October 23, 20224 yr I was running espressobin v7 with Welcome to Armbian 21.08.1 Bullseye with Linux 5.10.60-mvebu64 and made an upgrade in a regular way : # apt upgrade The following packages will be upgraded: apache2 apache2-bin apache2-data apache2-dev apache2-utils armbian-bsp-cli-espressobin armbian-config armbian-firmware armbian-zsh asterisk asterisk-config asterisk-modules asterisk-voicemail avahi-autoipd base-files bash curl deb.torproject.org-keyring dirmngr distro-info-data dpkg dpkg-dev ffmpeg gnupg gnupg-l10n gnupg-utils gnupg2 gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm gpgv gzip hostapd ifenslave inetutils-inetd inetutils-telnet libapache2-mod-php7.4 libavahi-client3 libavahi-common-data libavahi-common3 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4 libavutil56 libc-bin libc-dev-bin libc-l10n libc6 libc6-dev libcups2 libcurl3-gnutls libcurl4 libdpkg-perl libfreetype6 libfribidi0 libgnutls30 libgssapi-krb5-2 libk5crypto3 libkrb5-3 libkrb5support0 libldap-2.4-2 libldap2-dev libldb2 liblzma5 libnm0 libnss-myhostname libntfs-3g883 libpam-systemd libpcre2-16-0 libpcre2-32-0 libpcre2-8-0 libpcre2-dev libpcre2-posix2 libpostproc55 libpq5 libsdl2-2.0-0 libsmbclient libsnmp-base libsnmp40 libssl-dev libssl1.1 libswresample3 libswscale5 libsystemd0 libtiff5 libtirpc-common libtirpc-dev libtirpc3 libudev1 libwbclient0 libxml2 libxslt1.1 linux-dtb-current-mvebu64 linux-image-current-mvebu64 linux-libc-dev linux-u-boot-espressobin-current locales logrotate nano network-manager ntfs-3g openssh-client openssh-server openssh-sftp-server openssl php7.4 php7.4-cli php7.4-common php7.4-curl php7.4-json php7.4-opcache php7.4-readline python3-ldb python3-samba rsyslog samba samba-common samba-common-bin samba-libs smbclient systemd systemd-sysv tcpdump tor tor-geoipdb tzdata udev unzip wireless-regdb xz-utils zlib1g ... update-initramfs: Converting to u-boot format update-initramfs: Converting to u-boot FIT image FIT description: EspressoBIN 3720 FIT Image Created: Sun Oct 23 13:08:21 2022 Image 0 (kernel) Description: Vanilla Linux kernel Created: Sun Oct 23 13:08:21 2022 Type: Kernel Image Compression: lzma compressed Data Size: 6882687 Bytes = 6721.37 KiB = 6.56 MiB Architecture: AArch64 OS: Linux Load Address: 0x07000000 Entry Point: 0x07000000 Hash algo: sha1 Hash value: c8d92b9c244fdcc9fb56f640d05e6fc4d3f7ffb6 Image 1 (ramdisk) Description: Boot ramdisk Created: Sun Oct 23 13:08:21 2022 Type: RAMDisk Image Compression: Unknown Compression Data Size: 8909801 Bytes = 8700.98 KiB = 8.50 MiB Architecture: AArch64 OS: Linux Load Address: unavailable Entry Point: unavailable Hash algo: sha1 Hash value: 3be954cf886386101311f7673115fa0be0c95366 Image 2 (fdtv5) Description: Flattened Device Tree ebinv5 Created: Sun Oct 23 13:08:21 2022 Type: Flat Device Tree Compression: uncompressed Data Size: 11618 Bytes = 11.35 KiB = 0.01 MiB Architecture: AArch64 Load Address: 0x06f00000 Hash algo: sha1 Hash value: dcfa1e753a26493b713b8d6eee19e0895db09cc3 Image 3 (fdtv7) Description: Flattened Device Tree ebinv7 Created: Sun Oct 23 13:08:21 2022 Type: Flat Device Tree Compression: uncompressed Data Size: 11646 Bytes = 11.37 KiB = 0.01 MiB Architecture: AArch64 Load Address: 0x06f00000 Hash algo: sha1 Hash value: 0230f9e11a6f364dc66c0aca9a72620b19a0f1e0 Default Configuration: 'v5' Configuration 0 (v5) Description: Standard Boot ebinv5 Kernel: kernel Init Ramdisk: ramdisk FDT: fdtv5 Hash algo: sha1 Hash value: unavailable Configuration 1 (v7) Description: Standard Boot