Why not boot with rpi-7inch-lcd overlay? (enabled from armbian-config)
(only rockpi-4a tag available..)
After enabled `rpi-7inch-lcd` overlay, rockpi-4-b-plus doesnt boot, no display, no ip.
Before reboot:
root@rockpi-4c:/home/qnet# cat /boot/armbianEnv.txt
verbosity=1
bootlogo=true
overlay_prefix=rockchip
fdtfile=rockchip/rk3399-rock-pi-4b.dtb
rootdev=UUID=072c27ac-4335-4062-9b8d-a9d0a71d6c3a
rootfstype=ext4
overlays=rpi-7inch-lcd
root@rockpi-4c:/home/qnet# sudo reboot
Thank you!
What i read from uart with ch340 and ch341:
▒▒▒{▒▒▒▒▒▒▒▒▒▒▒{▒▒▒▒▒▒▒▒{▒▒▒▒ݫ▒▒▒▒▒▒▒▒▒▒wݫ▒▒▒▒▒▒u▒▒▒▒w▒▒}▒▒▒▒▒▒▒▒▒▒▒뫫W▒▒w▒▒▒▒▒▒▒▒▒▒▒▒▒▒u▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒o▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒w▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒u▒▒▒▒▒W߫▒▒▒▒▒▒▒u▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒u▒▒▒▒▒{▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒{▒▒▒▒▒u▒_▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒w▒▒▒{▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒{_▒▒_▒▒▒▒▒u▒▒▒▒W▒▒W▒▒▒▒w▒▒▒▒W▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒{▒_▒▒o▒▒▒▒▒߷▒▒u▒u▒▒▒▒߫▒▒▒▒{▒▒W▒▒▒▒▒▒w▒▒▒▒▒▒}▒▒▒▒▒▒▒▒▒▒۷▒▒▒▒▒▒▒▒▒▒▒▒▒W▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒u▒۫▒_▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒w▒▒▒▒▒▒▒▒▒▒▒▒
Yes, if RX-TX replaced, same result.
Same result linux or windows.
Refs: https://wiki.radxa.com/Rockpi4/dev/serial-console
Update:
▒▒S =▒▒▒▒ynneo▒0
▒MR4▒▒|3▒▒MR▒▒>x6▒▒MR▒=0x▒▒▒
                            ▒Z12=▒~72▒▒MR▒6=0|▒:
MR1<▒?x0▒▒MR▒==0x▒▒
▒MR0=<|19▒▒MR6=<x3▒▒Mz5=0x6▒▒mR<=0~9<=<~<▒▒MR24=<|<▒▒MR25=<|FF▒▒clynnel▒<▒tryining<xyss1▒▒clqnnel▒1▒trqining▒|yss1▒▒clqnge▒frey▒to▒4<<MLz▒<,1▒▒clannel <▒▒cS8=▒<
▒MR9>=8x<▒▒MR19=8~<▒
                    MR24=<|8▒▒MR25=8|fF▒▒c~ynnen▒1
▒S>= ▒▒▒MZ>=0x▒=
▒MR96=<x7:▒MZ92=<~72
▒MR19=>x8▒▒MR:4=0~?▒
                    ▒Z25=▒~FF▒▒chyonel▒▒▒trq}oingyss▒▒▒chyooel8▒▒traioing}ss▒▒▒chyoge uq to▒808▒▒z 1▒▒
s~}nnen▒<: dDR6▒<00M▒z
