I am having an issue with my system running a nanopi Air.
After boot, my system won't detect my rtc (i2cdetect doesn't show it) nor my USB device.
The problem must come from my SD card or is software related. Indeed, when I am booting from another SDcard, with aembian installed, everything is detected normally.
Does anyone has a clue?
Thank you,
Tibibs
Edited by tibibs
I have an error
line 862: [: -gt: unary operator expected
while running it but it doesn't seem to block the script
line where the error is happening
if [ ${LOGLEVEL} -gt 4 ]; then
	VERBOSE='-v'
	which lshw >/dev/null 2>&1 && (echo -e "\n### lshw:" ; lshw -quiet -sanitize -numeric)
fi
I don't get any URLat the end to post it 😕
Edited by tibibs
here is the "dmesg" ouput if it helps. it seems to detect my RTC at adress 0x68 which is where it should be
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.4.45-sunxi (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #20.05.4 SMP Sun Jun 14 21:46:20 CEST 2020
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: FriendlyARM NanoPi NEO Air
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 128 MiB at 0x57c00000
[    0.000000] On node 0 totalpages: 131072
[    0.000000]   Normal zone: 1152 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 131072 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: Using PSCI v0.1 Function IDs from DT
[    0.000000] percpu: Embedded 20 pages/cpu s50124 r8192 d23604 u81920
[    0.000000] pcpu-alloc: s50124 r8192 d23604 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=c859a48b-01 ubootsource=mmc usb-storage.quirks=   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] allocated 524288 bytes of page_ext
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 360732K/524288K available (8192K kernel code, 917K rwdata, 3008K rodata, 1024K init, 339K bss, 32484K reserved, 131072K cma-reserved, 0K highmem)
[    0.000000] random: get_random_u32 called from __kmem_cache_create+0x1f/0x36c with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 38601 entries in 76 pages
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000011] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000027] Switching to timer-based delay loop, resolution 41ns
[    0.000464] Console: colour dummy device 80x30
[    0.000486] printk: console [tty1] enabled
[    0.000564] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000583] pid_max: default: 32768 minimum: 301
[    0.000948] LSM: Security Framework initializing
[    0.001100] Yama: becoming mindful.
[    0.001205] SELinux:  Initializing.
[    0.001369] *** VALIDATE SELinux ***
[    0.001389] TOMOYO Linux initialized
[    0.001512] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001529] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001679] *** VALIDATE tmpfs ***
[    0.002888] *** VALIDATE proc ***
[    0.003411] *** VALIDATE cgroup1 ***
[    0.003425] *** VALIDATE cgroup2 ***
[    0.003531] CPU: Testing write buffer coherency: ok
[    0.004436] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005432] Setting up static identity map for 0x40100000 - 0x40100054
[    0.005644] rcu: Hierarchical SRCU implementation.
[    0.010537] smp: Bringing up secondary CPUs ...
[    0.021858] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.033405] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.044734] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.044932] smp: Brought up 1 node, 4 CPUs
[    0.044947] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.044954] CPU: All CPU(s) started in HYP mode.
[    0.044959] CPU: Virtualization extensions available.
