? Andi
Igor Posted September 2, 2015 Posted September 2, 2015 Start with brand new image and without any additional hardware. Switch configuration from banana to bananapro, reboot, load wifi driver. Than proceed with adding hardware and functionality.
potz Posted September 2, 2015 Author Posted September 2, 2015 Start with brand new image and without any additional hardware. Switch configuration from banana to bananapro, reboot, load wifi driver. Than proceed with adding hardware and functionality. Ok. I want to do it correct. How should I switch the configuration? I'm not realy sure. Sorry! Rename and save the script.bin in \boot, take the bananapipro.bin from \boot\bin and copy as script.bin to \boot ? A.
potz Posted September 2, 2015 Author Posted September 2, 2015 Yes, you can do it that way to. Is there an easier way? A.
Igor Posted September 2, 2015 Posted September 2, 2015 With re-linking. ln -sf /boot/bin/bananapipro.bin /boot/script.bin
potz Posted September 2, 2015 Author Posted September 2, 2015 With re-linking. ln -sf /boot/bin/bananapipro.bin /boot/script.bin Ok., I have done this. First and second booting seems ok. I had changed the root password, re-linked and rebooted. And now I have this: Load: 0.44, 0.27, 0.11 - Board: 41.1°C - Memory: 959Mb root@bananapi:~# sudo modprobe bcmdhd ERROR: could not insert 'bcmdhd': No such device root@bananapi:~# root@bananapi:~# uname -a Linux bananapi 3.4.108-banana #16 SMP PREEMPT Wed Aug 26 06:29:23 CEST 2015 armv7l GNU/Linux root@bananapi:~# A.
Igor Posted September 2, 2015 Posted September 2, 2015 Sorry. Sorry that I haven't figured out before. You need to load all those modules and they should be present by default. If not ... bug. hci_uart gpio_sunxi bt_gpio wifi_gpio rfcomm hidp sunxi-ir bonding spi_sun7i bcmdhd You can leave out some non related ...Than it MUST work
potz Posted September 2, 2015 Author Posted September 2, 2015 Sorry. Sorry that I haven't figured out before. You need to load all those modules and they should be present by default. If not ... bug. hci_uart gpio_sunxi bt_gpio wifi_gpio rfcomm hidp sunxi-ir bonding spi_sun7i bcmdhd You can leave out some non related ... Than it MUST work Hi Igor, I have: Load: 0.63, 0.22, 0.08 - Board: 40.3°C - Memory: 959Mb root@bananapi:~# lsmod Module Size Used by bnep 14462 2 cpufreq_userspace 3524 0 a20_tp 3365 0 8021q 18593 0 garp 6072 1 8021q stp 2032 1 garp llc 5365 2 stp,garp sunxi_ir 4037 0 hidp 17640 0 rfcomm 58686 0 hci_uart 25000 0 bluetooth 264185 12 bnep,hidp,hci_uart,rfcomm spidev 6366 0 root@bananapi:~# It looks a little bit different. Should I load the other modules by hand with modprobe? A.
potz Posted September 2, 2015 Author Posted September 2, 2015 Sorry. Sorry that I haven't figured out before. You need to load all those modules and they should be present by default. If not ... bug. hci_uart gpio_sunxi bt_gpio wifi_gpio rfcomm hidp sunxi-ir bonding spi_sun7i bcmdhd You can leave out some non related ... Than it MUST work Modules file include: # /etc/modules: kernel modules to load at boot time. # # This file contains the names of kernel modules that should be loaded # at boot time, one per line. Lines beginning with "#" are ignored. # Parameters can be specified after the module name. hci_uart gpio_sunxi rfcomm hidp sunxi-ir bonding spi_sun7i 8021q a20_tp A.
Igor Posted September 2, 2015 Posted September 2, 2015 Just use suggested /etc/modules list and I am pretty sure it will work. You are missing: wifi_gpio bcmdhd
potz Posted September 2, 2015 Author Posted September 2, 2015 Hi Igor! Just use suggested /etc/modules list and I am pretty sure it will work. You are missing: wifi_gpio bcmdhd Sorry, but bcmdhd is a problem: root@bananapi:~# lsmod Module Size Used by cpufreq_userspace 3524 0 bnep 14462 2 a20_tp 3365 0 8021q 18593 0 garp 6072 1 8021q stp 2032 1 garp llc 5365 2 stp,garp sunxi_ir 4037 0 hidp 17640 0 rfcomm 58686 0 bt_gpio 2741 0 wifi_gpio 6375 1 bt_gpio hci_uart 25000 0 bluetooth 264185 12 bnep,hidp,hci_uart,rfcomm spidev 6366 0 root@bananapi:~# modprobe bcmdhd ERROR: could not insert 'bcmdhd': Operation not permitted root@bananapi:~# # /etc/modules: kernel modules to load at boot time. # # This file contains the names of kernel modules that should be loaded # at boot time, one per line. Lines beginning with "#" are ignored. # Parameters can be specified after the module name. hci_uart gpio_sunxi bt_gpio wifi_gpio rfcomm hidp sunxi-ir bonding spi_sun7i bcmdhd 8021q a20_tp Any idea? A.
Igor Posted September 3, 2015 Posted September 3, 2015 None. Leave bcmdhd with /etc/modules and please provide full boot log. Maybe we could see something odd there. Change loglevel=1 to 9 in boot.cmd too.
potz Posted September 3, 2015 Author Posted September 3, 2015 Hello Igor! That sounds not so positive. I have to prepare an UART-cable-connection to my PC to log the full boot sequence, right? Ok., I can do that. So I can save the UART-output into a txt-file. That's it? How can I change the loglevel in boot.cmd? Is it a text-file, or with a linux command? Sorry, I'm not at home and the BPro isn't here. I'm busy until tommorow evening. Thanks!A.
Igor Posted September 3, 2015 Posted September 3, 2015 Yes, just post full boot sequence. edit /boot/boot.cmd alter loglevel and console=ttyS0,115000 save and convert mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr Take your time. No rush.
potz Posted September 5, 2015 Author Posted September 5, 2015 Hello Igor! I'm back! I catured the boot log in different kinds. I think the last one (V3) is the best, because editing "console=tty1" to "console=ttyS0,115000" produced a lot of rabbish in the terminal window. So I changed the loglevel from 1 to 9. <\0><\r> <\n>U-Boot SPL 2015.07-dirty (Aug 26 2015 - 06:24:24)<\r> <\n>DRAM: 1024 MiB<\r> <\n>CPU: 912000000Hz, AXI/AHB/APB: 3/2/2<\r> <\n><\n><\r> <\n><\r> U-Boot 2015.07-dirty (Aug 26 2015 - 06:24:24 +0200) Allwinner Technology<\n><\r> <\n><\r> CPU: Allwinner A20 (SUN7I)<\n><\r> I2C: ready<\n><\r> DRAM: 1 GiB<\n><\r> MMC: SUNXI SD/MMC: 0<\n><\r> *** Warning - bad CRC, using default environment<\n><\r> <\n><\r> HDMI connected: EDID block 0: checksum error, retrying<\n><\r> EDID block 0: checksum error, retrying<\n><\r> EDID block 0: checksum error<\n><\r> Setting up a 1024x768 dvi console<\n><\r> Error: no valid bmp image at 66000000<\n><\r> In: serial<\n><\r> Out: vga<\n><\r> Err: vga<\n><\r> SCSI: SUNXI SCSI INIT<\n><\r> SATA link 0 timeout.<\n><\r> AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode<\n><\r> flags: ncq stag pm led clo only pmp pio slum part ccc apst <\n><\r> Net: eth0: ethernet@01c50000<\n><\r> starting USB...<\n><\r> USB0: USB EHCI 1.00<\n><\r> USB1: USB OHCI 1.0<\n><\r> USB2: USB EHCI 1.00<\n><\r> USB3: USB OHCI 1.0<\n><\r> scanning bus 0 for devices... 1 USB Device(s) found<\n><\r> scanning bus 2 for devices... 1 USB Device(s) found<\n><\r> scanning bus 1 for devices... 2 USB Device(s) found<\n><\r> scanning bus 3 for devices... 1 USB Device(s) found<\n><\r> Hit any key to stop autoboot: 2 <\b><\b><\b> 1 <\b><\b><\b> 0 <\n><\r> 6944 bytes read in 211 ms (31.3 KiB/s)<\n><\r> switch to partitions #0, OK<\n><\r> mmc0 is current device<\n><\r> Scanning mmc 0:1...<\n><\r> Found U-Boot script /boot/boot.scr<\n><\r> 1822 bytes read in 251 ms (6.8 KiB/s)<\n><\r> ## Executing script at 43100000<\n><\r> ** File not found /boot/.next **<\n><\r> ** Unrecognized filesystem type **<\n><\r> 50612 bytes read in 607 ms (81.1 KiB/s)<\n><\r> 5606288 bytes read in 626 ms (8.5 MiB/s)<\n><\r> Kernel image @ 0x48000000 [ 0x000000 - 0x558b90 ]<\n><\r> <\n><\r> Starting kernel ...<\n><\r> <\n><\r> <6>Booting Linux on physical CPU 0<\n><\r> <6>Initializing cgroup subsys cpuset<\n><\r> <6>Initializing cgroup subsys cpu<\n><\r> <5>Linux version 3.4.108-banana (root@kitchen) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #16 SMP PREEMPT Wed Aug 26 06:29:23 CEST 2015<\n><\r> CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d<\n><\r> CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache<\n><\r> Machine: sun7i<\n><\r> <6>Memory Reserved:<\n><\r> <6><9>SYS : 0x43000000 - 0x4300ffff ( 64 kB)<\n><\r> <6><9>LCD : 0x44000000 - 0x44ffffff ( 16 MB)<\n><\r> Memory policy: ECC disabled, Data cache writealloc<\n><\r> <6>sunxi: Allwinner A20 (AW1651/sun7i) detected.