ebinv7 Kernel: kernel Init Ramdisk: ramdisk FDT: fdtv7 Hash algo: sha1 Hash value: unavailable After upgrade and reboot the kernel was upgraded to : Welcome to Armbian 22.08.6 Bullseye with Linux 5.15.74-mvebu64 The side effect is that cpu-freq regulation seems to be broken: root@tiger:~# cpufreq-info cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 0: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 1: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. The # htop is unable to determine it either : Cpu Freq: 0 MHz The previous setup before upgrade "Armbian 21.08.1 Bullseye with Linux 5.10.60-mvebu64" ran frequency switch flawlessly: # cpufreq-info current CPU frequency is 200 MHz (asserted by call to hardware). cpufreq stats: 200 MHz:93.04%, 300 MHz:0.48%, 600 MHz:0.18%, 1.20 GHz:6.30% (215) Due to inability of CPU frequency regulation, I found that the board temperature has been increased by about 5 deg. C. What could be done to fix this issue?
October 23, 20224 yr Author By some unknown reason cpufreq device has become unavailable after upgrade: cat: /sys/devices/system/cpu/cpufreq/policy0/scaling_available_governors: No such file or directory The old working system had : # cat /sys/devices/system/cpu/cpufreq/policy0/scaling_available_governors conservative ondemand userspace powersave performance schedutil
October 23, 20224 yr Author What could also be relevant to fix CPU scaling: # ls /sys/devices/system/cpu/cpu0 cpu_capacity crash_notes crash_notes_size hotplug node0 of_node online power regs subsystem topology uevent (no cpufreq) CPU governors are not available. root@tiger:~# dmesg -l emerg,alert,crit,err [ 1.917740] debugfs: Directory 'd0060900.xor' with parent 'dmaengine' already present! [ 2.420702] Unsupported CPU frequency 1200 MHz [ 3.937067] advk-pcie d0070000.pcie: link never came up I use the mainline u-boot with CPU frequency 1200 MHz, which proved itself stable before upgrade: Marvell>> reset resetting ... TIM-1.0 mv_ddr-devel-g7753d4b DDR4 16b 1GB 1CS WTMI-devel-18.12.1-4392eaf WTMI: system early-init SVC REV: 5, CPU VDD voltage: 1.225V Setting clocks: CPU 1200 MHz, DDR 750 MHz CZ.NIC's Armada 3720 Secure Firmware v2021.09.07-27-g489262b (Feb 9 2022 18:50:42) Running on ESPRESSObin NOTICE: Booting Trusted Firmware NOTICE: BL1: v2.6(release):v2.6-365-ge0a6a512b NOTICE: BL1: Built : 18:52:58, Feb 9 2022 NOTICE: BL1: Booting BL2 NOTICE: BL2: v2.6(release):v2.6-365-ge0a6a512b NOTICE: BL2: Built : 18:53:02, Feb 9 2022 NOTICE: BL1: Booting BL31 NOTICE: BL31: v2.6(release):v2.6-365-ge0a6a512b NOTICE: BL31: Built : 18:53:12, Feb 9 2022 U-Boot 2022.04-rc1-00087-gb5c5b9a0be (Feb 09 2022 - 18:44:33 +0100)
October 25, 20224 yr Author I used Igor's advice for another issue : Workaround: armbian-config -> system -> Other -> Switch to other kernels , pick previous, freeze, wait | |linux-image-current-mvebu64=22.08.2 5.15.69-mvebu64 | | | |linux-image-current-mvebu64=22.05.3 5.15.48-mvebu64 | | | |linux-image-current-mvebu64=22.05.1 5.15.35-mvebu64 | | | |linux-image-current-mvebu64=21.08.1 5.10.60-mvebu64 | | <<-- CPU scaling is not broken I progressively downgraded to kernels 5.15.69, than to 5.15.48 and 5.15.35. None of them allowed to fix CPU scaling. This is rather strange, as I run another espressobin, which doesn't loose CPU scaling with kernel 5.15.48-mvebu64. This second espressobin is version 5 and u-boot running at 1000 MHz. This could give a clue to fix broken CPU scaling in kernel 5.15.xx. Just to remind, that root@ebinv7# dmesg -l