Jae Woo Song Posted October 5, 2016 Posted October 5, 2016 Hi, I am using Armbian_5.20_Orangepiplus_Debian_jessie_3.4.112.img with emmc nand flash. I want to make .img file for emmc nand flash. because i am plan to use Phoenixsuit tool.. how can i make emmc nand flash image file? please help me.. thanks.
Igor Posted October 5, 2016 Posted October 5, 2016 We don't support Phoenix tools (closed source) image format. Currently the only way is to burn an SD card and than transfer to internal memory. Our open source flasher is under development and if things go well it might be possible to flash directly. In the future ...
Artyom Posted October 18, 2017 Posted October 18, 2017 On 05.10.2016 at 12:33 PM, Igor said: Our open source flasher is under development and if things go well it might be possible to flash directly. In the future ... And when its happen? I can not flash nand use of the program nand-sata-installer from SD The process of copying goes out, but later the error crashes ... Other operating systems Cubian, Lubuntu and other from the site http://dl.cubieboard.org/ are installed well! using the program LiveSuite. I'm tired of moving the system to the nand. Is there instruction on manual mode? 1. mounted nand 2. created a table on nand 3. run dd 4. made a chroot etc....
Igor Posted October 18, 2017 Posted October 18, 2017 8 minutes ago, Artyom said: The process of copying goes out, but later the error crashes ... What kind of error? It's highly possible that your NAND is dead. Nothing unusual. Last time I was checking install to NAND it was working perfectly fine. 8 minutes ago, Artyom said: Other operating systems Cubian, Lubuntu and other from the site http://dl.cubieboard.org/ are installed well! using the program LiveSuite. I'm tired of moving the system to the nand. I hope you saw the year of the last update? In case you find a better way: https://docs.armbian.com/Process_Contribute/
Artyom Posted October 18, 2017 Posted October 18, 2017 14 minutes ago, Igor said: What kind of error? My board Cubietruck with cubieez-ct-nand-vga-1080p-v2.0.img in nand install My steps: 1. Flash SD date && sudo dd if=/Armbian_5.31_Cubietruck_Ubuntu_xenial_default_3.4.113_desktop.img of=/dev/mmcblk0 bs=1M && date 2. Insert to CT 3. Login via ssh ssh root@ipaddress pass 1234 4. Change pass 5. Create user 6. Change output to VGA cd /boot bin2fex script.bin script.fex nano script.fex ctrl+w search string screen chang to 4 ctrl+x save fex2bin script.fex script.bin reboot after bootup CT 7. Alt+F1 login root with my new pass 8. nand (TAB) -> nand-sata-install ENTER Choise partition Warning ears -> YES NAND Install -> Formatting ... up to one minute. NAND install -> Counting files ... few seconds. Creating rootfs on /dev/nand2 (2329 MB) This will take around 38 minutes to finish. Please wait! AND: Quote It's highly possible that your NAND is dead But why other distr work from NAND?
Artyom Posted October 18, 2017 Posted October 18, 2017 22 minutes ago, Igor said: Thank you. I'll try to reproduce it. THX! May be when i do operations was plugged cable RJ45. I have done these operations several times with different installed systems in the nand I've tried different SD cards It may be necessary to expand the system on nand? In OS cubieez-ct-nand-vga-1080p-v2.0.img... By this comment, I realized that the script nand-sata-install does not create bootloader and the partition table. Maybe there is not enough space in partition? in the beginning on the board was installed android How do you know revision CT? Similar post, but in my case LiveSuite work fine
Igor Posted October 18, 2017 Posted October 18, 2017 I have no problems ... currently at 22% http://sprunge.us/IMiT It's something unrelated to this. This old kernel has some issues, wireless driver is shit, SD card quality? Why don't you use Etcher, since it also checks what writes to SD card? Quote I realized that the script nand-sata-install does not form the loader and the partition table. Maybe there is not enough room? Our installer nukes and creates two partitions.
Igor Posted October 18, 2017 Posted October 18, 2017 ... and my Cubietruck boots normally from NAND. http://sprunge.us/ZZXC
Artyom Posted October 24, 2017 Posted October 24, 2017 (edited) On 18.10.2017 at 12:04 PM, Igor said: I have no problems ... currently at 22% http://sprunge.us/IMiT It's something unrelated to this. This old kernel has some issues, wireless driver is shit, SD card quality? Why don't you use Etcher, since it also checks what writes to SD card? Our installer nukes and creates two partitions. Igor, thx very much! It`s work on my another CT. the first did not work ... i think problems with nand, but other operating systems load ... strange. Thank you for giving me a tip on the program Etcher Edited October 24, 2017 by Tido some typos
