June 16, 20233 yr Can anyone please share dts/dtb that working for HK1 RBOX R2 - kernel 6 (or 5.15) ? I don't have enough knowledge to do patching dtb/dts I tried the dtb from @hotnikq (thank you!), and it booted to os successfully, however, no ethernet (no usb 2.0, no hdmi but it's fine for me) 😁 I'm also looking for a way to build uboot and recreate sdcard for booting. I did it myself before but now I can't remember 😅 I'm using kernel 4.19 Please give me some advice, any help would be highly appreciated. Thanks kernel-4.19.log kernel 6.2.log
June 16, 20233 yr Author 2 hours ago, ewww said: no ethernet (no usb 2.0, no hdmi but it's fine for me) it's worse than when I started my thread back in 2022 if you have the patience to test and compile the adaptations we will create a topic efforts to develop firmware for HK1 RBOX R2 4gb 64gb ap6398s
June 20, 20233 yr hello everyone, I have not been able to install the hotnikq image yet, after the first step it is in MASKROM, and I have not been able to do anything else.
June 20, 20233 yr Author 14 hours ago, Kenneth Hidalgo said: hello everyone, I have not been able to install the hotnikq image yet, after the first step it is in MASKROM, and I have not been able to do anything else. You will need to create a update.img to your device, since the factory change the BOM list to build your device you can search for @SteeMan topics about that You can read more about this here ................. Everything you need is described on this topic. start from page 1 ................... Try flash uboot and loader from your Android image ......................... If you can, please send a readable board photo upside and downside Edited June 20, 20233 yr by hotnikq
June 20, 20233 yr Author 3 hours ago, Kenneth Hidalgo said: My image Is Debian The image that you post here Works Fine in my device.... i will share the miniLoaderAll.bin from your own firmware.... and a tutorial to you.... @Kenneth Hidalgo i found an 8gb ROM on 4pda it's time to create an 8gb ROM? and topic? @Kenneth Hidalgo Edited June 20, 20233 yr by hotnikq
June 21, 20233 yr Author @Kenneth Hidalgo and @ufsm can you test this image? new topic, new device, same method.... Edited June 21, 20233 yr by hotnikq
June 21, 20233 yr great, as soon as I have some time I'll try it out, I have a cp21xx ttl serial converter, soon I'll be posting the board's log output.
June 25, 20233 yr Author On 6/21/2023 at 7:04 AM, ufsm said: I have a cp21xx ttl serial converter I need your help to solve the problem in USB 2.0 not working DTB
June 25, 20233 yr Author On 6/20/2023 at 1:15 AM, Kenneth Hidalgo said: hello everyone, I have not been able to install the hotnikq image yet, after the first step it is in MASKROM, and I have not been able to do anything else. I made the changes to work on your device see there in the topic I created for your device @Kenneth Hidalgo Edited November 4, 20233 yr by hotnikq
June 25, 20233 yr The problem is that I can't do the second step, he pressed the reset button and connected the USB and it appears in MASKROM mode
June 26, 20233 yr Author 2 hours ago, Kenneth Hidalgo said: The problem is that I can't do the second step, he pressed the reset button and connected the USB and it appears in MASKROM mode Can you share a image that actually works on your device? Can be Android or Linux i think you already test this https://drive.google.com/file/d/1FTOKB0pgqkLCJedyJrBq-qdONQ9KTM3-/view?usp=sharing please confirm Edited June 26, 20233 yr by hotnikq
June 26, 20233 yr Hotnikq, It is correct, that is the firmware that my box has installed, the only problem I have is that the root partition is very small (6GB)
June 26, 20233 yr Author 10 hours ago, Kenneth Hidalgo said: Hotnikq, It is correct, that is the firmware that my box has installed, the only problem I have is that the root partition is very small (6GB) today I will work in that image....
