Good day!
I found some oddities with UART port driver.
If I change the speed or the number of bits in the transmission, then everything works fine.
But if I try to set the parity it does not sets.
Not work modes: "EVEN, SPACE, MARK".
Normal works only "NONE".
Anyone faced similar problem?  :huh:
Tested under minicom and Java prorgam. The same result.  :mellow:
p.s.
I mean this modes sets only logical and does not sets physical. The device on other end always reports parity errors.