Bu{>Widvn=32▒sol=9<▒rynk=<▒Row=96▒cS=1▒die<rus-Widtl=96▒Size=2<4<Mr▒▒cnynnel▒9:<N\ddR4,><<Mlz▒▒rus▒Widtl=32▒col=9<▒rynk=<▒Row=96▒cS=9▒die▒rus-Widtl=96▒Size=2<4<Mr▒▒256r▒strife▒▒cl▒<▒ddrconfig▒=▒<|9<9,▒ddrsize▒=▒<|4<▒▒cl▒9▒ddrconfig▒=▒<|9<9,▒ddrsize▒=▒<|4<▒▒|mugrf_os_reg[2]▒=▒<|32c1F2c9,▒stride▒=▒<|d▒▒OUT▒▒boov1:02>▒9-03-96.<vers}on: 1▒▒9
▒ipTe0=▒90,▒▒▒9
SdmmcInit=2 0▒▒rootCy~Size=9><<00▒▒UserCq~Size=296<<MB▒▒FwPyztOffsev=2808▒.▒1808▒>▒▒mmc<▒{md5,2▒▒▒SdmmcInit=>▒>▒▒rootsy~Size=>͊Usersy|Size=29<32Mr▒▒fw^qrtOffset=2>>>▒.▒>▒▒Svorqgeinit<ok▒=<6797>͊SesureMode▒=▒<▒▒SesureIniv▒reqv▒^rq:<>~6͊SecureInit▒reyd8^z▒:<8x6▒?▒
                             Secuz}mnit▒zu}d Pr▒8x8<▒▒▒Securu▒nit0ru}f0PB▒▒>xc86▒▒SecuInituyd P▒▒?>0x1▒▒▒▒
        SecureInit▒reyd<\ry:▒<|96<4▒▒SesureIniv▒reqd▒^ry:<8|9>>4▒▒SecureInit<reyd▒\by:▒>|9c<6▒▒SecureInit▒ret▒=▒>,▒SecureMode▒=▒<▒▒qtygs_set_rootdev:▒ret:,<)▒▒G\T▒<|33<<ec<▒signqture▒is▒wrong▒▒recovery▒g|t...▒▒G\T▒<|33<<ec<▒signyture▒is▒wrong▒▒recovery<g|v<fail▒͊LoadVrust0qvfr:0x4><<
No▒find bl3<.bin▒▒No▒finf▒rl32.rin▒▒Loyd▒uroot,▒ReydLry▒=▒2><>▒▒Noqd<OK.▒yddr=<|2<<<><,▒size=<|ce3e4▒▒RuN318?>008▒▒▒NOT▒▒E: ▒▒▒31:8v▒/3(dezug):4:▒?3b6▒▒OOTIc▒0BL▒▒?<Bui>: 8▒▒55:13▒▒Oct▒▒▒▒2019▒▒NOTI▒▒:0 bn▒=: Ro{kchixuleasu▒vers}on: v▒▒▒
▒▒FO:8▒▒▒GICv▒▒witl▒ougacy▒{uppo>dete{ved.▒▒ZM0GI▒V38driver<iniviqlizef<in▒eL3▒▒INfO:<8▒▒Using▒o|teev▒sec8s|u_conve|t1▒▒INfO:▒▒▒▒roov▒c|u8mysk:<<▒▒INFO:▒▒▒▒If▒l|ddr4▒need▒su|xorv<multi<frequensy,
INfO:8 <▒~lease▒u|date▒loader9
▒INFO:▒▒<8plyt_rockslip_|mu_iniv.9190):▒|d s~ytus03e▒▒INfO:▒< 8▒N31: Initialmzing0runtime▒servises▒
        WqRNINg:<No▒O\TEE0~zovide~▒ry bN2▒boot▒loadez.<booting8device0wivlout▒O\TEE8initializqtion.<SMC~s▒destined0for<O\Tee>will▒return<SM▒▒oFO:▒▒▒▒BL3▒▒▒\re|ing8fo{<EL3▒u~it▒~o▒norm}o<wor▒veed_wyst
▒▒OFO:8▒▒▒SXSR▒=<0x3s=▒                            IN▒▒:<  ▒▒ovry▒~omnt yress▒=▒8x2>▒><0
▒\MIc:▒▒RK<<<▒▒▒MM▒8 mmc|fe39><80:▒2.<mmc|fe3200<>:<1,8svlci@fe33<800:▒<▒<+>9><)▒▒▒▒Soc:8Rockcli~▒rk3399▒▒Resev▒cquse:▒\OR▒▒Model:<Ryd|q<ROsK▒^i▒4c▒▒dRyM:▒<3.9▒gib