June 27, 20233 yr Author On 6/26/2023 at 12:39 AM, Kenneth Hidalgo said: Hotnikq, It is correct, that is the firmware that my box has installed, since this image works with your H96 MAX I create an update.img file based on your image.... Edited June 28, 20233 yr by hotnikq
June 28, 20233 yr Author On 6/26/2023 at 9:20 PM, hotnikq said: since this image works with your H96 MAX I create an update.img file based on your image.... @Kenneth Hidalgo let's test another image how to install? https://forum.armbian.com/topic/24091-efforts-to-develop-firmware-for-h96-max-v56-rk3566-4g32g/?do=findComment&comment=166326 This is a new Update.img file for you to test Edited November 4, 20233 yr by hotnikq
June 30, 20233 yr On 6/28/2023 at 5:47 PM, hotnikq said: This is a new Update.img file for you to test After update.img in MASKROM mode, debug message as below U-Boot SPL board init U-Boot SPL 2017.09-gc613b7ea04-210315 #zzz (Mar 15 2021 - 18:08:14) unknown raw ID phN unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 MMC error: The cmd index is 1, ret is -110 Card did not respond to voltage select! mmc_init: -95, time 10 spl: mmc init failed with error: -95 Trying to boot from MMC1 SPL: A/B-slot: _a, successful: 0, tries-remain: 6 Not fit magic Trying fit image at 0x5000 sector Not fit magic SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### # Reset the board to bootrom # Edited July 2, 20233 yr by mvpwar
July 1, 20233 yr Quote Kenneth Hidalgo Posted Monday at 05:39 AM Hotnikq, It is correct, that is the firmware that my box has installed, the only problem I have is that the root partition is very small (6GB) I fixed the issue on a different firmware by running the following command: resize2fs /dev/mmcblk2p6 My main partition changed from 6GB to 56GB. Edited July 1, 20233 yr by wootje
July 2, 20233 yr when the box in MASKROM mode, I checked the "loader" with the MiniLoaderAll.bin path, and click the "Run" button to "Download Image" the Debug message as below Boot1 Release Time: Mar 5 2021 15:51:33, version: 1.05 support nand flash type: slc ...nandc_flash_init enter... No.1 FLASH ID:ff ff ff ff ff ff sfc nor id: ff ff ff sfc_nand id: ff ff ff SD IO init 0 Set SD Clk: 200, 5 Set SD Clk: 200, 5 SDC_BusRequest: CMD=8 SDC_RESP_TIMEOUT 1747 mmc0:cmd8,20 SDC_BusRequest: CMD=5 SDC_RESP_TIMEOUT 1747 mmc0:cmd5,20 SDC_BusRequest: CMD=55 SDC_RESP_TIMEOUT 1747 mmc0:cmd55,20 SDC_BusRequest: CMD=1 SDC_RESP_TIMEOUT 1747 mmc0:cmd1,20 Set SD Clk: 200, 5 SDC_BusRequest: CMD=8 SDC_RESP_TIMEOUT 1747 mmc0:cmd8,20 SDC_BusRequest: CMD=5 SDC_RESP_TIMEOUT 1747 mmc0:cmd5,20 SDC_BusRequest: CMD=55 SDC_RESP_TIMEOUT 1747 mmc0:cmd55,20 SDC_BusRequest: CMD=1 SDC_RESP_TIMEOUT 1747 mmc0:cmd1,20 Set SD Clk: 200, 5 SDC_BusRequest: CMD=8 SDC_RESP_TIMEOUT 1747 mmc0:cmd8,20 SDC_BusRequest: CMD=5 SDC_RESP_TIMEOUT 1747 mmc0:cmd5,20 SDC_BusRequest: CMD=55 SDC_RESP_TIMEOUT 1747 mmc0:cmd55,20 SDC_BusRequest: CMD=1 SDC_RESP_TIMEOUT 1747 mmc0:cmd1,20 SdmmcInit=0 1 Emmc IO init. Emmc IO init. mmc_set_bus_width: 1 SetEmmcClk: 375000, 5 SetEmmcClk: 375000, 5 mmc_set_bus_width: 8 SetEmmcClk: 200000000, 1 Enable PHY CLK: 200000000 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=59640MB FwPartOffset=2000 , 100000 ##############serialno_str = 4DA57NB8JI UsbBoot ...110226 the box cant be tested successfully this time, and follow the step2 to flashed the root.img by Address "0x0000A000", after reboot the debug message as below U-Boot SPL board init U-Boot SPL 2017.09-gc613b7ea04-210315 #zzz (Mar 15 2021 - 18:08:14) unknown raw