I own several Orange Pi 3 which I bought at different times.
The last batch couldn't run the firmware I used previously: the ethernet was broken.
So I suspect there is a new ethernet chipset on it.
Current Armbian (Armbian_22.08.1_Orangepi3_jammy_current_5.15.63) works on both types.
How could I differentiate the chipsets from the command line?
Thank you
Are you sure that the last batch was an Orange PI 3, not the new Orange PI 3 LTS - similar names but slightly different boards with different Armbian builds.