[    0.046599] devtmpfs: initialized
[    0.060976] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.061463] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.061545] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.070690] xor: measuring software checksum speed
[    0.108835]    arm4regs  :   598.000 MB/sec
[    0.148942]    8regs     :   416.000 MB/sec
[    0.189063]    32regs    :   393.000 MB/sec
[    0.229184]    neon      :   605.000 MB/sec
[    0.229193] xor: using function: neon (605.000 MB/sec)
[    0.229340] pinctrl core: initialized pinctrl subsystem
[    0.231182] NET: Registered protocol family 16
[    0.234662] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.235648] audit: initializing netlink subsys (disabled)
[    0.236138] audit: type=2000 audit(0.208:1): state=initialized audit_enabled=0 res=1
[    0.237449] cpuidle: using governor ladder
[    0.237509] cpuidle: using governor menu
[    0.238496] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.238506] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.274124] cryptd: max_cpu_qlen set to 1000
[    0.358023] raid6: neonx8   gen()   337 MB/s
[    0.426129] raid6: neonx8   xor()   276 MB/s
[    0.494306] raid6: neonx4   gen()   346 MB/s
[    0.562376] raid6: neonx4   xor()   289 MB/s
[    0.630651] raid6: neonx2   gen()   314 MB/s
[    0.698754] raid6: neonx2   xor()   277 MB/s
[    0.767037] raid6: neonx1   gen()   230 MB/s
[    0.835054] raid6: neonx1   xor()   209 MB/s
[    0.903191] raid6: int32x8  gen()   126 MB/s
[    0.971513] raid6: int32x8  xor()    82 MB/s
[    1.039923] raid6: int32x4  gen()   134 MB/s
[    1.107947] raid6: int32x4  xor()    91 MB/s
[    1.176160] raid6: int32x2  gen()   118 MB/s
[    1.244364] raid6: int32x2  xor()    89 MB/s
[    1.312876] raid6: int32x1  gen()    88 MB/s
[    1.380799] raid6: int32x1  xor()    69 MB/s
[    1.380807] raid6: using algorithm neonx4 gen() 346 MB/s
[    1.380813] raid6: .... xor() 289 MB/s, rmw enabled
[    1.380821] raid6: using neon recovery algorithm
[    1.382318] iommu: Default domain type: Translated
[    1.383964] SCSI subsystem initialized
[    1.384314] libata version 3.00 loaded.
[    1.384718] usbcore: registered new interface driver usbfs
[    1.384830] usbcore: registered new interface driver hub
[    1.384970] usbcore: registered new device driver usb
[    1.385552] pps_core: LinuxPPS API ver. 1 registered
[    1.385562] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.385595] PTP clock support registered
[    1.387167] NetLabel: Initializing
[    1.387178] NetLabel:  domain hash size = 128
[    1.387183] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.387354] NetLabel:  unlabeled traffic allowed by default
[    1.388560] clocksource: Switched to clocksource arch_sys_counter
[    1.594624] *** VALIDATE bpf ***
[    1.595159] VFS: Disk quotas dquot_6.6.0
[    1.595308] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.595490] *** VALIDATE ramfs ***
[    1.612249] thermal_sys: Registered thermal governor 'fair_share'
[    1.612259] thermal_sys: Registered thermal governor 'bang_bang'
[    1.612270] thermal_sys: Registered thermal governor 'step_wise'
[    1.612278] thermal_sys: Registered thermal governor 'user_space'
[    1.612285] thermal_sys: Registered thermal governor 'power_allocator'
[    1.613405] NET: Registered protocol family 2
[    1.614858] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.614932] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    1.615042] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    1.615163] TCP: Hash tables configured (established 4096 bind 4096)
[    1.615384] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    1.615434] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    1.615924] NET: Registered protocol family 1
[    1.617312] RPC: Registered named UNIX socket transport module.
[    1.617322] RPC: Registered udp transport module.
[    1.617329] RPC: Registered tcp transport module.
[    1.617335] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.617352] NET: Registered protocol family 44
[    1.617996] Trying to unpack rootfs image as initramfs...