        Loadmng<Envmronmen~▒from▒S\IFlasn... SF:▒detected<\T25F32b▒witl<|yge▒size▒256<bytes,<erqse▒size▒4▒Kir.▒totqn▒6▒Mir▒▒***▒Wyrning<-▒ryd▒cRc,▒using▒defqult▒environment▒▒▒▒In:▒▒▒>seriyl▒
                         Ouv:▒<8seziyl
▒Model:▒zyf|a ROcK<Pi▒>c▒▒▒et: ▒▒etl>:▒etlernet|fe3<<<<<▒▒Liv▒yny▒key▒vo▒svo~▒yuvoroov:▒▒>▒▒▒swivcl8to▒~yrtitions8#8.▒OK
mms9<is▒surrentevice▒▒Ssynning▒mms▒9:9...▒▒Found<U-root<scri|t▒/root/roov.scr▒▒39<5▒rytes▒reqd▒in▒6▒ms▒,517.6▒Kir/s)▒▒#3▒e~ecuving▒ssri~v▒yt▒>>5<><>>▒▒roov▒scri|v▒noydev▒from▒mms<9▒▒2>4▒zyves▒reyf▒in▒6▒ms▒.33.2▒Kir/s)▒▒<44<766<bytus▒read▒in<369▒ms<(29/<▒MiB/s)▒▒29626>4<▒ryves▒reyf▒in▒922▒ms▒.22.4▒Mir/s)▒▒93659▒rytes▒zeqd▒in▒99▒ms▒▒6.7▒Mir/s)▒▒269<▒ryves▒reyf▒in▒99▒ms▒,239.3▒Kir/s)▒▒y~~nying▒kernel▒~rovided▒fV▒fi|u~▒scri~v▒.rocksni|-fi~u|.scr)▒▒3#▒e|ecuting▒scri|t▒yt▒>9<<<<<<▒ʳ▒Loadmng<ini~▒Ramdisk>from▒oegacy▒▒mage▒>060▒▒▒>0 .▒▒▒  0▒m}ge Nymu:  8u▒oitrd▒▒▒< Im}wu<Tyxu▒▒< Aqz64 Lmou| Rq▒▒msk Im}ge (gz}~8comessed▒▒▒8  vy8Sizu▒>   >▒▒>702▒▒}ves0=▒▒.1 Mi▒▒  0No}f0Advzuss:0<▒▒>00<>▒▒< 0envry8Xoint:<<<><<<<<<▒ʾ<<Verifying▒clecksum▒...▒OK▒▒##▒flyvvenef▒fevise▒Tree▒rnor▒yt▒>9f>><<>▒ʾ▒<rooving▒using<vle▒fft▒rnoz▒qv▒>~9f<><>>▒ʼ▒▒Noyding▒Rymdisk<vo▒f97<e<>>.▒end▒f9f1cyre▒...▒OK▒▒eRROR:▒reserving<fdt▒memory<region<fain▒▒▒<Loadmng8Dev}{e8Treu▒vo 0<▒▒?<00f▒▒?e00<▒▒end <▒▒?800<w▒78dffw▒... OK▒▒▒▒[vartinw>kernuo>...▒▒▒▒▒▒Armqn 2▒▒?2.1▒▒}{ter▒}S2 ▒▒▒▒rosk~i-6s▒nogin:▒▒?▒▒▒▒▒▒▒▒▒▒▒▒fdR▒Version▒9.2>▒2<99>394▒▒In▒▒clannel88▒▒cS0=▒<
MR0=>|19▒▒MR6=<x3▒▒Mz5=0x6͊MR<=0~1<
▒MR9>=<x<▒▒MR99=8~>▒
▒▒S =▒▒▒            MR24=<|8▒▒MR25=8|fF▒▒qnnuo▒1
▒MR4▒▒~3▒▒MR5▒>x6▒▒MR▒=<x9▒▒
                            mZ12=72▒▒MR96=0x7:▒
                                               MR1<=>|0▒▒MR9==0x▒▒▒24=>
MR25▒?xFf▒▒cn}nnel▒?8tr}}ning▒~ass▒▒
                                    cl}onel▒▒<tr}}ning▒~ass▒▒cn}nge▒eq0vo>40▒▒nz ▒▒9