<\n><\r> <7>On node 0 totalpages: 262144<\n><\r> <7>free_area_init_node: node 0, pgdat c0a7bb40, node_mem_map d0000000<\n><\r> <7> DMA zone: 512 pages used for memmap<\n><\r> <7> DMA zone: 0 pages reserved<\n><\r> <7> DMA zone: 65024 pages, LIFO batch:15<\n><\r> <7> Normal zone: 1008 pages used for memmap<\n><\r> <7> Normal zone: 128016 pages, LIFO batch:31<\n><\r> <7> HighMem zone: 528 pages used for memmap<\n><\r> <7> HighMem zone: 67056 pages, LIFO batch:15<\n><\r> <6>PERCPU: Embedded 8 pages/cpu @d0808000 s8256 r8192 d16320 u32768<\n><\r> <7>pcpu-alloc: s8256 r8192 d16320 u32768 alloc=8*4096<c><\n><\r> <7>pcpu-alloc: <c>[0] <c>0 <c>[0] <c>1 <c><\n><\r> Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096<\n><\r> <5>Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=9<\n><\r> <6>PID hash table entries: 4096 (order: 2, 16384 bytes)<\n><\r> <6>Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)<\n><\r> <6>Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)<\n><\r> <6>allocated 2097152 bytes of page_cgroup<\n><\r> <6>please try 'cgroup_disable=memory' option if you don't want memory cgroups<\n><\r> <6>Memory: 1024MB = 1024MB total<\n><\r> <5>Memory: 1008344k/1008344k available, 40232k reserved, 270336K highmem<\n><\r> <5>Virtual kernel memory layout:<\n><\r> vector : 0xffff0000 - 0xffff1000 ( 4 kB)<\n><\r> fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)<\n><\r> vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)<\n><\r> lowmem : 0xc0000000 - 0xef800000 ( 760 MB)<\n><\r> pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)<\n><\r> modules : 0xbf000000 - 0xbfe00000 ( 14 MB)<\n><\r> .text : 0xc0008000 - 0xc09d1b30 (10023 kB)<\n><\r> .init : 0xc09d2000 - 0xc0a0b040 ( 229 kB)<\n><\r> .data : 0xc0a0c000 - 0xc0a842b8 ( 481 kB)<\n><\r> .bss : 0xc0a842dc - 0xc0c596b8 (1877 kB)<\n><\r> <6>SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1<\n><\r> <6>Preemptible hierarchical RCU implementation.<\n><\r> <6><9>RCU dyntick-idle grace-period acceleration is enabled.<\n><\r> <6><9>Additional per-CPU info printed with stalls.<\n><\r> <6>NR_IRQS:192<\n><\r> <6>Architected local timer running at 24.00MHz.<\n><\r> <6>sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms<\n><\r> <2>start_kernel(): bug: interrupts were enabled early<\n><\r> <6>Console: colour dummy device 80x30<\n><\r> <6>console [tty1] enabled<\n><\r> <6>Calibrating delay loop... <c>1819.40 BogoMIPS (lpj=3031040)<\n><\r> <6>pid_max: default: 32768 minimum: 301<\n><\r> <6>Mount-cache hash table entries: 512<\n><\r> <6>Initializing cgroup subsys cpuacct<\n><\r> <6>Initializing cgroup subsys memory<\n><\r> <6>Initializing cgroup subsys devices<\n><\r> <6>Initializing cgroup subsys freezer<\n><\r> <6>Initializing cgroup subsys blkio<\n><\r> <6>Initializing cgroup subsys perf_event<\n><\r> <6>CPU: Testing write buffer coherency: ok<\n><\r> <6>CPU0: thread -1, cpu 0, socket 0, mpidr 80000000<\n><\r> <6>hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available<\n><\r> <6>Setting up static identity map for 0x407127e0 - 0x40712838<\n><\r> CPU1: Booted secondary processor<\n><\r> <6>CPU1: thread -1, cpu 1, socket 0, mpidr 80000001<\n><\r> <6>Brought up 2 CPUs<\n><\r> <6>SMP: Total of 2 processors activated (3397.92 BogoMIPS).<\n><\r> <6>devtmpfs: initialized<\n><\r> <6>dummy: <\n><\r> <6>NET: Registered protocol family 16<\n><\r> <6>DMA: preallocated 256 KiB pool for atomic coherent allocations<\n><\r> <6>hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.<\n><\r> <6>hw-breakpoint: maximum watchpoint size is 8 bytes.<\n><\r> <6>[ccu-inf] aw clock manager init<\n><\r> <6>[ccu-inf] aw_ccu_init<\n><\r> <6>[ccu-inf] script config pll3 to 297MHz<\n><\r> <6>[ccu-inf] script config pll4 to 300MHz<\n><\r> <6>[ccu-inf] script config pll6 to 600MHz<\n><\r> <6>[ccu-inf] script config pll7 to 297MHz<\n><\r> <6>[ccu-inf] script config pll8 to 336MHz<\n><\r> <6>Init eGon pin module V2.0<\n><\r> <6>bio: create slab <bio-0> at 0<\n><\r> <6>sunxi_gpio driver init ver 1.3<\n><\r> <6>gpiochip_add: registered GPIOs 1 to 86 on device: A1X_GPIO<\n><\r> <5>SCSI subsystem initialized<\n><\r> <7>libata version 3.00 loaded.<\n><\r> <6>usbcore: registered new interface driver usbfs<\n><\r> <6>usbcore: registered new interface driver hub<\n><\r> <6>usbcore: registered new device driver usb<\n><\r> <6>Linux media interface: v0.10<\n><\r> <6>Linux video capture interface: v2.00<\n><\r> <6>Advanced Linux Sound Architecture Driver Version 1.0.25.<\n><\r> <6>Switching to clocksource arch_sys_counter<\n><\r> <6>cfg80211: Calling CRDA to update world regulatory domain<\n><\r> <5>FS-Cache: Loaded<\n><\r> <6>CacheFiles: Loaded<\n><\r> [usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG<\n><\r> WRN:L287(drivers/usb/sunxi_usb/manager/usb_manager.c):ERR: det_vbus pin is invaild<\n><\r> WRN:L426(drivers/usb/sunxi_usb/manager/usb_manager.c):ERR: check_usb_board_info failed<\n><\r> WRN:L480(drivers/usb/sunxi_usb/manager/usb_manager.c):ERR: get_usb_cfg failed<\n><\r> [sw_hcd0]: usb host driver initialize........<\n><\r> [sw_udc]: udc_init: version 20080411<\n><\r> <6>NET: Registered protocol family 2<\n><\r> <6>IP route cache hash table entries: 32768 (order: 5, 131072 bytes)<\n><\r> <6>TCP established hash table entries: 131072 (order: 8, 1048576 bytes)<\n><\r> <6>TCP bind hash table entries: 65536 (order: 7, 786432 bytes)<\n><\r> <6>TCP: Hash tables configured (established 131072 bind 65536)<\n><\r> <6>TCP: reno registered<\n><\r> <6>UDP hash table entries: 512 (order: 2, 16384 bytes)<\n><\r> <6>UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)<\n><\r> <6>NET: Registered protocol family 1<\n><\r> <6>RPC: Registered named UNIX socket transport module.<\n><\r> <6>RPC: Registered udp transport module.<\n><\r> <6>RPC: Registered tcp transport module.<\n><\r> <6>RPC: Registered tcp NFSv4.1 backchannel transport module.<\n><\r> <6>audit: initializing netlink socket (disabled)<\n><\r> <5>type=2000 audit(0.377:1): initialized<\n><\r> highmem bounce pool size: 64 pages<\n><\r> <5>VFS: Disk quotas dquot_6.5.2<\n><\r> Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)<\n><\r> <6>squashfs: version 4.0 (2009/01/31) Phillip Lougher<\n><\r> <5>NFS: Registering the id_resolver key type<\n><\r> <6>NTFS driver 2.1.30 [Flags: R/W].<\n><\r> <6>fuse init (API version 7.18)<\n><\r> <6>JFS: nTxBlock = 7877, nTxLock = 63021<\n><\r> <6>SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled<\n><\r> <6>Btrfs loaded<\n><\r> <6>msgmni has been set to 1441<\n><\r> <6>alg: No test for stdrng (krng)<\n><\r> <6>Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)<\n><\r> <6>io scheduler noop registered<\n><\r> <6>io scheduler deadline registered<\n><\r> <6>io scheduler cfq registered (default)<\n><\r> <6>sunxi disp driver loaded (/dev/disp api 1.0)<\n><\r> <6>Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled<\n><\r> <6>[uart]: used uart info.: 0x95<\n><\r> <6>[uart]: serial probe 0 irq 33 mapbase 0x01c28000<\n><\r> <6>sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a U6_16550A<\n><\r> <6>[uart]: serial probe 2 irq 35 mapbase 0x01c28800<\n><\r> <6>sunxi-uart.2: ttyS1 at MMIO 0x1c28800 (irq = 35) is a U6_16550A<\n><\r> <6>[uart]: serial probe 4 irq 49 mapbase 0x01c29000<\n><\r> <6>sunxi-uart.4: ttyS2 at MMIO 0x1c29000 (irq = 49) is a U6_16550A<\n><\r> <6>[uart]: serial probe 7 irq 52 mapbase 0x01c29c00<\n><\r> <6>sunxi-uart.7: ttyS3 at MMIO 0x1c29c00 (irq = 52) is a U6_16550A<\n><\r> <7>G2D: drv_g2d_init<\n><\r> <6>G2D: Module initialized.major:250<\n><\r> <6>brd: module loaded<\n><\r> <6>loop: module loaded<\n><\r> nand driver is disabled <\n><\r> <3>gpio count < =0 ,gpio_count is: 0<\n><\r> <6>sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP<\n><\r> <6>ahci: SSS flag set, parallel bus scan disabled<\n><\r> <6>sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode<\n><\r> <6>sw_ahci sw_ahci.0: flags: ncq sntf stag pm led clo only pio slum part ccc <\n><\r> <6>scsi0 : sw_ahci_platform<\n><\r> <6>ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88<\n><\r> <6>[spi-inf] Found 2 spi devices in config files<\n><\r> <6>[spi-inf] boards num modalias max_spd_hz bus_num cs mode<\n><\r> <6>[spi-inf] spi_board0 irq gpio not used<\n><\r> <6>[spi-inf] 0 spidev 12000000 0 0 0x3 <\n><\r> <6>[spi-inf] spi_board1 irq gpio not used<\n><\r> <6>[spi-inf] 1 spidev 12000000 0 1 0x3 <\n><\r> <6>[spi-inf] sun7i_spi_probe: spi0 dma type: normal<\n><\r> <6>[spi-inf] bus num = 0, spi used = 3 <\n><\r> <6>[spi-inf] sun7i_spi_probe: spi0 cs bitmap: 0x3<\n><\r> <6>[spi-inf] sun7i_spi_set_mclk: spi0 source = sdram_pll_p, src_clk = 432000000, mclk 108000000<\n><\r> <6>sun7i-spi sun7i-spi.0: master is unqueued, this is deprecated<\n><\r> <6>[spi-inf] sun7i_spi_probe: reuuimlla's SoC SPI Driver loaded for Bus SPI0 with 2 Slaves at most<\n><\r> <6>[spi-inf] sun7i_spi_probe: spi0 driver probe succeed, base f05cc000, irq 42, dma_id_rx 24, dma_id_tx 24<\n><\r> <6>bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)<\n><\r> <6>Fixed MDIO Bus: probed<\n><\r> <4>emac_init fetch emac using configuration failed<\n><\r> <6>emac driver is disabled<\n><\r> <4>eth%d: device MAC address 02:18:0a:41:2f:c8<\n><\r> gmac_para gpio count is 18<\n><\r> [gmac]: sun6i_gmac platform driver registration completed<\n><\r> <6>PPP generic driver version 2.4.2<\n><\r> <6>PPP BSD Compression module registered<\n><\r> <6>PPP Deflate Compression module registered<\n><\r> <6>PPP MPPE Compression module registered<\n><\r> <6>NET: Registered protocol family 24<\n><\r> <6>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver<\n><\r> <6>ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver<\n><\r> [sw-ehci1]: open clock<\n><\r> [sw-ehci1]: Set USB Power ON<\n><\r> <6>sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver<\n><\r> <6>sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 1<\n><\r> <6>sw-ehci sw-ehci.1: irq 71, io mem 0x01c14000<\n><\r> <6>sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00<\n><\r> ehci_irq: port change detect<\n><\r> <6>hub 1-0:1.0: USB hub found<\n><\r> <6>hub 1-0:1.0: 1 port detected<\n><\r> [sw-ohci1]: open clock<\n><\r> <6>sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver<\n><\r> <6>sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 2<\n><\r> <6>sw-ohci sw-ohci.1: irq 96, io mem 0x01c14400<\n><\r> <6>hub 2-0:1.0: USB hub found<\n><\r> <6>hub 2-0:1.0: 1 port detected<\n><\r> [sw-ehci2]: open clock<\n><\r> <6>ata1: SATA link down (SStatus 0 SControl 300)<\n><\r> [sw-ehci2]: Set USB Power ON<\n><\r> <6>sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver<\n><\r> <6>sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 3<\n><\r> <6>sw-ehci sw-ehci.2: irq 72, io mem 0x01c1c000<\n><\r> <6>sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00<\n><\r> <6>hub 3-0:1.0: USB hub found<\n><\r> <6>hub 3-0:1.0: 1 port detected<\n><\r> [sw-ohci2]: open clock<\n><\r> <6>sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver<\n><\r> <6>sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 4<\n><\r> <6>sw-ohci sw-ohci.2: irq 97, io mem 0x01c1c400<\n><\r> ehci_irq: port change detect<\n><\r> The port change to OHCI now!