[    3.239608] Freeing initrd memory: 11660K
[    3.241900] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    3.244208] Initialise system trusted keyrings
[    3.244301] Key type blacklist registered
[    3.244742] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    3.259137] zbud: loaded
[    3.264171] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    3.266420] fuse: init (API version 7.31)
[    3.266625] *** VALIDATE fuse ***
[    3.266641] *** VALIDATE fuse ***
[    3.270391] Platform Keyring initialized
[    3.363335] Key type asymmetric registered
[    3.363352] Asymmetric key parser 'x509' registered
[    3.363482] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    3.363861] io scheduler mq-deadline registered
[    3.363872] io scheduler kyber registered
[    3.364004] io scheduler bfq registered
[    3.375797] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    3.379135] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    3.390684] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    3.395339] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
[    3.396096] printk: console [ttyS0] disabled
[    3.416406] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 35, base_baud = 1500000) is a U6_16550A
[    3.416499] printk: console [ttyS0] enabled
[    3.438052] 1c28c00.serial: ttyS1 at MMIO 0x1c28c00 (irq = 36, base_baud = 1500000) is a U6_16550A
[    3.446288] brd: module loaded
[    3.467849] loop: module loaded
[    3.471629] libphy: Fixed MDIO Bus: probed
[    3.473772] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.473807] ehci-platform: EHCI generic platform driver
[    3.474187] ehci-platform 1c1a000.usb: EHCI Host Controller
[    3.474235] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    3.475084] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
[    3.488622] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    3.489245] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    3.489261] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.489274] usb usb1: Product: EHCI Host Controller
[    3.489285] usb usb1: Manufacturer: Linux 5.4.45-sunxi ehci_hcd
[    3.489298] usb usb1: SerialNumber: 1c1a000.usb
[    3.490456] hub 1-0:1.0: USB hub found
[    3.490551] hub 1-0:1.0: 1 port detected
[    3.491552] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.491592] ohci-platform: OHCI generic platform driver
[    3.491951] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    3.491993] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    3.492391] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
[    3.553067] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
[    3.553084] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.553096] usb usb2: Product: Generic Platform OHCI controller
[    3.553108] usb usb2: Manufacturer: Linux 5.4.45-sunxi ohci_hcd
[    3.553120] usb usb2: SerialNumber: 1c1a400.usb
[    3.554133] hub 2-0:1.0: USB hub found
[    3.554219] hub 2-0:1.0: 1 port detected
[    3.555870] usbcore: registered new interface driver usb-storage
[    3.556440] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    3.560270] sun6i-rtc 1f00000.rtc: registered as rtc0
[    3.560284] sun6i-rtc 1f00000.rtc: RTC enabled
[    3.560850] i2c /dev entries driver
[    3.561318] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[    3.564959] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    3.566143] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    3.566914] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    3.567672] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    3.568837] sun8i-h3-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator
[    3.570082] ledtrig-cpu: registered to indicate activity on CPUs
[    3.570234] hidraw: raw HID events driver (C) Jiri Kosina
[    3.570453] usbcore: registered new interface driver usbhid
[    3.570460] usbhid: USB HID core driver
[    3.573523] Initializing XFRM netlink socket
[    3.574693] NET: Registered protocol family 10
[    3.671358] Segment Routing with IPv6
[    3.671558] NET: Registered protocol family 17
[    3.672864] Registering SWP/SWPB emulation handler
[    3.673479] registered taskstats version 1
[    3.673486] Loading compiled-in X.509 certificates
[    3.702946] Loaded X.509 cert 'Build time autogenerated kernel key: d0edb8ed5701557bc88f39140ef99772ed24dcd2'
[    3.703315] zswap: loaded using pool lzo/zbud
[    3.703868] Key type ._fscrypt registered
[    3.703878] Key type .fscrypt registered
[    3.710702] Btrfs loaded, crc32c=crc32c-generic
[    3.805664] Key type big_key registered
[    3.852745] Key type encrypted registered
[    3.852826] ima: No TPM chip found, activating TPM-bypass!
[    3.852901] ima: Allocated hash algorithm: sha256
[    3.852977] ima: No architecture policies found
[    3.878004] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    3.879411] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    3.880751] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    3.882135] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    3.883344] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    3.884452] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    3.885563] sun6i-rtc 1f00000.rtc: setting system clock to 2022-07-03T18:11:02 UTC (1656871862)
[    3.886494] of_cfs_init
[    3.886684] of_cfs_init: OK
[    3.896405] Freeing unused kernel memory: 1024K
[    3.901017] Run /init as init process
[    4.677034] cam500b-avdd: supplied by vcc3v3
[    4.677840] cam500b-dovdd: supplied by vcc3v3
[    4.678622] cam500b-dvdd: supplied by vcc3v3
[    4.680710] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    4.685272] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    4.708647] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    4.709983] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    4.730336] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    4.759475] mmc0: host does not support reading read-only switch, assuming write-enable
[    4.761523] mmc0: new high speed SDHC card at address 0001
[    4.764705] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
[    4.766047] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    4.778728] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
[    4.792993]  mmcblk0: p1
[    4.796823] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    4.896863] mmc1: new DDR MMC card at address 0001
[    4.899615] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[    4.901747] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
[    4.903807] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
[    4.911322]  mmcblk1: p1 p2 p3
[    4.926633] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    5.073668] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    5.077465] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[    5.246650] random: fast init done
[    5.308716] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[    5.325559] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[    5.327127] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    5.328702] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    5.331561] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[    5.335074] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[    5.439430] mmc2: new high speed SDIO card at address 0001
[    5.852007] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    6.175401] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[    6.807262] systemd[1]: Inserted module 'autofs4'
[    6.910696] systemd[1]: systemd 245.4-4ubuntu3.1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    6.912344] systemd[1]: Detected architecture arm.
