Hi
I was using:
Title:                  Armbian 21.08.5 Odroidhc4 Debian buster legacy
Then something bad pushed me to run apt update/upgrade
No ZFS anymore.
Installed 22.08.2, but, when tried to install kernel headers using armbian-config, result: "grep: invalid max count" message.
What is the current correct way to install Armbian with ZFS?
Thanks
ChrisO
Edited by ChrisO
addition
Started armbian-config, selected "Software", error message appears: grep: invalid max count
Selected "Headers_install", again error message from grep. Headers not installed.
Installed headers with:
apt install linux-headers-current-meson64
Result:
Loading new zfs-2.1.4 DKMS files...
It is likely that 5.19.10-meson64 belongs to a chroot's host
Building for 5.10.144-meson64
Building initial module for 5.10.144-meson64
configure: error:
    *** Unable to build an empty module.
Error! Bad return status for module build on kernel: 5.10.144-meson64 (aarch64)
root@odroidhc4:~# tail /var/lib/dkms/zfs/2.1.4/build/make.log
DKMS make.log for zfs-2.1.4 for kernel 5.10.144-meson64 (aarch64)
Wed Sep 28 10:36:10 AM CEST 2022
make: *** No targets specified and no makefile found.  Stop.
Thanks
ChrisO
ZFS package on Debian is too old for 5.19.y ... You need 2.1.5. I only manage to bring it up to Ubuntu, while on Debian another afternoon. Which I can't afford.
Try getting updated packages, perhaps with those from Ubuntu will work. Dunno.
Expand
And also this looks odd. Do you perhaps have both (edge and current) kernels + headers installed? Perhaps you didn't reboot on upgrade?
Installed from scratch, Armbian_22.08.1_Odroidhc4_jammy_current_5.10.139.img
apt update/upgrade
apt install zfs-dkms zfsutils-linux
Forgot the linux-headers.
then
dpkg-reconfigure zfs-dkms
Result:
configure: error:
Consult /var/lib/dkms/zfs/2.1.4/build/make.log for more information.
root@odroidhc4:~# cat /var/lib/dkms/zfs/2.1.4/build/make.log
Wed Sep 28 12:44:00 PM CEST 2022
Thanks,
ChrisO