<\n><\r> <6>hub 4-0:1.0: USB hub found<\n><\r> <6>hub 4-0:1.0: 1 port detected<\n><\r> <6>Initializing USB Mass Storage driver...<\n><\r> <6>usbcore: registered new interface driver usb-storage<\n><\r> <6>USB Mass Storage support registered.<\n><\r> <6>usbcore: registered new interface driver ums-alauda<\n><\r> <6>usbcore: registered new interface driver ums-cypress<\n><\r> <6>usbcore: registered new interface driver ums-datafab<\n><\r> <6>usbcore: registered new interface driver ums_eneub6250<\n><\r> <6>usbcore: registered new interface driver ums-freecom<\n><\r> <6>usbcore: registered new interface driver ums-isd200<\n><\r> <6>usbcore: registered new interface driver ums-jumpshot<\n><\r> <6>usbcore: registered new interface driver ums-karma<\n><\r> <6>usbcore: registered new interface driver ums-onetouch<\n><\r> <6>usbcore: registered new interface driver ums-realtek<\n><\r> <6>usbcore: registered new interface driver ums-sddr09<\n><\r> <6>usbcore: registered new interface driver ums-sddr55<\n><\r> <6>usbcore: registered new interface driver ums-usbat<\n><\r> <6>mousedev: PS/2 mouse device common for all mice<\n><\r> ===========================hv_keypad_init=====================<\n><\r> ========HV Inital ===================<\n><\r> <3>tkey_fetch_sysconfig_para: tkey_unused. <\n><\r> hv_keypad_init: after fetch_sysconfig_para: normal_i2c: 0x0. normal_i2c[1]: 0x0 <\n><\r> <6>sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0<\n><\r> <6>i2c /dev entries driver<\n><\r> config i2c gpio with gpio_config api<\n><\r> <6>axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected<\n><\r> <6>axp_mfd 0-0034: AXP internal temperature monitoring enabled<\n><\r> [AXP]axp driver uning configuration failed(342)<\n><\r> [AXP]power_start = 0<\n><\r> <4>i2c i2c-0: Invalid probe address 0x00<\n><\r> <6>I2C: i2c-0: AW16XX I2C adapter<\n><\r> config i2c gpio with gpio_config api<\n><\r> <4>i2c i2c-1: Invalid probe address 0x00<\n><\r> <6>I2C: i2c-1: AW16XX I2C adapter<\n><\r> config i2c gpio with gpio_config api<\n><\r> <4>i2c i2c-2: Invalid probe address 0x00<\n><\r> <6>I2C: i2c-2: AW16XX I2C adapter<\n><\r> config i2c gpio with gpio_config api<\n><\r> <4>i2c i2c-3: Invalid probe address 0x00<\n><\r> <6>I2C: i2c-3: AW16XX I2C adapter<\n><\r> [cedar dev]: not installed! ve_mem_reserve=0<\n><\r> [tt]----- avs_dev driver load... ----<\n><\r> [tt]----- register iomem ----<\n><\r> Cannot reserve region for ccmu<\n><\r> [tt]--- avs_dev driver load ok!! -----<\n><\r> [ace_drv] start!!!<\n><\r> [ace_drv] init end!!!<\n><\r> [pa_drv] start!!!<\n><\r> [pa_drv] init end!!!<\n><\r> <6>axp20_ldo1: 1300 mV <\n><\r> <6>axp20_ldo2: 1800 <--> 3300 mV at 3000 mV <\n><\r> <6>axp20_ldo3: 700 <--> 3500 mV at 2800 mV <\n><\r> <6>axp20_ldo4: 1250 <--> 3300 mV at 2800 mV <\n><\r> <6>axp20_buck2: 700 <--> 2275 mV at 1450 mV <\n><\r> <3>somebody is trying to set dcdc3 range to (1300000, 1300000) uV<\n><\r> <3>but we keep dcdc3 = 1250000 uV from the bootloader<\n><\r> <6>axp20_buck3: 700 <--> 3500 mV at 1250 mV <\n><\r> <6>axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV <\n><\r> <6>input: axp20-supplyer as /devices/platform/sunxi-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/input0<\n><\r> <4>axp20_ldo2: Failed to create debugfs directory<\n><\r> <6>sunxi_wdt: sunxi WatchDog Timer Driver v1.0<\n><\r> <6>sunxi_wdt: initialized (timeout=23s, nowayout=0)<\n><\r> <6>usb 2-1: new low-speed USB device number 2 using sw-ohci<\n><\r> <6>device-mapper: uevent: version 1.0.3<\n><\r> <6>device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com<\n><\r> <6>device-mapper: multipath: version 1.3.2 loaded<\n><\r> <6>device-mapper: multipath round-robin: version 1.0.0 loaded<\n><\r> <6>device-mapper: multipath queue-length: version 0.1.0 loaded<\n><\r> <6>device-mapper: multipath service-time: version 0.2.0 loaded<\n><\r> <6>cpuidle: using governor ladder<\n><\r> <6>cpuidle: using governor menu<\n><\r> <6>[mmc-msg] sw_mci_init<\n><\r> <6>[mmc-msg] MMC host used card: 0x9, boot card: 0x0, io_card 8<\n><\r> <6>[mmc-msg] sdc0 set round clock 400000, src 24000000<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc0 Probe: base:0xf05f8000 irq:64 sg_cpu:f05fa000(4fc00000) ret 0.<\n><\r> <6>[mmc-msg] sdc3 set round clock 400000, src 24000000<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 Probe: base:0xf05fc000 irq:67 sg_cpu:f05fe000(4fc01000) ret 0.<\n><\r> [mmc_pm]: failed to fetch sdio card configuration!<\n><\r> <6>sunxi_leds driver init<\n><\r> <7>Registered led device: green:ph24:led1<\n><\r> <7>Registered led device: blue:pg02:led2<\n><\r> <6>ledtrig-cpu: registered to indicate activity on CPUs<\n><\r> <6>usbcore: registered new interface driver usbhid<\n><\r> <6>usbhid: USB HID core driver<\n><\r> <6>ashmem: initialized<\n><\r> <6>logger: created 256K log 'log_main'<\n><\r> <6>logger: created 256K log 'log_events'<\n><\r> <6>logger: created 256K log 'log_radio'<\n><\r> <6>logger: created 256K log 'log_system'<\n><\r> [IIS]Entered sunxi_i2s_init<\n><\r> [I2S]sunxi-i2s cannot find any using configuration for controllers, return directly!<\n><\r> [I2S]sndi2s cannot find any using configuration for controllers, return directly!<\n><\r> [IIS]Entered sunxi_sndi2s_init<\n><\r> <6>IPv4 over IPv4 tunneling driver<\n><\r> <6>TCP: bic registered<\n><\r> <6>TCP: cubic registered<\n><\r> <6>TCP: westwood registered<\n><\r> <6>TCP: highspeed registered<\n><\r> <6>TCP: hybla registered<\n><\r> <6>TCP: htcp registered<\n><\r> <6>TCP: vegas registered<\n><\r> <6>TCP: veno registered<\n><\r> <6>TCP: scalable registered<\n><\r> <6>TCP: lp registered<\n><\r> <6>TCP: yeah registered<\n><\r> <6>TCP: illinois registered<\n><\r> <6>Initializing XFRM netlink socket<\n><\r> <6>NET: Registered protocol family 10<\n><\r> <6>NET: Registered protocol family 17<\n><\r> <6>NET: Registered protocol family 15<\n><\r> [mmc_pm]: No sdio card, please check your config !!<\n><\r> <5>Registering the dns_resolver key type<\n><\r> <6>VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4<\n><\r> <5>Registering SWP/SWPB emulation handler<\n><\r> <6>input: HID 04d9:1400 as /devices/platform/sw-ohci.1/usb2/2-1/2-1:1.0/input/input1<\n><\r> <4>axp20_buck2: Failed to create debugfs directory<\n><\r> <6>generic-usb 0003:04D9:1400.0001: input,hidraw0: USB HID v1.10 Keyboard [HID 04d9:1400] on usb-sw-ohci-1/input0<\n><\r> <6>[cpu_freq] INF:-------------------V-F Table-------------------<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1450mv <9>frequency = 1008MHz<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1425mv <9>frequency = 912MHz<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1350mv <9>frequency = 864MHz<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1250mv <9>frequency = 720MHz<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1150mv <9>frequency = 528MHz<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1100mv <9>frequency = 312MHz<\n><\r> <6>input: HID 04d9:1400 as /devices/platform/sw-ohci.1/usb2/2-1/2-1:1.1/input/input2<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1050mv <9>frequency = 144MHz<\n><\r> <6>generic-usb 0003:04D9:1400.0002: input,hidraw1: USB HID v1.10 Mouse [HID 04d9:1400] on usb-sw-ohci-1/input1<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1000mv <9>frequency = 0MHz<\n><\r> <6>[cpu_freq] INF:-----------------------------------------------<\n><\r> <6>[cpu_freq] INF:sunxi_cpufreq_initcall, get cpu frequency from sysconfig, max freq: 912MHz, min freq: 720MHz<\n><\r> <6>registered taskstats version 1<\n><\r> <6>I2C: i2c-4: HDMI I2C adapter<\n><\r> <6>ParseEDID<\n><\r> <6>EDID version: 1.3<\n><\r> <6>PCLK=148500000 X 1920 2008 2052 2200 Y 1080 1084 1089 1125 fr 60 PN<\n><\r> <6>Using above mode as preferred EDID mode<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Unimplemented SVD code 2<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 53900000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 53900000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 108100000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 146850000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 118650000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 122350000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 