manotroll Posted October 19, 2022 Posted October 19, 2022 (edited) as I do the backup, pressing the button on the VA pin has no effect I'm using the image Armbian_22.05.0-trunk_Tanix-tx6_bullseye_current_5.15.27_xfce_desktop.img this is the model I bought it started normally I can do additional tests to help with additional information https://pt.aliexpress.com/item/32990357869.html?spm=a2g0o.order_list.0.0.21efcaa4zeR6Iy&gatewayAdapt=glo2bra on the weekend I can take better quality pictures if that's the case https://imgur.com/a/pm9SczS a tip put the username and password in the readme file https://imgur.com/Rltv1Fj after running the utility to configure the wifi 2 times now it is working Edited October 19, 2022 by manotroll
SteeMan Posted October 19, 2022 Posted October 19, 2022 11 hours ago, manotroll said: I'm using the image Armbian_22.05.0-trunk_Tanix-tx6_bullseye_current_5.15.27_xfce_desktop.img First question is where did you get this build, it isn't one I am aware of. Second question is what instructions are you following. So we know what steps you have done/are following. 11 hours ago, manotroll said: as I do the backup, pressing the button on the VA pin has no effect I don't understand this. What button, what is 'VA', what backup are you doing?
manotroll Posted October 19, 2022 Author Posted October 19, 2022 https://github.com/awawa-dev/build/releases this is the link where i found the picture to a button inside that exit of the more searching a little more I saw that the manufacturer has disabled the recovery mode the internet browser is not opening and chromium is not opening
SteeMan Posted October 20, 2022 Posted October 20, 2022 Since you are using a build from a third party (i.e. not armbian) you should probably ask your questions where you downloaded this from, as it is unlikely anyone around here is going to be able to help since you are using code forked off of armbian. (and we don't know what that code is). I do see that awawa is also a member of these forums, but he hasn't posted for three months, so he isn't actively engaged with the armbian community and probably isn't going to notice your posts here.
manotroll Posted October 20, 2022 Author Posted October 20, 2022 where can i download the official one to see if it has support?
SteeMan Posted October 21, 2022 Posted October 21, 2022 There is no official one. Per the Armbian FAQ: https://docs.armbian.com/User-Guide_FAQ/#i-have-a-tv-boxtablet-from-insert-random-vendor-can-i-use-armbian-on-it and from the TV Box forum FAQ: https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first
manotroll Posted October 23, 2022 Author Posted October 23, 2022 more the tested changes will be added to the official image ? the images that it has in an official way does not initialize it always loads the androd
SteeMan Posted October 23, 2022 Posted October 23, 2022 There are no official images since Armbian doesn't support TV boxes as the links I pointed you to clearly state.
manotroll Posted October 23, 2022 Author Posted October 23, 2022 how do i run this command before login? setxkbmap -model abnt2 -layout br -variant abnt2 because the keys are switched when I change the keyboard layout to different from English and I did the installation on emmc so that I only boot in ETX4 on the other file systems it doesn't start
