Hqnicolas Posted December 22, 2024 Author Posted December 22, 2024 (edited) On 12/7/2024 at 1:14 PM, Hqnicolas said: I should spend a week to update the google drive on this device Updated Links for this topic with Unofficial images Kernel 6.12.6 server noble https://drive.google.com/file/d/1ulAH8sqdGkkWeAEFSHqTZaWg1N1Yrqnh/view?usp=sharing desktop noble https://drive.google.com/file/d/1sVKe_HbmxcSpuls_AAGIOnyaxcYKTkKl/view?usp=sharing jammy server https://drive.google.com/file/d/1C_P2ojuMdtTgT9aMAjoblPDSVw1tD8Wr/view?usp=sharing jammy desktop https://drive.google.com/file/d/1pmOXNiedEWzHetJZ4CmASZKZsgAElQag/view?usp=sharing bookworm server https://drive.google.com/file/d/1NvUwikDr08RdY6oJj3PFtx-N16_QkMtR/view?usp=sharing bookworm desktop https://drive.google.com/file/d/1VtHnIidMDT8P-wzL_Wwv4v6TUzrgNC2z/view?usp=sharing How to flash: Same as V1.1 Quote Quote Edited December 23, 2024 by Hqnicolas 0 Quote
ring1012 Posted January 1 Posted January 1 Thank you @Hqnicolas, 4g32g img did not work for me. I had no debug tool, so I don't know what're the blockers. But I tried to install retroarch in armbian, and load the cores from https://github.com/christianhaitian/retroarch-cores, it works for me. 0 Quote
Hqnicolas Posted January 2 Author Posted January 2 (edited) On 1/1/2025 at 8:09 AM, ring1012 said: 4g32g img did not work for me. Can you share your experience? I literally downloaded the 32gb image to test and everything went fine, google didn't corrupt the file "yet" On 1/1/2025 at 8:09 AM, ring1012 said: But I tried to install retroarch in armbian, and load the cores from https://github.com/christianhaitian/retroarch-cores, it works for me. You're talking about this kernel 6.6 images? the image contains many built-in features, such as kodi and internet game archive with retroarch android emulator and Windows emulator Quote Edited January 3 by Hqnicolas 0 Quote
GBEM Posted Sunday at 09:38 PM Posted Sunday at 09:38 PM (edited) Hello, fellow H96 musers. I've just acquired a 4G/32G H96 Max V56, and tried to flash an image that works on an earlier 8G/64G H96 Max V56, using the appropriate 4G booloader rather than the one I used for the 8G. The HAOS image boots fine, but everything about the Ethernet and WiFi must be wrong, as I have no networking hardware configured. I'm curious to know if there are differences between the 4G/32G board and the 8G/64G, other than eMMC size, that might account for the above outcome? Tthe only other thing I can think of, is that the 4G/32G board I recently acquired has different WiFi/Bluetooth and Ethernet chips fitted, and the drivers from my 8G/64G build aren't suited? 8G/64G H96 Max V56 PCB: LP6E27116A0 Wifi/BT: HC16335, S3144335 Ethernet: Realtek, RTL8211 4G/32G H96 Max V56 PCB: LS6E28533A0 Wifi/BT: SKI.WB800D80S.1_D40, 2023AP20230(M) Ethernet: Maxio, MAE0621A-02C Thoughts, or driver suggestions, anyone? GBEM 👽 p.s. If anyone has the stock rom for this box I'd be entirely grateful. Through absent mindedness, I foolishly didn't preserve mine. Edited 10 hours ago by GBEM 0 Quote
WINEDS Posted yesterday at 03:55 AM Posted yesterday at 03:55 AM (edited) See my recent posts in the 64gb thread. You'll need to build an image with MAE0621A-02C support. The same thread will also give you some hints for to make the WiFi work with aic8800. Edited 1 hour ago by WINEDS 0 Quote
GBEM Posted 10 hours ago Posted 10 hours ago (edited) Thanks, @WINEDS. I see you guy's are all over it, have at least the Ethernet sorted, and hints on the path to WiFi. I found an AllWinner CPU board from Radxa, that uses the same network peripherals as the newer H96 Max V56. The Radxa Cubie A5E is reported to feature WiFi6 and Bluetooth 5.4 using it's BLink BL-M8800DS2, which would be a step-up for me. https://docs.radxa.com/en/cubie/a5e/other-system/tina-os/build-system <- bsp, etc. Wish me luck. GBEM 👽 Edited 10 hours ago by GBEM 1 Quote
WINEDS Posted 1 hour ago Posted 1 hour ago (edited) The WiFi is easy. Just : wget https://github.com/radxa-pkg/aic8800/releases/download/4.0%2Bgit20250410.b99ca8b6-3/aic8800-firmware_4.0+git20250410.b99ca8b6-3_all.deb wget https://github.com/radxa-pkg/aic8800/releases/download/4.0%2Bgit20250410.b99ca8b6-3/aic8800-sdio-dkms_4.0+git20250410.b99ca8b6-3_all.deb dpkg -i aic8800-firmware_4.0+git20250410.b99ca8b6-3_all.deb dpkg -i aic8800-sdio-dkms_4.0+git20250410.b99ca8b6-3_all.deb You will need the Linux kernel headers installed though. Edited 1 hour ago by WINEDS 0 Quote
