Hi,
I am using Armbian_5.20_Orangepiplus_Debian_jessie_3.4.112.img with emmc nand flash.
I want to make .img file for emmc nand flash. because i am plan to use Phoenixsuit tool..
how can i make emmc nand flash image file?
please help me..
thanks.
We don't support Phoenix tools (closed source) image format. Currently the only way is to burn an SD card and than transfer to internal memory.
Our open source flasher is under development and if things go well it might be possible to flash directly. In the future ...
And when its happen?
I can not flash nand use of the program nand-sata-installer from SD
The process of copying goes out, but later the error crashes ...
Other operating systems Cubian, Lubuntu and other from the site http://dl.cubieboard.org/ are installed well! using the program LiveSuite.
I'm tired of moving the system to the nand.
Is there instruction on manual mode?
1. mounted nand
2. created a table on nand
3. run dd
4. made a chroot
etc....
What kind of error? It's highly possible that your NAND is dead. Nothing unusual.
Last time I was checking install to NAND it was working perfectly fine.
I hope you saw the year of the last update? In case you find a better way: https://docs.armbian.com/Process_Contribute/
14 minutes ago, Igor said:
What kind of error?
My board Cubietruck with cubieez-ct-nand-vga-1080p-v2.0.img in nand install
My steps:
1. Flash SD
date && sudo dd if=/Armbian_5.31_Cubietruck_Ubuntu_xenial_default_3.4.113_desktop.img of=/dev/mmcblk0 bs=1M && date
2. Insert to CT
3. Login via ssh
ssh root@ipaddress pass 1234
4. Change pass
5. Create user
6. Change output to VGA
cd /boot
bin2fex script.bin script.fex
nano script.fex
ctrl+w search string screen
chang to 4
ctrl+x save
fex2bin script.fex script.bin
reboot
after bootup CT
7. Alt+F1
login root with my new pass
8. nand (TAB) -> nand-sata-install
ENTER
Choise partition59e71d866a687_2017-10-1812-19-05.png.8325c61be1cceda3da98723304c9c000.png
Warning ears -> YES
NAND Install -> Formatting ... up to one minute.
NAND install -> Counting files ... few seconds.
Creating rootfs on /dev/nand2 (2329 MB)
This will take around 38 minutes to finish. Please wait!
AND:
Quote
But why other distr work from NAND?
22 minutes ago, Igor said:
Thank you. I'll try to reproduce it.
THX!
May be when i do operations was plugged cable RJ45.
I have done these operations several times with different installed systems in the nand
I've tried different SD cards
It may be necessary to expand the system on nand? In OS cubieez-ct-nand-vga-1080p-v2.0.img...
By this comment,
I realized that the script nand-sata-install does not create bootloader and the partition table. Maybe there is not enough space in partition?
in the beginning on the board was installed android
How do you know revision CT?
Similar post, but in my case LiveSuite work fine
I have no problems ... currently at 22%
http://sprunge.us/IMiT
It's something unrelated to this. This old kernel has some issues, wireless driver is shit, SD card quality? Why don't you use Etcher, since it also checks what writes to SD card?
Quote
I realized that the script nand-sata-install does not form the loader and the partition table. Maybe there is not enough room?
Our installer nukes and creates two partitions.
Posted (edited)
Igor, thx very much!
It`s work on my another CT.
the first did not work ...
i think problems with nand, but other operating systems load ... strange.
Thank you for giving me a tip on the program Etcher
Edited by Tido
some typos