83650000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 74600000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 78800000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 53450000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 26150000 pclk<\n><\r> <6>Parse_VideoData_Block: VIC 16 support<\n><\r> <6>Parse_VideoData_Block: VIC 31 support<\n><\r> <6>Parse_VideoData_Block: VIC 4 (native) support<\n><\r> <6>Parse_VideoData_Block: VIC 19 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 2 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_AudioData_Block: max channel=2<\n><\r> <6>Parse_AudioData_Block: SampleRate code=7<\n><\r> <6>Parse_AudioData_Block: WordLen code=7<\n><\r> <6>Find HDMI Vendor Specific DataBlock<\n><\r> <6>PCLK=27000000 X 720 736 798 858 Y 480 489 495 525 fr 59 NN<\n><\r> <6>asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok<\n><\r> <6>disp clks: lcd 148500000 pre_scale 1 hdmi 148500000 pll 297000000 2x 0<\n><\r> <6>[mmc-msg] mmc 0 detect change, present 1<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc0 power on<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc0 set round clock 400000, src 24000000<\n><\r> <3>[mmc-err] smc 0 err, cmd 52, RTO<\n><\r> <3>[mmc-err] smc 0 err, cmd 52, RTO<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 0 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 0 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 0 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 0 err, cmd 5, RTO<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B<\n><\r> <6>[mmc-msg] sdc0 set round clock 46153846, src 600000000<\n><\r> <6>Console: switching to colour frame buffer device 240x67<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B<\n><\r> <6>mmc0: new high speed SDHC card at address aaaa<\n><\r> <6>mmcblk0: mmc0:aaaa SS16G 14.8 GiB <\n><\r> <6> mmcblk0: p1<\n><\r> <4>axp20_buck3: incomplete constraints, leaving on<\n><\r> <4>axp20_buck2: incomplete constraints, leaving on<\n><\r> <4>axp20_ldo4: incomplete constraints, leaving on<\n><\r> <4>axp20_ldo3: incomplete constraints, leaving on<\n><\r> <4>axp20_ldo2: incomplete constraints, leaving on<\n><\r> <4>axp20_ldo1: incomplete constraints, leaving on<\n><\r> <6>console [netcon0] enabled<\n><\r> <6>netconsole: network logging started<\n><\r> <3>otg_wakelock_init: No USB transceiver found<\n><\r> <6>sunxi-rtc sunxi-rtc: setting system clock to 2015-09-05 09:39:47 UTC (1441445987)<\n><\r> <6>ALSA device list:<\n><\r> <6> #0: sunxi-CODEC Audio Codec<\n><\r> <6> #1: sunxi-sndhdmi<\n><\r> <6>EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)<\n><\r> <6>VFS: Mounted root (ext4 filesystem) on device 179:1.<\n><\r> <6>devtmpfs: mounted<\n><\r> <6>Freeing init memory: 228K<\n><\r> <30>udevd[186]: starting version 175<\n><\r> <6>EXT4-fs (mmcblk0p1): re-mounted. Opts: data=writeback,commit=600,errors=remount-ro<\n><\r> <6>Bluetooth: Core ver 2.16<\n><\r> <6>NET: Registered protocol family 31<\n><\r> <6>Bluetooth: HCI device and connection manager initialized<\n><\r> <6>Bluetooth: HCI socket layer initialized<\n><\r> <6>Bluetooth: L2CAP socket layer initialized<\n><\r> <6>Bluetooth: SCO socket layer initialized<\n><\r> <6>Bluetooth: HCI UART driver ver 2.2<\n><\r> <6>Bluetooth: HCI H4 protocol initialized<\n><\r> <6>Bluetooth: HCI BCSP protocol initialized<\n><\r> <6>Bluetooth: HCILL protocol initialized<\n><\r> <6>Bluetooth: HCIATH3K protocol initialized<\n><\r> <4>pm: parse wifi_used failed<\n><\r> <6>[PM] bt is disable at script fex<\n><\r> <6>Bluetooth: RFCOMM TTY layer initialized<\n><\r> <6>Bluetooth: RFCOMM socket layer initialized<\n><\r> <6>Bluetooth: RFCOMM ver 1.11<\n><\r> <6>Bluetooth: HIDP (Human Interface Emulation) ver 1.2<\n><\r> <6>input: sunxi-ir as /devices/virtual/input/input3<\n><\r> IR Initial OK<\n><\r> <6>bcmdhd: got gpio2, mapped to irqno-22<\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn on WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power on<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 set round clock 400000, src 24000000<\n><\r> =========== WLAN placed in POWER ON ========<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 8, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 1, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power off<\n><\r> <\n><\r> failed to power up wifi chip, retry again (4 left) **<\n><\r> <\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn off WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> =========== WLAN placed in POWER OFF ========<\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn on WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power on<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 set round clock 400000, src 24000000<\n><\r> =========== WLAN placed in POWER ON ========<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 8, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 1, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power off<\n><\r> <\n><\r> failed to power up wifi chip, retry again (3 left) **<\n><\r> <\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn off WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> =========== WLAN placed in POWER OFF ========<\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn on WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power on<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 set round clock 400000, src 24000000<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> =========== WLAN placed in POWER ON ========<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 8, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 1, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power off<\n><\r> <\n><\r> failed to power up wifi chip, retry again (2 left) **<\n><\r> <\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn off WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> =========== WLAN placed in POWER OFF ========<\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn on WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power on<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 set round clock 400000, src 24000000<\n><\r> =========== WLAN placed in POWER ON ========<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 8, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 1, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power off<\n><\r> <\n><\r> failed to power up wifi chip, retry again (1 left) **<\n><\r> <\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn off WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> =========== WLAN placed in POWER OFF ========<\n><\r> <\n><\r> failed to power up wifi chip, max retry reached, exits **<\n><\r> <\n><\r> <6>8021q: 802.1Q VLAN Support v1.8<\n><\r> <6>a20-tp-hwmon a20-tp-hwmon: TP initialization success<\n><\r> <6>Adding 131068k swap on /var/swap. Priority:-1 extents:4 across:172032k SS<\n><\r> GMAC gpio_power_hd:gpio_direction_output<\n><\r> <4>eth0: device MAC address 02:18:0a:41:2f:c8<\n><\r> <6>sunxi_gmac: probed<\n><\r> <6>eth0: PHY ID 001cc915 at 0 IRQ 0 (sunxi_gmac-0:00) active<\n><\r> <6>eth0: PHY ID 001cc915 at 1 IRQ 0 (sunxi_gmac-0:01)<\n><\r> <6>PHY: sunxi_gmac-0:00 - Link is Up<c> - 1000/Full<c><\n><\r> <7>eth0: no IPv6 routers present<\n><\r> <6>Bluetooth: BNEP (Ethernet Emulation) ver 1.3<\n><\r> <6>Bluetooth: BNEP filters: protocol multicast<\n><\r> <\r> <\n>Debian GNU/Linux 7 bananapi ttyS0<\r> <\n><\r> <\n>bananapi login: <6>ParseEDID<\n><\r> <6>EDID version: 1.3<\n><\r> <6>PCLK=148500000 X 1920 2008 2052 2200 Y 1080 1084 1089 1125 fr 60 PN<\n><\r> <6>Using above mode as preferred EDID mode<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Unimplemented SVD code 2<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 53900000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 53900000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 108100000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 146850000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 118650000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 122350000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 83650000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 78800000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 53450000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 26150000 pclk<\n><\r> <6>disp clks: lcd 148500000 pre_scale 1 hdmi 148500000 pll 297000000 2x 0<\n><\r> <6>Parse_VideoData_Block: VIC 16 support<\n><\r> <6>Parse_VideoData_Block: VIC 31 support<\n><\r> <6>Parse_VideoData_Block: VIC 4 (native) support<\n><\r> <6>Parse_VideoData_Block: VIC 19 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 2 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_AudioData_Block: max channel=2<\n><\r> <6>Parse_AudioData_Block: SampleRate code=7<\n><\r> <6>Parse_AudioData_Block: WordLen code=7<\n><\r> <6>Find HDMI Vendor Specific DataBlock<\n><\r> <6>PCLK=27000000 X 720 736 798 858 Y 480 489 495 525 fr 59 NN<\n><\r>
potz Posted September 5, 2015 Author Posted September 5, 2015 Sorry! It seems, I pressed a false key on the keyboard.? Ok., that's the log. The last lines can be the result of KVM-switching to the pc. Is this helpful? Thanks! A.