emerg,alert,crit,err [ 1.917740] debugfs: Directory 'd0060900.xor' with parent 'dmaengine' already present! [ 2.420702] Unsupported CPU frequency 1200 MHz <<-- vs -->> ebinv5 @1000 MHz After 5.15.x disenchantment I've downgraded to 5.10.60-mvebu64, which fixed CPU scaling : root@ebinv7:/boot# dmesg -l emerg,alert,crit,err [ 2.319871] debugfs: Directory 'd0060900.xor' with parent 'dmaengine' already present! [ 5.739975] advk-pcie d0070000.pcie: link never came up root@ebinv7:/boot# cpufreq-info cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 0: driver: cpufreq-dt CPUs which run at the same hardware frequency: 0 1 CPUs which need to have their frequency coordinated by software: 0 1 maximum transition latency: 0.97 ms. hardware limits: 200 MHz - 1.20 GHz available frequency steps: 200 MHz, 300 MHz, 600 MHz, 1.20 GHz available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil current policy: frequency should be within 200 MHz and 1.20 GHz. The governor "ondemand" may decide which speed to use within this range. current CPU frequency is 1.20 GHz (asserted by call to hardware). cpufreq stats: 200 MHz:22.65%, 300 MHz:8.94%, 600 MHz:0.09%, 1.20 GHz:68.32% (1637) analyzing CPU 1: driver: cpufreq-dt CPUs which run at the same hardware frequency: 0 1 CPUs which need to have their frequency coordinated by software: 0 1 maximum transition latency: 0.97 ms. hardware limits: 200 MHz - 1.20 GHz available frequency steps: 200 MHz, 300 MHz, 600 MHz, 1.20 GHz available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil current policy: frequency should be within 200 MHz and 1.20 GHz. The governor "ondemand" may decide which speed to use within this range. current CPU frequency is 1.20 GHz (asserted by call to hardware). cpufreq stats: 200 MHz:22.65%, 300 MHz:8.94%, 600 MHz:0.09%, 1.20 GHz:68.32% (1637) root@ebinv7:/boot# lscpu Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 2 On-line CPU(s) list: 0,1 Thread(s) per core: 1 Core(s) per socket: 2 Socket(s): 1 NUMA node(s): 1 Vendor ID: ARM Model: 4 Model name: Cortex-A53 Stepping: r0p4 CPU max MHz: 1200.0000 CPU min MHz: 200.0000 BogoMIPS: 25.00 NUMA node0 CPU(s): 0,1 Vulnerability Itlb multihit: Not affected Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Spec store bypass: Not affected Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Not affected Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid Has this bug been reported and scheduled for fixing? On the other side, why do I still receive 2 upgrades available, while 22.08 is already setup? Welcome to Armbian 22.08.6 Bullseye with Linux 5.10.60-mvebu64 root@ebinv7:/boot# apt list --upgradable Listing... Done linux-dtb-current-mvebu64/bullseye 22.08.6 arm64 [upgradable from: 21.08.1] linux-image-current-mvebu64/bullseye 22.08.6 arm64 [upgradable from: 21.08.1]
October 29, 20224 yr On 10/23/2022 at 9:52 PM, y52 said: [ 2.420702] Unsupported CPU frequency 1200 MHz Here is the issue. 1.2 GHz variant of A3720 CPU is not supported by Linux. Trying to do frequency scaling on that variant cause CPU crashes. Hence it was disabled. On 10/25/2022 at 10:48 PM, y52 said: Has this bug been reported? Yes, on many places and there is just a silence: https://lore.kernel.org/linux-pm/20210809040224.j2rvopmmqda3utc5@vireshk-i7/ https://github.com/MarvellEmbeddedProcessors/linux-marvell/issues/20 On 10/23/2022 at 8:55 PM, y52 said: What could be done to fix this issue? Contacting your support departement or directly Marvell FAE. Opening RMA or returning broken product back to seller.