cnynnel▒<▒▒sS▒=▒<▒▒MR<=<|99▒▒MR4=<|3▒▒MR5=<|6▒▒MR<=<|9<▒▒MR92=<|72▒▒MR94=<|72▒▒MR1<=>|<▒▒MR99=>|<▒▒MR26=>~<▒▒MR25=>|ff▒▒slynnen▒9▒▒cS▒=▒>▒▒MR>=>~19▒▒MR6=<|3▒▒MR5=<~6▒▒MR>=>|9>▒▒MR92=>|72▒▒MR94=<~72▒▒MR9>=>|<▒▒MR99=<|>͊MR24=>~8▒▒MR25=<|ff͊snynnen▒<8vryining▒|qss▒▒▒snynnen▒9<tryining▒|qss▒▒▒snynge▒freq▒vo<<>>MLz▒9.<▒▒snqnnen<<:▒N\DdZ6.<<>Mnz▒▒rus<Wifvl=32▒con=9<▒rqnk=<<Row=16▒sS=9▒vie▒rus-Wivtl==6<Sizu=2<▒?MB▒▒ynneo▒1:▒▒_DDR▒▒80<▒▒z
Bu{>W=32▒sol=▒> Bynk=8▒{ow=96>CS==<Diu▒rus-Widtl=96 Smze=2▒68Mr▒▒256▒▒stri~u▒
▒{n 1frcongig▒▒▒<x1▒=, dvzsize▒=80|▒>                                        ch0▒▒ddrsonfig▒=80|▒>1rsiz}>= 60
~mugrf_os_reg[2]▒=▒<|32c1F2s9,▒svride<=▒<|d▒▒OUT▒▒ro1: 2▒▒=-03-▒▒.8ver{}on:09▒▒9
▒SdmmcInit=2▒<▒▒roovsy~Size=9<<<<>▒▒Usersy~Size=296<<Mr▒▒Fw^yrtOffsev=2<>>▒.<9<<>>>▒▒mms▒:cmd5▒▒>
SdmmsInit=<▒>▒
              BoovcqxSize=<
UsercapSmze=29<32Mb
▒StorqgeInmv▒ok =▒6><82▒▒Securemofe8=▒▒▒▒SecuzeInit▒zeyd8Pr▒:▒<x4▒▒SecureInit<reyd<Xby:<<x4<6▒▒▒ucure▒o}v re▒^BA:▒>04▒▒SesuzeIniv▒read▒~▒y:08~s▒6
▒SecuzuInit▒{uyd X▒▒;>0x16▒6▒
                             SesureInit▒reyf▒\rq:▒>|9><6▒▒SecureInit▒reyd▒\ry:▒>|9c<4▒▒SesureIniv▒ret▒=▒>.▒SesureMofe▒=▒>▒▒yvygs_sev_roovdev:▒rev:,<)▒▒G^T▒>~33<>es<▒signyture▒is▒wrong▒▒recovery▒g|t...▒▒G^V▒<|33<<ec<▒signyture▒is▒w▒▒NO^iCE:▒▒zN31:▒v9.3(fuzug):6:5<3b6▒▒NOTi▒e:0 rn▒9: Bumot :▒▒7:55:9▒.<Ocv▒=5 2<▒▒▒▒▒Loyv▒uroot.▒ReqdLry▒=<2<>>▒▒Loyf▒OK.▒yfdr=<|2>><<<,▒size=>~ce3e4▒▒Run▒▒980x6▒▒>0
▒INfO:▒▒▒▒Using▒o|teef▒sec▒s|u_conve|t▒▒▒INFO:▒▒▒▒root▒s|u▒mysk:▒<▒▒INfO:▒▒▒▒If▒l|ffr4▒neef▒su||orv▒munti▒freyuency,▒▒INFO:▒▒▒▒~leyse▒u|dyte▒loyder▒▒▒INfO:▒▒▒▒surrenv▒ctn▒inve|[>]▒frey=6><MLz▒▒iNFO:▒▒▒▒curzent▒cvn▒inde~[9]▒frey=>>>Mnz▒▒iNFO:▒▒▒<|lyv_rosksni|_|mu_init,999<):▒~f▒styvus▒3e▒▒INfO:▒▒▒▒rN39:▒Iniviqlizing▒runvime▒servises▒
        WyRNINg:▒No▒O^VeE8~rovidef▒ry<bN2▒root▒noqdez.▒rooving<devise<wivnout▒O^VEE▒iniviqnizytion.▒SMc|s▒vestinef8for▒O\Tee▒will▒revurn▒SMc_UNK▒▒ERROR:<<▒error<iniviqlizing<runvime▒servise<o~veed_fyst▒▒iNfO:<▒▒▒rL31:▒^re|yring8foz>EL3▒u~it to▒normyo▒worn~͊INF▒8  ▒ry xo}ot avess▒▒▒>x28▒▒?<
▒~▒IC: ▒z▒?<8 ▒▒MMs:▒<8mmc|fe39<<<>:▒2,<mmc|fe32<<<<:▒9,<sflci|fe33<<<<:▒<▒▒Loqding▒environment▒from<S^Ifnysl...▒SF:▒▒uvecte~▒^T25滿r wi▒~age▒{}ze 25▒▒bytes▒▒erasu▒{ize86▒kiB,▒vql 4▒▒}b
