Odroid N2+ Armbian 22.05 Jammy Kernel 5.10.y, Size: 360Mb, Updated: Jul 1, 2022 + XFCE installed by means of armbian-config
htop shows Systemd: degraded (1/372 failed)
root@n2p-dev:~# systemctl --failed
  UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
● fwupd-refresh.service loaded failed failed Refresh fwupd metadata and update motd
LOAD   = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB    = The low-level unit activation state, values depend on unit type.
1 loaded units listed.
root@n2p-dev:~# systemctl status fwupd-refresh
× fwupd-refresh.service - Refresh fwupd metadata and update motd
     Loaded: loaded (/lib/systemd/system/fwupd-refresh.service; static)
     Active: failed (Result: exit-code) since Thu 2022-08-04 14:14:15 +05; 7h ago
TriggeredBy: ● fwupd-refresh.timer
       Docs: man:fwupdmgr(1)
    Process: 10953 ExecStart=/usr/bin/fwupdmgr refresh (code=exited, status=1/FAILURE)
   Main PID: 10953 (code=exited, status=1/FAILURE)
        CPU: 79ms
Aug 04 14:14:14 n2p-dev systemd[1]: Starting Refresh fwupd metadata and update motd...
Aug 04 14:14:15 n2p-dev systemd[1]: fwupd-refresh.service: Main process exited, code=exited, status=1/FAILURE
Aug 04 14:14:15 n2p-dev systemd[1]: fwupd-refresh.service: Failed with result 'exit-code'.
Aug 04 14:14:15 n2p-dev systemd[1]: Failed to start Refresh fwupd metadata and update motd.
How do I can repair this? Where to look for?
Thanx
UPD:
root@n2p-dev:~# /usr/bin/fwupdmgr refresh
WARNING: UEFI capsule updates not available or enabled in firmware setup
  See https://github.com/fwupd/fwupd/wiki/PluginFlag:capsules-unsupported for more information.
Updating lvfs
Downloading…             [***************************************]
Successfully downloaded new metadata: 1 local device supported
Edited by vinser
