Hqnicolas Posted December 22, 2024 Author Posted December 22, 2024 (edited) On 12/7/2024 at 1:14 PM, Hqnicolas said: I should spend a week to update the google drive on this device Updated Links for this topic with Unofficial images Kernel 6.12.6 server noble https://drive.google.com/file/d/1ulAH8sqdGkkWeAEFSHqTZaWg1N1Yrqnh/view?usp=sharing desktop noble https://drive.google.com/file/d/1sVKe_HbmxcSpuls_AAGIOnyaxcYKTkKl/view?usp=sharing jammy server https://drive.google.com/file/d/1C_P2ojuMdtTgT9aMAjoblPDSVw1tD8Wr/view?usp=sharing jammy desktop https://drive.google.com/file/d/1pmOXNiedEWzHetJZ4CmASZKZsgAElQag/view?usp=sharing bookworm server https://drive.google.com/file/d/1NvUwikDr08RdY6oJj3PFtx-N16_QkMtR/view?usp=sharing bookworm desktop https://drive.google.com/file/d/1VtHnIidMDT8P-wzL_Wwv4v6TUzrgNC2z/view?usp=sharing How to flash: Same as V1.1 Quote Quote Edited December 23, 2024 by Hqnicolas 0 Quote
ring1012 Posted January 1 Posted January 1 Thank you @Hqnicolas, 4g32g img did not work for me. I had no debug tool, so I don't know what're the blockers. But I tried to install retroarch in armbian, and load the cores from https://github.com/christianhaitian/retroarch-cores, it works for me. 0 Quote
Hqnicolas Posted January 2 Author Posted January 2 (edited) On 1/1/2025 at 8:09 AM, ring1012 said: 4g32g img did not work for me. Can you share your experience? I literally downloaded the 32gb image to test and everything went fine, google didn't corrupt the file "yet" On 1/1/2025 at 8:09 AM, ring1012 said: But I tried to install retroarch in armbian, and load the cores from https://github.com/christianhaitian/retroarch-cores, it works for me. You're talking about this kernel 6.6 images? the image contains many built-in features, such as kodi and internet game archive with retroarch android emulator and Windows emulator Quote Edited January 3 by Hqnicolas 0 Quote
GBEM Posted 6 hours ago Posted 6 hours ago (edited) Hello, fellow H96 musers. I've just acquired a 4G/32G H96 Max V56, and tried to flash an image that works on an earlier 8G/64G H96 Max V56, using the appropriate 4G booloader rather than the one I used for the 8G. The HAOS image boots fine, but everything about the Ethernet and WiFi must be wrong, as I have no networking hardware configured. I'm curious to know if there are differences between the 4G/32G board and the 8G/64G, other than eMMC size, that might account for the above outcome? There was some early mention of 'type 1' and 'type 2' 4G/32G boards early on in this thread. Could I be using an inappropriate device tree source configuration for my 4G/32G board? If that's not it, then the only other thing I can think of, is that the 4G/32G board I recently acquired has different WiFi/Bluetooth and Ethernet chips fitted, and the drivers from my 8G/64G build aren't suited? 8G/64G H96 Max V56 PCB: LP6E27116A0 Wifi/BT: HC16335, S3144335 Ethernet: Realtek, RTL8211 4G/32G H96 Max V56 PCB: LS6E28533A0 Wifi/BT: SKI.WB800D80S.1_D40, 2023AP20230(M) Ethernet: Maxio, MAE0621A-02C Thoughts, board type clarification, or driver suggestions, anyone? GBEM 👽 p.s. If anyone has the stock rom for this box I'd be entirely grateful. Through absent mindedness, I foolishly didn't preserve mine. Edited 5 hours ago by GBEM 0 Quote