**▒▒Wqrninw▒- by~▒sRC,▒u{mng duw}ult▒uovironmunt
▒▒In:<<▒▒seriql▒▒Out:▒▒▒vidconsone▒▒err:<▒▒vifconsone▒▒Movuo:0Rq}<ROs▒▒_i 4s▒▒Nev:>80etn>:▒etnernetxfe3>>><>▒▒niv▒yny▒key▒vo▒svo~▒yuvoroov:▒▒>▒▒▒swivcn▒vo▒~yrvivions▒3>.▒OK▒▒mms9▒is▒surrenv▒fevise▒▒▒{ynninw<mmc▒9:9...▒▒found<U▒▒oot<{sripv▒/root/roov.scr▒▒39>5▒ryves▒reyv▒in▒6▒ms▒▒597/6▒▒iB/s)▒▒33▒e~esuving▒ssri~t▒yv▒>>5<>>><▒▒Boov▒scri~v▒loqvev>from▒mmc81▒▒2<6▒bytes▒reqd8in▒6<ms<(33.2▒KiB▒{)▒▒>44876▒▒rytes▒{ead▒io▒369▒m{▒▒29.>▒Mir/s)▒▒29624<6>▒rytes▒reqd▒in▒921▒ms▒.:2.4▒Mib/s)▒
                     93659▒rytes▒reyd▒in▒99▒ms▒.6.7<Mir/s)▒
                                                           269>▒zyves▒ruyv▒in▒99▒ms▒,239.3 Ki▒{▒͊y|~nying▒kernel▒~rovifef▒fV▒fi~u~▒ssri~v▒.rosksli~-fi~u~.ssr)▒▒#▒▒e|ecuving<sczi~t<at▒>9><8<>>͊▒#▒Noyving▒iniv>Rymvisk▒from▒Negysy▒Imyge▒yt<>6>>><<>▒...▒▒▒▒▒Imagu▒Oame:▒▒▒uIniv
▒▒▒}mage▒_y|e:▒▒▒yyrch66▒Ninu~▒RyMdisk▒Imyge▒.gzi|▒som~ressef)▒ʼ▒▒fyty▒Size:▒▒▒▒>44878:▒rytes▒=▒<.1 Mi▒▒▒8▒▒ooadress▒▒?<00<▒▒?▒
        ▒▒▒envry▒^oinv:▒▒>>>>>>>>▒ʾ▒▒Verifying▒snesksum▒...▒Ok͊#3▒fnyvvenev▒fevise▒Tree▒rnor▒yv▒>9f>>>>>▒ʾ▒▒rooving▒using▒vne▒fvv▒rnor▒yv▒>~9f>>>>>▒ʾ▒▒Noyving▒Rymvisk▒vo▒f17>e>>>,▒env▒f9f9syze▒...▒OK▒
▒▒~}rting▒kernen▒/..        eRROR:▒re
Baud rate: 1500000
Data bits: 8
Stop bits: 1
Parity: none
Flow control: XON/XOFF
Edited by Imzke
And  (after few minutes ) infinite loop that:
27<799]▒7c00:▒>><80>>>><80▒>>><88▒>>><00>>>6e8c▒>>><88>>>><86ef>><88>>><<8<>>><1e▒▒[<08▒;.2795>;]>7c2▒:▒><08▒>>><04▒>95< fvffff8<▒>eeca5~▒>><0<?>>ffff{5r28ffgfff80▒=3r51c▒▒▒[ ▒▒32.28<▒72]<7c▒>:>fffvffc<f3y><<0vfffffsf24e7s=>▒ffffvf><885>y>c88fvffffc<f26e7c9>▒▒[▒▒>32.2<9964]▒7s6<:▒ffffff>><<54y>>><<<>>><<<<>>><<45ffffff>>><19<▒3s<fffvwfc0f2u7cb0▒▒[ 0<▒▒.2819▒▒]<7c>▒?▒ffffwwfffffwwfff▒▒▒?><0<▒▒?>80<▒▒͊[▒▒>32.2>:642]▒[>ffffff>><<<>:7r4>]▒en9_iry+>|b4/>~96<▒▒[<0<3:▒2<2936]>[<ffffff8<▒>56a0<>>]>__den}y+0|▒▒/<x4<▒▒[8▒▒▒2.2<3▒=7] [>wwffff>▒?<54y▒{?