Igor Posted September 6, 2015 Posted September 6, 2015 I guess the problem emerge because we removed the duplicate driver (Lemaker's) from the source. Now FEX need some adaptations. I hope I do it correctly (if not there are few combinations to tests): - edit bananapro.fex and remove sections: [sdio_wifi_pro_para] [usb_wifi_para] than add this: [wifi_para] wifi_used = 1 wifi_sdc_id = 3 wifi_mod_sel = 7 wifi_power = "" ap6xxx_wl_regon = port:PH22<1><default><default><0> ap6xxx_wl_vdd_wn = port:PH27<1><default><default><0> [usb_wifi_para] usb_wifi_used = 0 usb_wifi_usbc_num = 2
potz Posted September 6, 2015 Author Posted September 6, 2015 Hi Igor! I think, it has no effect: <\r> <\n>U-Boot SPL 2015.07-dirty (Aug 26 2015 - 06:24:24)<\r> <\n>DRAM: 1024 MiB<\r> <\n>CPU: 912000000Hz, AXI/AHB/APB: 3/2/2<\r> <\n><\n><\r> <\n><\r> U-Boot 2015.07-dirty (Aug 26 2015 - 06:24:24 +0200) Allwinner Technology<\n><\r> <\n><\r> CPU: Allwinner A20 (SUN7I)<\n><\r> I2C: ready<\n><\r> DRAM: 1 GiB<\n><\r> MMC: SUNXI SD/MMC: 0<\n><\r> *** Warning - bad CRC, using default environment<\n><\r> <\n><\r> HDMI connected: EDID block 0: checksum error, retrying<\n><\r> EDID block 0: checksum error, retrying<\n><\r> EDID block 0: checksum error<\n><\r> Setting up a 1024x768 dvi console<\n><\r> Error: no valid bmp image at 66000000<\n><\r> In: serial<\n><\r> Out: vga<\n><\r> Err: vga<\n><\r> SCSI: SUNXI SCSI INIT<\n><\r> SATA link 0 timeout.<\n><\r> AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode<\n><\r> flags: ncq stag pm led clo only pmp pio slum part ccc apst <\n><\r> Net: eth0: ethernet@01c50000<\n><\r> starting USB...<\n><\r> USB0: USB EHCI 1.00<\n><\r> USB1: USB OHCI 1.0<\n><\r> USB2: USB EHCI 1.00<\n><\r> USB3: USB OHCI 1.0<\n><\r> scanning bus 0 for devices... 1 USB Device(s) found<\n><\r> scanning bus 2 for devices... 1 USB Device(s) found<\n><\r> scanning bus 1 for devices... 2 USB Device(s) found<\n><\r> scanning bus 3 for devices... 1 USB Device(s) found<\n><\r> Hit any key to stop autoboot: 2 <\b><\b><\b> 1 <\b><\b><\b> 0 <\n><\r> 6944 bytes read in 211 ms (31.3 KiB/s)<\n><\r> switch to partitions #0, OK<\n><\r> mmc0 is current device<\n><\r> Scanning mmc 0:1...<\n><\r> Found U-Boot script /boot/boot.scr<\n><\r> 1822 bytes read in 252 ms (6.8 KiB/s)<\n><\r> ## Executing script at 43100000<\n><\r> ** File not found /boot/.next **<\n><\r> ** Unrecognized filesystem type **<\n><\r> 50652 bytes read in 610 ms (81.1 KiB/s)<\n><\r> 5606288 bytes read in 627 ms (8.5 MiB/s)<\n><\r> Kernel image @ 0x48000000 [ 0x000000 - 0x558b90 ]<\n><\r> <\n><\r> Starting kernel ...<\n><\r> <\n><\r> <6>Booting Linux on physical CPU 0<\n><\r> <6>Initializing cgroup subsys cpuset<\n><\r> <6>Initializing cgroup subsys cpu<\n><\r> <5>Linux version 3.4.108-banana (root@kitchen) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #16 SMP PREEMPT Wed Aug 26 06:29:23 CEST 2015<\n><\r> CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d<\n><\r> CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache<\n><\r> Machine: sun7i<\n><\r> <6>Memory Reserved:<\n><\r> <6><9>SYS : 0x43000000 - 0x4300ffff ( 64 kB)<\n><\r> <6><9>LCD : 0x44000000 - 0x44ffffff ( 16 MB)<\n><\r> Memory policy: ECC disabled, Data cache writealloc<\n><\r> <6>sunxi: Allwinner A20 (AW1651/sun7i) detected.<\n><\r> <7>On node 0 totalpages: 262144<\n><\r> <7>free_area_init_node: node 0, pgdat c0a7bb40, node_mem_map d0000000<\n><\r> <7> DMA zone: 512 pages used for memmap<\n><\r> <7> DMA zone: 0 pages reserved<\n><\r> <7> DMA zone: 65024 pages, LIFO batch:15<\n><\r> <7> Normal zone: 1008 pages used for memmap<\n><\r> <7> Normal zone: 128016 pages, LIFO batch:31<\n><\r> <7> HighMem zone: 528 pages used for memmap<\n><\r> <7> HighMem zone: 67056 pages, LIFO batch:15<\n><\r> <6>PERCPU: Embedded 8 pages/cpu @d0808000 s8256 r8192 d16320 u32768<\n><\r> <7>pcpu-alloc: s8256 r8192 d16320 u32768 alloc=8*4096<c><\n><\r> <7>pcpu-alloc: <c>[0] <c>0 <c>[0] <c>1 <c><\n><\r> Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096<\n><\r> <5>Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=9<\n><\r> <6>PID hash table entries: 4096 (order: 2, 16384 bytes)<\n><\r> <6>Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)<\n><\r> <6>Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)<\n><\r> <6>allocated 2097152 bytes of page_cgroup<\n><\r> <6>please try 'cgroup_disable=memory' option if you don't want memory cgroups<\n><\r> <6>Memory: 1024MB = 1024MB total<\n><\r> <5>Memory: 1008344k/1008344k available, 40232k reserved, 270336K highmem<\n><\r> <5>Virtual kernel memory layout:<\n><\r> vector : 0xffff0000 - 0xffff1000 ( 4 kB)<\n><\r> fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)<\n><\r> vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)<\n><\r> lowmem : 0xc0000000 - 0xef800000 ( 760 MB)<\n><\r> pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)<\n><\r> modules : 0xbf000000 - 0xbfe00000 ( 14 MB)<\n><\r> .text : 0xc0008000 - 0xc09d1b30 (10023 kB)<\n><\r> .init : 0xc09d2000 - 0xc0a0b040 ( 229 kB)<\n><\r> .data : 0xc0a0c000 - 0xc0a842b8 ( 481 kB)<\n><\r> .bss : 0xc0a842dc - 0xc0c596b8 (1877 kB)<\n><\r> <6>SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1<\n><\r> <6>Preemptible hierarchical RCU implementation.<\n><\r> <6><9>RCU dyntick-idle grace-period acceleration is enabled.<\n><\r> <6><9>Additional per-CPU info printed with stalls.<\n><\r> <6>NR_IRQS:192<\n><\r> <6>Architected local timer running at 24.00MHz.<\n><\r> <6>sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms<\n><\r> <2>start_kernel(): bug: interrupts were enabled early<\n><\r> <6>Console: colour dummy device 80x30<\n><\r> <6>console [tty1] enabled<\n><\r> <6>Calibrating delay loop... <c>1819.40 BogoMIPS (lpj=3031040)<\n><\r> <6>pid_max: default: 32768 minimum: 301<\n><\r> <6>Mount-cache hash table entries: 512<\n><\r> <6>Initializing cgroup subsys cpuacct<\n><\r> <6>Initializing cgroup subsys memory<\n><\r> <6>Initializing cgroup subsys devices<\n><\r> <6>Initializing cgroup subsys freezer<\n><\r> <6>Initializing cgroup subsys blkio<\n><\r> <6>Initializing cgroup subsys perf_event<\n><\r> <6>CPU: Testing write buffer coherency: ok<\n><\r> <6>CPU0: thread -1, cpu 0, socket 0, mpidr 80000000<\n><\r> <6>hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available<\n><\r> <6>Setting up static identity map for 0x407127e0 - 0x40712838<\n><\r> CPU1: Booted secondary processor<\n><\r> <6>CPU1: thread -1, cpu 1, socket 0, mpidr 80000001<\n><\r> <6>Brought up 2 CPUs<\n><\r> <6>SMP: Total of 2 processors activated (3397.92 BogoMIPS).<\n><\r> <6>devtmpfs: initialized<\n><\r> <6>dummy: <\n><\r> <6>NET: Registered protocol family 16<\n><\r> <6>DMA: preallocated 256 KiB pool for atomic coherent allocations<\n><\r> <6>hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.<\n><\r> <6>hw-breakpoint: maximum watchpoint size is 8 bytes.<\n><\r> <6>[ccu-inf] aw clock manager init<\n><\r> <6>[ccu-inf] aw_ccu_init<\n><\r> <6>[ccu-inf] script config pll3 to 297MHz<\n><\r> <6>[ccu-inf] script config pll4 to 300MHz<\n><\r> <6>[ccu-inf] script config pll6 to 600MHz<\n><\r> <6>[ccu-inf] script config pll7 to 297MHz<\n><\r> <6>[ccu-inf] script config pll8 to 336MHz<\n><\r> <6>Init eGon pin module V2.0<\n><\r> <6>bio: create slab <bio-0> at 0<\n><\r> <6>sunxi_gpio driver init ver 1.3<\n><\r> <6>gpiochip_add: registered GPIOs 1 to 86 on device: A1X_GPIO<\n><\r> <5>SCSI subsystem initialized<\n><\r> <7>libata version 3.00 loaded.<\n><\r> <6>usbcore: registered new interface driver usbfs<\n><\r> <6>usbcore: registered new interface driver hub<\n><\r> <6>usbcore: registered new device driver usb<\n><\r> <6>Linux media interface: v0.10<\n><\r> <6>Linux video capture interface: v2.00<\n><\r> <6>Advanced Linux Sound Architecture Driver Version 1.0.25.