Hello all,
I setup an orangepi plus2 with Armbian_22.08.2_Orangepiplus_bullseye_current_5.15.69.img
I follow tuto and it worked with boot on SD card.
I run nand-sata-install
Then, I reboot.
I was in safe mode and try format emmc
Then I reboot again
Since, I have only green light.
I connect to COM port and see that :
U-Boot 2022.07-armbian (Sep 21 2022 - 18:37:27 +0000) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi Plus / Plus 2
DRAM:  2 GiB
Core:  65 devices, 18 uclasses, devicetree: separate
WDT:   Not starting watchdog@1c20ca0
MMC:   mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1
Loading Environment from FAT... ** No valid partitions found **
In:    serial@1c28000
Out:   serial@1c28000
Err:   serial@1c28000
Net:   phy interface9
eth0: ethernet@1c30000
starting USB...
Bus usb@1c1b000: USB EHCI 1.00
Bus usb@1c1d000: USB EHCI 1.00
scanning bus usb@1c1b000 for devices... 2 USB Device(s) found
scanning bus usb@1c1d000 for devices... Device NOT ready
   Request Sense returned 02 3A 00
prefetch abort
pc : [<fffffffa>]          lr : [<bffaa3fb>]
reloc pc : [<8a077ffa>]    lr : [<4a0223fb>]
sp : b8a99728  ip : bbf6b210     fp : bffdeb78
r10: ffffffff  r9 : bbf67ec0     r8 : b8a99780
r7 : 00000000  r6 : 00000001     r5 : e59ff014  r4 : 00000000
r3 : b8a99780  r2 : 00000001     r1 : 00000000  r0 : e59ff014
Flags: nzcv  IRQs off  FIQs off  Mode SVC_32 (T)
Code: 0000 0000 0000 0000 (0000) 0000
Resetting CPU ...
resetting ...
After resetting, it loops and again reset without any stop !
I don't understand "Loading Environment from FAT... ** No valid partitions found **"
My SD card is Armbian_22.08.2_Orangepiplus_bullseye_current_5.15.69.img flashed with etcher
Please, help found how to escape that caveat !
Many thanks
On 11/7/2022 at 8:56 AM, francoispe said:
Anyone can help find a solution to CPU ressetting continuously !
Try some older image to see if older u-boot supports your eMMC well. Its also possible of eMMC failure.
I try Armbian_5.30_Orangepiplus_Debian_jessie_default_3.4.113 which is very old, but seems to be the first one !
I works "almost"
I still have a green light but also a blinking red light !
On serial port I see :
U-Boot SPL 2017.05-armbian (Jun 13 2017 - 15:37:05)
DRAM: 2048 MiB
Trying to boot from MMC1
U-Boot 2017.05-armbian (Jun 13 2017 - 15:37:05 +0200) Allwinner Technology
I2C:   ready
DRAM:  2 GiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
In:    serial
Out:   serial
Err:   serial
Net:   phy interface7
38518 bytes read in 138 ms (272.5 KiB/s)
Unknown command 'bmp' - try 'help'
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3565 bytes read in 186 ms (18.6 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
115 bytes read in 148 ms (0 Bytes/s)
3795394 bytes read in 441 ms (8.2 MiB/s)
4750952 bytes read in 503 ms (9 MiB/s)
Found legacy kernel configuration
36128 bytes read in 476 ms (73.2 KiB/s)
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Data Size:    3795330 Bytes = 3.6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
Starting kernel ...
[sun8i_fixup]: From boot, get meminfo:
        Start:  0x40000000
ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1
ion_reserve_select: ion chipid  [0x2c00081!
ion_reserve_common: ion reserve: [0xb0000000, 0xc0000000]!
<<4Loading, please wait...
done.
Begin: Will now check root file system ... fsck from util-linux 2.25.2
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: recovering journal
/dev/mmcblk0p1: clean, 48528/78400 files, 252601/313600 blocks
done.
done.
Welcome to Debian GNU/Linux 8 (jessie)!
         Expecting device dev-ttyS0.device...
[  OK  ] Reached target Remote File Systems (Pre).
[  OK  ] Reached target Paths.
[  OK  ] Set up automount Arbitrary Executable File Formats F...utomount Point.
[  OK  ] Reached target Encrypted Volumes.
[  OK  ] Reached target Swap.
[  OK  ] Created slice Root Slice.
[  OK  ] Listening on Delayed Shutdown Socket.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Created slice User and Session Slice.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Listening on Journal Socket.
[  OK  ] Created slice System Slice.
         Starting Increase datagram queue length...
         Starting Nameserver information manager...
         Starting Restore / save the current clock...
         Starting Create list of required static device nodes...rrent kernel...
         Mounting Debug File System...
         Starting udev Coldplug all Devices...
         Mounting POSIX Message Queue File System...
         Starting LSB: Set keymap...
[  OK  ] Created slice system-serial\x2dgetty.slice.
         Starting Load Kernel Modules...
[  OK  ] Reached target Slices.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Debug File System.
[  OK  ] Started Increase datagram queue length.
[  OK  ] Started Restore / save the current clock.
[  OK  ] Started Create list of required static device nodes ...current kernel.
[  OK  ] Started LSB: Set keymap.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Nameserver information manager.
[  OK  ] Started udev Coldplug all Devices.