ID phN unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 MMC error: The cmd index is 1, ret is -110 Card did not respond to voltage select! mmc_init: -95, time 10 spl: mmc init failed with error: -95 Trying to boot from MMC1 SPL: A/B-slot: _a, successful: 0, tries-remain: 6 Not fit magic Trying fit image at 0x5000 sector Not fit magic SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### # Reset the board to bootrom # Trying to reset the box , and it still dosen't works , help me , THX... @hotnikq Edited July 2, 20233 yr by mvpwar
July 3, 20233 yr Author 13 hours ago, mvpwar said: Trying to reset the box , and it still dosen't works , help me , THX... The bootloader is incompatible with you board, you will need to go back to android image. https://androidtvbox.eu/firmware-rk3566-h96-max-for-android-11-tv-box-update-20210810/ or try the linaro from @Kenneth Hidalgo https://drive.google.com/file/d/1FTOKB0pgqkLCJedyJrBq-qdONQ9KTM3-/view?usp=drive_link Since my Uboot + Miniloaderall.bin don't detect your board you will have to adapt uboot and miniloaderall.bin somehow if you can't flash this images you will need to short the CLK + GND with tweezers to enable maskrom mode these two pins are exactly opposite the emmc side of the board short it, conect the USB male to male USB release the short flash the regular ROM https://roc-rk3328-cc.readthedocs.io/en/latest/flash_emmc.html#maskrom-mode Edited July 3, 20233 yr by hotnikq
July 7, 20233 yr Author On 7/2/2023 at 10:01 PM, hotnikq said: The bootloader is incompatible with you board, you will need to go back to android image. https://androidtvbox.eu/firmware-rk3566-h96-max-for-android-11-tv-box-update-20210810/ or try the linaro from @Kenneth Hidalgo https://drive.google.com/file/d/1FTOKB0pgqkLCJedyJrBq-qdONQ9KTM3-/view?usp=drive_link Since my Uboot + Miniloaderall.bin don't detect your board you will have to adapt uboot and miniloaderall.bin somehow if you can't flash this images you will need to short the CLK + GND with tweezers to enable maskrom mode these two pins are exactly opposite the emmc side of the board short it, conect the USB male to male USB release the short flash the regular ROM https://roc-rk3328-cc.readthedocs.io/en/latest/flash_emmc.html#maskrom-mode
August 22, 20233 yr Hi all, thanks for all work. I wonder if MIPI interface is going to work on Linux build?
September 3, 20233 yr Recently acquired an H96 Max v56 Rk3566 (Android 12) 8GB DDR4/64GB eMMC, and like the idea of using it for Linux and Android development. I can get it into both 'Loader' mode, with the reset switch, and into MaskROM mode, by shorting the eMMC Clock signal to ground. Unfortunately, that's where my expertise falls short, and I became stumped. I tried to extract the firmware in both modes, with a confirmed working M2M USB cable, with both rkdumper_1.1.1.0, and with the rkflashkit. No such luck. rkdumper_1.1.1.0 finds the device, but can't reset or upload from it, whilst the rkflaskit doesn't see it in either mode, despite the USB device appearing after an lsusb command. What are the tools and methods for firmware extraction, and flashing? I imagine, though I haven't tried it, that I can flash alternate firmware with the Rockchip-AndroidTool_Release_v2.84, but that's not what I'm trying to do. I'm wanting a full backup, before I find that the manufacturer's firmware on their website isn't suitable or enough to get me out of trouble. Any links, info or advice for this device, greatly appreciated. T. Edited September 3, 20233 yr by Guest
