DanielFilan Posted August 22, 2022 Posted August 22, 2022 (Note: this is crossposted from an ATS issue, since I think it might be quicker to get answers here. Will post on one thread when I get answers that work in the other) Have installed ats on my Rock64, running Armbian 22.05 Jammy with kernel version 5.10.63, and am having trouble getting the fan to spin. The fan I'm using is the one that comes with this case, and it spins when I connect it to a battery. One possible issue is that I had to manually add an entry for PWM_CTL: running sudo find /sys -name pwm\*, I get: /sys/kernel/tracing/events/pwm /sys/kernel/tracing/events/pwm/pwm_apply /sys/kernel/tracing/events/pwm/pwm_get /sys/kernel/debug/tracing/events/pwm /sys/kernel/debug/tracing/events/pwm/pwm_apply /sys/kernel/debug/tracing/events/pwm/pwm_get /sys/kernel/debug/pwm /sys/class/pwm /sys/bus/platform/drivers/pwm-clock /sys/bus/platform/drivers/pwm-regulator /sys/firmware/devicetree/base/pinctrl/pwm1 /sys/firmware/devicetree/base/pinctrl/pwm1/pwm1-pin /sys/firmware/devicetree/base/pinctrl/pwmir /sys/firmware/devicetree/base/pinctrl/pwmir/pwmir-pin /sys/firmware/devicetree/base/pinctrl/pwm2 /sys/firmware/devicetree/base/pinctrl/pwm2/pwm2-pin /sys/firmware/devicetree/base/pinctrl/pwm0 /sys/firmware/devicetree/base/pinctrl/pwm0/pwm0-pin /sys/firmware/devicetree/base/__symbols__/pwm0_pin /sys/firmware/devicetree/base/__symbols__/pwm3 /sys/firmware/devicetree/base/__symbols__/pwm1 /sys/firmware/devicetree/base/__symbols__/pwm1_pin /sys/firmware/devicetree/base/__symbols__/pwmir_pin /sys/firmware/devicetree/base/__symbols__/pwm2_pin /sys/firmware/devicetree/base/__symbols__/pwm2 /sys/firmware/devicetree/base/__symbols__/pwm0 /sys/firmware/devicetree/base/pwm@ff1b0030 /sys/firmware/devicetree/base/pwm@ff1b0020 /sys/firmware/devicetree/base/pwm@ff1b0010 /sys/firmware/devicetree/base/pwm@ff1b0000 My guess was that I should use /sys/firmware/devicetree/base/pinctrl/pwm1. Putting that in my ats config, when I run ats -t, I get: info:'SYSTEM' Table info: 'BOARD' Table info: 'NAME' = ROCK64 info: 'CPU' = RK3328 info: 'THERMAL0_CTL' = /sys/class/thermal/thermal_zone0/temp info: 'THERMAL1_CTL' = ERROR info: 'PWM_CTL' = /sys/firmware/devicetree/base/pinctrl/pwm1 info: 'MAX_CONTINUOUS_THERMAL_TEMP' = 45 info: 'MIN_CONTINUOUS_THERMAL_TEMP' = 20 info: 'MAX_PWM' = 255 info: 'MIN_PWM' = 40 info: 'ALWAYS_ON' = false info: 'PROFILE_NAME' = profile0 info: 'PROFILE' = 0 info:'Pratio' timers info: 'Pratio[ -20 - 20 [' = 0 info: 'Pratio[ 20 ]' = 40 ... info: 'Pratio[ 45 ]' = 255 info: 'Pratio[ 45 - 70 [' = 255 (the temperature range is low so that the fan would definitely run if it was working) When I run this command, the fan doesn't spin. For what it's worth, here's the rest of the output of ats -t: Stopping for[ seconds ]............... 3 CPU Temperature[ max 70 °C ].......... 0 GPU Temperature[ max 70 °C ].......... 0 Fan PWM Duty Cycle value[ 0 - 255 ]... 190 -------------------- Running for[ seconds ]................ 10 CPU Temperature[ max 70 °C ].......... 39 GPU Temperature[ max 70 °C ].......... 0 Fan PWM Duty Cycle value[ 0 - 255 ]... 0 -------------------- Any idea what might be wrong? 0 Quote
DanielFilan Posted August 23, 2022 Author Posted August 23, 2022 Update: I get the same list of pwm devices after updating to kernel version 5.15.52, so that doesn't appear to be the problem. 0 Quote
DanielFilan Posted August 23, 2022 Author Posted August 23, 2022 (Also the fan doesn't spin on the new kernel when I keep the ats config the same) 0 Quote
