Clean install Odroidc2 Armbian 5.20 to eMMC blue solid light after update
I did a clean install of Armbian_5.20_Odroidc2_Debian_jessie_3.14.79.img
i found that after installing updates: udev and libudev1
OdroidC2 with 128GB eMMC;  stops working with a blue solid light after reboot twice and no response from the device.
If i do the same install on a micro-sd card 1 UHS no problem :S
I have my mail, irc, web and openvpn server running on this device.
Please HELP!!
apt-get install udev libudev1
Preconfiguring packages ...
(Reading database ... 44010 files and directories currently installed.)
Preparing to unpack .../libudev1_215-17+deb8u5_arm64.deb ...
Unpacking libudev1:arm64 (215-17+deb8u5) over (215-17+deb8u4) ...
Setting up libudev1:arm64 (215-17+deb8u5) ...
Processing triggers for libc-bin (2.19-18+deb8u6) ...
Preparing to unpack .../udev_215-17+deb8u5_arm64.deb ...
locale: Cannot set LC_ALL to default locale: No such file or directory
Unpacking udev (215-17+deb8u5) over (215-17+deb8u4) ...
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for systemd (215-17+deb8u4) ...
Setting up udev (215-17+deb8u5) ...
addgroup: The group `input' already exists as a system group. Exiting.
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.120+deb8u2) ...
ln: failed to create hard link '/boot/initrd.img-3.14.79-odroidc2.dpkg-bak' => '/boot/initrd.img-3.14.79-odroidc2': Operation not permitted
update-initramfs: Generating /boot/initrd.img-3.14.79-odroidc2
I just issue an update to my eMMC driven C2, going from 5.16 to 5.20 without a problem.
How exactly did you install to eMMC? Do you have a serial console?
sudo dd if=Armbian_5.20_Odroidc2_Debian_jessie_3.14.79.img of=/dev/sdb bs=1M
sync
with a Transcend MicroSD reader USB3.0 and the eMMC Reader module that comes with the emmc module from the hardkernel site: http://www.hardkernel.com/main/products/prdt_info.php?g_code=G145622510341
it happens after the update and after rebooting twice
I repeat the same with clean 5.20 install to eMMC, the exact same way and with the same gears. I only don't have 128Gb eMMC but 8gb which should not play any role.
apt-get update
apt-get upgrade
reboot
all fine
next no boot ... true.
I can take a look later ...
This is the uart log:
  Reveal hidden contents
apt-get update
apt-get upgrade
reboot
all fine
Thanks you so far. Your efforts are much appreciated! Keep up the good work.
I tested the workaround with clean 5.20 install to eMMC: rebooted after login than did the apt-get update && apt-get upgrade rebooted 2 times but same issue
and tested reboot before login same issue after update && upgrade
Check image.armbian.com for updated 5.21 images. Both are tested and working O.K.
Noticed before my notice  :D  :P
