I have the same problem, but the OS does seem to cleanly shutdown, just does not power-off the board?
@teknoid are you are aware of this kernel panic when shutting down the Banana Pro?
Only reason I discovered the same is that when I shutdown Linux with poweroff, the SBC remained powered yet the OS has shutdown, so out came the USB to serial adaptor and I noticed the same. As mentioned before, it's not really an issue unless something that's pretty important that needs to be done before OS shutdown that does not get done as the exception terminates the shutdown process.  I think in Kernel 5.10.x the Banana Pro SBC did power off correctly.