<\n><\r> <6>Switching to clocksource arch_sys_counter<\n><\r> <6>cfg80211: Calling CRDA to update world regulatory domain<\n><\r> <5>FS-Cache: Loaded<\n><\r> <6>CacheFiles: Loaded<\n><\r> [usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG<\n><\r> WRN:L287(drivers/usb/sunxi_usb/manager/usb_manager.c):ERR: det_vbus pin is invaild<\n><\r> WRN:L426(drivers/usb/sunxi_usb/manager/usb_manager.c):ERR: check_usb_board_info failed<\n><\r> WRN:L480(drivers/usb/sunxi_usb/manager/usb_manager.c):ERR: get_usb_cfg failed<\n><\r> [sw_hcd0]: usb host driver initialize........<\n><\r> [sw_udc]: udc_init: version 20080411<\n><\r> <6>NET: Registered protocol family 2<\n><\r> <6>IP route cache hash table entries: 32768 (order: 5, 131072 bytes)<\n><\r> <6>TCP established hash table entries: 131072 (order: 8, 1048576 bytes)<\n><\r> <6>TCP bind hash table entries: 65536 (order: 7, 786432 bytes)<\n><\r> <6>TCP: Hash tables configured (established 131072 bind 65536)<\n><\r> <6>TCP: reno registered<\n><\r> <6>UDP hash table entries: 512 (order: 2, 16384 bytes)<\n><\r> <6>UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)<\n><\r> <6>NET: Registered protocol family 1<\n><\r> <6>RPC: Registered named UNIX socket transport module.<\n><\r> <6>RPC: Registered udp transport module.<\n><\r> <6>RPC: Registered tcp transport module.<\n><\r> <6>RPC: Registered tcp NFSv4.1 backchannel transport module.<\n><\r> <6>audit: initializing netlink socket (disabled)<\n><\r> <5>type=2000 audit(0.364:1): initialized<\n><\r> highmem bounce pool size: 64 pages<\n><\r> <5>VFS: Disk quotas dquot_6.5.2<\n><\r> Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)<\n><\r> <6>squashfs: version 4.0 (2009/01/31) Phillip Lougher<\n><\r> <5>NFS: Registering the id_resolver key type<\n><\r> <6>NTFS driver 2.1.30 [Flags: R/W].<\n><\r> <6>fuse init (API version 7.18)<\n><\r> <6>JFS: nTxBlock = 7877, nTxLock = 63021<\n><\r> <6>SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled<\n><\r> <6>Btrfs loaded<\n><\r> <6>msgmni has been set to 1441<\n><\r> <6>alg: No test for stdrng (krng)<\n><\r> <6>Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)<\n><\r> <6>io scheduler noop registered<\n><\r> <6>io scheduler deadline registered<\n><\r> <6>io scheduler cfq registered (default)<\n><\r> <6>sunxi disp driver loaded (/dev/disp api 1.0)<\n><\r> <6>Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled<\n><\r> <6>[uart]: used uart info.: 0x95<\n><\r> <6>[uart]: serial probe 0 irq 33 mapbase 0x01c28000<\n><\r> <6>sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a U6_16550A<\n><\r> <6>[uart]: serial probe 2 irq 35 mapbase 0x01c28800<\n><\r> <6>sunxi-uart.2: ttyS1 at MMIO 0x1c28800 (irq = 35) is a U6_16550A<\n><\r> <6>[uart]: serial probe 4 irq 49 mapbase 0x01c29000<\n><\r> <6>sunxi-uart.4: ttyS2 at MMIO 0x1c29000 (irq = 49) is a U6_16550A<\n><\r> <6>[uart]: serial probe 7 irq 52 mapbase 0x01c29c00<\n><\r> <6>sunxi-uart.7: ttyS3 at MMIO 0x1c29c00 (irq = 52) is a U6_16550A<\n><\r> <7>G2D: drv_g2d_init<\n><\r> <6>G2D: Module initialized.major:250<\n><\r> <6>brd: module loaded<\n><\r> <6>loop: module loaded<\n><\r> nand driver is disabled <\n><\r> <3>gpio count < =0 ,gpio_count is: 0<\n><\r> <6>sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP<\n><\r> <6>ahci: SSS flag set, parallel bus scan disabled<\n><\r> <6>sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode<\n><\r> <6>sw_ahci sw_ahci.0: flags: ncq sntf stag pm led clo only pio slum part ccc <\n><\r> <6>scsi0 : sw_ahci_platform<\n><\r> <6>ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88<\n><\r> <6>[spi-inf] Found 2 spi devices in config files<\n><\r> <6>[spi-inf] boards num modalias max_spd_hz bus_num cs mode<\n><\r> <6>[spi-inf] spi_board0 irq gpio not used<\n><\r> <6>[spi-inf] 0 spidev 12000000 0 0 0x3 <\n><\r> <6>[spi-inf] spi_board1 irq gpio not used<\n><\r> <6>[spi-inf] 1 spidev 12000000 0 1 0x3 <\n><\r> <6>[spi-inf] sun7i_spi_probe: spi0 dma type: normal<\n><\r> <6>[spi-inf] bus num = 0, spi used = 3 <\n><\r> <6>[spi-inf] sun7i_spi_probe: spi0 cs bitmap: 0x3<\n><\r> <6>[spi-inf] sun7i_spi_set_mclk: spi0 source = sdram_pll_p, src_clk = 432000000, mclk 108000000<\n><\r> <6>sun7i-spi sun7i-spi.0: master is unqueued, this is deprecated<\n><\r> <6>[spi-inf] sun7i_spi_probe: reuuimlla's SoC SPI Driver loaded for Bus SPI0 with 2 Slaves at most<\n><\r> <6>[spi-inf] sun7i_spi_probe: spi0 driver probe succeed, base f05cc000, irq 42, dma_id_rx 24, dma_id_tx 24<\n><\r> <6>bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)<\n><\r> <6>Fixed MDIO Bus: probed<\n><\r> <4>emac_init fetch emac using configuration failed<\n><\r> <6>emac driver is disabled<\n><\r> <4>eth%d: device MAC address 02:18:0a:41:2f:c8<\n><\r> gmac_para gpio count is 18<\n><\r> [gmac]: sun6i_gmac platform driver registration completed<\n><\r> <6>PPP generic driver version 2.4.2<\n><\r> <6>PPP BSD Compression module registered<\n><\r> <6>PPP Deflate Compression module registered<\n><\r> <6>PPP MPPE Compression module registered<\n><\r> <6>NET: Registered protocol family 24<\n><\r> <6>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver<\n><\r> <6>ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver<\n><\r> [sw-ehci1]: open clock<\n><\r> [sw-ehci1]: Set USB Power ON<\n><\r> <6>sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver<\n><\r> <6>sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 1<\n><\r> <6>sw-ehci sw-ehci.1: irq 71, io mem 0x01c14000<\n><\r> <6>sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00<\n><\r> ehci_irq: port change detect<\n><\r> <6>hub 1-0:1.0: USB hub found<\n><\r> <6>hub 1-0:1.0: 1 port detected<\n><\r> [sw-ohci1]: open clock<\n><\r> <6>sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver<\n><\r> <6>sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 2<\n><\r> <6>sw-ohci sw-ohci.1: irq 96, io mem 0x01c14400<\n><\r> <6>hub 2-0:1.0: USB hub found<\n><\r> <6>hub 2-0:1.0: 1 port detected<\n><\r> [sw-ehci2]: open clock<\n><\r> <6>ata1: SATA link down (SStatus 0 SControl 300)<\n><\r> [sw-ehci2]: Set USB Power ON<\n><\r> <6>sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver<\n><\r> <6>sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 3<\n><\r> <6>sw-ehci sw-ehci.2: irq 72, io mem 0x01c1c000<\n><\r> <6>sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00<\n><\r> <6>hub 3-0:1.0: USB hub found<\n><\r> <6>hub 3-0:1.0: 1 port detected<\n><\r> [sw-ohci2]: open clock<\n><\r> <6>sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver<\n><\r> <6>sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 4<\n><\r> <6>sw-ohci sw-ohci.2: irq 97, io mem 0x01c1c400<\n><\r> ehci_irq: port change detect<\n><\r> The port change to OHCI now!<\n><\r> <6>hub 4-0:1.0: USB hub found<\n><\r> <6>hub 4-0:1.0: 1 port detected<\n><\r> <6>Initializing USB Mass Storage driver...<\n><\r> <6>usbcore: registered new interface driver usb-storage<\n><\r> <6>USB Mass Storage support registered.<\n><\r> <6>usbcore: registered new interface driver ums-alauda<\n><\r> <6>usbcore: registered new interface driver ums-cypress<\n><\r> <6>usbcore: registered new interface driver ums-datafab<\n><\r> <6>usbcore: registered new interface driver ums_eneub6250<\n><\r> <6>usbcore: registered new interface driver ums-freecom<\n><\r> <6>usbcore: registered new interface driver ums-isd200<\n><\r> <6>usbcore: registered new interface driver ums-jumpshot<\n><\r> <6>usbcore: registered new interface driver ums-karma<\n><\r> <6>usbcore: registered new interface driver ums-onetouch<\n><\r> <6>usbcore: registered new interface driver ums-realtek<\n><\r> <6>usbcore: registered new interface driver ums-sddr09<\n><\r> <6>usbcore: registered new interface driver ums-sddr55<\n><\r> <6>usbcore: registered new interface driver ums-usbat<\n><\r> <6>mousedev: PS/2 mouse device common for all mice<\n><\r> ===========================hv_keypad_init=====================<\n><\r> ========HV Inital ===================<\n><\r> <3>tkey_fetch_sysconfig_para: tkey_unused. <\n><\r> hv_keypad_init: after fetch_sysconfig_para: normal_i2c: 0x0. normal_i2c[1]: 0x0 <\n><\r> <3>sunxi-rtc sunxi-rtc: Warning: RTC time is wrong!