November 1, 20224 yr Author Hello Pali, Thank you again for pointing out this flaw. I recall your alert earlier this year : https://forum.armbian.com/topic/19564-making-espressobin-v7-work-in-2022/page/2/# Beware, 1.2 GHz CPU is broken and Marvell refused to fix it. Hence kernel maintainers decided to delete/deactive 1.2 GHz mode. https://lore.kernel.org/linux-pm/20210809040224.j2rvopmmqda3utc5@vireshk-i7/ So rather stick with 1 GHz mode. Now kernel upgrade reminded this bug again. It remains yet unclear to me, why the 5.10.60-mvebu64 kernel works on 1.2 GHz variant of A3720 SOC and apparently does frequency scaling, while the next 5.15 tree does not. If init sequence related to CPU voltage configuration satisfy the 5.10 tree, why is it no more valid for 5.15? I have another ancillary issue with uboot implementation. When I followed your u-boot build guidance in February 2022, I didn't implement U-Boot distroboot feature by that time as Armbian distribution was not yet ready. Thus I haven't set default environment in u-boot so far. Armbian is currently passed from boot_targets=usb sata mmc1 mmc0 bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done instead if distroboot implementation : bootcmd=run distro_bootcmd What are implications of not setting default environment (=> env default -a) in u-boot with "distroboot Armbian"?
November 1, 20224 yr 1 minute ago, y52 said: Now kernel upgrade reminded this bug again. It remains yet unclear to me, why the 5.10.60-mvebu64 kernel works on 1.2 GHz variant of A3720 SOC and apparently does frequency scaling, while the next 5.15 tree does not. If init sequence related to CPU voltage configuration satisfy the 5.10 tree, why is it no more valid for 5.15? The whole thing is broken. For 1.2 GHz variant is officially documented CPU errata related to CPU voltage together with workaround. But source of the issue is not documented and is Marvell secret. That workaround is implemented in kernel for a long time (including 5.15). But for some unknown reasons since some kernel version 1.2 GHz variant of CPU crashes even with workaround. And because only Marvell knows source of one documented crahes, we can just guess... if this that documented issue, or some other issue... Only HW engineer of that A3720 CPU can answer to those questions. Anyway, if somebody is interested in, wants to debug this issue and is skilled in compiling, patching and debugging kernel, I can forward some new test info which I have (write me an email).
November 6, 20224 yr On 11/1/2022 at 10:18 PM, Pali said: Anyway, if somebody is interested in, wants to debug this issue and is skilled in compiling, patching and debugging kernel, I can forward some new test info which I have (write me an email). Just reminding, nobody?
January 16, 20233 yr @Pali Hi! I've run into this issue. I've got an ebin-v5 with cpu frequency stepping, and an ebin-v7 without, both on 5.15.86. Based on the CPU markings, the v7 is using platform firmware set for 1200 MHz. I'd be interested in seeing what ysou know, but claim no special skill. Likely, I'll just drop the u-boot config back to 1000 MHz even on the v7, if that solves it.
February 20, 20233 yr Author kernel 5.10.60 is the last version I've managed running v7 @ 1200 MHz with cpu frequency stepping. Thus, if you want the latest kernel, I fear you would need to downgrade your u-boot to 1000 MHz. I don't believe there were recent development debugging this issue, although there is a need for.
February 21, 20233 yr I switched to NixOS back in December, and so far have not been able to complete compiling u-boot on that system with any toolchain. The TF-A code needs to get into marvell git repos instead of just gathering binaries, it's not very clean. As such, I don't have any update on the issue either.
