armbian-config only shows kernels up to 5.15, I'm running on 5.17 and can't see 5.19
I don't understand why I can't update to 5.19. I just updated to various user-space Debian 11.5 packages, but I can't see any newer kernels.
root@odo:/boot# apt policy linux-image-edge-meson64
linux-image-edge-meson64:
  Installed: 22.05.1
  Candidate: 22.05.1
  Version table:
 *** 22.05.1 500
        500 https://mirrors.xtom.de/armbian bullseye/main arm64 Packages
        100 /var/lib/dpkg/status
     22.02.1 500
     22.02.0-trunk.0046 500
     22.02.0-trunk.0045 500
     22.02.0-trunk.0040 500
     22.02.0-trunk.0035 500
     22.02.0-trunk.0034 500
     22.02.0-trunk.0031 500
     22.02.0-trunk.0029 500
     22.02.0-trunk.0027 500
     22.02.0-trunk.0025 500
     22.02.0-trunk.0023 500
     22.02.0-trunk.0021 500
     22.02.0-trunk 500
     21.11.0-trunk.115 500
     21.11.0-trunk.108 500
     21.11.0-trunk.101 500
root@odo:/boot# apt policy linux-u-boot-odroidhc4-edge
linux-u-boot-odroidhc4-edge:
  Installed: 22.05.3
  Candidate: 22.05.3
  Version table:
 *** 22.05.3 500
     22.05.2 500
     22.05.1 500
     22.02.1 500
     21.08.8 500
     21.08.6 500
     21.08.1 500
I'm looking at https://mirrors.xtom.de/armbian/pool/main/l/ for example and I can see items such as https://mirrors.xtom.de/armbian/pool/main/l/linux-5.19.5-meson64/. How do I get my apt to see them?
Are they visible if you do an apt-cache search for those?
No, they're not. On the other hand, I now think the mirror also doesn't have them, looking for linux-image-edge-meson64 in `Packages` at https://mirrors.xtom.de/armbian/dists/bullseye/main/binary-arm64/Packages shows me that the one I got installed is in fact the latest one.
LE. do i need to switch my sources.list to "jammy"?
LLE. I don't need "jammy". I see that a different mirror from our github (https://github.com/armbian/mirror) has newer kernels - https://mirror.albony.xyz/armbian/dists/bullseye/main/binary-arm64/Packages. That `Packages` contains 5.19 kernels for example. Today I learned to read the `Packages` files for clues :). By the way, your mirror seems to have it all and updating with it worked just fine, thank you!
Edited by foxx1337
Since we do not have control over most of the mirrors shown some may or may not be up-to-date since sync interval is unknown. Mine (fi.mirror.armbian.de) syncs once a night (in Europe :D).
We haven't figured out a proper way to check if mirrors are up-to-date and remove them from rotation on-demand. This is still WIP.
That would be a very bad idea. Debian and Ubuntu userspaces - while both using apt and debs - are incompatible.