<\n><\r> <6>sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0<\n><\r> <6>i2c /dev entries driver<\n><\r> config i2c gpio with gpio_config api<\n><\r> <6>axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected<\n><\r> <6>axp_mfd 0-0034: AXP internal temperature monitoring enabled<\n><\r> [AXP]axp driver uning configuration failed(342)<\n><\r> [AXP]power_start = 0<\n><\r> <4>i2c i2c-0: Invalid probe address 0x00<\n><\r> <6>I2C: i2c-0: AW16XX I2C adapter<\n><\r> config i2c gpio with gpio_config api<\n><\r> <4>i2c i2c-1: Invalid probe address 0x00<\n><\r> <6>I2C: i2c-1: AW16XX I2C adapter<\n><\r> config i2c gpio with gpio_config api<\n><\r> <4>i2c i2c-2: Invalid probe address 0x00<\n><\r> <6>I2C: i2c-2: AW16XX I2C adapter<\n><\r> config i2c gpio with gpio_config api<\n><\r> <4>i2c i2c-3: Invalid probe address 0x00<\n><\r> <6>I2C: i2c-3: AW16XX I2C adapter<\n><\r> [cedar dev]: not installed! ve_mem_reserve=0<\n><\r> [tt]----- avs_dev driver load... ----<\n><\r> [tt]----- register iomem ----<\n><\r> Cannot reserve region for ccmu<\n><\r> [tt]--- avs_dev driver load ok!! -----<\n><\r> [ace_drv] start!!!<\n><\r> [ace_drv] init end!!!<\n><\r> [pa_drv] start!!!<\n><\r> [pa_drv] init end!!!<\n><\r> <6>axp20_ldo1: 1300 mV <\n><\r> <6>axp20_ldo2: 1800 <--> 3300 mV at 3000 mV <\n><\r> <6>axp20_ldo3: 700 <--> 3500 mV at 2800 mV <\n><\r> <6>axp20_ldo4: 1250 <--> 3300 mV at 2800 mV <\n><\r> <6>axp20_buck2: 700 <--> 2275 mV at 1450 mV <\n><\r> <3>somebody is trying to set dcdc3 range to (1300000, 1300000) uV<\n><\r> <3>but we keep dcdc3 = 1250000 uV from the bootloader<\n><\r> <6>axp20_buck3: 700 <--> 3500 mV at 1250 mV <\n><\r> <6>axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV <\n><\r> <6>input: axp20-supplyer as /devices/platform/sunxi-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/input0<\n><\r> <4>axp20_ldo2: Failed to create debugfs directory<\n><\r> <6>usb 2-1: new low-speed USB device number 2 using sw-ohci<\n><\r> <6>sunxi_wdt: sunxi WatchDog Timer Driver v1.0<\n><\r> <6>sunxi_wdt: initialized (timeout=23s, nowayout=0)<\n><\r> <6>device-mapper: uevent: version 1.0.3<\n><\r> <6>device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com<\n><\r> <6>device-mapper: multipath: version 1.3.2 loaded<\n><\r> <6>device-mapper: multipath round-robin: version 1.0.0 loaded<\n><\r> <6>device-mapper: multipath queue-length: version 0.1.0 loaded<\n><\r> <6>device-mapper: multipath service-time: version 0.2.0 loaded<\n><\r> <6>cpuidle: using governor ladder<\n><\r> <6>cpuidle: using governor menu<\n><\r> <6>[mmc-msg] sw_mci_init<\n><\r> <6>[mmc-msg] MMC host used card: 0x9, boot card: 0x0, io_card 8<\n><\r> <6>[mmc-msg] sdc0 set round clock 400000, src 24000000<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc0 Probe: base:0xf05f8000 irq:64 sg_cpu:f05fa000(4fc00000) ret 0.<\n><\r> <6>[mmc-msg] sdc3 set round clock 400000, src 24000000<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 Probe: base:0xf05fc000 irq:67 sg_cpu:f05fe000(4fc01000) ret 0.<\n><\r> [mmc_pm]: failed to fetch sdio card configuration!<\n><\r> <6>sunxi_leds driver init<\n><\r> <7>Registered led device: green:ph24:led1<\n><\r> <7>Registered led device: blue:pg02:led2<\n><\r> <6>ledtrig-cpu: registered to indicate activity on CPUs<\n><\r> <6>usbcore: registered new interface driver usbhid<\n><\r> <6>usbhid: USB HID core driver<\n><\r> <6>ashmem: initialized<\n><\r> <6>logger: created 256K log 'log_main'<\n><\r> <6>logger: created 256K log 'log_events'<\n><\r> <6>logger: created 256K log 'log_radio'<\n><\r> <6>logger: created 256K log 'log_system'<\n><\r> [IIS]Entered sunxi_i2s_init<\n><\r> [I2S]sunxi-i2s cannot find any using configuration for controllers, return directly!<\n><\r> [I2S]sndi2s cannot find any using configuration for controllers, return directly!<\n><\r> [IIS]Entered sunxi_sndi2s_init<\n><\r> <6>IPv4 over IPv4 tunneling driver<\n><\r> <6>TCP: bic registered<\n><\r> <6>TCP: cubic registered<\n><\r> <6>TCP: westwood registered<\n><\r> <6>TCP: highspeed registered<\n><\r> <6>TCP: hybla registered<\n><\r> <6>TCP: htcp registered<\n><\r> <6>TCP: vegas registered<\n><\r> <6>TCP: veno registered<\n><\r> <6>TCP: scalable registered<\n><\r> <6>TCP: lp registered<\n><\r> <6>TCP: yeah registered<\n><\r> <6>TCP: illinois registered<\n><\r> <6>Initializing XFRM netlink socket<\n><\r> <6>NET: Registered protocol family 10<\n><\r> <6>NET: Registered protocol family 17<\n><\r> <6>NET: Registered protocol family 15<\n><\r> [mmc_pm]: No sdio card, please check your config !!<\n><\r> <6>input: HID 04d9:1400 as /devices/platform/sw-ohci.1/usb2/2-1/2-1:1.0/input/input1<\n><\r> <5>Registering the dns_resolver key type<\n><\r> <6>generic-usb 0003:04D9:1400.0001: input,hidraw0: USB HID v1.10 Keyboard [HID 04d9:1400] on usb-sw-ohci-1/input0<\n><\r> <6>VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4<\n><\r> <5>Registering SWP/SWPB emulation handler<\n><\r> <4>axp20_buck2: Failed to create debugfs directory<\n><\r> <6>[cpu_freq] INF:-------------------V-F Table-------------------<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1450mv <9>frequency = 1008MHz<\n><\r> <6>input: HID 04d9:1400 as /devices/platform/sw-ohci.1/usb2/2-1/2-1:1.1/input/input2<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1425mv <9>frequency = 912MHz<\n><\r> <6>generic-usb 0003:04D9:1400.0002: input,hidraw1: USB HID v1.10 Mouse [HID 04d9:1400] on usb-sw-ohci-1/input1<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1350mv <9>frequency = 864MHz<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1250mv <9>frequency = 720MHz<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1150mv <9>frequency = 528MHz<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1100mv <9>frequency = 312MHz<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1050mv <9>frequency = 144MHz<\n><\r> <6>[cpu_freq] INF:<9>voltage = 1000mv <9>frequency = 0MHz<\n><\r> <6>[cpu_freq] INF:-----------------------------------------------<\n><\r> <6>[cpu_freq] INF:sunxi_cpufreq_initcall, get cpu frequency from sysconfig, max freq: 912MHz, min freq: 720MHz<\n><\r> <6>registered taskstats version 1<\n><\r> <6>I2C: i2c-4: HDMI I2C adapter<\n><\r> <6>ParseEDID<\n><\r> <6>EDID version: 1.3<\n><\r> <6>PCLK=148500000 X 1920 2008 2052 2200 Y 1080 1084 1089 1125 fr 60 PN<\n><\r> <6>Using above mode as preferred EDID mode<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Unimplemented SVD code 2<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>Reserved SVD code 0<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 53900000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 53900000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 108100000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 146850000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 118650000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 122350000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 83650000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 74600000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 78800000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 53450000 pclk<\n><\r> <4>disp_clk: Could not find a matching pll-freq for 26150000 pclk<\n><\r> <6>Parse_VideoData_Block: VIC 16 support<\n><\r> <6>Parse_VideoData_Block: VIC 31 support<\n><\r> <6>Parse_VideoData_Block: VIC 4 (native) support<\n><\r> <6>Parse_VideoData_Block: VIC 19 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 2 