         Starting Apply Kernel Variables...
         Mounting FUSE Control File System...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Listening on Syslog Socket.
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
         Starting udev Kernel Device Manager...
[  OK  ] Started udev Kernel Device Manager.
         Starting Copy rules generated while the root was ro...
         Starting LSB: Set preliminary keymap...
         Starting LSB: Tune IDE hard disks...
[  OK  ] Started Copy rules generated while the root was ro.
[  OK  ] Started LSB: Tune IDE hard disks.
[  OK  ] Found device /dev/ttyS0.
[  OK  ] Created slice system-systemd\x2drfkill.slice.
[  OK  ] Reached target Sound Card.
[  OK  ] Created slice system-ifup.slice.
[  OK  ] Started LSB: Set preliminary keymap.
         Starting Remount Root and Kernel File Systems...
[  OK  ] Started Remount Root and Kernel File Systems.
         Starting Load/Save RF Kill Switch Status of rfkill0...
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /tmp...
         Starting Load/Save Random Seed...
[  OK  ] Mounted /tmp.
[  OK  ] Started Load/Save RF Kill Switch Status of rfkill0.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Reached target Local File Systems.
         Starting Armbian enhanced Log2Ram...
         Starting Create Volatile Files and Directories...
         Starting LSB: Raise network interfaces....
[  OK  ] Reached target Remote File Systems.
         Starting LSB: Prepare console...
[  OK  ] Started Armbian enhanced Log2Ram.
[  OK  ] Started Create Volatile Files and Directories.
[  OK  ] Started LSB: Prepare console.
         Starting LSB: Set console font and keymap...
         Starting Update UTMP about System Boot/Shutdown...
         Starting Journal Service...
[  OK  ] Started Journal Service.
         Starting Trigger Flushing of Journal to Persistent Storage...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started LSB: Set console font and keymap.
[  OK  ] Started LSB: Raise network interfaces..
[  OK  ] Started Trigger Flushing of Journal to Persistent Storage.
         Starting ifup for eth0...
[  OK  ] Started ifup for eth0.
[  OK  ] Reached target Network.
[  OK  ] Reached target Network is Online.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Timers.
         Starting Armbian filesystem resize service...
         Starting Restore Sound Card State...
[  OK  ] Started Restore Sound Card State.
[  OK  ] Started Armbian filesystem resize service.
[  OK  ] Reached target Basic System.
         Starting Entropy daemon using the HAVEGE algorithm...
[  OK  ] Started Entropy daemon using the HAVEGE algorithm.
         Starting System Logging Service...
         Starting Regular background program processing daemon...
[  OK  ] Started Regular background program processing daemon.
         Starting Network Manager...
         Starting OpenBSD Secure Shell server...
[  OK  ] Started OpenBSD Secure Shell server.
         Starting Armbian first run tasks...
[  OK  ] Started Armbian first run tasks.
[  OK  ] Created slice system-getty.slice.
         Starting /etc/rc.local Compatibility...
         Starting Login Service...
         Starting Permit User Sessions...
         Starting D-Bus System Message Bus...
[  OK  ] Started D-Bus System Message Bus.
         Starting LSB: Armbian gathering hardware information...
         Starting LSB: Advanced IEEE 802.11 management daemon...
         Starting LSB: disk temperature monitoring daemon...
         Starting LSB: Start NTP daemon...
         Starting LSB: Load kernel modules needed to enable cpufreq scaling...
         Starting LSB: Start/stop sysstat's sadc...
         Starting LSB: Starts LIRC daemon....
[  OK  ] Started System Logging Service.
[  OK  ] Started /etc/rc.local Compatibility.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started LSB: Advanced IEEE 802.11 management daemon.
[  OK  ] Started LSB: disk temperature monitoring daemon.
[  OK  ] Started LSB: Armbian gathering hardware information.
[  OK  ] Started LSB: Start NTP daemon.
[  OK  ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
[  OK  ] Started LSB: Start/stop sysstat's sadc.
[  OK  ] Started LSB: Starts LIRC daemon..
[  OK  ] Started Login Service.
         Starting Authenticate and Authorize Users to Run Privileged Tasks...
         Starting LSB: set CPUFreq kernel parameters...
         Starting Getty on tty1...
[  OK  ] Started Getty on tty1.
         Starting Serial Getty on ttyS0...
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started Authenticate and Authorize Users to Run Privileged Tasks.
[  OK  ] Started LSB: set CPUFreq kernel parameters.
[  OK  ] Started Network Manager.
         Starting LSB: Set sysfs variables from /etc/sysfs.conf...
         Stopping LSB: Starts LIRC daemon....
[  OK  ] Started LSB: Set sysfs variables from /etc/sysfs.conf.
[  OK  ] Stopped LSB: Starts LIRC daemon..
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Update UTMP about System Runlevel Changes...
         Starting WPA supplicant...
[  OK  ] Started Update UTMP about System Runlevel Changes.
[  OK  ] Started WPA supplicant.
Debian GNU/Linux 8 orangepiplus ttyS0
orangepiplus login:
The problem is that
I try login with orangpei... But nothing happens (inside putty, keyboard has no effect on COM3)
I plug HDMI, witout any success : screen remains black
I plug usb keyboard, the same : impossible to push orangepi login !
How can I make it back to normal life ?
Many thanks