[    6.965877] systemd[1]: Set hostname to <AERS-TMA1001>.
[    7.729344] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
[    8.531527] random: systemd: uninitialized urandom read (16 bytes read)
[    8.542122] systemd[1]: Created slice system-modprobe.slice.
[    8.543260] random: systemd: uninitialized urandom read (16 bytes read)
[    8.546494] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    8.547156] random: systemd: uninitialized urandom read (16 bytes read)
[    8.550013] systemd[1]: Created slice User and Session Slice.
[    8.551424] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    8.552795] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    8.555891] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.557081] systemd[1]: Reached target Local Encrypted Volumes.
[    8.558289] systemd[1]: Reached target Remote File Systems.
[    8.558945] systemd[1]: Reached target Slices.
[    8.559592] systemd[1]: Reached target Swap.
[    8.560244] systemd[1]: Reached target System Time Set.
[    8.562396] systemd[1]: Listening on Syslog Socket.
[    8.564176] systemd[1]: Listening on fsck to fsckd communication Socket.
[    8.565449] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    8.568378] systemd[1]: Listening on Journal Audit Socket.
[    8.570279] systemd[1]: Listening on Journal Socket (/dev/log).
[    8.572243] systemd[1]: Listening on Journal Socket.
[    8.574318] systemd[1]: Listening on udev Control Socket.
[    8.575809] systemd[1]: Listening on udev Kernel Socket.
[    8.577840] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    8.589706] systemd[1]: Mounting POSIX Message Queue File System...
[    8.604140] systemd[1]: Mounting Kernel Debug File System...
[    8.620447] systemd[1]: Mounting Kernel Trace File System...
[    8.643254] systemd[1]: Starting Restore / save the current clock...
[    8.658685] systemd[1]: Starting Set the console keyboard layout...
[    8.675303] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    8.677329] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    8.695743] systemd[1]: Started Nameserver information manager.
[    8.698927] systemd[1]: Reached target Network (Pre).
[    8.706105] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    8.707128] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    8.730045] systemd[1]: Starting Load Kernel Modules...
[    8.746607] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.764334] systemd[1]: Starting udev Coldplug all Devices...
[    8.804606] systemd[1]: Mounted POSIX Message Queue File System.
[    8.807739] systemd[1]: Mounted Kernel Debug File System.
[    8.811455] systemd[1]: Mounted Kernel Trace File System.
[    8.822252] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    8.879110] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    8.903383] systemd[1]: Finished Remount Root and Kernel File Systems.
[    8.923014] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    8.924479] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    8.940395] systemd[1]: Starting Load/Save Random Seed...
[    8.963212] systemd[1]: Starting Create System Users...
[    9.061965] g_serial gadget: Gadget Serial v2.4
[    9.061983] g_serial gadget: g_serial ready
[    9.078226] systemd[1]: Finished Load Kernel Modules.
[    9.102656] systemd[1]: Mounting FUSE Control File System...
[    9.122018] systemd[1]: Mounting Kernel Configuration File System...
[    9.151649] systemd[1]: Starting Apply Kernel Variables...
[    9.185895] systemd[1]: Finished Restore / save the current clock.
[    9.203262] systemd[1]: Finished Create System Users.
[    9.206939] systemd[1]: Mounted FUSE Control File System.
[    9.210119] systemd[1]: Mounted Kernel Configuration File System.
[    9.228097] systemd[1]: Starting Create Static Device Nodes in /dev...
[    9.310448] systemd[1]: Finished Apply Kernel Variables.
[    9.369634] systemd[1]: Finished Create Static Device Nodes in /dev.
