Retroarch in Armbian
Go to solution Solved by Glock24,
I installed Retroarch from the repos, tried to install a "core" from the Retroarch updater but no cores were available. I searched about that if the installed version is too old no cores will be available, so I added the Retroarch ppa and installed the newest version, but got the same problem.
Does Retroarch work under Armbian? Do I need to manually install "core" binaries? If so, where can I get them?
Thanks.
  • Solution
I'm using the latest Ubuntu-based Armbian stable for Nanopi M4v2.
Thanks for the answer, I'll try to build the cores from source.
From what I understand, the current kernel does have 3D HW acceleration for Mali-T860, right?
