Help fail integrity check
Go to solution Solved by schwar3kat,
I tried to execute `sudo armbianmonitor -v` and I got this result.
Starting package integrity check. This might take some time. Be patient please...
It appears you may have corrupt packages.
This is usually a symptom of filesystem corruption caused by SD cards or eMMC
dying or burning the OS image to the installation media went wrong.
The following changes from packaged state files were detected:
/usr/lib/chromium-browser/master_preferences.dpkg-dist
This is from new orangepi pc board and new SD Card with new install OS.
On 6/30/2022 at 10:55 AM, schwar3kat said:
If you downloaded an Armbian image, did you do an integrity check?
https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-integrity
Did you verify the image when you flashed it to the SD?
https://docs.armbian.com/User-Guide_Basic-Troubleshooting/#writing-images-to-the-sd-card
Yes I did integrity check, and verify the flashed image, I used Balena Etcher.
Also tried with multiple SD Card and flashed multiple times with same result.
On first boot without updating the system I will got this
root@orangepipc:~# armbianmonitor -v
/usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf
Then after updating the system, I will got this
I was able to replicate your issue or a similar issue.  @LucasM
I suspect that this might be a build package list issue, rather than a cause for concern.  I will alert the maintainer.
I downloaded Armbian_22.05.3_Orangepipc_jammy_current_5.15.48_xfce_desktop.img, installed it on a 16GB Kioxia SD card and booted on a borrowed OrangePi PC.
You haven't indicated which image you are using.
There are 6 variant's available from the download page, and any number can be built on the build framework.
Regards K
/usr/share/applications/vim.desktop
/usr/share/applications/libreoffice-startcenter.desktop
I use this Armbian_22.05.3_Orangepipc_jammy_current_5.15.48.img.xz cli only
  • Solution
Thanks.  I have tagged the maintainer and let the team know.
Besides the warning, do you have any other issues?