>] __{onst_ulay+:4/0~▒{͊[▒▒<32.:>3958]▒[>ffffff><8<9=▒>3c>]▒~ynic+>~224/>~::<▒▒[<▒>32.2>4665]▒[>ffffff>>>>9567s>>]▒~ros_vonung_vysk_timeouv_sess+>~>/>~7s▒▒[▒▒<32.2>5>95]▒[>ffffff>>>>>v37e>>]▒ktnreyv+>~e>/>~f>▒▒[▒▒>32.2>55>>]▒[>ffffff▒[▒▒?>2.>>▒721]▒zoskchi~rm0dm{~lay-suzsysvum:<bou>ff9>▒▒><.v▒.oxs▒fffffv?><8cu{5e<)▒▒[>88<▒▒?><74:]▒rocks~m~-vo~▒ff<f>▒>>.vo~:▒missing▒rosksni~.grf▒~ro~ervy▒▒[▒▒<>:.>>>>22]▒rocksni~-frm▒vis~nyy-sursysvem:▒rounf▒ff>f>>>>.vo~▒.o~s▒>~ffffff>>>>ses5e>)▒▒[▒▒>>2.>>>>29]▒rosksli|-frm▒vis~nyy-sursysvem:▒fyinev▒vo▒rinv▒ff96>>>>.vsi▒.o~s▒>~ffffff>>>>se237>):▒-597▒▒[▒▒>>2.>>>973]▒rosksni~-vrm▒vis~nyy-sursysvem:▒mysver▒rinf▒fyinev:▒-597▒▒[▒▒>>2.>>936>]▒[vrm]▒Roskcni~▒vRM▒friver▒version:▒v9.>.9▒▒[▒▒>>2.>>2963]▒rosksli~-frm▒vis~nyy-sursysvem:▒vevfrey▒is▒nov▒sev▒▒[▒▒>>:.>>23>:]▒rosksni~-vo~▒ff9>>>><.vo~:▒missing▒rosksni~.gzf▒|ro~uzvy▒▒[▒▒><2.>>:519]▒zosksni~-frm▒vis~lyy-sursysvem:▒rounv▒ff9>>>>>.vo~▒.o~s▒>~ffffff>><>ses5e<)▒▒[<<>>2.><2539]▒rosksni|-vo~▒ff<f>>>>.vo~:▒missing>rosksni|,gzf▒|ro~ezvy▒▒[▒▒><2.>>:692]▒zoskcli~-vrm▒vis~lqy-sursysvem:<bounv▒ff<f>>><.vo~▒.o|s▒>~ffffff>><<ses5e<)▒▒[▒><<2.>>261<]▒zock▒[>88<▒▒▒>275>]▒rockm|-drmispl}}-subs}{vem:▒m}ster▒z}nd0fymoed:0▒▒▒7f>>88su:378):▒▒597
[▒▒?>2.>>▒935]▒[~zm]8Roskchi~▒▒RM<dzmver8vezsion:▒v9.<.9▒▒[80<▒▒▒>83957]>rosksnix-dzm▒dis|n}}-surs}stem:evfre}▒ms0no~▒set▒▒[>08<▒▒▒>419>]▒rock}~-vo~▒wf90<▒▒▒.vo|▒▒missinw▒rockm~,grvrope}▒
        [8▒>▒2.8<▒▒:>]8roskcli|-vzm<dis~nyy-sursystem:▒rounv▒ff9<>>>>.vo~▒.o~s▒<|ffffff<<>>ses5e>)▒▒[▒▒>>2.<<6367]<rosksni|-vo~▒ff>f>>><.vo~:▒missing<rosksni|.grf>xro~ervy▒▒[▒▒><2.>>662<]▒rosks~i~-vrm▒vis~ly}-sursysvem:<rounvff>f>>><.vo~▒.o~s▒>~ffffff><<>ses5e<)▒▒[▒▒<>2.>>6436]▒rocksni~-dzm▒fis|nyy-sursysvem:▒fyined▒vo▒rinf▒ff96>>>>.fsi▒.o~s<>~ffffff>>>>se237>):▒-597▒▒[▒▒>>2.>>659>]▒roskcli~-frm▒fis|lyy-sursystem:▒mysver▒rinv▒fyinev:▒-597▒▒[▒▒>>2.>>69>9]▒[frm]▒Rockcli|<dRMdriver8version:▒v9.0.9▒▒[ 8>>2.<85793]8roskslip-vrm<dis~nyy-suzsystem:▒fevfrey▒is nov▒set▒▒[< 8▒:.><683>]<rocksni|-vo~▒ff9<>>><.vo~:▒▒[▒▒><2.>>6967]▒zoskchi~-frm8vms~lay▒sursysvem:<bounvff9>>><.vo~▒.ops▒>~ffffvf>><8cus5e<)▒▒[<08▒;.><61>?]▒rocksni|-vo~▒ff8f▒?>>.vo~:▒missing>rocksni|,gzf▒~roxezvy