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_VideoData_Block: VIC 0 support<\n><\r> <6>Parse_AudioData_Block: max channel=2<\n><\r> <6>Parse_AudioData_Block: SampleRate code=7<\n><\r> <6>Parse_AudioData_Block: WordLen code=7<\n><\r> <6>Find HDMI Vendor Specific DataBlock<\n><\r> <6>PCLK=27000000 X 720 736 798 858 Y 480 489 495 525 fr 59 NN<\n><\r> <6>asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok<\n><\r> <6>disp clks: lcd 148500000 pre_scale 1 hdmi 148500000 pll 297000000 2x 0<\n><\r> <6>[mmc-msg] mmc 0 detect change, present 1<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc0 power on<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc0 set round clock 400000, src 24000000<\n><\r> <3>[mmc-err] smc 0 err, cmd 52, RTO<\n><\r> <3>[mmc-err] smc 0 err, cmd 52, RTO<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 0 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 0 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 0 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 0 err, cmd 5, RTO<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B<\n><\r> <6>[mmc-msg] sdc0 set round clock 46153846, src 600000000<\n><\r> <6>Console: switching to colour frame buffer device 240x67<\n><\r> <6>[mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B<\n><\r> <6>mmc0: new high speed SDHC card at address aaaa<\n><\r> <6>mmcblk0: mmc0:aaaa SS16G 14.8 GiB <\n><\r> <6> mmcblk0: p1<\n><\r> <4>axp20_buck3: incomplete constraints, leaving on<\n><\r> <4>axp20_buck2: incomplete constraints, leaving on<\n><\r> <4>axp20_ldo4: incomplete constraints, leaving on<\n><\r> <4>axp20_ldo3: incomplete constraints, leaving on<\n><\r> <4>axp20_ldo2: incomplete constraints, leaving on<\n><\r> <4>axp20_ldo1: incomplete constraints, leaving on<\n><\r> <6>console [netcon0] enabled<\n><\r> <6>netconsole: network logging started<\n><\r> <3>otg_wakelock_init: No USB transceiver found<\n><\r> <6>sunxi-rtc sunxi-rtc: setting system clock to 2010-01-01 00:00:00 UTC (1262304000)<\n><\r> <6>ALSA device list:<\n><\r> <6> #0: sunxi-CODEC Audio Codec<\n><\r> <6> #1: sunxi-sndhdmi<\n><\r> <6>EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)<\n><\r> <6>VFS: Mounted root (ext4 filesystem) on device 179:1.<\n><\r> <6>devtmpfs: mounted<\n><\r> <6>Freeing init memory: 228K<\n><\r> <30>udevd[187]: starting version 175<\n><\r> <6>EXT4-fs (mmcblk0p1): re-mounted. Opts: data=writeback,commit=600,errors=remount-ro<\n><\r> <6>Bluetooth: Core ver 2.16<\n><\r> <6>NET: Registered protocol family 31<\n><\r> <6>Bluetooth: HCI device and connection manager initialized<\n><\r> <6>Bluetooth: HCI socket layer initialized<\n><\r> <6>Bluetooth: L2CAP socket layer initialized<\n><\r> <6>Bluetooth: SCO socket layer initialized<\n><\r> <6>Bluetooth: HCI UART driver ver 2.2<\n><\r> <6>Bluetooth: HCI H4 protocol initialized<\n><\r> <6>Bluetooth: HCI BCSP protocol initialized<\n><\r> <6>Bluetooth: HCILL protocol initialized<\n><\r> <6>Bluetooth: HCIATH3K protocol initialized<\n><\r> <4>pm: parse wifi_sdc_id failed<\n><\r> <4>wifi_pm: Unsupported wifi type!<\n><\r> [wifi_pm]: wifi gpio init is OK !!<\n><\r> <6>[PM] bt is disable at script fex<\n><\r> <6>Bluetooth: RFCOMM TTY layer initialized<\n><\r> <6>Bluetooth: RFCOMM socket layer initialized<\n><\r> <6>Bluetooth: RFCOMM ver 1.11<\n><\r> <6>Bluetooth: HIDP (Human Interface Emulation) ver 1.2<\n><\r> <6>input: sunxi-ir as /devices/virtual/input/input3<\n><\r> IR Initial OK<\n><\r> <6>bcmdhd: got gpio2, mapped to irqno-22<\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn on WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power on<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 set round clock 400000, src 24000000<\n><\r> =========== WLAN placed in POWER ON ========<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 8, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 1, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power off<\n><\r> <\n><\r> failed to power up wifi chip, retry again (4 left) **<\n><\r> <\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn off WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> =========== WLAN placed in POWER OFF ========<\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn on WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power on<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 set round clock 400000, src 24000000<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> =========== WLAN placed in POWER ON ========<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 8, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 1, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power off<\n><\r> <\n><\r> failed to power up wifi chip, retry again (3 left) **<\n><\r> <\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn off WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> =========== WLAN placed in POWER OFF ========<\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn on WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power on<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 set round clock 400000, src 24000000<\n><\r> =========== WLAN placed in POWER ON ========<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 8, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 1, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power off<\n><\r> <\n><\r> failed to power up wifi chip, retry again (2 left) **<\n><\r> <\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn off WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> =========== WLAN placed in POWER OFF ========<\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn on WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power on<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 set round clock 400000, src 24000000<\n><\r> =========== WLAN placed in POWER ON ========<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 52, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 8, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 5, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <3>[mmc-err] smc 3 err, cmd 55, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <3>[mmc-err] smc 3 err, cmd 1, RTO<\n><\r> <6>[mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B<\n><\r> <6>[mmc-msg] sdc3 power off<\n><\r> <\n><\r> failed to power up wifi chip, retry again (1 left) **<\n><\r> <\n><\r> dhd_customer_gpio_wlan_ctrl: call customer specific GPIO to turn off WL_REG_ON<\n><\r> [wifi_pm]: No select wifi, please check your config !!<\n><\r> =========== WLAN placed in POWER OFF ========<\n><\r> <\n><\r> failed to power up wifi chip, max retry reached, exits **<\n><\r> <\n><\r> <6>8021q: 802.1Q VLAN Support v1.8<\n><\r> <6>a20-tp-hwmon a20-tp-hwmon: TP initialization success<\n><\r> <6>Adding 131068k swap on /var/swap. Priority:-1 extents:4 across:172032k SS<\n><\r> GMAC gpio_power_hd:gpio_direction_output<\n><\r> <4>eth0: device MAC address 02:18:0a:41:2f:c8<\n><\r> <6>sunxi_gmac: probed<\n><\r> <6>eth0: PHY ID 001cc915 at 0 IRQ 0 (sunxi_gmac-0:00) active<\n><\r> <6>eth0: PHY ID 001cc915 at 1 IRQ 0 (sunxi_gmac-0:01)<\n><\r> <6>PHY: sunxi_gmac-0:00 - Link is Up<c> - 1000/Full<c><\n><\r> <7>eth0: no IPv6 routers present<\n><\r> <6>Bluetooth: BNEP (Ethernet Emulation) ver 1.3<\n><\r> <6>Bluetooth: BNEP filters: protocol multicast<\n><\r> <\r> <\n>Debian GNU/Linux 7 bananapi ttyS0<\r> <\n><\r> <\n>bananapi login: No Wifi. What's next? A.
Igor Posted September 6, 2015 Posted September 6, 2015 Hard step: we need to double check GPIO numbers and get this done trough FEX configuration. It should work but I don't know why it's not working. Easy step: add apxxx driver back to source and recompile the kernel. Necessary step: try wifi with some other / stock / older image that we can rule out hardware defects.
