UdAvSt Posted July 10, 2022 Posted July 10, 2022 (edited) Installed the Armbian distribution on 05.22 Jammy. In other distributions armbian, zombies are similar. Does not complete the shutdown -P. Instead of disconnecting - a kernel panic. In other distributions, the completion of work is correct. What to do? armbianmonitor -u : http://ix.io/43ZK Error: https://freeimage.host/i/wa9cWF Edited July 10, 2022 by UdAvSt 0 Quote
Myron Posted July 11, 2022 Posted July 11, 2022 I have the same problem, but the OS does seem to cleanly shutdown, just does not power-off the board? @teknoid are you are aware of this kernel panic when shutting down the Banana Pro? 0 Quote
teknoid Posted July 26, 2022 Posted July 26, 2022 Not yet noticed - I don't have a serial console permanently connected to my board. Looks like an error in the PMU https://linux-sunxi.org/AXP209 driver or it's interaction with the kernel during shutdown: https://lkml.iu.edu/hypermail/linux/kernel/1909.2/04767.html No idea how to solve this. 0 Quote
Myron Posted July 31, 2022 Posted July 31, 2022 Only reason I discovered the same is that when I shutdown Linux with poweroff, the SBC remained powered yet the OS has shutdown, so out came the USB to serial adaptor and I noticed the same. As mentioned before, it's not really an issue unless something that's pretty important that needs to be done before OS shutdown that does not get done as the exception terminates the shutdown process. I think in Kernel 5.10.x the Banana Pro SBC did power off correctly. 0 Quote
Dieter Posted September 1, 2022 Posted September 1, 2022 Hi same here, this is my http://ix.io/49l4 link. I have tried both with only SD-Kard and runnung on a sata ssd. Both behave the same. Reboot seems to be fine. Latest Arbian 22.05.3. Will attach logs from putty (serial port). Thanks Dieter putty_ttyUSB0_reboot_ok.log putty_ttyUSB0_shutdowm_crash.log putty_ttyUSB0_SHUTDOWN_CRASH_2.log 0 Quote
Myron Posted September 5, 2022 Posted September 5, 2022 Yep. That's just about what I get. The result is that the board does not power-down. 0 Quote