[▒▒>>2.<<626<]8roskchi|-frm<dis~lqy-sursystem:<bound<ff>f<<<<.vo|<,o~s▒<|ffffff<<>>sec5e>▒▒▒[ 0>▒▒.>862▒▒]<rosk{n▒[▒▒<<2.>>6437]▒rockcli~-drm▒vis|lqy-subsysvem:8mysver8bin~>fainu~:8-5▒▒͊[▒▒▒▒2.0<6▒=7]0[m]0Ro{kslip▒▒▒M<drivuz<vez{}on:0v▒▒?.1▒▒[>888:▒▒>768>]▒rocks~m~-drmisply}▒subsyem:▒vuwfreq▒ms>not▒suv▒▒[▒▒<<2▒>>7>72]▒zockcni~-vo|▒ff9><>>>.vo|:▒missing▒rosksni~.grf▒|ro~ervy▒▒[▒▒>>2.>>>>>9]▒roskcni~-frm▒vis~nyy-sursysvem:▒rounf▒ff9>>>>>.vo~▒.o~s▒>~ffffff>>>>ses5e>)▒▒[▒▒>>2.>>>>33]▒rosksni~-vo~▒ff>f>>>>.vo~:▒missing▒rosksni~.grf▒~ro~ervy▒▒[▒▒>>2.>>>995]▒rosksni~-vrm▒vis~nyy-sursysvem:▒rounf▒ff>f>>>>.vo~▒.o~s▒>~ffffff>>>>ses5e>)▒▒[▒▒>>2.>>>922]▒rosksni~-vrm▒vis~nyy-sursysvem:▒fyinev▒vo▒rinv▒ff96>>>>.vsi▒.o~s▒>~ffffff>>>>se237>):▒-597▒▒[▒▒>>:.>>>29>]▒zosksni~-drm▒vis|nyy-sursysvem:▒mysver▒rinv▒fyinev:▒-597͊[▒▒>>2.>>>679]▒[vzm]▒Rosksli~▒▒ZM▒friver▒version:▒v9.>.9▒▒[>▒>>2.><96>2]▒rosks~i~-vrm▒vis~nyy-sursysvem:▒vevfrey▒is>nov▒set▒▒[▒<<<:.>>9799]▒zocksni~-vo~▒ff9<<>>>.vo~:▒missing▒rocks~i~,gzf▒~ro|ervy▒▒[▒▒>>2.<<9>59]<rosksli~-vzm<dis~nyy-suzsystem:▒rounv▒ff9<<>>>.vo~▒▒o~s<>~ffffff>>>>ces5e>)▒▒[▒▒<<2.>>9>72]▒zockc~i~-vo~▒ff>f<>>>.vo~:▒missing▒rosksli~.gzf<|ro~erty▒▒[▒▒<<2▒▒>9956]▒{ockcn-frm▒v}s|lqy▒{ubsyum: rouof8ff▒w?>80.v<(o|s▒?|ffffwf<00<sus5e0)▒▒[<08>▒▒><9963]▒rocks~i|-drm▒vis|nyy-subsysvem:▒fyiledo>binv▒gf96<>▒?.dsi▒▒o|s8<~wwffff>▒?<ce2▒▒?):0-▒▒7▒
         [▒▒><2.▒▒▒984]▒{oskch▒frm▒v}{~lay▒{ursysvum:0myur0bi▒fail;<-59▒▒▒[ ▒>▒▒.89<▒▒?]8[dzm]<Rosk{nix0dZm▒frivu▒[▒▒<<2.>992<5]▒rocksni~-frm▒fis~nyy-sursystem:▒fevfrey▒is▒nov▒set▒▒[<<<>2.>915:9]▒rosksni~-vo~▒ff9>>>>>.vo~:▒missing▒rosksni|,grf▒~ro~ervy▒▒[▒▒>>2.>9965>]▒rosksli~-vrm<vis~nyy-sursysvem:▒rounvff9>>>>>.vo~▒.o|s▒>~ffffff>>><ces5e>)▒▒[▒><>2.>99679]▒rocksni~-vo~▒ff<f>>>>.vo~:▒missing▒rosksni|,grf▒~ro~erty͊[▒▒>>2.