I own several SPI touch displays, and I would like to use them with armbian.
I got the displays to work already, but I'm now trying to get the touchpanels to work also.
I'm using Debian Jessie Server Legacy 5.20 with a BananaPro board.
I tried to add the module to /etc/modules :
ads7846_device gpio_pendown=17 cs=1 x_plate_ohms=400 pressure_max=255 swap_xy=0
ads7846
... does not work, I don't even see an error in dmesg.
I also tried to put the options in a /etc/modprobe.d/ads7846.conf, /etc/modprobe.d/ads7846_device.conf and /etc/modprobe.d/fbtft_device.conf but nothing works.
Manual modprobe :
modprobe ads7846
loads fine (I could see it in lsmod), but
modprobe ads7846_device gpio_pendown=17 cs=1 x_plate_ohms=400 pressure_max=255 swap_xy=0
returns modprobe: FATAL: Module ads7846_device not found.
Do you have an idea ?
Thank you !
