banana pi m2 zero with Waveshare 7inch HDMI LCD (H) 1024x600
Hi guy's urgent help needed,
I have banana pi m2 zero and I need the hdmi Waveshare 7inch LCD  settings help.
I have tried to change the config file also dts file, none of those worked. Tried to build with hdmi lcd (internet help) - none
Could any one point out what is need to be done to get it work?
thank you
for anyone have same problem 7" display
what i did was changing boot script
 1. modify file /boot/boot.cmd
setenv disp_mode "1024x600p60"
mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
but now I have another problem.
It's loading long time can anybody help me with that?
sorry for not clarifying.
once I have changed the boot.cmd and added to the armbianEnv.txt
extraargs=drm_kms_helper.edid_firmware=HDMI-A-1:edid/1024x600.bin video=HDMI-A-1:1024x600@60
OS loading long time about 30s to 1min
once it loaded then touchscreen and display works perfectly.
Edited by Urmas
15.033s bootsplash-hide-when-booted.service
11.318s logrotate.service
 5.116s snapd.service
 4.652s armbian-ramlog.service
 4.173s networkd-dispatcher.service
 3.562s armbian-hardware-optimize.service
 2.934s dev-loop5.device
 2.921s dev-mmcblk0p1.device
 2.409s armbian-zram-config.service
 2.329s networking.service
 1.999s systemd-random-seed.service
 1.827s xrdp.service
 1.768s fstrim.service
 1.745s dev-loop4.device
 1.743s dev-loop3.device
 1.740s dev-zram0.device
 1.620s apt-daily-upgrade.service
 1.556s dev-loop1.device
 1.537s snapd.seeded.service
 1.464s dev-loop2.device
 1.439s dev-loop0.device
 1.438s NetworkManager.service
 1.186s systemd-resolved.service
 1.107s chrony.service
 1.004s smartmontools.service
  888ms ssh.service
  876ms lightdm.service
  852ms systemd-logind.service
  852ms wpa_supplicant.service
  834ms user@0.service
  795ms loadcpufreq.service
  787ms user@1000.service
  769ms nfs-server.service
  723ms systemd-udev-trigger.service
  683ms proc-fs-nfsd.mount
  677ms e2scrub_reap.service
  638ms snapd.apparmor.service
  626ms keyboard-setup.service
  617ms alsa-restore.service
  587ms apparmor.service
  524ms dev-zram1.device
  519ms systemd-udevd.service
  477ms rpc-statd.service
  475ms openvpn.service
  467ms rc-local.service
  467ms nfs-mountd.service
  462ms hostapd.service
  459ms rsyslog.service
  448ms systemd-user-sessions.service
  445ms sysstat.service
  379ms dev-mqueue.mount
  361ms sys-kernel-debug.mount
  353ms sys-kernel-tracing.mount
  352ms xrdp-sesman.service
  338ms fake-hwclock.service
  325ms kmod-static-nodes.service
  309ms systemd-journald.service
  309ms modprobe@drm.service
  308ms modprobe@configfs.service
  302ms modprobe@fuse.service
  288ms systemd-rfkill.service
  265ms systemd-tmpfiles-clean.service
  265ms systemd-modules-load.service
  244ms systemd-remount-fs.service
  232ms resolvconf-pull-resolved.service
  224ms plymouth-quit-wait.service
  212ms cpufrequtils.service
  202ms nfs-idmapd.service
  189ms snap-bare-5.mount
  182ms systemd-update-utmp.service
  178ms snap-chromium-2058.mount
  177ms modprobe@chromeos_pstore.service
  164ms snap-core20-1615.mount
  160ms armbian-led-state.service
  156ms modprobe@mtdpstore.service
  149ms snap-gnome\x2d3\x2d38\x2d2004-114.mount
  148ms rpc-statd-notify.service
  145ms dpkg-db-backup.service
  142ms sysfsutils.service
  139ms modprobe@efi_pstore.service
  137ms snap-gtk\x2dcommon\x2dthemes-1535.mount
  122ms dev-loop6.device
  122ms polkit.service
  121ms systemd-sysctl.service
  117ms snap-snapd-16300.mount
  115ms modprobe@pstore_blk.service
  114ms sys-fs-fuse-connections.mount
  111ms systemd-sysusers.service
  107ms systemd-tmpfiles-setup.service
  106ms run-rpc_pipefs.mount
  104ms dev-loop7.device
  104ms sys-kernel-config.mount
  103ms tmp.mount
   98ms rpcbind.service
   90ms modprobe@pstore_zone.service
   85ms ifupdown-pre.service
   79ms console-setup.service
   79ms modprobe@ramoops.service
   78ms snap-gnome\x2d3\x2d38\x2d2004-117.mount
   75ms setvtrgb.service
   72ms plymouth-read-write.service
   69ms nfs-blkmap.service
   68ms user-runtime-dir@1000.service
   67ms systemd-update-utmp-runlevel.service
   63ms systemd-tmpfiles-setup-dev.service
   61ms snap-chromium-2079.mount
   60ms user-runtime-dir@0.service
   57ms sysstat-collect.service
   56ms snapd.socket
   55ms armbian-hardware-monitor.service
   53ms nfsdcld.service
   43ms sysstat-summary.service
   37ms systemd-journal-flush.service
   16ms e2scrub_all.service
found easier display modifying
commet out  #setenv disp_mode "1024x600p60"
then set it armbianConfig.txt
in this way you be abele to change easily 5" and 7" lcd displays - just change the display resolution
however the OS loading is still long time
I understand drm_kms_helper generates the 1024x600.bin file but it does not save it or I just can't find it.
Does anyone know where is it?
Hi there,
I have a problem with startup boot loader showing script
when I added to the armbianConfig.txt file
I lost boot startup loading script text on display - does not show anything until the desktop loaded.
ones is desktop loaded it is very good resolution - want to keep that.
but I need startup loading showing something image or startup loading text.
Does anybody knowing how to do that?