<99759]▒zosksni~-vrm▒tis~nyy-sursysvem:▒rounv▒ff>f>>>>.vo~▒.o~s▒>~ffffff>>>>ses5e>)▒▒[▒▒>>2.>9975>]▒rockcli~-drm▒dis|lyy-sursystem:▒fqilev▒vo▒[▒<802.>91922]▒rockc~i|-drm▒visxly}-subsysvem: m}sver0rmnf<fainef:8-597͊[▒▒>>2.<9:3>3]<[vrm]8Roskchix▒vRM<driver<▒[▒<<02.>93354]▒rockc~i~-vo|▒ff9<0<>>.vop:▒missing▒rocks~i~,grf▒~roxer~y͊[88>>2.<936>6]<rosksli|-vzm<dis~nyy-sursysvem:<round<ff9><<<<.vo~<,o~s▒>~ffffff<<8<ses5e0)▒▒[0 <▒▒/>935>7]<rosk{nix-vff8f▒▒><.vo~;>missmog8rosksnip,gzg>x▒[▒▒><2.>935<8]▒zoskchi~-frm<vis~lqy-sursysvem:<bounv<ff<f>>><.vo~▒.o|s▒▒~fffffv>><8su{5e8)▒▒[▒888:▒▒93595]▒rocks~}~-drmisply}▒subsyem:▒f}}ned▒vo▒rind▒ww960<▒▒▒fsi▒▒s80|fwgfff<▒▒?ce237▒-:8-5▒▒͊[▒▒?>2.<9375<]<roskchi~▒~rm8dis~nqy-suzsystum:▒mqsverrinvfyilev:▒-597▒▒[▒▒>>2.>96966]▒[vrm]▒Zosksni~▒vRM▒vziver▒version:▒v9.>.9▒▒[▒▒>>2.>9696>]▒rosksni~-vrm▒vis~nyy-sursysvem:▒vevfrey▒is▒nov▒sev▒▒[▒▒>>2.>959>7]▒rosksni~-vo~▒ff9>>>>>.vo~:▒missing▒rosksni~.grf▒~ro~ervy▒▒[▒▒>>2.>9539>]▒rosksni~-frm▒vis~lyy-sursysvem:▒rounv▒ff9>>>>>.vo~▒.o~s▒>~ffffff>>>>ses5e>)▒▒[▒▒>>2.>9536>]▒rosksni~-vo~▒ff>f>>>>.vo~:▒missing▒rosksni~.grf▒~ro~ervy▒▒[▒▒>>2.>95622]▒rosksni~-vrm▒vis~nyy-sursysvem:▒rounf▒ff>f>><>.vo~▒,o~s▒>~ffffff><>>ses5e>)▒▒[▒▒>>:.>956:=]▒rosks~i|-vzm▒vis~n}}-surs}svem:▒fyinev▒~o▒rinv▒ff96>>▒>.vsi▒▒o~s▒>~ffffff>>>>se237>):▒-597▒▒[▒▒><2.>9557<]▒zoskcni~-vrm▒vis~lqy-sursysvem:<mysver<rinv▒fqinev:<-597▒▒[▒▒>>2.<959>5]<[vrm]<Rosksni|▒vZM▒drivez▒version:<v9.>.1▒▒[▒><<:.▒967<7]▒zocksni~-drm▒vis|lyy▒subsysvem:▒vevfreq▒is▒not▒sev▒▒[▒▒><2.>97>26]▒rosksni~-vo~▒ff9>>>>>.vo~:▒missing<rosksni|.grf>|ro~ervy▒▒[▒▒><2.>▒7958]▒zoskcli~-drm▒v}s|lay▒{ubsys~um: bouov<ff9▒▒><0.v>(oxs▒▒~fffffw>808su{5e0)▒▒[00<▒▒▒>9797=]<rosksni|-vo~▒ff<f>>>>.vo~:▒missmng<rosks▒[▒▒><2.>▒▒:60]▒zoskchi~▒vrm8v}{~lay▒{ursysvum:<bou>ff8f▒▒>8.v▒.ops▒fffffv?>88cu{5e8)▒▒[▒<802▒▒=7267]▒{ockcnm~-drmis|lyy-subsysvem:8fyined8to▒zind▒ff96<<<>.vsi▒.o~s▒<~ffffff>>>>se237>):▒-597▒▒[▒<<>:.>974<5]▒rocksni~-drm▒vis|l}y-subs}svem:▒mysver▒zinv>fyinev:<-597͊[▒▒>>2.>977>6]▒[vrm]<Rosksli~▒vRM>driver>version:▒v9.>.1▒