[    9.386791] systemd[1]: Starting udev Kernel Device Manager...
[    9.655998] systemd[1]: Finished Set the console keyboard layout.
[    9.658435] systemd[1]: Reached target Local File Systems (Pre).
[    9.673465] systemd[1]: Mounting /tmp...
[    9.678406] systemd[1]: Started udev Kernel Device Manager.
[    9.731739] systemd[1]: Finished udev Coldplug all Devices.
[    9.762193] systemd[1]: Mounted /tmp.
[    9.820081] systemd[1]: Found device /dev/ttyGS0.
[    9.821888] systemd[1]: Reached target Local File Systems.
[    9.835153] systemd[1]: Starting Armbian ZRAM config...
[    9.849935] systemd[1]: Starting Set console font and keymap...
[    9.883502] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[    9.890694] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    9.950356] systemd[1]: Finished Set console font and keymap.
[    9.975788] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[   10.014173] systemd[1]: Starting Raise network interfaces...
[   10.540219] mc: Linux media interface: v0.10
[   10.595116] videodev: Linux video capture interface: v2.00
[   10.808949] zram: Added device: zram0
[   10.811925] zram: Added device: zram1
[   10.823450] zram: Added device: zram2
[   10.886887] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
[   10.893602] cedrus 1c0e000.video-codec: Device registered as /dev/video0
[   10.940183] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   11.010800] zram1: detected capacity change from 0 to 258297856
[   11.086328] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   11.152952] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[   11.183315] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.friendlyarm,nanopi-neo-air.txt failed with error -2
[   11.183330] brcmfmac mmc2:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac43430-sdio.friendlyarm,nanopi-neo-air.txt
[   11.207781] systemd[1]: Found device /dev/ttyS0.
[   11.376826] ov5640 0-003c: ov5640_read_reg: error: reg=300a
[   11.382590] ov5640 0-003c: ov5640_check_chip_id: failed to read chip identifier
[   11.471254] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   11.472007] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   11.472614] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   11.472935] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   11.473154] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   11.588679] random: crng init done
[   11.588695] random: 7 urandom warning(s) missed due to ratelimiting
[   11.643534] systemd[1]: Finished Load/Save Random Seed.
[   11.686596] systemd[1]: Finished Raise network interfaces.
[   11.696865] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   11.698954] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   11.752814] Adding 252240k swap on /dev/zram1.  Priority:5 extents:1 across:252240k SSFS
[   11.794867] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[   11.801609] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-11), device may have limited channels available
[   11.805623] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Mar 30 2016 11:30:56 version 7.45.77.h8.4 FWID 01-ee8a6268
[   11.839754] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   11.884518] systemd[1]: Started Load/Save RF Kill Switch Status.
[   11.983423] zram0: detected capacity change from 0 to 52428800
[   12.062802] systemd[1]: Finished Armbian ZRAM config.
[   12.069443] systemd[1]: Starting Armbian memory supported logging...
[   12.173575] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[   12.173621] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
[   16.253001] systemd[1]: Finished Armbian memory supported logging.
[   16.264275] systemd[1]: Starting Journal Service...
[   16.588914] systemd[1]: Started Journal Service.
[   16.626862] systemd-journald[575]: Received client request to flush runtime journal.
[   22.838454] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   24.181498] i2c i2c-0: new_device: Instantiated device ds1307 at 0x68
[   35.832389] vcc3v0: disabling
[   35.832407] vcc5v0: disabling
[   35.832416] cam500b-avdd: disabling
[   35.832423] cam500b-dovdd: disabling
[   35.832431] cam500b-dvdd: disabling
[  141.348659] ieee80211 phy0: brcmf_vif_set_mgmt_ie: vndr ie set error : -52
[  141.356050] ieee80211 phy0: brcmf_vif_set_mgmt_ie: vndr ie set error : -52
[  141.363488] ieee80211 phy0: brcmf_vif_set_mgmt_ie: vndr ie set error : -52
[  143.770758] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  374.809122] TCP: request_sock_TCP: Possible SYN flooding on port 8888. Sending cookies.  Check SNMP counters.
Edited by tibibs
