Here is a solution:
Put these lines into ~/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-keyboard-shortcuts.xml if it does not exist
      <property name="&lt;Alt&gt;Print" type="string" value="xfce4-screenshooter -w"/>
      <property name="Print" type="string" value="xfce4-screenshooter"/>
      <property name="&lt;Shift&gt;Print" type="string" value="xfce4-screenshooter -r"/>
You can add the key via settings too, but to add alt-print can be a little bit tricky. Try to do it in 2 steps, first alt, then with editing add print. For me, editing the file is easier.
vor 2 Stunden schrieb Igor:
I think there is nothing wrong if those are added to the defaults
I have taken it from Xubuntu, since I had problems via the settings-interface to press alt+print.  The other way is to use settings / keyboard / shortcuts (don't know the exact names in English). I have no problems with ctrl-print, but with alt-print definition using the settings.
Edited by pi400user
